Page 2 of 2
Re: Domoticz Plug-In for Tasker
Posted: Sunday 24 May 2020 12:35
by eserero
wimmme wrote: Saturday 23 May 2020 23:10
eserero wrote: Saturday 23 May 2020 18:36
Hi, can i use this plugin to notify tasker to launch an app in android?
I would like to click a physical button connected to domoticz and this should open a camera app on my andoid tablet.
You can do this with Tasker and Autoremote, I do this already.
Bought this plugin, and it should be able to do the same. Domoticz event triggers tasker via the Domoticz app and the plug-in. Haven't tried it yet however
Thanks @wimmme, I tried autoremote but it require connection to their server to operate, I want to have direct connection only. were you able to do that with autoremote?
I think I"ll give the domoticz tasker plugin a try then... see if it does what I need
Posted: Sunday 24 May 2020 12:40
by wimmme
eserero wrote: Sunday 24 May 2020 12:35
Indeed, Autoremote relies on GMS, as a standard behaviour that is. It should be possible to use it local too, but i don't have a need for that (
https://forum.joaoapps.com/index.php?th ... evices.30/) .
I do like the idea to have entry-level interaction between the Domoticz app and tasker too, without having to code and intercept messages etc ...
Posted: Sunday 24 May 2020 14:28
by eserero
wimmme wrote: Sunday 24 May 2020 12:40
OK - I just installed the plugin, took me a bit of time to find the options but it works almost perfectly. I actually got what I want and can open the tablet screen and show the camera app by pressing a zigbee button connected to domoticz through conbee
One bug I found is that I"m using a multiple selection switch - I configured it to respond to the first button click, but it actually works for the second button click. can this be fixed?
Posted: Monday 25 May 2020 11:08
by galadril
eserero wrote: Sunday 24 May 2020 14:28
So your using an Tasker event with a connected Selector? And you've set the value that you like to receive as the input event right?
Posted: Monday 25 May 2020 12:00
by eserero
Correct.
say I have a selector button with 4 options: off, B1, B2, B3
I setup the plugin to listen to the selector button, and choose B1 as the value to listen on.
what actually happens, is that the event works if I press B2, and not B1.
if I choose "off", then it will work on B1 press as B1 comes after "off"
Posted: Monday 25 May 2020 23:23
by galadril
eserero wrote: Monday 25 May 2020 12:00
Correct.
Thanks for the info, ill test this tomorrow!
Posted: Tuesday 26 May 2020 9:04
by galadril
Correct.
Is it possible that you have the off button hidden as setting on the selector in domoticz.. i found that the issue was for selectors with that setting ticked..
Im pushing a fix
Posted: Thursday 28 May 2020 13:36
by eserero
Yup - that is indeed the case.
just tested your fix and it is now working fine - much obliged
Posted: Friday 29 May 2020 14:18
by eserero
Actually, i have one more problem. I noticed that I get the notification about 1-10 seconds after I generate the event in domoticz (I press a physical button). is there a timeout setting I can set to shorten the time?
at most I can live with 1-2 seconds delay, otherwise it becomes quite unusable..
I dont know if its something inside Tasker, or because of the way the plugin listen to events. I tried just generating a test message in tasker - and I can see the delay time varies - are you polling for events every few seconds?
Posted: Friday 05 June 2020 8:31
by galadril
eserero wrote: Friday 29 May 2020 14:18
Oef websockets are real time. so it should be real time..
Maybe Tasker doesn't run the QueryReceiver, or a background process is killed by battery optimalization....
Posted: Monday 08 June 2020 16:15
by gvamporov
I installed the plug-in and I'm trying to make it work with Macrodroid.
So far it works fine with regular switch (On/Off), but i have problems to make it work with selector switches.
I select the switch, choose "selector values" and the action is saved, but it does not work.
Am i missing something specific for setting up a selector switch?
Posted: Sunday 05 July 2020 21:52
by nosehook
I just downloaded the plugin and inserted all the data for the server
It detects the server and devices and reports 207 devices found, then noting.... I've waited several minutes, but nothing happens and I am not able to see any of the other screens I saw when I purchased it in the play store.
Furthermore, the plugin is not shown in Tasker.
Obviously something is not going as it showld, but I have no clue what..
Is there anyone who could help me?
Update: rebooten die the trick... nog visible in tasker
Posted: Thursday 18 February 2021 10:16
by yan1950
Hello
I use to use an old smartphone with tasker and it works well.
I use Domoticz too. I want to play with tasker AND domoticz.
Android version is 4.4 on this old phone.
Domoticz tasker plugin cannot be installed on this phone ( andoid too old verrsion ! )
Is there a way to install it on android 4.4 ?
please excuse my bad english im french, nobody is perfect.
Yannick
Posted: Sunday 27 February 2022 17:39
by BennY
I'm struggeling with one issue with the websocket Connection.
If my phone changed the Connection from WiFi to Mobile or back to WiFi the Websocket Connection do not refresh. I have to run Tasker an save a Task or something else without a change. After saving the Websocket disconnect and connect again. Does somebody know a solution?
Benny
Posted: Tuesday 26 July 2022 17:18
by Nefsolive
Im using the domoticz plugin for tasker.
Im using a NFC TAG for Toggle Switch, but i want use the same TAG for ON and OFF!
is there any way in the plugin to run toggle?
Ty
Posted: Monday 16 October 2023 15:03
by rezzalex
Hello @galadril.
Is the tasker plugin and it's "listening server" are not based on Firebase Cloud messenging ?
I wanted to build a wall Domotic Tablet I have bought a Amazon Fire HD 10, which does not support Fire Cloud messenging... ==> I cant have the Doorbell app to natively pop-up when riging .... Except I the taskger plugin allow me to open the doorbell app in fullscreen when ringing (I already have the Doorbell event in DZ).
Am I knocking a the right place ?
Posted: Sunday 25 August 2024 20:18
by rezzalex
Hello @Galadril,
It seems the "on Switch Changed" event is not detected anymore, it seems to have worked previously...
I am using Tasker 6.1.32
What did I missed ?
Posted: Tuesday 27 January 2026 22:48
by jimbou
I don't know if this thread is still active.
I have an issue with this plugin. It connects correctly to the domoticz server, and I can use it to send logs to domoticz.
But when I try to switch a light on or off, it does not work. I can see in the domoticz log that the app logs in, but the light does not react.
Thanks for any help.
