OpenUV.io plugin max. 50 request/day Topic is solved
Derik
- Domoticz version: BETA
Re: OpenUV.io plugin max. 50 request/day
@firewizard
Your last flow is working good? So the plugin is not neaded any more.
Love this option to protect my kids...
Edit:
Which nodes i have to import..?
Edit:
- FireWizard
Hi @Derik,
Import the flow and Node Red will tell you, which nodes you are missing and have to install.
Derik
Hi...
i did hope i have the flow working..
Make the idx for the sensor.
Only i see in the flow a other idx, 8 before the gate node.
What type sensor is this? and what is the function of the sensor.
- FireWizard
Hello @Derik,
This flow was typically made for @Jan Jansen.
In his solution he had a switch, with IDX = 8, that when pushed to On, represents the "Day" situation
and when in "Off" position represents the "Night" situation.
If you copy that flow, then your device with IDX = 8 will control the gate. Which device it is, I don't know, but you can find it under
Setup > Devices.
In the original flow, posted at May 15, 2020, 21:18 h , the gate was not controlled by a simple switch, but by the results of 'Owntracks".
Those, who don't know "Owntracks", this is an app on your phone that sends the lat/lon co-ordinates to your (Mosquitto) MQTT server.
See: https://owntracks.org/
So, originally the flow was controlled by the day/night node, which depends on the lat/lon co-ordinates of your phone.
But what do you want to achieve?
Best regards
I think that you refer to the flow, posted at may 24, 2020, 19:19.i did hope i have the flow working..
Setup > Devices.
Best regards
Derik
I hope i can use this flow also.
The idx 8 i not more dan a dummy switch that can open the gate when there is sun.
Can i use the flow with that option?
- FireWizard
@Derik,
Yes you can.
It was a "Dummy Switch" (with IDX =8). Create your own switch. Note down the IDX.
If you use the "Filter" node, change the IDX number in the "Filter" node, If you go for the solution without the "Filter" node, you have to modify the
"Function" node and insert your IDX number.
Do not forget to modify the "Function" node, called "Prepare URL Open UV" and insert your own lat/lon co-ordinates and your own X-access token.
@Derik,
Yes you can.
- EdwinK
So... It seems I now have this working. Removed MQTT and node-red completely and reinstalled, now it works as it shoudl.
Just not sure if I have the sensors right.
- EdwinK
Chanced IDX 552 to an UV sensor
- FireWizard
Hi Edwin
@EdwinK
The sensors you want to use, is in fact up to you. E.g a "Text" sensor can contain more text than a "Custom Sensor".
I have the following:
For the "Open UV"sensor, called UV index, I use a UV sensor. This one will appear under the "Weather" tab.
For UV and UV max, I use for both an "Alert" sensor. They will appear under the "Utility" tab.
My function node (see below) is based on the use of an "Alert" sensor.
For the "Safe Exposure Time" and the Ozone sensors, I use "Custom" sensors.
On the x-axis of "Safe Exposure Time" you should use min. On the x-axis of "Ozone" you should use DU, which stands for "Dobson Units"
If you want, you can change the icon for a "Custom" sensor, which you cannot for a "Text" sensor.
The contents of the "Function" node in Node Red.
@EdwinK
// Declarations
var msg1 ={}; // UV sensor value
var msg2 ={}; // UV alert
var msg3 ={}; // Max UV
var msg4 ={}; // Ozone
var msg5 ={}; // Max. Exposure Time
// Function to convert UV index to level
function uvi2level(x) {
if (x < 3) {
return 0;
} else if (x < 6) {
return 1;
} else if (x < 8 ) {
return 2;
} else if (x < 11 ) {
return 3;
} else {
return 4;
msg1.payload = {"command":"udevice","idx":397,"nvalue":0,"svalue":msg.payload.result.uv.toFixed(1).toString() + ";0"};
msg2.payload = {"command":"udevice","idx":398,"nvalue":uvi2level(msg.payload.result.uv),"svalue":msg.payload.result.uv.toFixed(1).toString() + " UVI"};
msg3.payload = {"command":"udevice","idx":399,"nvalue":uvi2level(msg.payload.result.uv_max),"svalue":msg.payload.result.uv_max.toFixed(1).toString() + " UVI" + "\n" + msg.payload.result.uv_max_time};
msg4.payload = {"command":"udevice","idx":400,"nvalue":0,"svalue":msg.payload.result.ozone.toString()};
msg5.payload = {"command":"udevice","idx":401,"nvalue":0,"svalue":msg.payload.result.safe_exposure_time.st3.toString()};
return [[msg1,msg2,msg3,msg4,msg5]];
- EdwinK
Thanks for your answer. Glad to finally having this work.
(Onwards to find something for lux
Jan Jansen
- Domoticz version: Stable
The sun is shining more and more intensely so I regularly look at my UV sensors again. I use the flow below (thanks @FireWizard). Unfortunately, the flow gives an error message (see sidebar). I can't explain the error and therefore can't fix it. The settings of the moment node can also be found below. Does anyone have an idea how to fix this?
Thanks in advance.
Regards,
Jan
Thanks in advance.
Regards,
Jan
- OPenUV flow1.png (46.25 KiB) Viewed 1242 times
- FireWizard
Hello Jan (@Jan Jansen)
This error message comes from the "moment" node, called Date/Time Formatter.
As you can see in the Debug output below msg.payload.result.uv_max_time exist.
However I see that your moment node shows a different "Edit" window. Might it, that you use an older version?
Mine looks like:
I do not use that node, but you might also try to put as "Input msg msg.payload.result.uv_max_time instead of only payload.result.uv_max_time.
If it works do the same with the Output msg.
Let me know.
Mine looks like:
Let me know.
Jan Jansen
My system is up to date. I can't explain why my moment node looks different.FireWizard wrote: Thursday 21 April 2022 16:34
Changing the input and output msg has no effect. Which node do you use instead of the moment node?
Regards,
Jan
- FireWizard
Hello Jan (@Jan Jansen),
I use: node-red-contrib-moment and then specific the moment node.
See: https://flows.nodered.org/node/node-red-contrib-moment
It is called "Date/Time Formatter".
This works fine for me.
If you need another copy of my flow, let me know.
[{"id":"a4c34c84.d9cda","type":"moment","z":"27808d8a.76f2c2","name":"","topic":"","input":"payload.result.uv_max_time","inputType":"msg","inTz":"Europe/Amsterdam","adjAmount":0,"adjType":"days","adjDir":"add","format":"DD-MM-YYYY HH:mm:ss","locale":"en_US","output":"payload.result.uv_max_time","outputType":"msg","outTz":"Europe/Amsterdam","x":680,"y":100,"wires":[["e94602a.c7aa3"]]}]This works fine for me.
Jan Jansen
@FireWizard,
Thanks, it works again! I used node-red-contribute-moment2. With that, the flow has worked well before. The icon of the moment node is exactly the same as the icon of the moment node of node-red-contribute-moment. Under the hood there are differences.
Regards,
Jan
Regards,
Jan
- FireWizard
Hi @Jan Jansen.
I have never used node-red-contribute-moment2 and I assume it should work. And as you said it worked before.
But let us not waste time on it, as it woks again now.
