Dashticz - ANWB traffic info
TapNL
Re: Dashticz - ANWB traffic info
Post by TapNL »
Is this working or not. If I set it up - it keeps loading. But it not fully clear if this is broken at this moment.
Does anyone has this working?
Thanks for the clarification.
Cheers, M.
HansieNL
Post by HansieNL »
Still working here.
Can you post your block configuration?
Blah blah blah
TapNL
Post by TapNL »
My relevant config parts:
//TrafficInfo
var trafficinfo = {}
trafficinfo.anwbA12 = {
    trafficJams: true,
    roadWorks: false,
    radars: false,
    road:'A12',
    provider: 'anwb',
    show_lastupdate:true,
    icon: 'fas fa-car',
    width:12,
    results: 100 };
trafficinfo.anwbA50 = {
    trafficJams: true,
    roadWorks: true,
    radars: false,
    road:'A50',
    provider: 'anwb',
    icon: 'fas fa-car',
    width:12,
    results: 100 };
columns[2] = {}
columns[2]['blocks'] = ['clock','currentweather_big_owm','weather_owm',trafficinfo.anwbA12,trafficinfo.anwbA50]
columns[2]['width'] = 4;
Thanks in advance for the support
HansieNL
Post by HansieNL »
@TapNL I tried with latest beta and used the following working block settings.
Can you try if these settings works for you?:
//TrafficInfo
blocks['trafficinfo.anwbA12'] = {
    type: 'trafficinfo',
    trafficJams: true,
    roadWorks: false,
    radars: false,
    road:'A12',
    provider: 'anwb',
    icon: 'fas fa-car',
    width:12,
    results: 100 };
blocks['trafficinfo.anwbA50'] = {
    trafficJams: true,
    roadWorks: true,
    radars: false,
    road:'A50',
    provider: 'anwb',
    icon: 'fas fa-car',
    width:12,
    results: 100 };
Blah blah blah
TapNL
Post by TapNL »
No effect.How is your codeblock where you define it on the dashboard, in the column?
I am not in the beta I am on the latest stable version
HansieNL
Post by HansieNL »
TapNL wrote: Sunday 12 December 2021 15:04 No effect.How is your codeblock where you define it on the dashboard, in the column?
Can you try to add the single quotes.
I'm using the following colum block:
columns[1] = {}
columns[1]['blocks'] = ['trafficinfo.anwbA12','trafficinfo.anwbA50']
columns[1]['width'] = 5;
Blah blah blah
HansieNL
Post by HansieNL »
@TapNL see following info (this is not updated in master yet)
v3.8.4 Beta (13-8-2021)
Fixes
- ANWB traffic info: Change API v1 to v2
If you wanna hotfix it for your master you have to change in the file trafficinfo.js the following text api.anwb.nl/v1/incidents to api.anwb.nl/v2/incidents
Blah blah blah
HansieNL
Post by HansieNL »
@TapNL: A master with fix is available now. With git pull you can update to that version.
Blah blah blah
TapNL
Post by TapNL »
I did the git pull and now it works again.
@HansielNL: Thx for the support!
