Page 2 of 4
Re: Easiest way to get google home connected to domoticz?
Posted: Friday 17 April 2020 23:57
by ronaldbro
If it works in Google home app then it should work with voice too.
Don't know what kind of device 'window' is, but maybe you should ask 'close window' if it's a blind.
Maybe it takes some time to transfer the new google settings to the google home.
Posted: Friday 17 April 2020 23:59
by ronaldbro
Just remembered something. In the google home app I configures the google home device in a room and also added some of the Domoticz devices in that room. So that we you ask google to turn on the lights that only the lights in the room turn on and not the complete house...
Posted: Saturday 18 April 2020 0:10
by tjabas
no i just made a switch for our kitchen window named "window" but the stange thing is that sometimes when i ask my google home it still says "sorry i couldnt reach controlicz" even though i have removed that plugin from the home app, how can that be?
do i need to reinstall the google home itself?
Posted: Saturday 18 April 2020 0:26
by ronaldbro
I'm afraid I can't help you much further. I'm an Apple guy, only my son has a google home. That's the only google device in the house and it's only linked to homebridge.
Basically I reached the end of my google knowledge
Posted: Saturday 18 April 2020 0:39
by tjabas
ok,
thank you so much, i almost got it working now,
mabee someone else knows why my google home still thinks that controlicz is installed when i have deleted it in the home app, google in my phone works works good with homebridge, but not my home mini.
and i also noticed that temp sensors doesnt work in homebridge, or am i doing anything wrong?
Posted: Saturday 18 April 2020 0:49
by ronaldbro
I don't have any problems with temperature sensors, but I only use the single sensors in Homebridge. So only temperature and only humidity and not the THB sensors. Apple HomeKit doesn't support THB sensors. It does support temp/humidity sensors, but you need to click a tile first before you can see the humidity. When using single sensors I can show temp en humidity on two tiles next to each other.
It's not an exact answer to your question, but maybe it helps.
Posted: Saturday 18 April 2020 1:07
by tjabas
i see the temp sensors in homebridge, the problem is that they dont show in the home app.
Posted: Saturday 18 April 2020 10:53
by ronaldbro
Yep, that's what the note says on github. Sensor devices are not yet supported.
Posted: Saturday 18 April 2020 19:24
by tjabas
now everything works great, the google assistant works great, the only thing to wish for now is to get the tempsensors working, all the sensors are visible in homebridge but it would be nice if i could ask google for the temperature.
Posted: Saturday 18 April 2020 23:08
by FireWizard
@ronaldbro
I do not want to change the topic, but I have a simple question.
You wrote:
But I have installed the google plugin too and my son uses his Google home to control the Domoticz devices in his room. This works very good. Only thing that didn’t work was asking Google what the temperature in his room is, but maybe this is also already implemented.
As I have the same issue, with a thermostat, connected by nora node in node red in case the thermostat is in "auto" mode (clock program) I wonder how your sons thermostat is configured, if he asks for the temperature. Also "auto" mode?
Posted: Saturday 18 April 2020 23:24
by ronaldbro
It’s not a thermostat but only a THB sensor.
But looking at the github of the google plugin I think you can ask for the setpoint. Only sensor types are not supported yet.
Posted: Saturday 18 April 2020 23:48
by FireWizard
@ronaldbro
Thanks for your answer. The background is that their seems to be issues with thermostat modes.
I will investigate further.
Posted: Sunday 19 April 2020 10:56
by tjabas
i wonder if there is a thread about the homebridge google smart home plugin?
Posted: Sunday 19 April 2020 12:14
by ronaldbro
Sure, see here:
https://www.reddit.com/r/homebridge/
This is outside the Domoticz scope so I think you'll have better luck there for questions.
Posted: Sunday 19 April 2020 12:16
by tjabas
thanks
Posted: Saturday 25 April 2020 0:14
by tjabas
homebridge is working just fine and im very happy with it.
i have noticed one thing though,
sometimes homebridge doesnt update the switches from domoticz, that isnt really a big problem, but let say that the TV switch has been turned off in domoticz, sometimes homebridge doesnt see that, the TV switch is still showing on in homebridge, the problem is then, if it tell google to turn the TV on, homebridge will then not execute the voice command since the TV is set to on in homebridge, even if its really of in domoticz.
Is it possible to get homebridge to execute the on command even if the TV switch is set to on in homebridge?
hope you understand what i mean.
Posted: Thursday 07 May 2020 15:19
by rick8245
Hi ,
I got it all workingalmost.
In Homebridge i have these 3 plugins : 1.) Homebridge Config UI X 2.) Homebridge Edomoticz 3.) Homebridge Google Smart Home
they are all up to date.
Homebridge and Google home both see my Domoticz devices
I speak to my Google assistant -> GA responds: I will turn on light 1-> Homebridge icon shows the light is on -> Domoticz icon shows light is on but the light is not turned on.
anyone an idea what I missed here ?
thanks in advance
Posted: Thursday 07 May 2020 15:33
by FireWizard
@rick8245
MQTT?
See: Hardware > MQTT and set "Prevent Loop" to "False".
Posted: Thursday 07 May 2020 15:37
by rick8245
Thanks FireWizard.
That works GREAT !!!!!
Posted: Thursday 07 May 2020 16:14
by tjabas
I have the same problem, where do i get into the MQTT settings?, is it in homebridge or domoticz?
