Page 2 of 4
Re: Dashticz Calendar - Features, Fixes & Updates
Posted: Friday 17 April 2020 12:06
by geertvercamer
even the old version is not working anymore for me...
No none of my calendars is loading anymore.
Even with debug on in C:\xampp\htdocs\dashticz-beta\vendor\dashticz\ical\index.php
Posted: Friday 17 April 2020 12:32
by Lokonli
geertvercamer wrote: Friday 17 April 2020 12:06
Maybe first update to latest beta.
Then check whether Dashticz recognizes your PHP version.
It's reported in Dashticz, via settings icon (upper right) on the info tab.
Then check that you are using the internal CORS proxy (remove CORS_URL setting from your CONFIG.js)
Posted: Friday 17 April 2020 15:59
by geertvercamer
- updated to latest
- Dashticz info reads version 3.4.3 beta
- Dashticz info detects php 7.3.0
- CORS_URL is not in config.js
I'm focussing on the new block definition now, as it is much cleaner and more clear:
blocks['myCalendar'] = {
type: 'calendar',
layout: 1,
icalurl: 'https://calendar.google.com/calendar/ical/........../basic.ics',
maxitems: 6,
weeks: 5,
lastweek: false,
isoweek: true
columns[3]['blocks'] = ['myCalendar', 'garbage'];
nothing...
in the console no errors, this warning however:
DevTools failed to load SourceMap: Could not load content for https://my_local_domain_set_in_hosts_file:444/dashticz-beta/ical.min.js.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE
Posted: Friday 17 April 2020 16:51
by Lokonli
geertvercamer wrote: Friday 17 April 2020 15:59
- updated to latest
type: 'calendar',
layout: 1,
maxitems: 6,
weeks: 5,
lastweek: false,
isoweek: true
nothing...
The part 'my_local_domain_set_in_hosts_file:444' looks a bit strange to me.
Do you see more load errors on the network tab of DevTools?
If you open the link of icalurl directly in a browser do you then receive an ics file?
Posted: Friday 17 April 2020 17:00
by Jimster
Also try to delete your cookies and browser history. I had an issue that half of my blocks didn't appear on my tablet. Clearing them solved it.
Posted: Friday 17 April 2020 20:00
by clinkadink
If you are getting a 404 in devtools, it means 'file/page not found'. As already mentioned, I would try pasting the icalurl into the browser directly. If your ics file downloads, then it rules that out.
Posted: Saturday 18 April 2020 11:03
by geertvercamer
@jimster, did that. Several times even
@clinkadink, the ics files download ok. As they did on version 4.3.1, nothing has changed there
@lonkoli, I have 'depatine54.be 127.0.0.1' set in my hosts file
So I have the same error if I go to
http://127.0.0.1/dashticz-beta/
http://127.0.0.1/dashticz-beta/ical.min.js.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE
I did see this error:
unknown string block {type: "myCalendar", c: 3, key: "myCalendar", $mountPoint: jQuery.fn.init(1), mountPoint: "#block_42", …}
Posted: Saturday 18 April 2020 11:42
by Lokonli
geertvercamer wrote: Saturday 18 April 2020 11:03
ok, that last error gives an indication.
In your CONFIG.js you should have something like:
type: 'calendar',
icalurl: '....'
columns[3] = {
blocks: [ 'myCalendar', ...]
So the type in the block definition must be 'calendar'.
The names in columns.blocks and blocks must match.
Posted: Saturday 18 April 2020 11:51
by geertvercamer
Thanks, but I thought I had that covered:
type: 'calendar',
layout: 1,
icalurl: 'https://calendar.google.com/calendar/ical/***/basic.ics',
maxitems: 6,
weeks: 5,
lastweek: false,
isoweek: true
columns[3]['blocks'] = ['myCalendar', 'garbage', 289];
Posted: Saturday 18 April 2020 13:23
by Lokonli
Can you double check that you are running the latest beta? Update with:
No errors should be reported.
(I still have to create the 3.4.4 release.)
Posted: Saturday 18 April 2020 18:27
by geertvercamer
@Lokonli, I always download the zip and unpack it. Done that (twice)
Posted: Saturday 18 April 2020 18:39
by clinkadink
This is a strange one. As it appears from the error above that your calendar block has an incorrect
type set. Please can you double check, so we can rule this out?
Incorrect:
Correct:
Posted: Saturday 18 April 2020 20:05
by Lokonli
geertvercamer wrote:@Lokonli, I always download the zip and unpack it. Done that (twice)
In this case downloading the zip will be insufficient because then you won't get the latest changes.
I'll try to create the new release tonight.
Posted: Sunday 19 April 2020 0:30
by geertvercamer
blocks.js
line 55: handleStringBlock(cols['blocks'], myblockselector, c);
in my config cols['blocks'] = ['xxx', 'garbage', 289];
I thought one should provide the name or the index.
Apparently, this is not always the case, it is a fixed type apparently. Isn't this a problem. Suppose I want my calendar to the left and my girlfriend's to the right. If the name can't be set, this is impossible, I think.
Correct me if I'm wrong.
Modified config to cols['blocks'] = ['calendar', 'garbage', 289];
In that case, I get a block on the screen with the calendar icon, no data
Modified config to cols['blocks'] = [i'calendar', 'garbage', 289];
In that case, I get a block on the screen with a different calendar icon, no data, but the text 'loading'
Posted: Sunday 19 April 2020 8:28
by Lokonli
geertvercamer wrote: Sunday 19 April 2020 0:30
blocks.js
line 55: handleStringBlock(cols['blocks'][b], myblockselector, c);
You can show two different calendars in two different block, or combine multiple calendars into one block, or display one calendar multiple times with different settings.
I think your CONFIG.js is not completely correct. Probably you should not use 'cols'. Try with something as follows:
blocks['calendar1'] = {
type:'calendar',
icalurl: 'https://calendar.google.com/calendar/ical/.../basic.ics',
layout: 1,
title: 'First',
width:6
blocks['calendar2'] = {
type:'calendar',
icalurl: 'https://calendar.google.com/calendar/ical/.../1352b72845/basic.ics',
layout: 1,
title: 'Second',
width:6
columns[10] = {
blocks: [
'calendar1', 'calendar2'
width: 12
or post your CONFIG.js and we'll have a look.
Posted: Sunday 19 April 2020 14:46
by clinkadink
calFormat is for the old calendar.
layout is for the new calendar block.
Posted: Sunday 19 April 2020 16:19
by clinkadink
This also happens when you place a block
above this line in CONFIG.js.
Posted: Monday 20 April 2020 22:45
by geertvercamer
I am not using cols, it's in the Javascript.
The function takes the name and assumes it's a type...
my config:
var config = {}
config['domoticz_ip'] = 'https://depatine54.domoticz.com'; //'http://192.168.1.11:8090';
config['user_name'] = '';
config['pass_word'] = '';
config['room_plan'] = '0';
config['default_news_url'] = 'http://deredactie.be/cm/vrtnieuws';
config['news_scroll_after'] = '20';
config['theme'] = 'default';
config['background_image'] = 'img/bg2.jpg';
config['standby_after'] = '0';
config['auto_swipe_back_to'] = '1';
config['auto_swipe_back_after'] = '20';
config['auto_slide_pages'] = '0';
config['slide_effect'] = 'coverflow';
config['standard_graph'] = 'month';
config['language'] = 'nl_NL';
config['timeformat'] = 'DD/MM/YY HH:mm';
config['calendarformat'] = 'dd DD/MM HH:mm';
config['calendarlanguage'] = 'Nl-Be';
config['boss_stationclock'] = 'RedBoss';
config['edit_mode'] = 0;
config['idx_moonpicture'] = '0';
config['longfonds_zipcode'] = '';
config['longfonds_housenumber'] = '';
config['switch_horizon'] = '0';
config['sonarr_url'] = '';
config['sonarr_apikey'] = '';
config['sonarr_maxitems'] = '';
config['loginEnabled'] = 0;
config['disable_update_check'] = 0;
config['no_rgb'] = 0;
config['auto_positioning'] = 0;
config['use_favorites'] = 0;
config['disable_googleanalytics'] = 1;
config['last_update'] = 0;
config['hide_topbar'] = 0;
config['security_button_icons'] = 0;
config['hide_seconds'] = 0;
config['hide_seconds_stationclock'] = 0;
config['use_fahrenheit'] = 0;
config['use_beaufort'] = 0;
config['translate_windspeed'] = 1;
config['static_weathericons'] = 1;
config['hide_mediaplayer'] = 0;
config['standby_call_url'] = '';
config['standby_call_url_on_end'] = '';
config['blink_color'] = '255, 255, 255, 1';
var blocks = {};
blocks['cal'] = {
type: 'calendar',
layout: 1,
icalurl: 'https://calendar.google.com/calendar/ical/ge77/basic.ics',
maxitems: 6,
weeks: 5,
lastweek: false,
isoweek: true
var columns = {};
columns[1] = {width: 12};
columns[1]['blocks'] = ['cal'];
var screens = {};
screens['default'] = {};
screens['default']['maxwidth'] = 1920;
screens['default']['maxheight'] = 1080;
screens['default'][1] = {};
screens['default'][1]['background'] = 'brushedAlluminium.jpg';
screens['default'][1]['columns'] = [1];
Posted: Monday 20 April 2020 22:56
by Jimster
What if you remove weeks: 5, ? That is only for layout 2.
Posted: Monday 20 April 2020 23:34
by clinkadink
Correct.
