Dashticz Calendar - Features, Fixes & Updates
geertvercamer
- Target OS: -
Re: Dashticz Calendar - Features, Fixes & Updates
even the old version is not working anymore for me...
No none of my calendars is loading anymore.
Even with debug on in C:\xampp\htdocs\dashticz-beta\vendor\dashticz\ical\index.php
Lokonli
Maybe first update to latest beta.geertvercamer wrote: Friday 17 April 2020 12:06 even the old version is not working anymore for me...
Then check whether Dashticz recognizes your PHP version.
It's reported in Dashticz, via settings icon (upper right) on the info tab.
Then check that you are using the internal CORS proxy (remove CORS_URL setting from your CONFIG.js)
geertvercamer
- Target OS: -
- updated to latest
- Dashticz info reads version 3.4.3 beta
- Dashticz info detects php 7.3.0
- CORS_URL is not in config.js
I'm focussing on the new block definition now, as it is much cleaner and more clear:
nothing...
in the console no errors, this warning however:
DevTools failed to load SourceMap: Could not load content for https://my_local_domain_set_in_hosts_file:444/dashticz-beta/ical.min.js.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE
blocks['myCalendar'] = {
type: 'calendar',
layout: 1,
icalurl: 'https://calendar.google.com/calendar/ical/........../basic.ics',
maxitems: 6,
weeks: 5,
lastweek: false,
isoweek: true
columns[3]['blocks'] = ['myCalendar', 'garbage'];
Lokonli
The part 'my_local_domain_set_in_hosts_file:444' looks a bit strange to me.geertvercamer wrote: Friday 17 April 2020 15:59 - updated to latest
I'm focussing on the new block definition now, as it is much cleaner and more clear:nothing...Code: Select all
blocks['myCalendar'] = { type: 'calendar', layout: 1, icalurl: 'https://calendar.google.com/calendar/ical/........../basic.ics', maxitems: 6, weeks: 5, lastweek: false, isoweek: true } columns[3]['blocks'] = ['myCalendar', 'garbage'];
Do you see more load errors on the network tab of DevTools?
If you open the link of icalurl directly in a browser do you then receive an ics file?
Jimster
- Domoticz version: 2020.2
Also try to delete your cookies and browser history. I had an issue that half of my blocks didn't appear on my tablet. Clearing them solved it.
- clinkadink
If you are getting a 404 in devtools, it means 'file/page not found'. As already mentioned, I would try pasting the icalurl into the browser directly. If your ics file downloads, then it rules that out.
geertvercamer
- Target OS: -
@jimster, did that. Several times even
@clinkadink, the ics files download ok. As they did on version 4.3.1, nothing has changed there
@lonkoli, I have 'depatine54.be 127.0.0.1' set in my hosts file
So I have the same error if I go to http://127.0.0.1/dashticz-beta/
DevTools failed to load SourceMap: Could not load content for http://127.0.0.1/dashticz-beta/ical.min.js.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE
I did see this error:
unknown string block {type: "myCalendar", c: 3, key: "myCalendar", $mountPoint: jQuery.fn.init(1), mountPoint: "#block_42", …}
Lokonli
ok, that last error gives an indication.geertvercamer wrote: Saturday 18 April 2020 11:03 @jimster, did that. Several times even
In your CONFIG.js you should have something like:
type: 'calendar',
icalurl: '....'
columns[3] = {
blocks: [ 'myCalendar', ...]
The names in columns.blocks and blocks must match.
geertvercamer
- Target OS: -
Thanks, but I thought I had that covered:
type: 'calendar',
layout: 1,
icalurl: 'https://calendar.google.com/calendar/ical/***/basic.ics',
maxitems: 6,
weeks: 5,
lastweek: false,
isoweek: true
columns[3]['blocks'] = ['myCalendar', 'garbage', 289];
Lokonli
Can you double check that you are running the latest beta? Update with:
No errors should be reported.
(I still have to create the 3.4.4 release.)
git checkout beta
git pull
geertvercamer
- Target OS: -
@Lokonli, I always download the zip and unpack it. Done that (twice)
- clinkadink
This is a strange one. As it appears from the error above that your calendar block has an incorrect type set. Please can you double check, so we can rule this out?geertvercamer wrote: Saturday 18 April 2020 11:03 unknown string block {type: "myCalendar", c: 3, key: "myCalendar", $mountPoint: jQuery.fn.init(1), mountPoint: "#block_42", …}
Incorrect:
type: 'myCalendar',Code: Select all
type: 'calendar',"UI is the saddle, the stirrups, & the reins. UX is the feeling you get being able to ride the horse."
Lokonli
In this case downloading the zip will be insufficient because then you won't get the latest changes.geertvercamer wrote:@Lokonli, I always download the zip and unpack it. Done that (twice)
I'll try to create the new release tonight.
geertvercamer
- Target OS: -
blocks.js
line 55: handleStringBlock(cols['blocks'], myblockselector, c);
in my config cols['blocks'] = ['xxx', 'garbage', 289];
I thought one should provide the name or the index.
Apparently, this is not always the case, it is a fixed type apparently. Isn't this a problem. Suppose I want my calendar to the left and my girlfriend's to the right. If the name can't be set, this is impossible, I think.
Correct me if I'm wrong.
Modified config to cols['blocks'] = ['calendar', 'garbage', 289];
In that case, I get a block on the screen with the calendar icon, no data
Modified config to cols['blocks'] = [i'calendar', 'garbage', 289];
In that case, I get a block on the screen with a different calendar icon, no data, but the text 'loading'
Lokonli
You can show two different calendars in two different block, or combine multiple calendars into one block, or display one calendar multiple times with different settings.geertvercamer wrote: Sunday 19 April 2020 0:30 blocks.js
in my config cols['blocks'] = ['xxx', 'garbage', 289];Code: Select all
line 55: handleStringBlock(cols['blocks'][b], myblockselector, c);
I think your CONFIG.js is not completely correct. Probably you should not use 'cols'. Try with something as follows:
blocks['calendar1'] = {
type:'calendar',
icalurl: 'https://calendar.google.com/calendar/ical/.../basic.ics',
layout: 1,
title: 'First',
width:6
blocks['calendar2'] = {
type:'calendar',
icalurl: 'https://calendar.google.com/calendar/ical/.../1352b72845/basic.ics',
layout: 1,
title: 'Second',
width:6
columns[10] = {
blocks: [
'calendar1', 'calendar2'
width: 12
- clinkadink
calFormat is for the old calendar.
layout is for the new calendar block.
- clinkadink
This also happens when you place a block above this line in CONFIG.js.geertvercamer wrote: Saturday 18 April 2020 11:03 unknown string block {type: "myCalendar", c: 3, key: "myCalendar", $mountPoint: jQuery.fn.init(1), mountPoint: "#block_42", …}
blocks = {}"UI is the saddle, the stirrups, & the reins. UX is the feeling you get being able to ride the horse."
geertvercamer
- Target OS: -
I am not using cols, it's in the Javascript.
The function takes the name and assumes it's a type...
my config:
my config:
var config = {}
config['domoticz_ip'] = 'https://depatine54.domoticz.com'; //'http://192.168.1.11:8090';
config['user_name'] = '';
config['pass_word'] = '';
config['room_plan'] = '0';
config['default_news_url'] = 'http://deredactie.be/cm/vrtnieuws';
config['news_scroll_after'] = '20';
config['theme'] = 'default';
config['background_image'] = 'img/bg2.jpg';
config['standby_after'] = '0';
config['auto_swipe_back_to'] = '1';
config['auto_swipe_back_after'] = '20';
config['auto_slide_pages'] = '0';
config['slide_effect'] = 'coverflow';
config['standard_graph'] = 'month';
config['language'] = 'nl_NL';
config['timeformat'] = 'DD/MM/YY HH:mm';
config['calendarformat'] = 'dd DD/MM HH:mm';
config['calendarlanguage'] = 'Nl-Be';
config['boss_stationclock'] = 'RedBoss';
config['edit_mode'] = 0;
config['idx_moonpicture'] = '0';
config['longfonds_zipcode'] = '';
config['longfonds_housenumber'] = '';
config['switch_horizon'] = '0';
config['sonarr_url'] = '';
config['sonarr_apikey'] = '';
config['sonarr_maxitems'] = '';
config['loginEnabled'] = 0;
config['disable_update_check'] = 0;
config['no_rgb'] = 0;
config['auto_positioning'] = 0;
config['use_favorites'] = 0;
config['disable_googleanalytics'] = 1;
config['last_update'] = 0;
config['hide_topbar'] = 0;
config['security_button_icons'] = 0;
config['hide_seconds'] = 0;
config['hide_seconds_stationclock'] = 0;
config['use_fahrenheit'] = 0;
config['use_beaufort'] = 0;
config['translate_windspeed'] = 1;
config['static_weathericons'] = 1;
config['hide_mediaplayer'] = 0;
config['standby_call_url'] = '';
config['standby_call_url_on_end'] = '';
config['blink_color'] = '255, 255, 255, 1';
var blocks = {};
blocks['cal'] = {
type: 'calendar',
layout: 1,
icalurl: 'https://calendar.google.com/calendar/ical/ge77/basic.ics',
maxitems: 6,
weeks: 5,
lastweek: false,
isoweek: true
var columns = {};
columns[1] = {width: 12};
columns[1]['blocks'] = ['cal'];
var screens = {};
screens['default'] = {};
screens['default']['maxwidth'] = 1920;
screens['default']['maxheight'] = 1080;
screens['default'][1] = {};
screens['default'][1]['background'] = 'brushedAlluminium.jpg';
screens['default'][1]['columns'] = [1];
Last edited by geertvercamer on Tuesday 21 April 2020 17:16, edited 1 time in total.
Jimster
What if you remove weeks: 5, ? That is only for layout 2.
- clinkadink
Correct.
