Native Buienradar Hardware options Topic is solved
akamming
Re: Native Buienradar Hardware options
Post by akamming »
ILoveIOT wrote: Wednesday 13 May 2020 17:26 Hi akamming, many thanks for the advise, I tried 6 at least, for me no luck (see spoiler), If I'am not the only one, maybe a future request, where we can (maybe fixed times 5-10-15-30) change the polling time in the hardware/plugin section. If could change the time, the error would go away I guess, now its fine for me, excluded the error from the syslog, shows only in Domoticz now. (I was thinking to build Domoticz from source, but its just a error, plugin is working fine)
i don't share your conclusion. My "meetstation" is working fine today, only a few lines. But when i switch to the location settings in your log i immediately get an error:
2020-05-13 18:59:52.193  Status: BuienRadar: using Configured location settings (51.6949647, 5.0345487)
2020-05-13 18:59:52.194  Status: BuienRadar: Nearest Station: Meetstation Gilze Rijen (Gilze Rijen), Distance: 15.7 km, ID: 6350, Lat/Lon: 51.57,4.93
2020-05-13 18:59:52.333  (Buienradar) Temp + Humidity + Baro (TempHumBaro)
2020-05-13 18:59:52.335  (Buienradar) Temp (Ground Temperature (10 cm))
2020-05-13 18:59:52.336  (Buienradar) Temp (Feel Temperature)
2020-05-13 18:59:52.337  (Buienradar) Wind (Wind)
2020-05-13 18:59:52.339  (Buienradar) General/Visibility (Visibility)
2020-05-13 18:59:52.340  (Buienradar) General/Custom Sensor (Sun Power)
2020-05-13 18:59:52.343  (Buienradar) Rain (Rain)
2020-05-13 18:59:56.876  Error: BuienRadar: Problem Connecting to Buienradar! (Check your Internet Connection!)
When i go back to using meetstation Heino the error is gone again:
2020-05-13 19:01:50.115  Status: BuienRadar: Worker started...
2020-05-13 19:01:57.359  Status: BuienRadar: using Domoticz location settings (XX.XXXXX, YY.YYYYYYY)
2020-05-13 19:01:57.359  Status: BuienRadar: Nearest Station: Meetstation Heino (Zwolle), Distance: 13.7 km, ID: 6278, Lat/Lon: 52.43,6.27
2020-05-13 19:01:57.499  (Buienradar) Temp + Humidity (TempHum)
2020-05-13 19:01:57.501  (Buienradar) Temp (Ground Temperature (10 cm))
2020-05-13 19:01:57.502  (Buienradar) Temp (Feel Temperature)
2020-05-13 19:01:57.503  (Buienradar) Wind (Wind)
2020-05-13 19:01:57.504  (Buienradar) General/Custom Sensor (Sun Power)
2020-05-13 19:01:57.507  (Buienradar) Rain (Rain)
2020-05-13 19:01:57.764  (Buienradar) General/Custom Sensor (Next Rainshower Leadtime)
2020-05-13 19:01:57.765  (Buienradar) General/Custom Sensor (Next Rainshower Duration)
2020-05-13 19:01:57.766  (Buienradar) General/Custom Sensor (Next Rainshower Avg Rainrate)
2020-05-13 19:01:57.767  (Buienradar) General/Custom Sensor (Next Rainshower Max Rainrate)
2020-05-13 19:01:57.768  (Buienradar) General/Percentage (Rain Intensity)
2020-05-13 19:01:57.769  (Buienradar) General/Custom Sensor (Rainfall next Hour)
ILoveIOT
Post by ILoveIOT »
Hehe I tried 6, including the 5min error, I guess its just my source ip from Hungary what is the problem :D
1x OPI PC 5.8.16 Debian 10, MiniDNLA,SMD230,EpEver,MPD,800GB,Wiegand,7 temps,DHT,32/64 I/O,2022.1
2x OPI PC 4.19.25 Debian 9, MPD,7 temps,16/32 I/O,BMP,4.10717
1x IntelNUC 5.10 Debian 10, 2TB,DalyBMS,2023.1
3x ESPEasy NodeMCU V3, 16/16 I/O
