Dashticz - Module - 112 Meldingen (Dutch) Topic is solved
PietjePuck
Re: Dashticz - Module - 112 Meldingen (Dutch)
Post by PietjePuck »
Change
columns[1]['blocks'] = ['alarmmeldingen']
To
columns[1]['blocks'] = [alarmmeldingen]
Lokonli
Post by Lokonli »
Define your block as follows:
blocks['alarmmeldingen'] = {
  rss: 'https://www.alarmeringen.nl/feeds/region/rotterdam-rijnmond.rss',
  filter: 'Poortugaal,Rhoon,Hoogvliet,Traumaheli,Pernis',
  show_lastupdate:true,
  width:12,
  interval: 180,
  results: 5}
(or as what PietjePuck is proposing)
city has been renamed to filter
HansieNL
Post by HansieNL »
Don't know what changed, but in the latest beta it's working :D
Blah blah blah
Lokonli
Post by Lokonli »
That's what I like to hear :)
HansieNL
Post by HansieNL »
Lokonli wrote: Thursday 19 March 2020 19:49 If you want to remove the icon, add the following to your block definition:
	icon: '',  //This are two tick-marks
Just found out that you can change the icon to your own image :D :D :
    image: '../custom/img/siren.png',
Blah blah blah
Alfagek
Domoticz version: 2020.1
Post by Alfagek »
Thanks PietjePuk and Lokonli. Running nice over here :D
HansieNL
Post by HansieNL »
Is it possible to remove the seconds from the time? Or can I do that with css?
Blah blah blah
PietjePuck
I need to change the code for this
PietjePuck
:lol: I am a very punctual guy
HansieNL
Post by HansieNL »
I’m punctual on the minute ;)
All other blocks are using hh:mm. Than they’ll be in line with the rest then.
Maybe show seconds optional?
Blah blah blah
qwerk
Post by qwerk »
Hi, I am running dashticz of a synology webserveer. php 7.3 and apache 2.4 ( tried all combinations (php 5.6, 7.2 and apache 2.2)
I copies the same block as you provide
rss: 'http://www.alarmeringen.nl/feeds/region ... jnmond.rss',
show_lastupdate: true,
width:12,
icon: 'fas fa-bullhorn',
interval: 180,
results: 5,
this is my line
columns[3]['blocks'] = [buttons.buienradar,maps.a50,'garbage',buttons.webcamoprit,buttons.webcamtuin,buttons.webcamterras,'alarmmeldingen'];
In a browser the rss url works on the webserver. so no resolving issues orso.
on my dashticz web I only get:
Aantekening 2020-03-22 095610.jpg (6.56 KiB) Viewed 3224 times
and the error:
Aantekening 2020-03-22 095528.jpg (4.42 KiB) Viewed 3224 times
please advice
EdwinK
Post by EdwinK »
In your blocks, change
to
columns[3]['blocks'] = [buttons.buienradar,maps.a50,'garbage',buttons.webcamoprit,buttons.webcamtuin,buttons.webcamterras,alarmmeldingen];
Remove the '
qwerk
Post by qwerk »
When I remove both the '
The whole column disappears.
When using var instead of blocks you are correct.
I tried both the var and the blocks option.
it has to be something stupid.
I added the alarmmeldingen.js
I added the line in dashticz.js
Lokonli
Post by Lokonli »
qwerk wrote: Sunday 22 March 2020 10:11 When I remove both the '
I would advice to update to the latest beta, and follow the instructions in the manual:
https://dashticz.readthedocs.io/en/beta ... ingen.html
qwerk
Post by qwerk »
@lokonli I used "git fetch" but that does not update to the latests.
I removed dashticz, did a "git clone" beta. And copied my CONFIG.js
same error.
I installed dashticz on my domoticz server. and alarmmeldingen works !!!! ( I now have other issues)
So the problem is with my synology webserver.
I will search there
Lokonli
Post by Lokonli »
qwerk wrote: Sunday 22 March 2020 11:31 @lokonli I used "git fetch" but that does not update to the latests.
same error.
I will search there
git fetch doesn't update. Try git pull.
alarmeringen requires a working CORS proxy.
Did you configure PHP for Dashticz on your Synology correctly?
You can try using a public CORS server:
config['default_cors_url'] = 'https://cors-anywhere.herokuapp.com/';
However, this server is not always running, so it would be better to use the internal CORS server.
qwerk
Post by qwerk »
I found my issue. In the php settings openssl was not activated.
I have a working alarmmeldingen.
thanks for your help and the git explanation
PietjePuck
HansieNL wrote: Friday 20 March 2020 18:36 Is it possible to remove the seconds from the time? Or can I do that with css?
I just changed the code to fulfill your request wait a bit until @lokonli will merge it in the beta.
Lokonli
Post by Lokonli »
Done
toro
Post by toro »
This is realy great, I like it a lot.
Thank you very much PietjePuck. And Lokonli for adding it to the beta.
Just a small request though. Is it possible to add the day in front of the time?
If you live in a town where not every day alerts are given, it is a little bit hard to track what happend when.
It is just a simple addition, I made it for myself. But would be nice to get this implemented in the release.
Alarmmeldingen with day.png (9.82 KiB) Viewed 3099 times
And realy great would be if it is possible to show it in the locale language.
As this only works in the Netherlands, that would be in Dutch ;-)
I did it like this (just a snippit):
pubDate = pubDate.toString();
	switch(pubDate.split(' ')[0]) {
		case 'Sun':
			newDay = 'Zo';
			break;
		case 'Mon':
			newDay = 'Ma';
			break;
		case 'Tue':
			newDay = 'Di';
			break;
		case 'Wed':
			newDay = 'Wo';
			break;
		case 'Thu':
			newDay = 'Do';
			break;
		case 'Fri':
			newDay = 'Vr';
			break;
		case 'Sat':
			newDay = 'Za';
			break
pubDate = pubDate.split(' ')[4];
pubDate = newDay + ' ' + pubDate.split(':')[0] + ':' + pubDate.split(':')[1];
