Script to restart Domoticz if it crashes Topic is solved
jannl
- Domoticz version: 2025.5.x
Re: Script to restart Domoticz if it crashes
I test if domoticz is running by issuing a json call. The status of the service might be ok even if domoticz hangs.
adjego
- Domoticz version: V3.5163
I also have this happening.
Jan 3 23:22:00 raspberrypi domoticz: Error: /home/pi/domoticz/domoticz() [0x1a9650]
Jan 3 23:22:00 raspberrypi domoticz: Error: /home/pi/domoticz/domoticz(_Z14signal_handleri+0x58) [0x1a9708]
Jan 3 23:22:00 raspberrypi domoticz: Error: /lib/arm-linux-gnueabihf/libc.so.6(__default_sa_restorer_v2+0) [0x76b9eb20]
Jan 3 23:22:00 raspberrypi domoticz: Error: /lib/arm-linux-gnueabihf/libc.so.6(gsignal+0x40) [0x76b9d8dc]
Is there an actual fix for this issue?
I now have the script in place, but it's a workaround, not a fix.
@jannl, can you share your script?
jannl
Basically the script I use is in the wiki:
https://www.domoticz.com/wiki/Monitoring_domoticz
I only tweaked the curl parameters a little bit to include a timeout
I had the problem also.tjabas wrote:Im really new to this Linux and rasberry, but how do i install this script?
I have lot of problems with Domoticz freezing, so i guess this script would do the trick.
Installed new and restored the db.
Now it is working fine for a week (normaly in a few days web and ssh not accessible).
- philchillbill
The script works by checking the text that results from running the command: sudo service domoticz.sh status
The rpi version of Linux replies with a slightly different text that e.g. Ubuntu: 'domoticz is running' vs 'active (running)'.
If the version of the script you are using is checking for the wrong text it will never find it. Please look carefully at the earlier examples above and watch out for these differences I just mentioned.
hansrune
I use another approach, i.e a healthcheck script that runs from cron to check on port listeners, network connectivity and more.
Reboots on some conditions, restarts Domoticz if no listener for that network port. I chose to not restart services if someone is logged in to a shell, assuming that I me doing some maintenance.
You can pick this up, or perhaps use some ideas from https://github.com/hansrune/domoticz-co ... lthchkdomo
Instruction in the beginning....
- K3rryBlue
- Domoticz version: V4.10xx
Made a small change to this script. As the status response changed:
#!/bin/bash
DomoticzState=`sudo service domoticz.sh status`
if [[ $DomoticzState == *"active (running)"* ]]
then
echo 'Domoticz is running. Nothing to do.'
elif [[ $DomoticzState == *"inactive (dead)"* ]]
then
echo 'Domoticz is not running. Restarting Domoticz...'
sudo service domoticz.sh restart
echo 'Domoticz restarted.'
fiDomoticz V4.10717, RPi2 -> Linux raspberrypi 4.4.47-v7+ , RFXCOM - RFXtrx433 USB 433.92MHz ,RAZBERRY2 and OpenZWave USB Version: 1.4-2363-g1f10253-dirty
- Egregius
- Domoticz version: v2024.7
I believe it's better to query the json API to check that domoticz is online.
Because:
a) A service might be running but hanging and thus give a false response
b) A port might be listening but the service behind it hangs, again false response.
Because:
oohlaf
If it's just to check when domoticz has crashed (ie exited) and if your system uses systemd, then use the following:
(change the execstart parameters to your own usage)
[Unit]
Description=Domoticz Home Automation
After=network.target
[Service]
Type=forking
User=pi
Group=pi
WorkingDirectory=/home/pi/domoticz
PIDFile=/var/run/domoticz/domoticz.pid
ExecStart=/home/pi/domoticz/domoticz -daemon -pidfile /var/run/domoticz/domoticz.pid -www 8080 -sslwww 0 -log /var/log/domoticz/domoticz.log
ExecReload=/bin/kill -HUP $MAINPID
KillMode=process
Restart=on-failure
RestartSec=10
[Install]
WantedBy=multi-user.target
Alias=domoticz.sh.service
- K3rryBlue
Yes, there are indeed better, or multiple, ways but so far the simple script does what it needs to do.
However i must admit, that lately, the pi runs very stable, by using berryboot and run everything from a USB thumb. teh sd-card is only used to boot the rPi. So far Domoticz is stable for 2 weeks, no "database malfunctions" or crashes.
Cause the rPi runs stable now, it revealed a new problem, with OpenZWave + RazBerry2. Need to figure a way to detect that ZWave is not responding anymore, probably via a JSON call. IF no response THEN reboot rPi.
uc530
Hello!
I am new user of raspberry and domoticz and I am asking you for some help.
I have no success with the script to make it run. I made a file with name domoticz_state_checker.sh with:
But I have all possible errors listed when I try to run it:
If I change elif with elseif, then I have:
Can anyone please write it from the beginning, how to make this script to work properly. Where to put the files, how to write the code correctly...
I run raspbyan jessie on RPI ver.1.
Thanks in advance!
Ps:Sorry for my english.
#!/bin/bash
while true
do
DomoticzState=`sudo service domoticz status`
if [ $DomoticzState == "active (running)" ]
then
elif [ $DomoticzState == "inactive (dead)" ]
then
sudo service domoticz restart
fi
sleep 15
doneCode: Select all
sudo su pi /home/pi/domoticz/scripts/domoticz_state_checker.sh
/home/pi/domoticz/scripts/domoticz_state_checker.sh: line 10: syntax error near unexpected token `elif'
'home/pi/domoticz/scripts/domoticz_state_checker.sh: line 10: `elif [ $DomoticzState == "inactive (dead)" ]Code: Select all
/home/pi/domoticz/scripts/domoticz_state_checker.sh: line 18: syntax error near unexpected token `done'
/home/pi/domoticz/scripts/domoticz_state_checker.sh: line 18: `done'I run raspbyan jessie on RPI ver.1.
Thanks in advance!
- K3rryBlue
You ran a bit short on [ and ]
Please use this:
To check this every 15 seconds might be an overkill.......
Please use this:
#!/bin/bash
while true
do
then
then
fi
sleep 15
done
uc530
Hi!
Thanks for the answer.
I tryed that alredy with the code you posted few days ago, but i`ve got errors:
About the 15 seconds.... I`ll change that with longer period.
pi@raspberrypi:~ $ sudo su pi /home/pi/domoticz/scripts/domoticz_state_checker.sh
/home/pi/domoticz/scripts/domoticz_state_checker.sh: line 7: syntax error in conditional expression
'home/pi/domoticz/scripts/domoticz_state_checker.sh: line 7: syntax error near `]]
/home/pi/domoticz/scripts/domoticz_state_checker.sh: line 7: `if [[ $DomoticzState == *"active (runn'ng)"* ]]- K3rryBlue
I think you are creating your files in windows and copy them to the rPi.
- Please copy the code below to your script file. I use as example "domoticz_status_check.sh"
#!/bin/bash while true do DomoticzState=`sudo service domoticz.sh status` if [[ $DomoticzState == *"active (running)"* ]] then echo 'Domoticz is running. Nothing to do.' elif [[ $DomoticzState == *"inactive (dead)"* ]] then echo 'Domoticz is not running. Restarting Domoticz...' sudo service domoticz.sh restart echo 'Domoticz restarted.' fi sleep 15 done - Save the file and run the following commands via putty"
sudo chmod 755 domoticz_status_check.sh - Remove the horror from windows
sed -i -e 's/\r$//' domoticz_status_check.sh - Execute the script
sudo ./domoticz_status_check.sh
uc530
Thank you very much! It works!
Another one thing please... Procedure how to make the script to run after rpi reboot.
Thanks again! I owe you a big beer!
- K3rryBlue
uc530
Hi!
Script without loop and crontab command works like charm.
Thanks again for help.
script and added all rights:
crontab edit:
With best regards UC530
#!/bin/bash
then
then
fi
crontab edit:
crontab -e
*/1 * * * * /home/pi/domoticz/scripts/domoticz_state_checker.sh
- K3rryBlue
Thanks for your feedback. To make it even more complete you could add a simple log to your script, so you know when something happened.
If Domoticz need to restart it will write a datetime stamp to a file.
#!/bin/bash
CONFIG=/home/pi/domoticz/scripts/domoticz_state_checker.txt
dt=$(date '+%d/%m/%Y %H:%M:%S')
then
echo "Domoticz is running. Nothing to do."
then
echo "$dt, Domoticz is not running. Restarting Domoticz..." >> "$CONFIG"
echo "$dt, Domoticz restarted..." >> "$CONFIG"
jannl
I get a pushover notification when domoticz is restarted. I only check is json is respondig. With the status check you propably won't detect if domoticz hangs.
- havnegata
- Domoticz version: V4.10162
This is what I would like as welljannl wrote:I get a pushover notification when domoticz is restarted. I only check is json is respondig. With the status check you propably won't detect if domoticz hangs.
