background block Topic is solved
Lokonli
Re: background block
Post by Lokonli »
The ion module, which is used to play sounds, is not loaded. Normally it should be loaded at startup.
Can you post the output of:
git log -1
and
git status
With the developer window open in chrome, refresh Dashticz. Open the network tab in the developer window.
What is the status of the 'bundle.js' request? Probably it's the second network request.
pvklink
Domoticz version: latest b
Post by pvklink »
pi@raspberrypi:~/dashticz $ git log -1
commit 8d744ab9849daf3fb0f187caeb9dbdb2afc44be5 (HEAD -> beta, origin/beta)
Author: Lokonli <[email protected]>
Date: Wed Nov 20 20:12:20 2019 +0100
Secpanel (#133)
* secpanel special block
* security panel
and
pi@raspberrypi:~/dashticz $ git status
On branch beta
Your branch is up to date with 'origin/beta'.
Changes not staged for commit:
(use "git add/rm <file>..." to update what will be committed)
(use "git checkout -- <file>..." to discard changes in working directory)
deleted: custom/CONFIG_DEFAULT.js
modified: custom/custom.css
modified: custom/custom.js
Untracked files:
(use "git add <file>..." to include in what will be committed)
img/kan_weg_pvk_door_closed.png
img/kan_weg_pvk_door_open.png
img/pvk_blind_off.png
img/pvk_blind_on.png
img/pvk_blindorg_off.png
img/pvk_microphone_off.png
img/pvk_microphone_on.png
no changes added to commit (use "git add" and/or "git commit -a")
Jablotron connection, Ikea
pvklink
Post by pvklink »
it works!
I remove the quotes from secpanel, and put them back again, and no errors!
Perhaps there was a non visible character in the file that did not show up, i dont know this is possible?
Secpanel looks great!
Do i have to test more?
Lokonli
Post by Lokonli »
I'm not sure. Good to know it's working now :)
