switch and sensor combination  [Solved]
robbert1977
Re: switch and sensor combination
Post by robbert1977 »
Final code with Lux and based on motion keep light on.
In the code above if motion kept activated till end of timer the switch off command took place.
Solved in this one by starting the counter after motion sensor goes in OFF state, if reactivated on motion counter reset till next OFF state
No problems :) just wanted to share this.
  active = true,
    devices = {
      "Lamp Gang",
      "PIR Gang"
  data =
        sensorTurnedOnLights = { initial = false },
  execute = function(dz, item)
        local Lux        = dz.devices('PIR Test Lux').lux
        local maxLux     = 150
        local maxSeconds = 300
        local motion = dz.devices('PIR Gang')
        local switch = dz.devices('Lamp Gang')
        if item == motion and Lux < maxLux then -- motion active
          if motion.state == 'On' and switch.state == 'Off' then -- motion was the trigger
            dz.data.sensorTurnedOnLights = true
            switch.cancelQueuedCommands()
            switch.switchOn().checkFirst()
          elseif motion.state == 'On' and switch.state == 'On' and dz.data.sensorTurnedOnLights == true then -- new motion detection
          elseif motion.state == 'Off' and dz.data.sensorTurnedOnLights == true then -- switched on by sensor now motion in off state
            switch.switchOff().afterSec(maxSeconds).checkFirst()
        elseif item == switch and item.state == 'On' and motion.state == 'Off' then -- switch activated
          dz.data.sensorTurnedOnLights = false
Raspberry Pi 4
domoticzVersion: 2020.2
dzVentsVersion: 3.0.2
OpenZWave USB: 1.6-1033-g3661f170
RFXCOM - RFXtrx433 USB: Pro XL1/1043, Noise: 109 dB
Homebridge - Siri integration
Sjonnie2017
Domoticz version: Latest ß
Post by Sjonnie2017 »
Reviving an old thread here hoping anyone can shed some light on my problem. I have modified the script to remove the lux part and added a timer. The result of my modification is that the light switches on the first time I enter the room after I saved it independent of the time of day. If I enter the room a minute later the switch is activated again. I have no clue what causes this behaviour.
The script looks like this:
local motionName = 'Sensor Keuken'
local switchName = 'Plafond Keuken'
return
    active = true,
    on =
      devices =
          motionName,
          switchName,
      timer =
          'between 15 minutes after sunset and 3 minutes before sunrise'
    data =
    logging =
        level =  domoticz.LOG_DEBUG,
        marker = 'SensorKeuken'
--     local Lux        = dz.devices('PIR Gang Lux').lux <= I am not using this as the sensor has no lux capabilities
--     local maxLux     = 150
--     local Lights     = dz.devices('Plafond Keuken')
        local maxSeconds = 10
        local motion = dz.devices(motionName)
        local switch = dz.devices(switchName)
        --DEBUG
        dz.log('state of switch:   ' .. switch.state,dz.LOG_DEBUG)
        dz.log('state of motion:   ' .. motion.state,dz.LOG_DEBUG)
        dz.log('name of item:   ' .. item.name,dz.LOG_DEBUG)
        dz.log('sensorTurnedOnLights value: ' .. tostring(dz.data.sensorTurnedOnLights),dz.LOG_DEBUG)
        if item == motion then
            dz.log('if item == motion',dz.LOG_DEBUG)
            if switch.state == 'On' and item.state == 'On' and dz.data.sensorTurnedOnLights then
                dz.log("switch.state == 'On' and item.state == 'On' and dz.data.sensorTurnedOnLights",dz.LOG_DEBUG)
                switch.switchOff().afterSec(maxSeconds).checkFirst().silent()
            elseif item.state == 'On' and switch.state == 'Off' then
                dz.log("item.state == 'On' and switch.state == 'Off'",dz.LOG_DEBUG)
                switch.switchOn().checkFirst().silent()
                switch.switchOff().afterSec(maxSeconds).silent()
        elseif item.state == 'On' and  motion.state == 'Off' then
            dz.log("item.state == 'On' and  motion.state == 'Off'",dz.LOG_DEBUG)
Any help or tips greatly appreciated!
YouLess Energy meter
besix
Post by besix »
Change
to this form
if item == motion and dz.time.matchesRule('between 15 minutes after sunset and 3 minutes before sunrise') then
Sjonnie2017
Tx! That works. I experimented a little bit by introducing a schedule which seems to work as well. We'll see tonight if the results are as expected.
This is the final code I used:
-- Script based on this thread: https://www.domoticz.com/forum/viewtopic.php?f=59&t=29834&start=20
-- Purpose: switch on light when motion is detected between sunset and sunrise (more or less ;-))
local schedule1 = 'between 15 minutes after sunset and 3 minutes before sunrise on mon, tue, wed, thu'
local schedule2 = 'between 15 minutes after sunset and 08:30 on fri, sat, sun'
return
    active = true,
    on =
      devices =
          motionName,
          switchName,
    data =
    logging =
--     local Lights     = dz.devices('Lamp Gang')
        --DEBUG
        if item == motion and dz.time.matchesRule(schedule1) or dz.time.matchesRule(schedule2) then
Again... tx for your support!
