Python Plugin: WLED
Ankan
Re: Python Plugin: WLED
I have found the problem and fixed it by converting Color to string.
Row 237:
Changed from: Devices[Unit].Update(nValue=nValue, sValue=str(sValue), Color=Color)
Changed to: Devices[Unit].Update(nValue=nValue, sValue=str(sValue), Color=str(Color))
Row 237:
Ankan
Maye the true ploblem is this:
Quoted from https://www.domoticz.com/wiki/Developin ... hon_pluginThe Color parameter is valid if Command is "Set Color" and is a JSON serialized Domoticz color object.
Ankan
Instead of changing row 237 I changed the calling rows instead:
Row 145:
To: UpdateDevice(3,1,self.Level)
Row 157:
Row 161:
To: UpdateDevice(3,0,self.Level)
Row 145:
Row 157:
Row 161:
frustreerMeneer
Thanks! I have changed it and will test it for a while.Ankan wrote: Wednesday 27 November 2019 22:13 Instead of changing row 237 I changed the calling rows instead:
Row 145:
Row 157:
Row 161:
Ankan
If you don't set the color you should not send that argument to Devices[Unit].Update()
So you have to change the code little bit more. Maybe check if color is set and then call Update with or without color argument.
Else maybe you could overload the UpdateDevice function. One with 3 arguments and one with 4 arguments.
Ankan
I got stability problems with my system after installing your plugin. Maybe it's because it connect to the WLED on every heartbeat.
You can see the problem in the log for the device. I have only enabled "Color & Brightness".
My log looks like this without doing anything:
I guess you get this on onHertbeat callback every 10s. Maybe you don't have to do anything on heartbeat as long as you don't control your WLED strip from the WLED app or website.
2019-12-02 19:44:27 On
2019-12-02 19:44:17 On
2019-12-02 19:44:07 On
2019-12-02 19:43:56 On
2019-12-02 19:43:46 On
2019-12-02 19:43:36 On
2019-12-02 19:43:26 On
2019-12-02 19:43:16 On
2019-12-02 19:43:06 On
2019-12-02 19:42:56 On
2019-12-02 19:42:46 On
2019-12-02 19:42:36 On
2019-12-02 19:42:26 On
2019-12-02 19:42:16 On
2019-12-02 19:42:06 On
frustreerMeneer
Are you sure the above notifications are caused by the WLED plugin?Ankan wrote: Monday 02 December 2019 19:56 I got stability problems with my system after installing your plugin. Maybe it's because it connect to the WLED on every heartbeat.
My log looks like this without doing anything:Code: Select all
2019-12-02 19:44:27 On 2019-12-02 19:44:17 On 2019-12-02 19:44:07 On 2019-12-02 19:43:56 On 2019-12-02 19:43:46 On 2019-12-02 19:43:36 On 2019-12-02 19:43:26 On 2019-12-02 19:43:16 On 2019-12-02 19:43:06 On 2019-12-02 19:42:56 On 2019-12-02 19:42:46 On 2019-12-02 19:42:36 On 2019-12-02 19:42:26 On 2019-12-02 19:42:16 On 2019-12-02 19:42:06 On
Can you try the new version i uploaded yesterday? (You have to restart Domoticz after installing.)
WLED doesn't actively let the plugin know something has changed. That is why the plugin updates the status every heartbeat. Otherwise changes in the app or website aren't reflected quickly in Domoticz.Ankan wrote: Monday 02 December 2019 19:56 I guess you get this on onHeartbeat callback every 10s. Maybe you don't have to do anything on heartbeat as long as you don't control your WLED strip from the WLED app or website.
Maybe that would be possible with UDP but i have not looked into that and have no experience with it.
I'll try to find out if i can detect changes in WLED so the plugin doesn't have to update Domoticz every heartbeat.
Ankan
Yes, this log is from my system today after updating to latest version of your plugin. My device log stop adding On command every 10s after comment out onHeartbeat so the problem is there.
If you have to update every 10s you have to change the script to not update the domoticz device every time if there is no change. Else I guess you will have problems with events that trigger on wled device change.
kurczak2
Thanks for your hard work! The plugin works very well. It was useful to me just in time - before Christmas. Thanks again!
WIFI: Sonoff, ESPEasy, Tasmota, Xiaomi Gateway, Shelly, Tuya, magic home
Sensors: temp, humi, baro, CO2, PM10, PM2,5, lux, power, energy, voltage, current
frustreerMeneer
I have updated the plugin to update Domoticz only when something changes.Ankan wrote: Monday 02 December 2019 20:41 If you have to update every 10s you have to change the script to not update the domoticz device every time if there is no change. Else I guess you will have problems with events that trigger on wled device change.
Hope it works better for you now
frustreerMeneer
Glad you like it!kurczak2 wrote: Monday 02 December 2019 20:46 Thanks for your hard work! The plugin works very well. It was useful to me just in time - before Christmas. Thanks again!
Ankan
That is what I call good support.frustreerMeneer wrote: Monday 02 December 2019 21:42I have updated the plugin to update Domoticz only when something changes.Ankan wrote: Monday 02 December 2019 20:41 If you have to update every 10s you have to change the script to not update the domoticz device every time if there is no change. Else I guess you will have problems with events that trigger on wled device change.
Hope it works better for you now![]()
Thanks, it looks better!
Ankan
Hi there. I found one more little bug you maybe could check up.
When turning on, off or dimming "WLED - Color & Brightness" in Domoticz, very often there are two lines in the device log.
If turning off the device I sometimes get:
2019-12-03 21:52:50 On
2019-12-03 21:52:47 Off
When turning on or dimming:
2019-12-03 21:52:10 On
2019-12-03 21:52:06 On
I guess you update the device in Domoticz when do a action on it and then update it again on Heartbeat to get into sync.
Best way would be if the WLED update domoticz and skip polling on every heartbeat. Maybe the problem is in the dimmer/brightness value as you convert from procent to 0-255 and then back on status request.
It would be nice to use WLED builtin sync function to update Domoticz.
frustreerMeneer
I'm looking at the UDP sync but can't get Domoticz to listen yet.Ankan wrote: Tuesday 03 December 2019 22:05 It would be nice to use WLED builtin sync function to update Domoticz.
When i have more time i will dive into it
Ankan
I think I have something for you. The code now listen to UDP Sync port and update devices from it.
I think it need some more testing but it's a good start. Enjoy!
I had to change name to WLED2 as I wanted both plugins run side by side
# WLED Plugin for Domoticz
# Author: Frustreermeneer
<plugin key="WLED2" name="WLED2" author="frustreermeneer" version="0.0.1" wikilink="http://www.domoticz.com/wiki/plugins/plugin.html" externallink="https://github.com/frustreermeneer/domoticz-wled-plugin">
<description>
<h2>WLED Plugin</h2><br/>
<h3>Features</h3>
<ul style="list-style-type:square">
<li>Switching WLED on/off</li>
<li>Setting brightness</li>
<li>Setting effect from list</li>
<li>Setting effect speed & intensity</li>
<li>Setting presets from list</li>
<li>Setting palette from list</li>
</ul>
<h3>Configuration</h3>
</description>
<params>
<param field="Address" label="WLED IP Address" width="200px" required="true" default=""/>
<param field="Port" label="WLED UDP Sync Port" width="200px" required="true" default=""/>
<param field="Mode6" label="Debug" width="150px">
<options>
<option label="None" value="0" default="true" />
<option label="Python Only" value="2"/>
<option label="Basic Debugging" value="62"/>
<option label="Basic+Messages" value="126"/>
<option label="Connections Only" value="16"/>
<option label="Connections+Queue" value="144"/>
<option label="All" value="-1"/>
</options>
</param>
</params>
</plugin>
import Domoticz
import requests
import json
sAddress = ""
sPort = ""
wledData = None
jsonArray = None
class BasePlugin:
BeaconConn = None
getWLEDStatusConn = None
def __init__(self):
return
def onStart(self):
self.counter = 0
self.Color = {}
self.Level = 100
global sAddress
global sPort
sAddress = Parameters["Address"].strip()
sPort = Parameters["Port"].strip()
if Parameters["Mode6"] != "0":
Domoticz.Debugging(int(Parameters["Mode6"]))
DumpConfigToLog()
if (len(Devices) == 0):
Domoticz.Log("creating devices")
Options = {"LevelActions": "",
"LevelNames": "Loading...",
"LevelOffHidden": "true",
"SelectorStyle": "1"}
Domoticz.Device(Name="Palettes", Unit=1, TypeName="Selector Switch", Options=Options, Image=0).Create()
Domoticz.Device(Name="Effects", Unit=2, TypeName="Selector Switch", Options=Options).Create()
Domoticz.Device(Name="Color & Brightness", Unit=3, Type=241,Subtype=2,Switchtype=7,Options=Options).Create()
Domoticz.Device(Name="Presets", Unit=4, TypeName="Selector Switch", Options=Options).Create()
Domoticz.Device(Name="FX Speed", Unit=5, Type=244,Subtype=62,Switchtype=7,Options=Options).Create()
Domoticz.Device(Name="FX Intensity", Unit=6, Type=244,Subtype=62,Switchtype=7,Options=Options).Create()
else:
Domoticz.Log("devices existed already")
UpdatePresetsInDomoticz()
self.getWLEDStatusConn = Domoticz.Connection(Name="getWLEDStatusConn", Transport="TCP/IP", Protocol="HTTP", Address=sAddress, Port="80" )
self.getWLEDStatusConn.Connect()
self.BeaconConn = Domoticz.Connection(Name="Beacon", Transport="UDP/IP", Address=sAddress, Port=str(sPort))
self.BeaconConn.Listen()
def onConnect(self, Connection, Status, Description):
global sAddress
# er is een externe verbinding gemaakt
# json request doen
if( Connection.Name == "getWLEDStatusConn" ):
sendData = { 'Verb' : 'GET',
'URL' : '/json',
'Headers' : { 'Content-Type': 'application/json; charset=utf-8',
'Connection': 'close',
'Accept': 'Content-Type: text/plain; charset=UTF-8',
'Host': sAddress+":80",
'User-Agent':'Domoticz/1.0' }
Connection.Send(sendData)
def onMessage(self, Connection, Data):
global wledData
global jsonArray
try:
# we krijgen antwoord terug op onze request
# json update request afhandelen
Connection.Disconnect()
Status = int(Data["Status"])
if( Status == 200 ):
strData = Data["Data"].decode("utf-8", "ignore")
jsonArray = json.loads( str(strData) )
if( len( jsonArray ) ):
UpdateEffectsInDomoticz()
UpdatePalettesInDomoticz()
if (Connection.Name == "Beacon"):
Domoticz.Debug("Connection detail: "+str(Connection))
# Is it notifier protocol
if ( Data[0] == 0x00 and Data[21] == 0x00 and Data[22] == 0x00 and Data[23] == 0x00 and Data[24] == 0x00):
wledData = {
"callMode": Data[1],
"bri": Data[2],
"red": Data[3],
"green": Data[4],
"blue": Data[5],
"nightlightActive": Data[6],
"nightlightDelayMins": Data[7],
"effectCurrent": Data[8],
"effectSpeed": Data[9],
"white": Data[10],
"redSec": Data[12],
"greenSec": Data[13],
"blueSec": Data[14],
"whiteSec": Data[15],
"effectIntensity": Data[16],
"transitionDelayHi": Data[17],
"transitionDelayLow": Data[18],
"effectPalette": Data[19]
UpdateStatusInDomoticz()
except Exception as inst:
Domoticz.Error("Exception detail: '"+str(inst)+"'")
raise
def onCommand(self, Unit, Command, Level, Color):
# Domoticz.Log("onCommand called for Unit " + str(Unit) + ": Command '" + str(Command) + "', Level: " + str(Level) + "', Color: " + str(Color) )
# palettes keuze
if( Unit == 1 ):
if( Command == "Set Level" ):
doWLEDRequest( "&FP="+str(int(Level/10)-1) )
# effect keuze
if( Unit == 2 ):
doWLEDRequest( "&T=1&FX="+str(int(Level/10)-1) )
if( Command == "Off" ):
doWLEDRequest( "&T=0" )
# kleurkeuze
if( Unit == 3 ):
self.Level = Level if Level < 100 else 100
doWLEDRequest( "/win&A="+str(int(self.Level*2.55)) )
if( Command == "Set Color" ): #set kleur en level
self.Color = Color;
self.Level = Level
Domoticz.Log( "Color:" + str(self.Color) )
parsedColor = json.loads(self.Color)
doWLEDRequest( "/win&FX=0&A="+str(int(self.Level*2.55))+"&R="+str(parsedColor["r"])+"&G="+str(parsedColor["g"])+"&B="+str(parsedColor["b"] ) )
if( Command == "On" ):
doWLEDRequest( "/win&T=1&A="+str(int(self.Level*2.55)) )
doWLEDRequest( "/win&T=0&A="+str(int(self.Level*2.55)) )
# preset keuze
if( Unit == 4 ):
Domoticz.Log( "Switching to preset" + str(int(Level/10)))
doWLEDRequest( "/win&PL="+str(int(Level/10)) )
# fx speed
if( Unit == 5 ):
Domoticz.Log( "FX Speed: " + str(int(Level*2.55)))
doWLEDRequest( "/win&SX="+str(int(Level*2.55)) )
# fx intensity
if( Unit == 6 ):
Domoticz.Log( "FX Intensity: " + str(int(Level*2.55)))
# UpdateDevice(6,1,int(Level))
doWLEDRequest( "/win&IX="+str(int(Level*2.55)) )
global _plugin
_plugin = BasePlugin()
def onStart():
global _plugin
_plugin.onStart()
def onConnect(Connection, Status, Description):
global _plugin
_plugin.onConnect(Connection, Status, Description)
def onMessage(Connection, Data):
global _plugin
_plugin.onMessage(Connection, Data)
def onCommand(Unit, Command, Level, Hue):
global _plugin
_plugin.onCommand(Unit, Command, Level, Hue)
# Generic helper functions
def DumpConfigToLog():
for x in Parameters:
if Parameters[x] != "":
Domoticz.Debug( "'" + x + "':'" + str(Parameters[x]) + "'")
for x in Devices:
Domoticz.Debug("Device: " + str(x) + " - " + str(Devices[x]))
Domoticz.Debug("Device ID: '" + str(Devices[x].ID) + "'")
Domoticz.Debug("Device Name: '" + Devices[x].Name + "'")
Domoticz.Debug("Device nValue: " + str(Devices[x].nValue))
Domoticz.Debug("Device sValue: '" + Devices[x].sValue + "'")
Domoticz.Debug("Device LastLevel: " + str(Devices[x].LastLevel))
return
def UpdateDevice(Unit, nValue, sValue, Color=""):
# Make sure that the Domoticz device still exists (they can be deleted) before updating it.
if (Unit in Devices):
if (Devices[Unit].nValue != nValue) or (Devices[Unit].sValue != sValue) or (Devices[Unit].Color != Color):
if( Color ):
Devices[Unit].Update(nValue=nValue, sValue=str(sValue), Color=str(Color) )
else:
Devices[Unit].Update(nValue=nValue, sValue=str(sValue) )
return
def UpdateEffectsInDomoticz():
# Domoticz.Log("updateEffects")
LevelNames = "Off|"
LevelActions = "|"
effectsArray = jsonArray["effects"]
for idx,effect in enumerate(effectsArray):
LevelNames = LevelNames + str(idx+1) + " - " + str(effect)
if( idx < len(effectsArray)-1 ):
LevelNames = LevelNames + "|"
LevelActions = LevelActions + "|"
dictOptions = Devices[2].Options
dictOptions["LevelNames"] = LevelNames
dictOptions["LevelActions"] = LevelActions
nValue = Devices[2].nValue;
sValue = Devices[2].sValue;
Devices[2].Update(nValue = nValue, sValue = sValue, Options = dictOptions)
def UpdatePalettesInDomoticz():
global jsonArray
# Domoticz.Log("updatePallettes")
LevelNames = "Off|"
LevelActions = "|"
palettesArray = jsonArray["palettes"]
for idx,palette in enumerate(palettesArray):
LevelNames = LevelNames + str(idx+1) + " - " + str(palette)
if( idx < len(palettesArray)-1 ):
dictOptions = Devices[1].Options
nValue = Devices[1].nValue;
sValue = Devices[1].sValue;
Devices[1].Update(nValue = nValue, sValue = sValue, Options = dictOptions)
def UpdatePresetsInDomoticz():
# Domoticz.Log("updatePresets")
LevelNames = "None|"
LevelActions = "|"
for i in range(1,25):
LevelNames = LevelNames + str(i)
if( i < 24 ):
# Domoticz.Log( LevelNames )
dictOptions = Devices[4].Options
dictOptions["LevelOffHidden"] = "false"
nValue = Devices[4].nValue;
sValue = Devices[4].sValue;
Devices[4].Update(nValue = nValue, sValue = sValue, Options = dictOptions)
def UpdateStatusInDomoticz():
global wledData
brightness = wledData["bri"]
r = wledData["red"]
g = wledData["green"]
b = wledData["blue"]
color = json.dumps({ "b":b, "cw":0, "g":g, "m":3, "r":r, "t":0, "ww":0 })
UpdateDevice(3,1,int(brightness/2.55),color) #Devices[3].sValue)
UpdateDevice(6,1,wledData["effectIntensity"]/2.55)
UpdateDevice(5,1,wledData["effectSpeed"]/2.55)
effect = wledData["effectCurrent"]
UpdateDevice(2,1,(effect+1)*10)
UpdateDevice(1, 1, (wledData["effectPalette"]+1)*10 )
def doWLEDRequest( parameters ):
global sAddress
url = "http://"+sAddress+"/win"+parameters
# Domoticz.Log( url )
resp = requests.get(url=url)
# Domoticz.Log(str(resp.status_code))
# Domoticz.Log(str(resp))
frustreerMeneer
Thanks Ankan, i will check it out.Ankan wrote: Saturday 07 December 2019 11:04 Hi,
Apparently you had more success getting UDP to work.
I will have to figure out if UDP will be the only source for updates or not.
It depends on wether Aircoookie will keep the data in UDP and JSON the same.
frustreerMeneer
The latest version of the plugin now updates Domoticz status via UDP and is therefore much more efficient and faster.
Don't forget to restart Domoticz after updating and fill out the new sync settings.
Thanks for @Ankan for helping me out!
Ankan
Great!
By the way, I think you should change udp port to what the user enter in the configuration and not hardcode it.
frustreerMeneer
Ankan wrote: Tuesday 10 December 2019 23:16 By the way, I think you should change udp port to what the user enter in the configuration and not hardcode it.
Wow! You're fast and sharp
I forgot to change it. Now fixed it.
