pipiche wrote: Thursday 26 December 2019 12:41
Johnny5 wrote: Tuesday 24 December 2019 22:02
Johnny5 wrote: Tuesday 24 December 2019 21:20
Today suddenly some of the Xiaomi Aquara sensors what was connected to Tradfri repeater lost the connection. What is weird that one is working what connected to Tradrfri repeater. What I don't understand that Topology map doesn't show that connection. Only one another Temp sensor is visible what was connected directly to Zigate as well.
So only two temp sersors sending data currently. One (1.) was connected drirectly to Zigate, another one (2.) used Tradfri repeater but only 1. is visible on Topology map. Same issue after plugin restart.
What can I do now?
After reset Xiaomi sensors all started to work but not through Tradfri repeaters. Connected the Zigate directly this time. All of them visible on the Topology map as well. Tradfri repeaters are still not alive. Not even after reset them. I don't know what to do. The most strange thing that both of them lost today. That can't be a coincidence. I didn't change anything in the system. I'm clueless what happend.
There is nothing we can do to force a device to use a particular route.
Could you let me know what is the Wifi 2.4 Channel you are using and what is the Zigbee/Zigate channel use (you can see that in the Log at plugin start)
When you said the repeater are still not alive, what does that mean ? How do you get to that conclusion ?
Hi Pipiche,
I know that devices take their own way to the Zigate. I meant about repeaters were not alive that Device manager on Plugin page reported as not alive. Unfortunately Domoticz doesn't show "real last connection time" for Tradfri repeaters. I don't know why. I never seen any real conenction data even when they worked fine. So that isn't so infromative.
Some of the devices used the repeater to connect as they were too far from Zigate. They didn't send any data anymore. Strangely both two repeaters lost their connection (and all connected devices) around same time. I couldn't see any usable info in Domoticz log about that. I tried to reconect Tradfri repeaters using reset switch without success. Log showed this (filtered for word "Tradfri"):
2019-10-29 23:36:50.815 (Zigate) timedOutDevice unit Tradfri repeater nwkid: fd56
2019-10-29 23:36:50.818 Error: (Zigate) Command: 0x0120:Configure reporting request failed on Tradfri repeater
2019-10-29 23:36:50.818 Error: (Zigate) - Device: Tradfri repeater NwkID: fd56 IEEE: 000d6ffffe7aceda
2019-11-29 21:24:39.398 Status: (Zigate) [1] NEW OBJECT: 94c7 Model Name: TRADFRI signal repeater
2019-11-30 21:24:37.980 Error: (Zigate) Device Health - Nwkid: 94c7,Ieee: 000d6ffffe2f13f9 , Model: TRADFRI signal repeater seems to be out of the network
2019-12-01 02:14:15.499 Error: (Zigate) Device Health - Nwkid: fd56,Ieee: 000d6ffffe7aceda , Model: TRADFRI signal repeater seems to be out of the network
2019-12-04 03:03:11.217 Error: (Zigate) Device Health - Nwkid: fd56,Ieee: 000d6ffffe7aceda , Model: TRADFRI signal repeater seems to be out of the network
2019-12-21 11:54:26.955 (Zigate) timedOutDevice unit Tradfri repeater 2 nwkid: 94c7
2019-12-21 11:54:26.957 Error: (Zigate) Command: 0x0100:Read Attribute request failed on Tradfri repeater 2
2019-12-21 11:54:26.957 Error: (Zigate) - Device: Tradfri repeater 2 NwkID: 94c7 IEEE: 000d6ffffe2f13f9
2019-12-21 11:54:26.958 Error: (Zigate) - Device: Tradfri repeater 2 NwkID: 94c7 IEEE: 000d6ffffe2f13f9
2019-12-21 11:54:27.059 Error: (Zigate) Command: 0x0100:Read Attribute request failed on Tradfri repeater 2
2019-12-21 11:54:27.059 Error: (Zigate) - Device: Tradfri repeater 2 NwkID: 94c7 IEEE: 000d6ffffe2f13f9
2019-12-24 02:55:52.598 (Zigate) timedOutDevice unit Tradfri repeater 2 nwkid: 94c7
2019-12-24 02:55:52.600 Error: (Zigate) Command: 0x0120:Configure reporting request failed on Tradfri repeater 2
2019-12-24 02:55:52.600 Error: (Zigate) - Device: Tradfri repeater 2 NwkID: 94c7 IEEE: 000d6ffffe2f13f9
2019-12-24 03:06:52.683 (Zigate) timedOutDevice unit Tradfri repeater 1 nwkid: fd56
2019-12-24 03:06:52.685 Error: (Zigate) Command: 0x0120:Configure reporting request failed on Tradfri repeater 1
2019-12-24 03:06:52.685 Error: (Zigate) - Device: Tradfri repeater 1 NwkID: fd56 IEEE: 000d6ffffe7aceda
2019-12-24 23:56:10.647 Error: (Zigate) Command: 0x0120:Configure reporting request failed on Tradfri repeater 2
2019-12-24 23:56:10.647 Error: (Zigate) - Device: Tradfri repeater 2 NwkID: 94c7 IEEE: 000d6ffffe2f13f9
2019-12-25 00:07:10.811 Error: (Zigate) Command: 0x0120:Configure reporting request failed on Tradfri repeater 1
2019-12-25 00:07:10.811 Error: (Zigate) - Device: Tradfri repeater 1 NwkID: fd56 IEEE: 000d6ffffe7aceda
2019-12-25 20:56:21.778 Error: (Zigate) Command: 0x0120:Configure reporting request failed on Tradfri repeater 2
2019-12-25 20:56:21.778 Error: (Zigate) - Device: Tradfri repeater 2 NwkID: 94c7 IEEE: 000d6ffffe2f13f9
2019-12-25 21:07:21.978 Error: (Zigate) Command: 0x0120:Configure reporting request failed on Tradfri repeater 1
2019-12-25 21:07:21.978 Error: (Zigate) - Device: Tradfri repeater 1 NwkID: fd56 IEEE: 000d6ffffe7aceda
2019-12-26 10:59:18.077 Status: (Zigate) Device Tradfri repeater 1 with IEEE: 000d6ffffe7aceda fully removed from the system.
2019-12-26 11:07:59.266 Status: (Zigate) [1] NEW OBJECT: fde9 Model Name: TRADFRI signal repeater
At the end I deleted the repeater from Domoticz rebooted the NAS and then it was ok to conenct using the reset button.
Losing the connection happeend after some time midnight 24 Dec. However same error messgaes appears before 24 Dec. But that time both repeaters worked fine. SO I really don't know what happened with them and what these errors are about.
Regarcing the question of Wifi channels. I searched on the Net some articles about Zigbee and 2.4 Wifi. It sad that there are many owerlappings. What I did yesterday I switched my router from Auto channel selection to channel 1.
Can you tell me where can I find the Log for that? I can see that teh channel is 0 on Plugin page.
One more thing to mention. Since this issue I can't run scan to see the topology. I doesn't show anything. What can be the issue with that?
Thank you!
