Sensibo through dzVents  [Solved]
Re: Sensibo through dzVents
remcod wrote: Monday 05 October 2020 20:16 2020-10-05 20:22:50.976 Status: dzVents: Error (2.4.19): /usr/local/domoticz/dzVents/runtime/Domoticz.lua:172: attempt to perform arithmetic on local 'x' (a nil value)
I guess the setPoint cannot be found so the round function will fail. I added some extra log to below script.
Can you try it and show ALL loglines from one execution of this script?
        devices = { 'Airco', 'Airco temperatuur', 'Airco fan', 'Airco mode' },
        httpResponses = { 'Airco' } -- matches callback string below
    logging =
        level = 'domoticz.LOG_DEBUG',
        marker = 'Sensibo',
    execute = function(domoticz, triggerItem)
    local device_id = 'yyyyy' -- change to id of salon
    local api_key = 'zzzzz' -- change to API key
    --define related switches
    local ac_state = domoticz.devices('Airco')
    local ac_mode = domoticz.devices('Airco mode')
    local ac_fan_level = domoticz.devices('Airco fan')
    local ac_salon_termo = domoticz.devices('Airco temperatuur')
    domoticz.log(tostring(ac_salon_termo.setPoint), domoticz.LOG_DEBUG)
    if ac_salon_termo.setPoint == nil then
        domoticz.log('setPoint not found. Will set it to 19 ', domoticz.LOG_ERROR)
    local function boo() -- the on parameter must be passed as a boolean. This function does that
        if ac_state.state == 'On' then
            return true
            return false
    --get the levels from the related switches
    local acmode = ac_mode.levelName
    local flevel = ac_fan_level.levelName
    local set_temp = domoticz.utils.round((ac_salon_termo.setPoint or 19), 0)
    preppostData = {
        acState = {
                on =  boo(),
                targetTemperature = set_temp,
                mode = acmode,
                fanLevel = flevel
    --domoticz.utils.dumpTable(preppostData)
        if (triggerItem.isDevice) then
            domoticz.openURL({
                url = 'https://home.sensibo.com/api/v2/pods/'..device_id..'/acStates?apiKey='..api_key,
                method = 'POST',
                callback = 'Airco',
                postData = preppostData
        elseif (triggerItem.isHTTPResponse) then
    local response = triggerItem
        if (response.ok and response.isJSON) then
           print('Command sent OK to Airco')
                print('**Airco failed to fetch info')
remcod
Post by remcod »
Thanks! problem solved. I added temperature as virtual switch and it had to be an virtual thermostat.
Thank you for the support!
delius
Post by delius »
stupid question. How do I make a thermostat type switch? The other three are logical, but I don't see a thermostat in my type selection list.
Nevermind: found it
delius
Post by delius »
I made a second script that fills two dummy temperature / humidity sensors with the values of my Sensibo Sky devices. The script needs a dummy temperature and a dummy humidity sensor. You need to fill the xxx with your own values.
return
    on =
        timer =
            'every 30 minutes',
        httpResponses =
            'trigger',
   --  logging =    {   level = domoticz.LOG_DEBUG ,  },
    execute = function(dz, item)
        function extract_json( tbl )
            local checklist = {}
            local function innerdump( tbl, indent )
                checklist[ tostring(tbl) ] = true
                for k,v in pairs(tbl) do
                        if (k == "humidity") then
                             dz.openURL({
                                url = 'http://xxx.xxx.xxx.xxx:xxxx/json.htm?type=command&param=udevice&idx=xxx&nvalue='..v,
                                method = 'GET',
                                callback = 'trigger',
                        if (k == "temperature") then
                             dz.openURL({
                                url = 'http://xxx.xxx.xxx.xxx:xxx/json.htm?type=command&param=udevice&idx=xxx&nvalue=0&svalue='..v,
                                method = 'GET',
                                callback = 'trigger', -- see httpResponses above.
                    if (type(v) == "table" and not checklist[ tostring(v) ]) then
                        innerdump(v,indent .. tostring(k) .. ".")
            innerdump( tbl, "Key: " )
        local json = assert(loadfile "/home/pi/domoticz/scripts/lua/JSON.lua")()  -- For Linux
        local device_id = 'xxxxxxxx'
	    local api_key = 'xxxxxxxxxxxxxxxxxxxxxxxxxxxxx'
        if item.isTimer then
            dz.openURL({
                url = 'https://home.sensibo.com/api/v2/pods/'..device_id..'/measurements?apiKey='..api_key,
                method = 'GET',
        if (item.isHTTPResponse) then
            if item.ok then
                if (item.isJSON) then
                    local ACInfo = json:decode(item.data)
                    extract_json(ACInfo)
                elseif LOGGING == true then
                    print('There was a problem handling the request', dz.LOG_ERROR)
                    print(item, dz.LOG_ERROR)
I struggled a lot with the LUA - JSON combination. Hence the somewhat wonderful extract_json loop. If someone succeeds in picking the correct value directly from the JSON, please let me know.
delius wrote: Thursday 25 March 2021 12:22 I struggled a lot with the LUA - JSON combination. Hence the somewhat wonderful extract_json loop. If someone succeeds in picking the correct value directly from the JSON, please let me know.
If you add
dz.utils.dumpTable(item.json)
directly after line
And share the log, I might be able to show how you can access the data using native dzVents / Lua
delius
Post by delius »
waaren wrote: Thursday 25 March 2021 14:07
If you add
directly after line
I've tried, but that's part of the problem. dumpTable does not output. Actually all JSON functions do not output, hence the strange construction.
delius wrote: Friday 26 March 2021 9:27 I've tried, but that's part of the problem. dumpTable does not output. Actually all JSON functions do not output, hence the strange construction.
OK. Can you then please try to add
 dz.utils.dumpTable(item.data)
 dz.utils.dumpTable(globalvariables)
 dz.log(package.path, dz.LOG_FORCE)
directly after line
rolandtwilt wrote: Friday 26 March 2021 11:34 friends of automation, I have a Blocky script and there is a decent delay here at 34 seconds to be exact.
Post moved to Blockly subtopic.
@rolandtwilt Please do not hijack another unrelated topic for this. Thx
