[Experimental] New graph module. Testers needed.
renerene
Re: [Experimental] New graph module. Testers needed.
Post by renerene »
Latest version does not work on my Chinese Android tablet running WallPanel. Also tested FullyKiosk, no luck. It gets stuck at "loading 10%" or "Could not load graph!"
on PC with Mozilla evrything is ok.
Additional: the three time range buttons at the top consume a lot of space and are rarely used. Is it possible to hide them, or make them smaller?
Lokonli
Post by Lokonli »
Gianni wrote: Thursday 29 August 2019 22:19 update to v 3.0.6
get the newest graph.js
add some colors to my js and everything works fine
nice :)
Lokonli
Post by Lokonli »
renerene wrote: Thursday 29 August 2019 22:22 Latest version does not work on my Chinese Android tablet running WallPanel. Also tested FullyKiosk, no luck. It gets stuck at "loading 10%" or "Could not load graph!"
In the latest graphjs version they already shift to the upper right (if it fits).
You can also hide them completely via custom.css. I'll update the documentation.
Lokonli
Post by Lokonli »
Did it work before? Until when?
I've started to use some more modern js functionalities (ES6, css flex)
Probably you need to update your browser. FullyKiosk uses Webview. WallPanel probably as well. Do you already have the latest webview module? You can download it from the Google play store. If you update Chrome you get the latest webview as well.
Gianni
Post by Gianni »
@lokonli is it possible to set the graph into 24 h and not am/pm
Lokonli
Post by Lokonli »
Gianni wrote: Friday 30 August 2019 8:35 @lokonli is it possible to set the graph into 24 h and not am/pm
It can be done now already by manually overriding the graph options:
blocks['graph_6'] = {
    options : {
       scales: {
            xAxes: [{
                time: {
                    displayFormats: {
                    'minute': 'HH:mm',
                    'hour': 'H',
(in this example is 6 the Domoticz device ID for which you want to show the graph)
Maybe I'll make it a bit easier to configure in the future.
Gianni
Post by Gianni »
dashticz keep loading ;-)
//graph
blocks['graph_126'] = {
   title: 'Zonnepanelen',
   width: 12,
   type: 'bar',
   datasetColors: ['yellow']
   options : {
       scales: {
            xAxes: [{
                time: {
                    displayFormats: {
                    'minute': 'HH:mm',
                    'hour': 'H',
checked all my open en close tags and it's seen correct.
Gianni
Post by Gianni »
i have a little bit experience wit Java oop programming so i did try to fix it and go on a search
Found out on Stack this.
I found that this wasn't possible for Chart.js so I moved to Highcharts.js instead, which supports this functionality.
Here below is my code for the solution:
Lokonli
Post by Lokonli »
Gianni wrote: Friday 30 August 2019 12:35 dashticz keep loading ;-)
//graph
   width: 12,
   type: 'bar',
   options : {
       scales: {
            xAxes: [{
                time: {
                    displayFormats: {
                    'minute': 'HH:mm',
                    'hour': 'H',
You have to add a comma behind the datasetColors line:
   datasetColors: ['yellow'],
Lokonli
Post by Lokonli »
Gianni wrote: Friday 30 August 2019 12:43 i have a little bit experience wit Java oop programming so i did try to fix it and go on a search
It's working with chart.js on my system with the code I provided.
renerene
Post by renerene »
Solved. The problem was in
            range: '24 hours',
            filter: '8 hours',
After changing the first line to range: 'day' the could not load graph error was gone.
Lokonli
Post by Lokonli »
renerene wrote: Friday 30 August 2019 21:57
            range: '24 hours',
            filter: '8 hours',
Good, thanks. Probably I've to add some checks on valid values.
renerene
Post by renerene »
/*	P1 power gas*/
blocks['graph_428'] = {
    type: 'line',
    datasetColors: ['white'],
    width:6
Hmm, 'vandaag' (today) looks more like 4 days. Also, there is just one data point per hour, but that is the same in domoticz. Maybe it only sends (or stores?) one value per hour. In the domoticz log an updated is annonced every 10 seconds:
2019-08-30 22:17:39.314 (stroommeter-USB1) P1 Smart Meter (Stroom)
2019-08-30 22:17:39.315 (stroommeter-USB1) Usage (Usage L1)
2019-08-30 22:17:39.315 (stroommeter-USB1) Usage (Delivery L1)
2019-08-30 22:17:39.326 (stroommeter-USB1) P1 Smart Meter (Gas)
Lokonli
Post by Lokonli »
If you select 'vandaag' you should receive the same amount of data as in the Domoticz graph.
What is your Domoticz setting for 'Log geschiedenis' -> 'Korte log sensoren'?
Probably it's 4 days.
A gasmeter can't measure the flow. It only shows the used amount. Domoticz stores the used amount per hour.
Gianni
Post by Gianni »
Damn i hate this :-)
does remind me at my college and need to debug 10 time's to find out i forget of ;
thx works now
renerene
Post by renerene »
Hmm, i'm a bit puzzled here. Since a few days, dashticz crashes after ca. 1/2 hour. Don't know the exact time. It happens both on Wallpanel and Fullykiosk. After a while there is the startup screen on my tablet. Thought the cause was in the graphs, but after not displaying them (modify columns declaration), the problem remains. Is there something else modified that could cause a crash?
I will do a 'git checkout beta' and keep you updated.
Lokonli
Post by Lokonli »
renerene wrote: Wednesday 04 September 2019 7:39 Hmm, i'm a bit puzzled here. Since a few days, dashticz crashes after ca. 1/2 hour. Don't know the exact time. It happens both on Wallpanel and Fullykiosk. After a while there is the startup screen on my tablet. Thought the cause was in the graphs, but after not displaying them (modify columns declaration), the problem remains. Is there something else modified that could cause a crash?
You had the crash with the chartjs branch? or with the beta branch?
renerene
Post by renerene »
I was on Chartjs branch. But the problem continues back on the beta branch. Probably another issue something with the tablet.
Lokonli
Post by Lokonli »
madradrakie wrote: Wednesday 11 September 2019 21:36 My water usage graph in dashticz does not show liters but m3. In domoticz the values are reported in liters (x1000). Is there a possibility to adjust the graph so it shows liters instead of m3?
With the new graph module, a first version is available via the chartjs branch, you can create a custom graph.
It's still a bit experimental, but I expect the following will work:
First find the value name. You can do that as follows (assuming the device id is 6) :
    graph: 'bar',
    legend: true
In the legend you see the name of value name. Probably it's 'v'
Then you can create a custom graph:
    graph: 'bar',
    legend: true,
    custom : {
        "last day": {
            range: 'day',
            filter: '24 hours',
            data: {
                liter: 'd.v*1000'            }
madradrakie
Post by madradrakie »
it works! Thank you so much!
