SMA Sunny Boy 1.5
rklomp
Re: SMA Sunny Boy 1.5
Do you have pip installed?
Can you try running "sudo pip3 install requests"
- René
- René
svdhaar
No pip installed. Will do it directly and let you if it helps.rklomp wrote: Friday 10 April 2020 9:04 Do you have pip installed?
- René
Pip is installed succefully:
https://imgshare.io/image/4rUKl
I have added the SMA hardware again, still the same error.
Where / how to use the command sudo pip3 install requests?
"command not found"
rklomp
What version of Python are you running? It looks like you have installed pip for python2.7. You should have pip for python3 aka pip3.
Try piping the curl command to python3 instead.
svdhaar
I'm running Python 3.5.1-0108
When i use the general command, PIP 2 seems te get installed (pip20.0.2)
https://imgshare.io/image/pip.4rJYw
Could you please help me with the correct syntaxt to download and /or install pip3?
rklomp
Try running:
python3 get-pip.py
python3 get-pip.py
svdhaar
Seems succesfully installed, but stil the same error in domoticz log and stil not possible to run the command sudo pip3
error from domoticz and install pip3 log
https://imgshare.io/image/pip.4rDzn
rklomp
The issue is clearly stated in the warning.
add /volume1/@appstore/py3k/usr/local/bin to your PATH
or just run /volume1/@appstore/py3k/usr/local/bin/pip3
svdhaar
Hi Rene,
As mentioned before, i'm a noob concerning SSH / Linux / developing..
sorry for my questions.
Could you please explain a bit more about your last comment?
where should i add the path you mentioned? in the plugin.py script?
rklomp
https://opensource.com/article/17/6/set-path-linux
or just run
or just run
/volume1/@appstore/py3k/usr/local/bin/pip3 install requests-
svdhaar
jeeeej, hardware and devices are visable.
one question about this error.
In the hardware config i specified the ipadres. It is an internal adres, so no https is configured.
It seems that port 443 is automatically added?
2020-04-10 12:25:05.084 (SMA omvormer) Error accessing SMA inverter on 192.168.0.200; HTTPSConnectionPool(host='192.168.0.200', port=443): Max retries exceeded with url: /dyn/login.json (Caused by NewConnectionError('<urllib3.connection.VerifiedHTTPSConnection object at 0x4850ac50>: Failed to establish a new connection: [Errno 111]
rklomp
What software version a you running?
Mine is using 3.10.16.R and serving https by default.
If you access 192.168.0.200 in your browser, are you only able to access it on port 80? not 443?
EDIT:
I made the protocol configurable now.
Go to the plugin directory and do a git pull
After that set the protocol in the domoticz GUI.
EDIT:
svdhaar
My converter is a SB1.5-1VL-40 293, with firmware version 3.10.5.R
via https the converter is not available. Via http://192.** it is available
super! thats quick.
What is de correct syntax for a git pull?
Nevermind
Working like a charm!! thx for your support
super! thats quick.
Nevermind
rklomp
Good to hear! If you come across any other issues please let me know
svdhaar
Hi, one question. The script works really nice! But now and then an error occurs:rklomp wrote: Saturday 11 April 2020 0:11 Good to hear! If you come across any other issues please let me know![]()
This seems to started after i installed https://github.com/Xorfor/Domoticz-Speedtest-Plugin
There's no issue with updating the sensors, but it's always better when there are no errors at all.
The query intervall is 10min on the SMA hardware, and i've setup the speedtest interval at 90min.
2020-04-21 07:32:13.949 Error: SMA omvormer hardware (5) thread seems to have ended unexpectedly
2020-04-21 07:32:28.896 Error: SMA omvormer hardware (5) thread seems to have ended unexpectedly
2020-04-21 07:32:29.047 Error: Internet speedtest hardware (9) thread seems to have ended unexpectedly
2020-04-21 07:32:43.543 Error: SMA omvormer hardware (5) thread seems to have ended unexpectedly
2020-04-21 07:32:43.573 Error: Internet speedtest hardware (9) thread seems to have ended unexpectedly
rklomp
I have seen that issue at my setup before as well, but have not been able to figure out the exact issue yet
Joske
Hello, first of all...thanks for sharing this all!!
A little question:
I dit everything like told and succesfully loaded the python script. In the pull down menu the SMA Sunnyboy is visible.
The only question i have:
I can only fill in user name / password.
But when i acces my Sunnyboy directly via my network (URL with IP) is also have to choose for 'installer/user'.
How do i have to login?
EDIT: I added 2 variantes:
1. http://192.168.1.XXX/?login=Gebruiker
and then bij the fiels 'password' i filled in my password.
2. http://192.168.1.XXX/?login=Gebruiker&password=XXX
On a direct URl (chrome) it works, but i can't see the device within Domoticz
A little question:
rklomp
It uses the User account to login to the device.
At IP Address fill in the IP of the device, not the URL.
At User group password the password of the "User" account.
Joske
Thanks, sorry...i wasn't quite clear
I also tried:
192.168.1.X AND the password (the one i have to give AFTER i choose between INSTALLER or USER)
At hardware i filled in:
Type: SMA Sunny Boy 1.5 Solar Inverter
Timeout: Niet actief
SMA Sunny Boy 1.5 Solar Inverter Plugin
IP Adres:
192.168.1.X
User group password:
Debug:
True
Nothing works
I also tried:
IP Adres:
192.168.1.X
Debug:
True
Nothing works
Joske
What i did now:
Went to (your) URL:https://github.com/rklomp/Domoticz-SMA- ... /plugin.py
And made an new plugin.py (via 'touch plugin.py) and via NANO is copied and pasted the sourcecode of your file
Still doesn't work
Still doesn't work
rklomp
Yes best is to use my version.
Can you supply the log output?
