Page 2 of 2
Re: CVS file (on pi) to virtual sensors
Posted: Wednesday 13 May 2020 21:01
by sanderj1985
Waaren,
Thank you for al the info.
I can decode my vbus file with manual codes. But automatic doenst work yet.
Which codes have you added in crontab?
0/1 * * * * wget -O /home/pi/resol-vbus.rs/vbus/current_packets.vbus
http://192.168.2.19/current/current_packets.vbus
0/1 * * * * /home/pi/resol-vbus.rs/examples/formatter/target/release/formatter csv /home/pi/resol-vbus.rs/vbus/current_packets.vbus
the second code doesnt work, only when you are in the formatter folder. Do you have an solution?
The next step. How have you uploaded your .lua script in domoticz. I have added it to the dzvents folder but nnothing happens.
Thanks Sander
waaren wrote: Monday 17 June 2019 17:41
Almost forgot to post the final working version here.
get values from csv file and store in virtual sensors
(dzVents >= 2.4.19)
Based on <TAB> separated data file: HR Solar BASIC controller [Regler] HR Solar BASIC controller [WMZ 1]
[01] Date / Time
[02] Systemdatum
[03] Temperatur Sensor 1
[04] Temperatur Sensor 2
[05] Temperatur Sensor 3
[06] Temperatur Sensor 4
[07] TAGE
[08] Volumenstrom Sensor V40
[09] Volumenstrom Sensor VFS
[10] Temperatur Sensor VFS
[11] Drehzahl Relais 1
[12] Drehzahl Relais 2
[13] Regler Ausgang 1
[14] Wmz1_Wert_Wh
[15] SW-Version
[16] Betriebsstunden Relais1
[17] Betriebsstunden Relais2
[18] Urlaubsfunktion
[19] Blockierschutz 1
[20] Initalisieren
[21] Befüllung
[22] Stabilisieren
[23] Pumpenverzögerung
[24] Überwärmeabfuhr
[25] Nachlauf
[26] Speicherkühlung
[27] Frostschutz
[28] Kollektorkühlung
[29] Einheit Temperatur
[30] Speichermaximaltemperatur
[31] Neustarts
[32] Fehlermaske
[33] Wmz1_Wert_Wh
[34] Wmz1_Leistung_W
[35] Wmz1_WertHeute_Wh
[36] Wmz1_WertWoche_Wh
on =
timer = { 'every minute' }, -- change to the interval suited for your situation
logging =
level = domoticz.LOG_DEBUG, -- set to LOG_ERROR when script is working as expected
marker = 'read CSV data'
execute = function( dz )
local maxAge = 300 -- max Age of data file in seconds
local round = dz.utils.round -- shorthand
local dataFile = '/home/pi/resol-vbus.rs/examples/formatter/Output.csv' -- location/csfFile
local temperatureSensor1 = dz.devices('temperature Solar collector') -- create as virtual temperature sensor
local temperatureSensor2 = dz.devices('temperature Boilervat') -- create as virtual temperature sensor
local temperatureSensorVFS = dz.devices('temperature outlet') -- create as virtual temperature sensor
local drehzahlRelais1 = dz.devices('pump-speed Solar collector') -- create as virtual percentage sensor
local Wmz1_Wert = dz.devices('total power Solar collector') -- create as Usage Electric
local VolumenstromSensorVFS = dz.devices('Boiler outlet') -- create as waterflow (l/m)
local Wmz1_WertHeute = dz.devices('daily total Solar collector') -- create as Usage Electric
local function readCSVLine(OSfile)
local f = assert(io.popen('tail -1 '.. OSfile)) -- OS command to read last line of file
local line = assert(f:read('*a')) -- read the complete result into string variable
f:close() -- close the file
dz.log('line: ' .. line,dz.LOG_DEBUG)
return dz.utils.stringSplit(line:gsub(',','.'),'%\t') -- replace decimal commas with . ; use TAB as delimiter and split line into columns (table)
local function isRecent(csvData)
if csvData == nil or #csvData < 15 then
dz.log("Problem with reading and converting to table of the data" ,dz.LOG_ERROR)
return
local Time = require('Time')
local csvTime = Time(csvData[1]:gsub('T',' ')) -- convert timestamp in csv file to time object
local now = dz.time -- Get current time into time object
if now.compare(csvTime).secs > maxAge then
dz.log('Timestamp in ' .. dataFile .. ' is ' .. now.compare(csvTime).secs .. ' seconds old. Please check!',dz.LOG_ERROR)
return
return true
local function updateTemperatureCheckFirst(device, temperature)
if round(device.temperature,1) ~= round(temperature,1) then
dz.log('---------' .. temperature ..' ==>> ' .. device.temperature ,dz.LOG_DEBUG)
device.updateTemperature(round(temperature,1))
local function updateSensorsCheckFirst(csvData)
-- Sensors will only be updated when old value ~= new value
updateTemperatureCheckFirst(temperatureSensor1,csvData[3])
updateTemperatureCheckFirst(temperatureSensor2,csvData[4])
updateTemperatureCheckFirst(temperatureSensorVFS,csvData[10])
if round(drehzahlRelais1.percentage,1) ~= round(csvData[11],1) then drehzahlRelais1.updatePercentage(round(csvData[11],1)) end
if round(Wmz1_Wert.WhActual,1) ~= round(csvData[14],1) then Wmz1_Wert.updateEnergy(round(csvData[14],1)) end
if round(VolumenstromSensorVFS.flow,1) ~= round(csvData[9],1) then VolumenstromSensorVFS.updateWaterflow(round(csvData[9],1)) end
if round(Wmz1_WertHeute.WhActual,1) ~= round(csvData[35],1) then WertHeute.updateEnergy(round(csvData[35],1)) end
-- main
csvData = readCSVLine(dataFile)
if isRecent(csvData) then
dz.log("Something was not OK. Skipping device updates",dz.LOG_ERROR)
Posted: Wednesday 13 May 2020 21:14
by waaren
sanderj1985 wrote: Wednesday 13 May 2020 21:01
@sanderj1985
I did not do anything on the crontab side. I just process the csv file that was presented by the OP using a dzVents script.
You can find how to get the dzVents script active in domoticz in the wiki
Quickstart chapter
When not yet familiar with dzVents please start with reading
Get started Before implementing (~ 5 minutes). Special attention please for "In Domoticz go to Setup > Settings > Other and in the section EventSystem make sure the checkbox 'dzVents enabled' is checked. Also make sure that in the Security section in the settings you allow 127.0.0.1 to not need a password. dzVents uses that port to send certain commands to Domoticz. Finally make sure you have set your current location in Setup > Settings > System > Location, otherwise there is no way to determine nighttime/daytime state."
Posted: Friday 15 May 2020 14:21
by sanderj1985
Waaren,
Thank you for the information.
I have dzVents working. The only problem is one command.
domoticz.utils.osExecute('/home/pi/resol-vbus.rs/examples/formatter/formatter -- simple-json /tmp/current_packets.vbus')
When I put the command ('') in Putty it works and the vbus file is decoded.
But dzVents does not execute the command. I think it is a autorisation question.
Any ideas?
Posted: Friday 15 May 2020 16:29
by waaren
sanderj1985 wrote: Friday 15 May 2020 14:21
Any ideas?
A couple of posts back you stated that this only works when in the formatter directory. Maybe if you change this to
os.execute('cd <formatter directory> ;/home/pi/resol-vbus.rs/examples/formatter/formatter -- simple-json /tmp/current_packets.vbus')
Posted: Friday 15 May 2020 20:04
by sanderj1985
Waaren,
Thx the script is now working perfect.
Have a nice weekend!
Posted: Sunday 13 November 2022 20:25
by MarkusHD
Hey my friends,
as I am new in posting because all I looked for I figured out I am now stuck somewhere related to this topic and hope you can help.
I have a python script which provides by regulare speedtests a csv (speedtest.csv) with 6 values like the following:
Date,Time,Ping (ms),Jitter (ms),Download (Mbps),Upload (Mbps)
11/09/22,07:40,9.93,3.37,925.84,48.61
As the script runs every 15 minutes there are several lines and I am interested in the last one to be transfered into domoticz. Here I only care about Download, Upload and Ping.
Due to this I tried to transfer the here provided dzVents to my needs but got stuck with the following:
(dzVents >= 2.4.19)
[01] Date
[02] Time
[03] Ping (ms)
[04] Jitter (ms)
[05] Download (Mbps)
[06] Upload (Mbps)
on =
logging =
local csvDataFile = '/home/pi/speedtest/speedtest.csv' -- location of csv file on raspberry
local sep = "," -- define seperated as comma
local Dld = dz.devices('Download') -- created as virtual Custom sensor
local Uld = dz.devices('Upload') -- created as virtual Custom sensor
local Ping = dz.devices('Ping') -- created as virtual Custom sensor
local csvDataTable = line:split(sep)
local function updateData(csvData)
Dld.updateCustomSensor(csvData[5]) -- Update custom sensor with value from 5th column
Uld.updateCustomSensor(csvData[6]) -- Update custom sensor with value from 6th column
Ping.updateCustomSensor(csvData[3]) -- Update custom sensor with value from 3rd column
Currently I dont get any errors but unfortunately nothing got transfered into domoticz as the dummy devices do not get any data.
My goal is to store every 15 minutes the last line in speedtest.csv to the devices so I get an overview of my speed data into domoticz.
I think I am not that far away but do something wrong by transformation of values and am missing timestamp as well but am not sure if domoticz registers the change with timestamp anyway?
Hope anyone can help me solve this!
Thanks and best
Markus
Posted: Monday 14 November 2022 10:24
Use dzvents .stringSplit function:
stringSplit(string [,separator ] [,convertNumber ][,convertNil ]3.0.17):Function. Helper function to split a line in separate words. Default separator is space. Return is a table with separated words. Default convertNumber is false when set to true it will convert strings to number where possible. Word is ignored when nil, unless convertNil is set; in that case word will be set to the convertNil value.
eg
local csvDataTable = domoticz.utils.stringSplit(line , ',')
Posted: Monday 14 November 2022 11:57
by MarkusHD
If I got you right, the mentioned statement is missing or do I have to exchange something from my code? Maybe you can add the line where you would recommend to integrate it into my code?
Posted: Monday 14 November 2022 13:08
I think there is a lot missing. You for example miss the main program to start all your sub functions. That is why it is not doing anything only declaring local functions.
You should for example add the main section to the end of your script, see also the previous scripts in this thread:
-- main
updateData(csvData)
You should change line
with
This changes will probably give some errors but when adding some logging you will get there fixing those.
Posted: Monday 14 November 2022 13:26
by MarkusHD
Damn, I removed the line by mistake because previously there was a time and date comparison which I didnt need - thanks for pointing this out, I will come back as soon as I checked your lines.
Thanks up to now!
Posted: Monday 14 November 2022 22:30
by MarkusHD
I now end up at least with the prepared error messages, but do not understand why - from my point of view it should work now, where am I wrong?
on =
logging =
level = domoticz.LOG_ERROR, -- set to LOG_ERROR when script is working as expected
local Dld = dz.devices(64) -- created as virtual Custom sensor
local Uld = dz.devices(65) -- created as virtual Custom sensor
local Ping = dz.devices(66) -- created as virtual Custom sensor
local csvDataTable = dz.utils.stringSplit(line ,',') -- Separate by line and comma
dz.log('line: ' .. line,dz.LOG_ERROR)
if csvData == nil then
return
-- main
csvData = readCSVLine(csvDataFile)
updateData(csvData)
The error I get in domoticz log is - I can see the data read from the file correctly, but it is not going to be separated and converted to table as I think?!
2022-11-14 22:15:00.201 Error: dzVents: Error: (3.1.8) read CSV data: line: 11/14/22,22:00,178.88,249.85,98.35,0.28
2022-11-14 22:15:00.201 Error: dzVents: Error: (3.1.8) read CSV data: Problem with reading and converting to table of the data
2022-11-14 22:15:00.201 Error: dzVents: Error: (3.1.8) read CSV data: Something was not OK. Skipping device updates
Thanks for any advice!
Posted: Tuesday 15 November 2022 0:17
I suppose you better start with setting the right indentation so you know what lines belongs to what function.
I think you miss or have to much 'end' statements.
Posted: Tuesday 15 November 2022 23:10
by MarkusHD
Actually I dont make it through. I tried to transfer the needed "ends" from code above but always end up in "unexpected symbol near '}' " in last line which means for me I have some end missing.
I resorted the code a bit, can anyone help?
on =
logging =
-- main
updateData(csvData)
Hope we can solve this! Thanks!
Posted: Wednesday 16 November 2022 16:02
I think you were missing some ends
Please try this script (did not test it!)
on =
logging =
-- main
updateData(csvData)
Posted: Wednesday 16 November 2022 22:47
by MarkusHD
I finally did it! Thanks to your help - in fact I was nearer than I thought.
Today I went through line by line as you mentioned to check the "ends" but this wasnt actually the problem or at least not the only thing missing. Especially I missed some returns and return true statements which where necessary for the last statement to get executed.
Here is the finally working code:
on =
logging =
return dz.utils.stringSplit(line ,',') -- Separate by line and comma
return
return true
-- main
updateData(csvData)
Result looks good as I now can track my speedtest results in domoticz, see attachement. And as we also can see this will help to proof for my provider that this is not a 1mbit connection
Thanks for your suggestions and help!
