Page 2 of 2
Re: style box height
Posted: Friday 07 June 2019 22:16
by pvklink
cant find.. is this helpful...
see atachment
Posted: Friday 07 June 2019 22:59
by Lokonli
pvklink wrote: Friday 07 June 2019 22:16
see atachment
Yes, that helps.
It seems to be a bug in Dashticz, which happens if you have an url defined in your calendar block.
Solution 1:
remove the url parameter
Solution 2:
In file js/calendar.js add two slashes in front of line 47, like this:
// calobject.attr('data-id', '');
Can you first test solution 1, then add the url parameter and test solution 2?
If solution 2 is working then I'll make a fix for the next beta version of Dashticz.
Posted: Friday 07 June 2019 23:22
by pvklink
do you mean the xxx part or the yyy part
calendars.fam = { key:'dvfam', maxitems: 6, title: 'Familie kalender', url: 'https://xxx',icalurl: 'yyyy/basic.ics' }
Posted: Friday 07 June 2019 23:23
by pvklink
ok, when i remove xxx part the sizechanges work!
Posted: Friday 07 June 2019 23:26
by pvklink
ok, the // also work!
thanks lokonli!
Posted: Saturday 08 June 2019 12:24
by pvklink
@lokonli, all looks GREAT !
Thank you VERY much! EVERYTHING works...
Would like to show te result(screendump) but the file is to big to upload....so you can see what the result is off your effort and that from @waaren
Posted: Saturday 08 June 2019 13:31
by Lokonli
pvklink wrote: Saturday 08 June 2019 12:24
Thanks for the feedback. Enjoy
