set color based on value
Vondee
Re: set color based on value
Post by Vondee »
I tried this:
function getStatus_28(block){
var idx = block.idx;
var device = block.device;
    if (device['Data'] == 'Off') {
        Dashticz.setBlock('462', {
            addClass: 'warningyellow'
    else {
            addClass: ''
But is seem not to work?
The color of block 462 does not change
Lokonli
Post by Lokonli »
Your code looks ok.
How do you handle .warningyellow in custom.css?
Vondee
Post by Vondee »
.warningyellow {
   color: Yellow;
Lokonli
Post by Lokonli »
Device 28 is a switch?
How did you define the block for device 28?
Device 28 must have been added to a column as well.
How did you define block "462" in CONFIG.js?
How did you add it to a column?
Vondee
Post by Vondee »
Yes, device 28 is a switch.
In CONFIG.js:
blocks[28] = {}
blocks[28]['title'] = 'Laders'
blocks[28]['icon'] = 'fas fa-battery-half'
blocks[28]['hide_data'] = 1
blocks[462] = {}
blocks[462]['title'] = "Batterij"
blocks[462]['switch'] = 1
blocks[462]['icon'] = 'fa fa-car'
In the column:
columns[1]['blocks'] = ['blocktitle_1','graph_337','64_1','332_1','58_1',333,'141_2','141_5',462,498,458,500,68,39,362,36,28]
Lokonli
Post by Lokonli »
That all looks fine.
What's your Dashticz version?
Any other class in custom.css that sets a color value?
Vondee
Post by Vondee »
I still had Dashtics version 2. Upgraded to version 3 and it works. Thanks
Lokonli
Post by Lokonli »
Good to hear it's working. Next time the version number will be my first question :)
Vondee
Post by Vondee »
I tried to use the 'SetBlock' for a dial to change the Title, but that does not work?
Lokonli
Post by Lokonli »
Vondee wrote: Monday 14 December 2020 13:38 I tried to use the 'SetBlock' for a dial to change the Title, but that does not work?
setBlock indeed doesn't work for dial blocks.
I'll try to add that in a future update.
Vondee
Post by Vondee »
Nice! Looking forward for the update
