[Solved]Display a different Variable value at the Dashboard [not with Blockly] but with dzVents
Re: Display a different Variable value at the Dashboard with Blockly
besix wrote: Tuesday 30 April 2019 17:19 Thank you very much waaren for help, but I get an error in line 18
I just had it when I tried to modify it myself. Still important, I do not have to have the max only current
link to foto
https://prntscr.com/nir6sx
Please post logs and scripsts here between code display tags. Use the </> button
The setpointVariable should be defined as type float because that is the type of the setPoint attribute that will be written to it.
I don't understand what you mean with "Still important, I do not have to have the max only current" Please elaborate.
besix
Post by besix »
Ok, I will use </>
In the script, I need the current state of Set Point in the Device text
Ok, I set the variable float script is ok!
Gives max Set Piont
I just want to change it to work for each change of the Device Set Piont
besix wrote: Tuesday 30 April 2019 17:31 I just want to change it to work for each change of the setpoint
If I understand your requirement correctly this is all you need.
                     devices = { 'SetPoint' }, -- change to name of your setpoint device
    execute = function(dz, item)
        setpointTextDevice = dz.devices('Setpoint text sensor')  -- change to name of your text device
        setpointTextDevice.updateText('Current setpoint : ' .. dz.utils.round(item.setPoint,1)  .. ' set at ' .. dz.time.rawTime)
besix
Post by besix »
It was so easy.:)
Thank you. Works
