Page 2 of 6
Re: GoodWe Solar: get data from the new semsportal (lua script)
Posted: Saturday 27 April 2019 17:47
by CrazyFrog
sandeman684 wrote: Saturday 27 April 2019 14:41
In my last post I mentioned I needed other key numbers, but that was partially incorrect because the domoticz log only showed me the last roughly 100 keys. I had to output them to a file to see them all.
In this way I found that for my case, each of the keys is one higher than in CrazyFrogs script. So now I have:
output_power = getValue(splitString[183])
last_refresh_time = getValue(splitString[189])
eDay = getValue(splitString[200])
This works well but indicates that the keys are not fully fixed.
Maybe we should not look for key number but for key value?
Thanks for the info,
i shall update het script and post it here.
Posted: Saturday 27 April 2019 20:24
by CrazyFrog
CrazyFrog wrote: Saturday 27 April 2019 17:47
I wrote the following solution:
replace the function getValue with the following code:
function printAllValues(s)
for key, value in pairs(splitString) do
print(string.format("Key = [%s] Value = [%s]",split(value, ":")[1],split(value, ":")[2]))
function getValue(s, name)
key = split(value, ":")[1]
value = split(value, ":")[2]
if (name == key) then
return value
return ""
Then you can use this with the following code:
-- Show al variable
--printAllValues(s)
output_power = getValue(splitString, "output_power")
last_refresh_time = getValue(splitString, "last_refresh_time")
eDay = getValue(splitString, "eDay")
daily_generation = getValue(splitString, "daily_generation")
work_mode = getValue(splitString, "work_mode")
warning = getValue(splitString, "warning")
print("last_refresh_time :" .. last_refresh_time)
print("output_power :" .. output_power)
print("eDay :" .. eDay)
print("daily_generation :" .. daily_generation )
print("work_mode :" .. work_mode)
print("warning :" .. warning)
If needed i can place here the full code, let me know
Posted: Sunday 28 April 2019 10:00
by sandeman684
CrazyFrog wrote: Saturday 27 April 2019 20:24
Works like a charm! Thanks.
Posted: Monday 29 April 2019 19:21
by klaaspiet
Hy
it is working super.
but i would like to have some more info from my goodwe portal.
like the temperature, status,
how do i get the output of the key in to a file so i could see all of the key's en not only the fist 100
already thanks for the great support of this code is great.
greetz klaas
Posted: Monday 29 April 2019 19:56
by sandeman684
klaaspiet wrote: Monday 29 April 2019 19:21
See here for a lua description of how to write to a file:
https://www.tutorialspoint.com/lua/lua_file_io.htm
You can then add this code to for example the printAllValues function and replace the print command by io.write. You should then also add a line end "\n" otherwise everything will be printed on one line.
Posted: Tuesday 30 April 2019 9:14
by dospider
I still have a problem retrieving the data.
Does anybody have an idea how to solved this error?
2019-04-30 09:08:43.249 Error: EventSystem: in Goodwe portal: [string "
..."]:88: attempt to perform arithmetic on global 'endPos' (a nil value)
Posted: Tuesday 30 April 2019 11:19
by Tiger362
dospider wrote: Tuesday 30 April 2019 9:14
I get the same error message... also tried all the sollutions offered, but no luck...
Posted: Tuesday 30 April 2019 15:42
by sandeman684
Tiger362 wrote: Tuesday 30 April 2019 11:19
If you want to see your data you can add this function:
function printToFile(s)
file = io.open("myoutput.txt", "w")
io.output(file)
io.write(s)
io.close(file)
And then call printToFile(s) before the lines giving the issues. In this way at least know the contents of s.
The location of the file myoutput.txt may have to be adapted to suit your system. In my case (a Synology NAS) it writes the file in the root of the file system (not the best place I would say).
Posted: Wednesday 01 May 2019 11:02
by dospider
When i print variable s=assert i get.
2019-05-01 10:58:47.457 Status: LUA: waarde s=assert<html><head><title>Object moved</title></head><body>
2019-05-01 10:58:47.457 <h2>Object moved to <a href="/home/login">here</a>.</h2>
I think s=assert is going to-- extract the JSON-data from the response
Is the response ok from s=assert
Posted: Wednesday 01 May 2019 15:09
by mennohaeck
With testscript.lua I get a lot of data. I replaced the scipt once again, after that I got error line 51 a few times. Then I received Domoticz update ( more then one, don't know why). After that nothing anymore, no errors as well.
Posted: Wednesday 01 May 2019 15:38
by mennohaeck
Hielkep wrote: Friday 26 April 2019 16:07
mennohaeck wrote: Friday 26 April 2019 14:36
No matter what I do or how I name the script, there is no output. I checked all the rights and syntax. Funny thing is: no errors as wel. Is there anyone with a bright idea?
is the name of dummy switch and the declaration in line 65 of the name of the switch completely the same?
YEP
Posted: Wednesday 01 May 2019 20:36
by CrazyFrog
mennohaeck wrote: Wednesday 01 May 2019 15:38
YEP
Can you execute the follow script from the command line (execute with lua <filename>)
and send me the results, hopefully we can see your problem
local UserName = "YOUR USERNAME"
local Password = "YOUR PASSWORD"
local token = "YOUR TOKEN"
-- To get you token use the curl command below, replace [LOGINNAME] and [PASSWORD] for your own id's
-- "curl -d 'account=[LOGINNAME]&pwd=[PASSWORD]&code=' https://www.semsportal.com/Home/Login";
curl_getToken = string.format("curl -d 'account=%s&pwd=%s&code=' https://www.semsportal.com/Home/Login",UserName,Password)
--- print(curl_getToken)
command = string.format("curl --silent --output /dev/null --cookie-jar - -d 'account=%s&pwd=%s&code=' https://www.semsportal.com/Home/Login",UserName,Password)
-- print(command)
function stripchars(str, chrs)
local s = str:gsub("["..chrs:gsub("%W","%%%1").."]", '')
return s
function split(s, delimiter)
result = {};
for match in (s..delimiter):gmatch("(.-)"..delimiter) do
table.insert(result, match);
return result;
return value
return ""
print("============== get Token ======================")
local f = assert(io.popen(curl_getToken, 'r'))
s = assert(f:read('*a'))
f:close()
print(string.format("====> Response get token : %s", s))
print("============== get sessionID ======================")
local f = assert(io.popen(command, 'r'))
f:close()
print(string.format("====> Response get sessionID : %s", s))
sessionId = string.sub(s, -26)
sessionId = string.gsub(sessionId,"[\r\n]", "" )
sessionId = string.gsub(sessionId, "%s+", "")
print("============== get Data ======================")
getData = string.format("%s%s%s%s" , "curl -v --cookie 'ASP.NET_SessionId=", sessionId, "' https://www.semsportal.com/PowerStation/PowerStatusSnMin/",token )
local f = assert(io.popen(getData, 'r'))
f:close()
print(string.format("====> Response data : %s", s))
print("================================================")
Posted: Thursday 02 May 2019 16:53
by dennispracht
after a long time only one error message after the other. I finally have the right script that works and displays all values correctly.
use this script with lua and time and your own email / password and token and everything works perfectly.
And set your name from your dummy right on line 76.
--- Created by Raymond Wiertz
--- DateTime: 2019-04-21
-- Note: The GoodWe data is refreshed every 60 seconds.
-- Note: Enter your own data at [LOGINNAME] and [PASSWORD]
-- Tracking your token
-- To find out your token, you must execute the CURL command below from the command line.
--- curl -d 'account=[LOGINNAME]&pwd=[PASSWORD]&code=' https://www.semsportal.com/Home/Login;
-- Place here your token
token = "[token]"
-- The curl command below retrieves the get session ID named "ASP.NET_SessionId", the session ID is used to request the final data
command = "curl --silent --output /dev/null --cookie-jar - -d 'account=[e-mail]&pwd=[password]&code=' https://www.semsportal.com/Home/Login"
i=1
function UpdateDevice(device, data)
idx = otherdevices_idx[device]
if (idx == nil) then
print('** Unknown device'..device)
commandArray[i] = {['UpdateDevice'] = idx..'|0|'..data}
i = i+1
return s
result = {};
return result;
return value
return ""
function timedifference(s)
year = string.sub(s, 1, 3)
month = string.sub(s, 6, 7)
day = string.sub(s, 9, 10)
hour = string.sub(s, 12, 13)
t1 = os.time()
t2 = os.time{year=year, month=month, day=day, hour=hour, min=minutes,sec=seconds}
difference = os.difftime (t1, t2)
return difference
-- Sensor declaration
sensorSolarPanels = "solar panels"
difference = timedifference(otherdevices_lastupdate[sensorSolarPanels])
if (difference > 60) then
f:close()
-- extract the ASP.NET_SessionId from the curl response
-- update curl command with the session id.
f:close()
dummy, startPos = string.find(s, "var pw_info = ")
dummy, endPos = string.find(s, "}};")
s = string.sub(s, startPos, endPos-1)
-- remove excess brackets
valueString = stripchars(s, "[]{}\"")
-- and split the records
splitString = split(valueString, ",")
-- for debugging only
-- Show al variable
-- printAllValues(s)
current = tonumber(stripchars(output_power, "kwhKWH"))
dayTotal = tonumber(eDay)*1000
UpdateDevice(sensorSolarPanels, current..";"..dayTotal)
Posted: Friday 03 May 2019 8:51
by Tiger362
Also used this script and still no result..
Log entry:
Error: EventSystem: in Goodwe: [string "--- Created by Raymond Wiertz
Posted: Friday 03 May 2019 11:25
by CrazyFrog
i found out that sometimes the --- for comments cause some problem, replace the 3 minus signs "---" for 2 minus signs "--"
or remove all the comment lines
Posted: Friday 03 May 2019 20:14
by CrazyFrog
I have updated my script.
- Installation instructions added
- error handling when no data is being retrieved
- comment --- replaced by --
- repetition of code placed in functions
- all comments and improvement posted here picked up and applied
Hopefully this is clearer and there are fewer problems than my first post
Tips, improvements and comments let me know, if necessary I will update my code and on request I will place the new code.
-- DateTime: 2019-05-03
-- How to install this script:
-- Before you can use this script you must first create a virtual sensor.
-- Create dummy hardware and device
-- Go to Setup -> Hardware
-- Name: anything, e.g. "Ele_Consumption" (this name is only used internally)
-- Type: "Dummy (does nothing, use for virtual switches only)"
-- Click on 'Add'
-- Click on 'Create Virtual Sensors' from the table of hardware above
-- Name: solar panels (this name must be the same as in the variable sensorSolarPanels)
-- Sensor type: "Electric (Instant+Counter)"
-- Click 'Ok'
-- Now you are ready to install this script.
-- Go to Setup -> More Options -> events
-- Event name: anything (this name is only used internally)
-- Select LUA
-- Select Time
-- Select "Event active"
-- Copy this script to the left side
-- hit the "save" button
-- Your script is now active, to disable this script deselect "Event active" and
-- hit the "save" button again.
-- curl -d 'account=[YOUR USERNAME]&pwd=[YOUR PASSWORD]&code=' https://www.semsportal.com/Home/Login;
-- EXAMPLE
-- curl -d '[email protected]&pwd=!QAZ1qaz&code=' https://www.semsportal.com/Home/Login;
-- EXAMPLE RESPONE:
-- { "code" : 0, "msg" : "","data":{"redirect":"/PowerStation/PowerStatusSnMin/295a07ac-745d-2f84-ad8c-81537fca2d94"} }%
-- YOUR TOKEN IS:
-- 295a07ac-745d-2f84-ad8c-81537fca2d94
local sensorSolarPanels = "solar panels"
i=1
return s
result = {};
return result;
io.output(file)
io.write(s)
io.close(file)
function isempty(s)
return s == nil or s == ''
return value
return ""
function extractJSonFromResponse(responseData)
response = ""
searchResult = string.find(responseData,"var pw_info = ")
if (isempty(searchResult)== false) then
response = string.sub(s, startPos, endPos-1)
return response
function getExecuteCommand(command)
f:close()
return s
function getSessionID()
result = getExecuteCommand(command)
sessionId = string.sub(result, -26)
return sessionId
year = string.sub(s, 1, 4)
t1 = os.time()
return difference
i = i+1
-- The sensor will update every 180 seconds
if (difference > 180) then
sessionId = getSessionID()
response = getExecuteCommand(getData)
jsonResult = extractJSonFromResponse(response)
if (isempty(jsonResult) == false) then
-- remove excess brackets and split the records
valueString = stripchars(jsonResult, "[]{}\"")
-- Show al variable
-- printAllValues(splitString)
-- printToFile(splitString)
Posted: Friday 03 May 2019 20:53
by CrazyFrog
Hy
greetz klaas
you can get the following data from the goodwe portal.
in my post above i have also add the option to write the data to file.
you can use the function printToFile(s) by removing the comment signs (thanks to @sandeman684 )
Key = [ info]
Key = [time]
Key = [stationname]
Key = [address]
Key = [owner_name]
Key = [owner_phone]
Key = [owner_email]
Key = [battery_capacity]
Key = [turnon_time]
Key = [create_time]
Key = [capacity]
Key = [longitude]
Key = [latitude]
Key = [powerstation_type]
Key = [status]
Key = [is_stored]
Key = [charts_type]
Key = [has_pv]
Key = [has_statistics_charts]
Key = [only_bps]
Key = [only_bpu]
Key = [time_span]
Key = [kpi]
Key = [power]
Key = [total_power]
Key = [day_income]
Key = [total_income]
Key = [yield_rate]
Key = [currency]
Key = [images]
Key = [weather]
Key = [cond_code_n]
Key = [cond_txt_d]
Key = [cond_txt_n]
Key = [date]
Key = [time]
Key = [hum]
Key = [pcpn]
Key = [pop]
Key = [pres]
Key = [tmp_max]
Key = [tmp_min]
Key = [uv_index]
Key = [vis]
Key = [wind_deg]
Key = [wind_dir]
Key = [wind_sc]
Key = [wind_spd]
Key = [cond_code_d]
Key = [cond_code_n]
Key = [cond_txt_d]
Key = [cond_txt_n]
Key = [date]
Key = [time]
Key = [hum]
Key = [pcpn]
Key = [pop]
Key = [pres]
Key = [tmp_max]
Key = [tmp_min]
Key = [uv_index]
Key = [vis]
Key = [wind_deg]
Key = [wind_dir]
Key = [wind_sc]
Key = [wind_spd]
Key = [cond_code_d]
Key = [cond_code_n]
Key = [cond_txt_d]
Key = [cond_txt_n]
Key = [date]
Key = [time]
Key = [hum]
Key = [pcpn]
Key = [pop]
Key = [pres]
Key = [tmp_max]
Key = [tmp_min]
Key = [uv_index]
Key = [vis]
Key = [wind_deg]
Key = [wind_dir]
Key = [wind_sc]
Key = [wind_spd]
Key = [cond_code_d]
Key = [cond_code_n]
Key = [cond_txt_d]
Key = [cond_txt_n]
Key = [date]
Key = [time]
Key = [hum]
Key = [pcpn]
Key = [pop]
Key = [pres]
Key = [tmp_max]
Key = [tmp_min]
Key = [uv_index]
Key = [vis]
Key = [wind_deg]
Key = [wind_dir]
Key = [wind_sc]
Key = [wind_spd]
Key = [cond_code_d]
Key = [cond_code_n]
Key = [cond_txt_d]
Key = [cond_txt_n]
Key = [date]
Key = [time]
Key = [hum]
Key = [pcpn]
Key = [pop]
Key = [pres]
Key = [tmp_max]
Key = [tmp_min]
Key = [uv_index]
Key = [vis]
Key = [wind_deg]
Key = [wind_dir]
Key = [wind_sc]
Key = [wind_spd]
Key = [cond_code_d]
Key = [cond_code_n]
Key = [cond_txt_d]
Key = [cond_txt_n]
Key = [date]
Key = [time]
Key = [hum]
Key = [pcpn]
Key = [pop]
Key = [pres]
Key = [tmp_max]
Key = [tmp_min]
Key = [uv_index]
Key = [vis]
Key = [wind_deg]
Key = [wind_dir]
Key = [wind_sc]
Key = [wind_spd]
Key = [cond_code_d]
Key = [cond_code_n]
Key = [cond_txt_d]
Key = [cond_txt_n]
Key = [date]
Key = [time]
Key = [hum]
Key = [pcpn]
Key = [pop]
Key = [pres]
Key = [tmp_max]
Key = [tmp_min]
Key = [uv_index]
Key = [vis]
Key = [wind_deg]
Key = [wind_dir]
Key = [wind_sc]
Key = [wind_spd]
Key = [basic]
Key = [location]
Key = [cnty]
Key = [lat]
Key = [lon]
Key = [tz]
Key = [update]
Key = [utc]
Key = [status]
Key = [inverter]
Key = [is_stored]
Key = [name]
Key = [in_pac]
Key = [out_pac]
Key = [eday]
Key = [emonth]
Key = [etotal]
Key = [status]
Key = [turnon_time]
Key = [releation_id]
Key = [type]
Key = [capacity]
Key = [d]
Key = [capacity]
Key = [model]
Key = [output_power]
Key = [output_current]
Key = [grid_voltage]
Key = [backup_output]
Key = [soc]
Key = [soh]
Key = [last_refresh_time]
Key = [work_mode]
Key = [dc_input1]
Key = [dc_input2]
Key = [battery]
Key = [bms_status]
Key = [warning]
Key = [charge_current_limit]
Key = [discharge_current_limit]
Key = [firmware_version]
Key = [creationDate]
Key = [eDay]
Key = [eTotal]
Key = [pac]
Key = [hTotal]
Key = [vpv1]
Key = [vpv2]
Key = [vpv3]
Key = [vpv4]
Key = [ipv1]
Key = [ipv2]
Key = [ipv3]
Key = [ipv4]
Key = [vac1]
Key = [vac2]
Key = [vac3]
Key = [iac1]
Key = [iac2]
Key = [iac3]
Key = [fac1]
Key = [fac2]
Key = [fac3]
Key = [istr1]
Key = [istr2]
Key = [istr3]
Key = [istr4]
Key = [istr5]
Key = [istr6]
Key = [istr7]
Key = [istr8]
Key = [istr9]
Key = [istr10]
Key = [istr11]
Key = [istr12]
Key = [istr13]
Key = [istr14]
Key = [istr15]
Key = [istr16]
Key = [it_change_flag]
Key = [tempperature]
Key = [check_code]
Key = [next]
Key = [prev]
Key = [next_device]
Key = [isStored]
Key = [prev_device]
Key = [isStored]
Key = [invert_full]
Key = [powerstation_id]
Key = [name]
Key = [model_type]
Key = [change_type]
Key = [capacity]
Key = [eday]
Key = [iday]
Key = [etotal]
Key = [itotal]
Key = [hour_total]
Key = [status]
Key = [turnon_time]
Key = [pac]
Key = [vpv1]
Key = [vpv2]
Key = [vpv3]
Key = [vpv4]
Key = [ipv1]
Key = [ipv2]
Key = [ipv3]
Key = [ipv4]
Key = [vac1]
Key = [vac2]
Key = [vac3]
Key = [iac1]
Key = [iac2]
Key = [iac3]
Key = [fac1]
Key = [fac2]
Key = [fac3]
Key = [istr1]
Key = [istr2]
Key = [istr3]
Key = [istr4]
Key = [istr5]
Key = [istr6]
Key = [istr7]
Key = [istr8]
Key = [istr9]
Key = [istr10]
Key = [istr11]
Key = [istr12]
Key = [istr13]
Key = [istr14]
Key = [istr15]
Key = [istr16]
Key = [last_time]
Key = [vbattery1]
Key = [ibattery1]
Key = [pmeter]
Key = [soc]
Key = [soh]
Key = [bms_discharge_i_max]
Key = [bms_charge_i_max]
Key = [bms_warning]
Key = [bms_alarm]
Key = [battary_work_mode]
Key = [workmode]
Key = [vload]
Key = [iload]
Key = [firmwareversion]
Key = [pbackup]
Key = [seller]
Key = [buy]
Key = [yesterdaybuytotal]
Key = [yesterdaysellertotal]
Key = [yesterdayetotal]
Key = [yesterdayetotalload]
Key = [thismonthetotle]
Key = [lastmonthetotle]
Key = [ram]
Key = [outputpower]
Key = [fault_messge]
Key = [isbuettey]
Key = [isbuetteybps]
Key = [isbuetteybpu]
Key = [isESUOREMU]
Key = [backUpPload_S]
Key = [backUpVload_S]
Key = [backUpIload_S]
Key = [backUpPload_T]
Key = [backUpVload_T]
Key = [backUpIload_T]
Key = [eTotalBuy]
Key = [eDayBuy]
Key = [eBatteryCharge]
Key = [eChargeDay]
Key = [eBatteryDischarge]
Key = [eDischargeDay]
Key = [battStrings]
Key = [meterConnectStatus]
Key = [mtActivepowerR]
Key = [mtActivepowerS]
Key = [mtActivepowerT]
Key = [time]
Key = [battery]
Key = [warning_bms]
Key = [soh]
Key = [discharge_current_limit_bms]
Key = [charge_current_limit_bms]
Key = [soc]
Key = [pv_input_2]
Key = [pv_input_1]
Key = [back_up_output]
Key = [output_voltage]
Key = [backup_voltage]
Key = [total_generation]
Key = [daily_generation]
Key = [battery_charging]
Key = [bms_status]
Key = [pw_id]
Key = [fault_message]
Key = [battery_power]
Key = [point_index]
Key = [points]
Key = [target_name]
Key = [display]
Key = [unit]
Key = [target_key]
Key = [text_cn]
Key = [target_sn_six]
Key = [target_sn_seven]
Key = [target_type]
Key = [storage_name]
Key = [target_index]
Key = [target_name]
Key = [display]
Key = [unit]
Key = [target_key]
Key = [text_cn]
Key = [target_type]
Key = [target_name]
Key = [display]
Key = [unit]
Key = [target_key]
Key = [text_cn]
Key = [target_type]
Key = [target_name]
Key = [display]
Key = [unit]
Key = [target_key]
Key = [text_cn]
Key = [target_type]
Key = [target_name]
Key = [display]
Key = [unit]
Key = [target_key]
Key = [text_cn]
Key = [target_type]
Key = [target_name]
Key = [display]
Key = [unit]
Key = [target_key]
Key = [text_cn]
Key = [target_type]
Key = [target_name]
Key = [display]
Key = [unit]
Key = [target_key]
Key = [text_cn]
Key = [target_type]
Key = [target_name]
Key = [display]
Key = [unit]
Key = [target_key]
Key = [text_cn]
Key = [target_type]
Key = [target_name]
Key = [display]
Key = [unit]
Key = [target_key]
Key = [text_cn]
Key = [target_type]
Key = [target_name]
Key = [display]
Key = [unit]
Key = [target_key]
Key = [text_cn]
Key = [target_type]
Key = [target_name]
Key = [display]
Key = [unit]
Key = [target_key]
Key = [text_cn]
Key = [target_type]
Key = [target_name]
Key = [display]
Key = [unit]
Key = [target_key]
Key = [text_cn]
Key = [target_type]
Key = [backup_pload_s]
Key = [backup_vload_s]
Key = [backup_iload_s]
Key = [backup_pload_t]
Key = [backup_vload_t]
Key = [backup_iload_t]
Key = [etotal_buy]
Key = [eday_buy]
Key = [ebattery_charge]
Key = [echarge_day]
Key = [ebattery_discharge]
Key = [edischarge_day]
Key = [batt_strings]
Key = [meter_connect_status]
Key = [mtactivepower_r]
Key = [mtactivepower_s]
Key = [mtactivepower_t]
Key = [has_tigo]
Key = [hjgx]
Key = [tree]
Key = [coal]
Key = [pre_powerstation_id]
Key = [nex_powerstation_id]
Key = [powerflow]
Key = [pvStatus]
Key = [bettery]
Key = [betteryStatus]
Key = [load]
Key = [loadStatus]
Key = [grid]
Key = [soc]
Key = [socText]
Key = [hasEquipment]
Key = [gridStatus]
Key = [energeStatisticsCharts]
Key = [buy]
Key = [buyPercent]
Key = [sell]
Key = [sellPercent]
Key = [selfUseOfPv]
Key = [consumptionOfLoad]
Key = [chartsType]
Key = [hasPv]
Key = [hasCharge]
Key = [charge]
Key = [disCharge]
Key = [soc]
Key = [status]
Posted: Sunday 05 May 2019 18:38
by franzel
I am definitely not an expert concerning Domoticz and certainly not where it comes to scripting, but with this script even I appeared to be able to show data from my Goodwe device. Thanks for the clear explanation.
Posted: Sunday 05 May 2019 22:02
by CrazyFrog
franzel wrote: Sunday 05 May 2019 18:38
you're welcome
Posted: Wednesday 08 May 2019 7:51
by Flitske
Hello all,
I'm trying to get this working however i cannot get the curl command to work. I run windows 10 on my desktop and domoticz on a raspberry pi. Where do i put in the curl command? In de CMD on win 10 or in on the Raspberry Pi??
Thanks for your help.
