DHT22 sensor value's into Domoticz
ILoveIOT
Re: DHT22 sensor value's into Domoticz
Post by ILoveIOT »
There as "donate" button on the domoticz main page
Oh ;) I always "donate" my very limited wisdom, now you are a full C programmer, you can do the same :lol:
I guess $ will helps too, Domoticz is a nice product that I support where I can !! (I'am not part of the team)
1x OPI PC 5.8.16 Debian 10, MiniDNLA,SMD230,EpEver,MPD,800GB,Wiegand,7 temps,DHT,32/64 I/O,2022.1
2x OPI PC 4.19.25 Debian 9, MPD,7 temps,16/32 I/O,BMP,4.10717
1x IntelNUC 5.10 Debian 10, 2TB,DalyBMS,2023.1
3x ESPEasy NodeMCU V3, 16/16 I/O
lwolf
Post by lwolf »
Just in case: RPIEasy is a python based webGUI which can forward sensor datas, like DHT to Domoticz by HTTP or MQTT. ;)
ILoveIOT
Post by ILoveIOT »
Hehe i sed NO Python code, but nice, I made the most already in C code on this forum, mcp23017, wiegand, dht, dallas, nothing beats good C code :lol:
But I must remember this project, looks nice, I use espeasy with the wifi chips allot (nodemcu v3), if I can use C, it will be C, otherwise python.
Freelance
Post by Freelance »
One last thing, i got everything working incl the blocky script for relay switching.
But, when i exit putty the dht script stops. I tried to run it with /dht & command for background but it still outputs in the putty terminal and stops when i close putty.
How to make sure that it always runs?
ILoveIOT
Post by ILoveIOT »
When system starts, put somewhere in a script. (i have /root/scripts/dht &)
You have to also UNCOMMENT the output, otherwise you get output everywhere, the console output is just for a test, so you can make small steps, got output, yes ok next step. :)
fabry91
Domoticz version: 2022.2
Post by fabry91 »
I'm trying to get it work but I think I'm losing something, I compiled the script as described:
 * dht.c:
 * Read temperature and humidity from DHT11 or DHT22 sensor on a Orange/Raspberry PI and put the value's into Domoticz every 3 minutes.
 * Customize the DHT_PIN and Domoticz IDX below, make a dummy temp/hum in Domoticz.
 * Console output is default off, silent in console output, enable below.
 * Its seems normal that you see "Data not good, skip" a few times, if enabled below.
 * IP address is set to 127.0.0.1 change below.
 * For compiling use   : cd /root/scripts/gpio/ ; gcc -Wall -o dht dht.c -lwiringPi
 * For console use     : /root/scripts/gpio/dht
 * For background use  : /root/scripts/gpio/dht &
 * More info : http://www.uugear.com/portfolio/read-dht1122-temperature-humidity-sensor-from-raspberry-pi/
 * Updated : 04-03-2019 by ILoveIoT.
#include <wiringPi.h>
#include <stdio.h>
#include <stdlib.h>
#include <stdint.h>
#include <string.h>
#define MAX_TIMINGS	85
// gpio readall BCM10 |  wPi24 |  GPIO.24 | ALT3 | 0 | Physical 35 |
#define DHT_PIN 4	/* GPIO-4 */
// Set the Domoticz IDX from the dummy device (temp/hum) you created
#define DOM_IDX 19	/* Domoticz IDX 19 */
int data[5] = { 0, 0, 0, 0, 0 };
void read_dht_data()
	uint8_t laststate	= HIGH;
	uint8_t counter		= 0;
	uint8_t j			= 0, i;
	data[0] = data[1] = data[2] = data[3] = data[4] = 0;
	/* pull pin down for 18 milliseconds */
	pinMode( DHT_PIN, OUTPUT );
	digitalWrite( DHT_PIN, LOW );
	delay( 30 );
	/* prepare to read the pin */
	pinMode( DHT_PIN, INPUT );
	/* detect change and read data */
	for ( i = 0; i < MAX_TIMINGS; i++ )
		counter = 0;
		while ( digitalRead( DHT_PIN ) == laststate )
			counter++;
			delayMicroseconds( 2 );
			if ( counter == 255 )
				break;
		laststate = digitalRead( DHT_PIN );
			break;
		/* ignore first 3 transitions */
		if ( (i >= 4) && (i % 2 == 0) )
			/* shove each bit into the storage bytes */
			data[j / 8] <<= 1;
			if ( counter > 16 )
				data[j / 8] |= 1;
			j++;
	 * check we read 40 bits (8bit x 5 ) + verify checksum in the last byte
	 * print it out if data is good
	if ( (j >= 40) &&
	     (data[4] == ( (data[0] + data[1] + data[2] + data[3]) & 0xFF) ) )
		float h = (float)((data[0] << 8) + data[1]) / 10;
		if ( h > 100 )
			h = data[0];	// for DHT11
		float c = (float)(((data[2] & 0x7F) << 8) + data[3]) / 10;
		if ( c > 125 )
			c = data[2];	// for DHT11
		if ( data[2] & 0x80 )
			c = -c;
		// For console temp & hum readings uncomment these 2 lines
		//float f = c * 1.8f + 32;
		//printf( "Humidity = %.1f %% Temperature = %.1f *C (%.1f *F)\n", h, c, f );
		// Making the string with sensor data for Domoticz
		char str1[] = "/bin/bash -c 'curl -i -s \"http://192.168.0.101:8080/json.htm?type=command&param=udevice&idx=";
		// Put variable c (Value celsius) into a string
		char str2[25]; //size of the number
		sprintf(str2, "%g", c);
		// Some comma separated value's in between
		char str3[] = ";";
		// Put variable h (Value humidity) into a string
		char str4[25]; //size of the number
		sprintf(str4, "%g", h);
		// And the final end string
		char str5[] = ";0\"' > /dev/null 2>&1";
		// Setting the domoticz IDX var from above
		char str6[25]; //size of the number
		sprintf(str6, "%i", DOM_IDX);
		char str7[] = "&";
		char str8[] = "nvalue=0&svalue=";
		// Concentrate all the str1/str8 and resulting in 1 string is stored in str1.
		strcat(str6,str7);
		strcat(str6,str8);
		strcat(str1,str6);
		strcat(str2,str3);
		strcat(str2,str4);
		strcat(str2,str5);
		strcat(str1,str2);
		// If you wanna view the output of the Domoticz string on console
		//puts(str1);
		// Case of invalid celsius temps, ignore more then +80 or -40 or 0, and recheck in 3sec
		if ( c > -40 && c < 80 && c != 0 )
			// Send the string/data to Domoticz server
			system(str1);
			//delay( 2000 ); /* wait 2 seconds before next read */
			//delay( 300000 ); /* wait 5 minutes before next read */
			delay( 180000 ); /* wait 3 minutes before next read */
		} else {
			delay( 3000 ); /* wait 3 seconds before next try */
	} else {
		// Uncomment this line below if you dont see any data coming
		//printf( "Data not good, skip\n" );
int main( void )
	//printf( "Orange/Raspberry PI DHT11/DHT22 temperature/humidity test\n" );
	if ( wiringPiSetup() == -1 )
		exit( 1 );
	while ( 1 )
		read_dht_data();
		delay( 5000 ); /* wait 5 seconds before next try */
	return(0);
I tested with the script https://easydomoticz.com/dht-11-22-rasp ... che-enfin/ running "sudo python name.py" I get the temperature/humidity.
When I try to run your script I get the error: What I am doing wrong? :oops:
ILoveIOT
Post by ILoveIOT »
Hehe, sudo /root/scripts/gpio/dht ?
fabry91
Post by fabry91 »
ILoveIOT wrote: Thursday 24 December 2020 20:48 Hehe, sudo /root/scripts/gpio/dht ?
Hello LoveIOT, what do you mean? I don't have anything in these folder!
fabry91
Post by fabry91 »
fabry91 wrote: Thursday 24 December 2020 20:36 Hello,
 * dht.c:
#include <stdio.h>
#include <stdlib.h>
#include <stdint.h>
#include <string.h>
	uint8_t j			= 0, i;
	delay( 30 );
		counter = 0;
			counter++;
				break;
			break;
			data[j / 8] <<= 1;
			if ( counter > 16 )
				data[j / 8] |= 1;
			j++;
	if ( (j >= 40) &&
		if ( h > 100 )
		if ( c > 125 )
			c = -c;
		char str3[] = ";";
		char str7[] = "&";
		strcat(str6,str7);
		strcat(str6,str8);
		strcat(str1,str6);
		strcat(str2,str3);
		strcat(str2,str4);
		strcat(str2,str5);
		strcat(str1,str2);
		//puts(str1);
			system(str1);
		} else {
	} else {
int main( void )
		exit( 1 );
	while ( 1 )
		read_dht_data();
	return(0);
Figured it out with the french script! Everything is working now, with an update of the temp/hum every 10 minute :D
