Page 2 of 15
Re: Domoticz to Google Assistan integration
Posted: Wednesday 10 April 2019 11:48
by DAVIZINHO
HELLO..
This is a very interesting solution! but i dont understand somo of the things you make
i will search for more info about configuration a reverse proxy in the synology (i have one too) and maybe i cand understand all.
Because, its not posible to make this solution without this reverse proxy?, only redirecting ports in router?
thanks!
Posted: Wednesday 10 April 2019 13:44
by DewGew
DAVIZINHO wrote: Wednesday 10 April 2019 11:48
HELLO..
thanks!
It's not so difficult:
https://www.grahamleggat.com/blog/2017/ ... oxy-server
Posted: Wednesday 10 April 2019 15:23
by DAVIZINHO
DewGew wrote: Wednesday 10 April 2019 13:44
HELLO..
thanks!
Thanks a lot for the info! is great.
But i dont understand the needing of reverse proxy, is only for make a secure connection?. No i access to my domoticz with a secure ssl connection with a letsencrypt certification.
Its not posible to connect directly?
i think i dont understand something and im wrong
sorry
Posted: Wednesday 10 April 2019 15:37
by EldigoR
Great work sofar!
I'm trying to set things up but I get these responses when I'm trying to sync devices with https://[PROXY URL]/sync
browser:
Synchronization request sent, status_code: 404
console
127.0.0.1 - - [10/Apr/2019 15:30:41] "GET /sync?code=6887d014144740c890c58be4c61f3a48&state=undefined HTTP/1.0" 200 -
I'm a doing something wrong?
The action simulator also gives errors when trying to talk to the my app's name
We're sorry, but something went wrong. Please try again.
Posted: Wednesday 10 April 2019 19:46
by EldigoR
EldigoR wrote:Great work sofar!
browser:
console
Got it! I had to link the service to the assistant on my phone
I now see the domoticz scenes
Posted: Wednesday 10 April 2019 23:16
by EldigoR
Does it sync switches as well? Or do they need to be manually added in config.py?
Posted: Thursday 11 April 2019 10:29
by EldigoR
EldigoR wrote:Does it sync switches as well? Or do they need to be manually added in config.py?
Talking too my self here
It does sync switches when the type is "Type" : "Light/Switch"
My rfxcom switches are type "Type" : "Lighting 2", Those do not sync (yet).
Posted: Thursday 11 April 2019 16:51
by DewGew
EldigoR wrote: Thursday 11 April 2019 10:29
It syncs well enough
Posted: Thursday 11 April 2019 17:09
by DewGew
I have a modifyed version here:
https://github.com/DewGew/Domoticz-Google-Assistant
Would be great if you want to test it.
Posted: Thursday 11 April 2019 17:19
by EldigoR
Cool, I will give it a try tonight.
As I have a lot of switches which don't have to be controlled by voice, I'd made a room especially to sync with the assistant.
Added in the config.py
and change this URL:
DOMOTICZ_GET_ALL_DEVICES_URL = DOMOTICZ_URL + '/json.htm?type=devices&filter=all&used=true&plan=' + ROOMPLAN
It would be great if you can implement this as well
Posted: Thursday 11 April 2019 20:24
by EldigoR
You have made some nice progress!
never thought of adding temperature
I noticed 2 things.
[*]When I ask the temperature, google also answered that the temperature device is off
like:
it's 20 degrees and in the livingroom is off.
[*]The blinds and screen detection isn't working for me
if 'Light/Switch' == device["Type"]:
if device["SwitchType"] in ['Blinds', 'Venetian Blinds EU', 'Venetian Blinds US'] :
return blindsDOMAIN
it wil never detect my blinds as blinds because the device["Type"] is "Lighting 2" and Type" : "RFY" in my setup.
other than that great job
Posted: Thursday 11 April 2019 22:18
by DewGew
EldigoR wrote: Thursday 11 April 2019 17:19
I just use a separate user for GA and assign devices in user settings. Then I can see in the log if GA swithches the devices.
Try to fix the issues about the blinds..
Posted: Thursday 11 April 2019 22:27
by EldigoR
Good one!
Posted: Friday 12 April 2019 10:15
by ressof
EldigoR wrote: Thursday 11 April 2019 20:24
like:
There is a setting called "queryOnlyTemperatureSetting" but I havent got any luck with this setting.
https://developers.google.com/actions/ ... uresetting
Also I don't see the point with modes on thermostats. Changing this will not do anything in Domoticz?
Posted: Friday 12 April 2019 12:34
by DewGew
ressof wrote: Friday 12 April 2019 10:15
like:
Assistant says "inactivated" instead of "off"
Posted: Friday 12 April 2019 12:57
by DewGew
I noticed 2 things.
like:
return blindsDOMAIN
Test if you can get the blinds now.
Posted: Friday 12 April 2019 14:11
by EldigoR
DewGew wrote: Friday 12 April 2019 12:57
I noticed 2 things.
like:
return blindsDOMAIN
Al most. The Lighting 2 types are working properly now but the Type" : "RFY" (which is my somfy screen) is still ignored
Posted: Friday 12 April 2019 15:00
by DewGew
EldigoR wrote: Friday 12 April 2019 14:11
”RFY” is that used for lights and switches too?
Posted: Friday 12 April 2019 15:25
by EldigoR
DewGew wrote: Friday 12 April 2019 15:00
I think it can be yes
https://shop.somfy.co.uk/smart-home/lights-switches
but I only have screens
Posted: Friday 12 April 2019 16:17
by DewGew
EldigoR wrote: Friday 12 April 2019 15:25
I added RFY
Give it a try again
