Domoticz to Google Assistant integration
Alexa, Google Home and Siri
DAVIZINHO
Re: Domoticz to Google Assistan integration
Post by DAVIZINHO »
HELLO..
This is a very interesting solution! but i dont understand somo of the things you make :-(
i will search for more info about configuration a reverse proxy in the synology (i have one too) and maybe i cand understand all. :-)
Because, its not posible to make this solution without this reverse proxy?, only redirecting ports in router?
thanks!
DewGew
Domoticz version: V4.10618
Post by DewGew »
DAVIZINHO wrote: Wednesday 10 April 2019 11:48 HELLO..
thanks!
It's not so difficult:
https://www.grahamleggat.com/blog/2017/ ... oxy-server
DAVIZINHO
Post by DAVIZINHO »
DewGew wrote: Wednesday 10 April 2019 13:44
thanks!
Thanks a lot for the info! is great.
But i dont understand the needing of reverse proxy, is only for make a secure connection?. No i access to my domoticz with a secure ssl connection with a letsencrypt certification.
Its not posible to connect directly?
i think i dont understand something and im wrong :-( sorry
EldigoR
Post by EldigoR »
Great work sofar!
I'm trying to set things up but I get these responses when I'm trying to sync devices with https://[PROXY URL]/sync
browser:
Synchronization request sent, status_code: 404
console
127.0.0.1 - - [10/Apr/2019 15:30:41] "GET /sync?code=6887d014144740c890c58be4c61f3a48&state=undefined HTTP/1.0" 200 -
I'm a doing something wrong?
The action simulator also gives errors when trying to talk to the my app's name
We're sorry, but something went wrong. Please try again.
EldigoR
Post by EldigoR »
EldigoR wrote:Great work sofar!
browser:
console
Got it! I had to link the service to the assistant on my phone Image
I now see the domoticz scenes Image
EldigoR
Post by EldigoR »
Does it sync switches as well? Or do they need to be manually added in config.py?
EldigoR
Post by EldigoR »
EldigoR wrote:Does it sync switches as well? Or do they need to be manually added in config.py?
Talking too my self here Image
It does sync switches when the type is "Type" : "Light/Switch"
My rfxcom switches are type "Type" : "Lighting 2", Those do not sync (yet).
DewGew
Post by DewGew »
EldigoR wrote: Thursday 11 April 2019 10:29
It syncs well enough
DewGew
Post by DewGew »
I have a modifyed version here: https://github.com/DewGew/Domoticz-Google-Assistant
Would be great if you want to test it.
EldigoR
Post by EldigoR »
I have a modified version here: https://github.com/DewGew/Domoticz-Google-Assistant
Cool, I will give it a try tonight.
As I have a lot of switches which don't have to be controlled by voice, I'd made a room especially to sync with the assistant.
Added in the config.py
ROOMPLAN = '6'
and change this URL:
DOMOTICZ_GET_ALL_DEVICES_URL = DOMOTICZ_URL + '/json.htm?type=devices&filter=all&used=true&plan=' + ROOMPLAN
It would be great if you can implement this as well
EldigoR
Post by EldigoR »
You have made some nice progress!
never thought of adding temperature ;)
I noticed 2 things.
[*]When I ask the temperature, google also answered that the temperature device is off
like: it's 20 degrees and in the livingroom is off.
[*]The blinds and screen detection isn't working for me
if 'Light/Switch' == device["Type"]:
        if device["SwitchType"] in ['Blinds', 'Venetian Blinds EU', 'Venetian Blinds US'] :
            return blindsDOMAIN
it wil never detect my blinds as blinds because the device["Type"] is "Lighting 2" and Type" : "RFY" in my setup.
other than that great job :lol:
DewGew
Post by DewGew »
EldigoR wrote: Thursday 11 April 2019 17:19
ROOMPLAN = '6'
I just use a separate user for GA and assign devices in user settings. Then I can see in the log if GA swithches the devices.
Try to fix the issues about the blinds..
EldigoR
Post by EldigoR »
DewGew wrote: I just use a separate user for GA and assign devices in user settings. Then I can see in the log if GA swithches the devices.
Good one!
ressof
Domoticz version: Latest
Post by ressof »
EldigoR wrote: Thursday 11 April 2019 20:24
There is a setting called "queryOnlyTemperatureSetting" but I havent got any luck with this setting.
https://developers.google.com/actions/ ... uresetting
Also I don't see the point with modes on thermostats. Changing this will not do anything in Domoticz?
DewGew
Post by DewGew »
ressof wrote: Friday 12 April 2019 10:15
Assistant says "inactivated" instead of "off"
DewGew
Post by DewGew »
EldigoR wrote: Thursday 11 April 2019 20:24 You have made some nice progress!
I noticed 2 things.
            return blindsDOMAIN
Test if you can get the blinds now.
EldigoR
Post by EldigoR »
DewGew wrote: Friday 12 April 2019 12:57
I noticed 2 things.
            return blindsDOMAIN
Al most. The Lighting 2 types are working properly now but the Type" : "RFY" (which is my somfy screen) is still ignored
DewGew
Post by DewGew »
EldigoR wrote: Friday 12 April 2019 14:11
”RFY” is that used for lights and switches too?
EldigoR
Post by EldigoR »
DewGew wrote: Friday 12 April 2019 15:00
I think it can be yes
https://shop.somfy.co.uk/smart-home/lights-switches
but I only have screens
DewGew
Post by DewGew »
EldigoR wrote: Friday 12 April 2019 15:25
I added RFY
Give it a try again😀
