Page 2 of 2
Re: Zigate and Xiaomi temp/hum/baro sensors adjustment of temp
Posted: Monday 04 March 2019 17:15
by pipiche
@mcmikev, which version of Domoticz are you using ? Stable V.49700 or something else ?
Posted: Monday 04 March 2019 17:17
by mcmikev
build from source, up2date till yesterday. Version V4.10532
Posted: Monday 04 March 2019 17:18
by pipiche
And which branche of the plugin ? stable, beta or pre-4.1 ?
Posted: Monday 04 March 2019 17:19
by pipiche
The TH devices are, but the THB not. Temp, Humi,Baro can this be applied as well please???
I'll have a look ... Indeed that is posisble
Posted: Monday 04 March 2019 17:20
by mcmikev
I run pre-4.1 plugin version
Posted: Monday 04 March 2019 17:37
by pipiche
This looks strange, from the code side, the adjustment is made when receiving a new temperature, despite it is T, TH or THB
I'll investigate on my end
Posted: Monday 04 March 2019 17:42
by mcmikev
The Temp device Temp Humi devices are doing it right. But the THB device does nothing with the offset.
Posted: Monday 04 March 2019 18:59
by pipiche
@mcmikev, could you do an update (git pull). I changed the way it was done, as I was not really happy with it.
Tested here with a Xiaomi device, and all T, TH and THB are updated based on the adjusted value that you have to set for each single widget.
So you need to put the Adj value on T, TH and THB
Posted: Monday 04 March 2019 19:02
by mcmikev
So if i only use and add the thb device it Will not work?
Posted: Monday 04 March 2019 19:06
by pipiche
Yes, it should work
Posted: Monday 04 March 2019 19:07
by mcmikev
Testing now
Posted: Monday 04 March 2019 19:10
by mcmikev
Seems fine. Need Some more updates
