Sorry but this answer does not clear things up. I'm interested in the led setting (configuration setting) and the actual kWh measure (the number).pimseb wrote: Monday 11 February 2019 23:06 Yes it runs OK. I didnt check the led settings.
But everything seems to work fine in domoticz. The kWh mesure aswell
2019-02-11 23:03:18.097 (Zwave) General/kWh (kWh Meter) 2019-02-11 23:03:18.430 (Zwave) Usage (Poele) 2019-02-11 23:03:18.432 (Zwave) General/kWh (kWh Meter) 2019-02-11 23:03:18.898 (Zwave) General/Voltage (Voltage)
Neo CoolCam Unknown: type=0200, id=1027 using NAS-WR01ZE
MultiZW074
Re: Neo CoolCam Unknown: type=0200, id=1027 using NAS-WR01ZE
Jendemen
Same here, after amending the .xml file, rebooting, delete and add the plug, the power plug is recognized but cannot change device parameters and the kWh measurement reads an abnormal 21474836.62 kWh
pimseb
- Domoticz version: 2020.1
Yes same here
KWh usage shows -2.14748e+07 kWh
Watt usage is ok
Watt usage is ok
knielen
I have the same issues, but also experiencing random switching on & off, more people have this?
pimseb
I dont have on off switching problems
Could you also check if you have this problem : https://www.domoticz.com/forum/viewtopi ... =6&t=26949
Thx
Thx
dens1975
I have the same problem. Did upload new config files, device is recognized correct now but kWh is not working correctly. Also configuration parameters can't be changed.
KWh usage at dashboard shows 2.14748e+07 kWh In devices it shows however a kWh which looks correct but is too high in my opnion. In logs it shows strange counter values. Hope anyone has any ideas, thanks!
MultiZW074
Are the issues neo coolcam or domoticz related?
In other words do i have to send back the device or wait for a domoticz update?
Jendemen
I think it is a domoticz related-'ish' problem, I have 4 of these new power plugs and all 4 of them show the same problem.
MultiZW074
Check the detailed manual on https://community.smartthings.com/t/rel ... /144274/50
How to notify the domoticz developer(s)?
jf149
I have the same problem with these plugs.
I read the article and if I understand it right, we need the new parameter to reset the metering report?
So whats next then, go to git and make a change request?
MultiZW074
I did create an openzwave file regarding the new parameters into openzwave (repository) on github. And related to the new neo device wrong kWh readings i did create an issue into domoticz on github.
dens1975
I just saw on the Openzwave website that in the latest openzwave code update 1.4.3389 there is something new. There is a new file nas-wr01ze.xml and this new powerplug is linked to it.
I have no time to test right now but maybe someone could.
See: http://old.openzwave.com/snapshots/
download: http://old.openzwave.com/snapshots/open ... 4.3389.zip
I tested it, and it works....
dens1975
I just remotely updated the files and reboot my NAS but no luck. Did you do anything special? Like remove the device and add it again or did it work right away?
Yes, you have to remove the device and add it again.
MultiZW074
The openzwave files will be part of the domoticz beta version very soon. After you update domoticz (next week or later) an exclude plus include action for this device is needed.
dens1975
Well I exclude and include it and configuration parameters are working but my kWh reading is still incorrect in Domoticz (-2.14748e+07 kWh)
I also tried to get it back to factory default (hold power button for 10 seconds). But after doing this and include it again the counters (total kWh) isn't reset. However it looks like reading it out ok if I look in the OpenZwave panel, so I don't understand why domoticz is still displaying it wrong.
Any ideas?
Any ideas?
rron
I have the above problems but I'm also missing the switch option. I have already exclude and include the NEO CoolCam several times but that didn't help.
I have only kWh, electric voltage and CM113.
I'm on the last beta version.
Did you exclude the plug, delete all this plug devices in Domoticz, and then include it again.
When the device is excluded you might want to reset the device, before you include it again.
What Domoticz version are you on? Just a remark latest does not mention the version itself.
Is the file domoticz/Config/shenzen_neo/nas-wr01ze.xml present?
rron
You are right I ,m on V4.10541. I exclude the plug but didn,t delete all teh devices in domoticz. I will try that and I will also check the xml file.EddyG wrote: Wednesday 06 March 2019 21:55 Did you exclude the plug, delete all the devices in Domticz, and then include it again.
What Domoticz version are you on? Just a remark latest does not mention the version itself.![]()
I report my findings tomorrow.
Thx
