Page 2 of 2
Re: Using Google Home with Domoticz
Posted: Thursday 23 April 2020 18:46
by krizzz
Homebridge was VERY easy to setup with google. Too shame that Routines is not yet available in the Netherlands so that Google Home could perform a multiple of sequences with only 1 command.
Posted: Sunday 24 May 2020 20:15
by daniellejorge
FireWizard wrote: Tuesday 28 January 2020 23:43
@daniellejorge,
Can you explain exactly what you expect from Domoticz and Google Home?
1. Only voice commands from the Google Home (Mini)?
2. Display Domoticz on the Google Nest Hub?
3. Are the devices, you want to control, natively supported by Google Assistant?
4. Do you have already support tools installed, such as MQTT and Node Red?
There are several posts available on this forum, covering different approaches.
The better you indicate your goal, the better someone can help you.
I'm just a noob, so i probably don't have MQTT or Node Red (whatever it means)
I just have figured myself to install domoticz on my raspberry and set it up my lights (livolo) and blinds on it and wanted to control it from google home by voice with Rotines or something. They are not natively supported. I've figured to do some routines with my broadlink to turn on TV and speakers.
I've tried the
https://github.com/DewGew/Domoticz-Goog ... stant/wiki
But i can't even "Make local deployment available trough HTTPS with valid certificate" lol
It's just too hard for noobs, even with the tutorial. lol
Posted: Sunday 24 May 2020 21:41
by FireWizard
HI,
@daniellejorge,
It might be a process, that will take some time.
I'm not so familiar with DewGew solution (dzga).
Questions?
What platform (hardware) is Domoticz installed? As I look to the information in your profile. I assume Raspberry Pi, version?
Do you want to control it with Google Home (Mini) or a Google Home Hub (with display)?
Regards.
Posted: Thursday 25 June 2020 19:47
by daniellejorge
Yes, raspberry pi ( I use rfxcom to control my blinds thru domoticz).
I want to control it with Google Home (mini) using voice, I already control blinds and light with the domoticz app in my cellphone.
Any idea how should I start?
Posted: Thursday 25 June 2020 20:56
by daniellejorge
FireWizard wrote: Sunday 24 May 2020 21:41
HI,
@daniellejorge,
Questions?
Regards.
Raspberry Pi 2 (RPi2) Model B Quad-Core 900 MHz 1 GB RAM
Posted: Wednesday 04 November 2020 11:58
by jellex87
Hello daniellejorge,
Are you already a step further in this? I'm looking for a same kind of solution,
