Page 2 of 3
Re: Plugwise Adam
Posted: Monday 18 February 2019 20:32
by Dr8072
Perfect.... Thanks....
That actually makes more sense
Right now I had a version that tried to update each separate device but It makes more sense if we are using zones ....
Based on this the plan now is:
I add a setpoint per zone so when I update a zone..... we can assume that the Adam will sort out which device needs to be updated
Then how about I change the setpoint for the lisa and Tom into a Desired temp and leave the actual temp and battery in place so you can see if the difference
That would match the app pretty well I Think.
would that work for you ?
Re: Plugwise Adam
Posted: Tuesday 19 February 2019 10:29
by ahattink
I think that would work perfectly!
Re: Plugwise Adam
Posted: Tuesday 19 February 2019 14:50
by Dr8072
This will require a bit of rewrite as it changes to plugin from thermostat focused to zone focused.
it may take me a bit longer, as I need to keep the functionality for the Anna intact but I'm working on it
Re: Plugwise Adam
Posted: Friday 22 February 2019 21:01
by akatar
Dr8072 wrote: Tuesday 19 February 2019 14:50
Perhaps a stupid question, but, why is there need to keep the anna intact? why not 2 plugins (1 for adam, 1 for anna)
people use the anna OR the adam, it makes no sense to use the anna if you have a adam (i guess)
Re: Plugwise Adam
Posted: Friday 22 February 2019 21:04
by akatar
Dr8072 wrote: Friday 15 February 2019 9:20
Keep in mind... I cannot physical test the Adam part as I do not have physical access to one
If you need access, i can give you acces to mine, but i have only 1 adam and 1 lisa
you can Always contact plugwise for a test set, they are mostly willing to help creating a plugin.
Re: Plugwise Adam
Posted: Monday 25 February 2019 16:34
by Dr8072
@Akatar,
The reason for keeping the Anna system in place is because from Domoticz point of view its a Plugwise system, it doesn't matter that if you have an Anna, Adam, Smile, Tom, Lisa or floor
They are handled all in the same way so its a bit overkill to have two plugins that almost do the same thing
Even the current Anna basically works like a zone system. It just has a single zone... i.e the living room
Re: Plugwise Adam
Posted: Monday 25 February 2019 16:42
by akatar
Dr8072 wrote: Monday 25 February 2019 16:34
@Akatar,
Even the current basically Anna works like a zone system. It just has a single zone... i.e the living room
ok, can i ask you to add the water pressure to the plugin? it's nice to see if i have to refill it or not?
<point_log id="0f2f09edf21646f2813790ddbe67f085">
<updated_date>2019-02-25T16:26:06.109+01:00</updated_date>
<type>central_heater_water_pressure</type>
<unit>bar</unit>
<last_consecutive_log_date>2019-02-25T16:26:06.108+01:00</last_consecutive_log_date>
<period end_date="2019-02-25T16:26:06.109+01:00" start_date="2019-02-25T16:26:06.109+01:00">
<measurement log_date="2019-02-25T16:26:06.109+01:00">1.20</measurement>
Re: Plugwise Adam
Posted: Tuesday 26 February 2019 9:34
by Dr8072
Yeah I saw that one too in the XML from the Adam I'm using . Its in my test version already, you will get a pressure sensor but only if your CV reports it back to the Plugwise system.
I still have an older CV, and it not reporting it back, So I have to do the manual walk to check it. But if the gateway has it it will report it and you put your automation around it.
Re: Plugwise Adam
Posted: Tuesday 26 February 2019 23:25
by Dr8072
Doing last bit of testing... first release will go out soon
Re: Plugwise Adam
Posted: Monday 11 March 2019 17:26
by tcviper
Will the plugwise domoticz plugin also work for Smile P1?
Would love to see that added.
Re: Plugwise Adam
Posted: Wednesday 20 March 2019 18:46
by akatar
Dr8072 wrote: Tuesday 26 February 2019 23:25
Any idea when?
Re: Plugwise Adam
Posted: Wednesday 27 March 2019 12:00
by Dr8072
Apologies. Real life got in the way... Changed jobs etc.. so. Coding for fun took a back seat, hoping to find some time soon
Re: Plugwise Adam
Posted: Thursday 28 March 2019 20:03
by akatar
no problem, take you're time
Re: Plugwise Adam
Posted: Thursday 16 May 2019 15:21
by ahattink
hi Dr8072,
Did you find some time to code?
Arthur
Re: Plugwise Adam
Posted: Tuesday 24 September 2019 20:05
by djreesing
Hi there, what is the status of the Adam integration? Looking into buying one so I would like to know if it already works with Domoticz.
Re: Plugwise Adam
Posted: Wednesday 27 November 2019 11:37
by schj
Dr8072 wrote: Wednesday 27 March 2019 12:00
Very interested in this also. Let me know if I can give a hand. Cheers -- Jaap
Re: Plugwise Adam
Posted: Thursday 28 November 2019 15:19
by ahattink
schj wrote: Wednesday 27 November 2019 11:37
Dr8072 has not been seen on this forum for months now, so i don't think there is any progress. Someone else who can further develop this?
Re: Plugwise Adam
Posted: Sunday 09 February 2020 13:03
by eddieb
Is there any development on the Plugwise Smile / Anna / Adam plugin ?
I got 3.1.11 firmware and there seems to be a couple of options availiable that would be nice to have
Eddie
Re: Plugwise Adam
Posted: Thursday 25 June 2020 17:55
by gerben
Any progress in this item. It would be nice to be able to integrate the Adam device with all its linked valves and temperature sensors.
Gerben
Re: Plugwise Adam
Posted: Wednesday 26 August 2020 10:45
by Dr8072
Apologies to all who have been following this topic. I started to extend the Anna plugin for the ADAM, however as stated before, life got in the way and haven't had the change to do private coding until now.
I fear i have to start again if i would pick this up again completely from scratch as the repository i used for this has been corrupted - read hard disk crash.
I'm focusing on bug fixing the base Anna plugin for now.
