Plugwise Adam
Dr8072
- Domoticz version: 4.10xxx
Re: Plugwise Adam
Perfect.... Thanks....
That actually makes more sense
Right now I had a version that tried to update each separate device but It makes more sense if we are using zones ....
Based on this the plan now is:
I add a setpoint per zone so when I update a zone..... we can assume that the Adam will sort out which device needs to be updated
Then how about I change the setpoint for the lisa and Tom into a Desired temp and leave the actual temp and battery in place so you can see if the difference
That would match the app pretty well I Think.
would that work for you ?
ahattink
- Domoticz version: Stable
Re: Plugwise Adam
I think that would work perfectly!
Pi 3B, latest stable
RFXCOM, Z-wave, Zigate, Hue, Harmony hub, Netatmo Weather station, Opentherm Gateway, EnOcean,P1 SmartMeter, Plugwise Anna & Adam, Xiaomi Roborock, Sonos One, Google Home, Philips Hue, Homey, D-link and Bitron Video camera.
Dr8072
Re: Plugwise Adam
This will require a bit of rewrite as it changes to plugin from thermostat focused to zone focused.
it may take me a bit longer, as I need to keep the functionality for the Anna intact but I'm working on it
akatar
Re: Plugwise Adam
Perhaps a stupid question, but, why is there need to keep the anna intact? why not 2 plugins (1 for adam, 1 for anna)Dr8072 wrote: Tuesday 19 February 2019 14:50 This will require a bit of rewrite as it changes to plugin from thermostat focused to zone focused.
people use the anna OR the adam, it makes no sense to use the anna if you have a adam (i guess)
akatar
Re: Plugwise Adam
If you need access, i can give you acces to mine, but i have only 1 adam and 1 lisaDr8072 wrote: Friday 15 February 2019 9:20
Keep in mind... I cannot physical test the Adam part as I do not have physical access to one
you can Always contact plugwise for a test set, they are mostly willing to help creating a plugin.
Dr8072
Re: Plugwise Adam
@Akatar,
The reason for keeping the Anna system in place is because from Domoticz point of view its a Plugwise system, it doesn't matter that if you have an Anna, Adam, Smile, Tom, Lisa or floor
They are handled all in the same way so its a bit overkill to have two plugins that almost do the same thing
Even the current Anna basically works like a zone system. It just has a single zone... i.e the living room
akatar
Re: Plugwise Adam
ok, can i ask you to add the water pressure to the plugin? it's nice to see if i have to refill it or not?Dr8072 wrote: Monday 25 February 2019 16:34 @Akatar,
Even the current basically Anna works like a zone system. It just has a single zone... i.e the living room
<point_log id="0f2f09edf21646f2813790ddbe67f085">
<updated_date>2019-02-25T16:26:06.109+01:00</updated_date>
<type>central_heater_water_pressure</type>
<unit>bar</unit>
<last_consecutive_log_date>2019-02-25T16:26:06.108+01:00</last_consecutive_log_date>
<period end_date="2019-02-25T16:26:06.109+01:00" start_date="2019-02-25T16:26:06.109+01:00">
<measurement log_date="2019-02-25T16:26:06.109+01:00">1.20</measurement>
Dr8072
Re: Plugwise Adam
Yeah I saw that one too in the XML from the Adam I'm using . Its in my test version already, you will get a pressure sensor but only if your CV reports it back to the Plugwise system.
I still have an older CV, and it not reporting it back, So I have to do the manual walk to check it. But if the gateway has it it will report it and you put your automation around it.
Dr8072
Re: Plugwise Adam
Doing last bit of testing... first release will go out soon
- tcviper
Re: Plugwise Adam
Will the plugwise domoticz plugin also work for Smile P1?
Would love to see that added.
akatar
Re: Plugwise Adam
Any idea when?Dr8072 wrote: Tuesday 26 February 2019 23:25 Doing last bit of testing... first release will go out soon
Dr8072
Re: Plugwise Adam
Apologies. Real life got in the way... Changed jobs etc.. so. Coding for fun took a back seat, hoping to find some time soon
akatar
Re: Plugwise Adam
no problem, take you're time
ahattink
Re: Plugwise Adam
hi Dr8072,
Did you find some time to code?
Arthur
Arthur
djreesing
- Domoticz version: stable
Re: Plugwise Adam
Hi there, what is the status of the Adam integration? Looking into buying one so I would like to know if it already works with Domoticz.
schj
Re: Plugwise Adam
Very interested in this also. Let me know if I can give a hand. Cheers -- JaapDr8072 wrote: Wednesday 27 March 2019 12:00 Apologies. Real life got in the way... Changed jobs etc.. so. Coding for fun took a back seat, hoping to find some time soon
ahattink
Re: Plugwise Adam
Dr8072 has not been seen on this forum for months now, so i don't think there is any progress. Someone else who can further develop this?
eddieb
Re: Plugwise Adam
Is there any development on the Plugwise Smile / Anna / Adam plugin ?
I got 3.1.11 firmware and there seems to be a couple of options availiable that would be nice to have
Eddie
Eddie
RPI4 Beta / Tasmota / ZigBee2MQTT / P1meter / Haier AC MQTTmapper / SolarEdge SE3500H modbus_tcp / Marstek Venus / Opentherm gateway / Plugwise Anna/Smile / ObserverIP weatherstation thru WuDirect
gerben
- Domoticz version: 2021.1
Re: Plugwise Adam
Any progress in this item. It would be nice to be able to integrate the Adam device with all its linked valves and temperature sensors.
Gerben
Gerben
Dr8072
Re: Plugwise Adam
Apologies to all who have been following this topic. I started to extend the Anna plugin for the ADAM, however as stated before, life got in the way and haven't had the change to do private coding until now.
I fear i have to start again if i would pick this up again completely from scratch as the repository i used for this has been corrupted - read hard disk crash.
I'm focusing on bug fixing the base Anna plugin for now.
