Python Plugin: MillHeat
copywizard
Re: Python Plugin: MillHeat
Post by copywizard »
appelflap wrote: Wednesday 18 March 2020 11:54 Did you install the pymill component using this command?
pip3 install millheater
Thansk alot ! that helped i hav eno idea why i did not do that? i think i did pip instead of pip3
the error is fixed but i still have the same problem as mentioned above that the devices are created and deleted directly.
Could you explain to me in a bit of noob terms where and what to edit the python script to allow it to work i think its a gen2 device problem like the ppl above in this thread.
P.s. i got it wokring somewhat using the instructions from @sema2022
but i,am only stuck on this part
"Further I changed the heater values in line 130 from “0, str(myHeaters[heaterId].is_heating))” to “myHeaters[heaterId].power_status, str(myHeaters[heaterId].is_heating))”. This might be due to the gen2 Wifi Socket having an extra function where you can choose to utilize the internal thermostat function combined with the power On/Off switch or not, and this is controlled by the “fan_status=1” parameters, or... ?"
i can change the temperature en the temperature read out is correct but i cannot turn it on/off thru domoticz.
if you could help met find what line i need to change and where in the plugin.py script it would be much appriciated!
jobvr
Post by jobvr »
Yes, the part from Sema2022 helped me a lot as well.
I think the plugin is running fine now, when I restart the domoticz server I see:
2020-04-02 07:35:02.045 Status: (Bathroom_Heater) Started.
2020-04-02 07:35:03.002 (Bathroom_Heater) onStart called
2020-04-02 07:35:03.000 Status: (Bathroom_Heater) Entering work loop.
2020-04-02 07:35:03.000 Status: (Bathroom_Heater) Initialized version 0.1.4, author 'appelflap
And on regular intervals is see
2020-04-02 07:36:14.983 (Bathroom_Heater) onHeartbeat called
2020-04-02 07:36:15.347 (Bathroom_Heater) createDevices called
without any errors. However NO device is created :?: Any suggestions ??
copywizard
Still nobody that can or will help us ? i got it working but the switch is still not working and the devices disappear from my device list so now and then.
any help would be appreciated
R1ch9rd80
Post by R1ch9rd80 »
I've installed the MillHeat plugin. I'm running Domoticz (2020.2 build 12256) on a Synology NAS.
When I enable the MillHeat plugin on the hardware tab, I see the following in the log:
2020-08-30 19:43:12.066 Error: (MillHeat) failed to load 'plugin.py', Python Path used was '/usr/local/domoticz/var/plugins/millheat/:/volume1/@appstore/py3k/usr/local/lib/python35.zip:/volume1/@appstore/py3k/usr/local/lib/python3.5/:/volume1/@appstore/py3k/usr/local/lib/python3.5/plat-linux:/volume1/@appstore/py3k/usr/local/lib/python3.5/lib-dynload:/volume1/@appstore/py3k/usr/local/lib/python3.5/site-packages'.
2020-08-30 19:43:12.067 Error: (Millheat) Module Import failed, exception: 'ImportError'
2020-08-30 19:43:12.067 Error: (Millheat) Module Import failed: ' Name: mill'
2020-08-30 19:43:12.067 Error: (Millheat) Error Line details not available.
After a while I see the following constantly in the log:
2020-08-30 20:32:16.923 Error: Millheat hardware (22) thread seems to have ended unexpectedly
Does anyone have an idea? I am quite a novice with Domoticz and Python scripts, so help will be appreciated!
