Page 2 of 2
Re: Average outside temperature with Lua
Posted: Tuesday 20 November 2018 20:26
by jvdz
Knibor wrote: Tuesday 20 November 2018 20:19
Now I use the script for measure the "Gasverbruik per graaddag" in conjunction with the previous script "average temperature"
The following error is in the error log "
2018-11-20 20:17:00.475 Error: EventSystem: Lua script Gasverbuik per graaddag did not return a commandArray
What do I wrong?
This looks like a Dzevent script, not regular LUA script, which always needs the: "return commandArray" as it acts on the contents of that array.
Maybe some reading/studying is needed now to understand the different script options and how their basics work?
Jos
Posted: Tuesday 20 November 2018 20:44
by Knibor
Thanks for the info Jos, its works now.
Time to learn a little bit more about scripting Lua and Dzvents
Posted: Tuesday 24 September 2024 12:48
by Hink
If you get this error:
[WebServer] Depricated RType (graph) for API request. Please use correct API Command!
I solved is by replacing:
local sQuery = 'curl "http://127.0.0.1:8080/json.htm?type=graph&sensor=temp&idx='..tostring(uitlees_idx)..'&range=day"'
with
local sQuery = 'curl "http://127.0.0.1:8080/json.htm?type=command¶m=graph&sensor=temp&idx='..tostring(uitlees_idx)..'&range=day"'
Posted: Tuesday 24 September 2024 13:57
by jvdz
Yep... things change after 6 years!
