DOMOTICZ version 4.9700 RPI
Blind is CLOSED
Settings SHELLY:
Status DOMOTICZ:
TEST:
1.)OPEN --
NOT WORKING
2019-01-04 07:42:12.232 (Shelly) shellies/shellyswitch-134D85/roller/0/
command/pos Off 100
2019-01-04 07:42:12.232 (Shelly) MqttClient::Publish shellies/shellyswitch-134D85/roller/
0/command/pos (100)
2019-01-04 07:42:12.283 (Shelly) MQTT message: shellies/shellyswitch-134D85/roller/
0/command/pos 100
2.) CLOSE WORKING
2019-01-04 07:44:01.863 (Shelly) MqttClient::Publish shellies/shellyswitch-134D85/roller/0/command (open)
2019-01-04 07:44:01.914 (Shelly) MQTT message: shellies/shellyswitch-134D85/roller/0/command open
2019-01-04 07:44:02.115 (Shelly) MQTT message: shellies/shellyswitch-134D85/roller/0 open
2019-01-04 07:44:02.230 (Shelly) MQTT message: shellies/shellyswitch-134D85/relay/power 9.98
2019-01-04 07:44:02.344 (Shelly) MQTT message: shellies/shellyswitch-134D85/relay/power 107.19
3.)SLIDER WORKING
2019-01-04 07:45:27.046 (Shelly) shellies/shellyswitch-134D85/roller/0/command/pos Set Level 85
2019-01-04 07:45:27.046 (Shelly) MqttClient::Publish shellies/shellyswitch-134D85/roller/0/command/pos (85)
2019-01-04 07:45:27.097 (Shelly) MQTT message: shellies/shellyswitch-134D85/roller/0/command/pos 85
2019-01-04 07:45:27.298 (Shelly) MQTT message: shellies/shellyswitch-134D85/roller/0 close
2019-01-04 07:45:27.412 (Shelly) MQTT message: shellies/shellyswitch-134D85/relay/power 11.49
2019-01-04 07:45:27.525 (Shelly) MQTT message: shellies/shellyswitch-134D85/relay/power 123.79
2019-01-04 07:45:29.841 (Shelly) MQTT message: shellies/shellyswitch-134D85/roller/0 stop
2019-01-04 07:45:29.905 (Shelly) MQTT message: shellies/shellyswitch-134D85/roller/0/pos 85
2019-01-04 07:45:29.970 (Shelly) MQTT message: shellies/shellyswitch-134D85/relay/power 100.21
2019-01-04 07:45:30.078 (Shelly) MQTT message: shellies/shellyswitch-134D85/relay/power 0.0
2019-01-04 07:45:40.704 (Shelly) MQTT message: shellies/shellyswitch-134D85/relay/power 1.02
2019-01-04 07:45:40.818 (Shelly) MQTT message: shellies/shellyswitch-134D85/relay/power 0.0
4.)VENETIAN OPEN WORKING BUT INVERTED
2019-01-04 07:46:49.163 (Shelly) MqttClient::Publish shellies/shellyswitch-134D85/roller/0/command (open)
2019-01-04 07:46:49.214 (Shelly) MQTT message: shellies/shellyswitch-134D85/roller/0/command open
2019-01-04 07:46:49.415 (Shelly) MQTT message: shellies/shellyswitch-134D85/roller/0 open
2019-01-04 07:46:49.580 (Shelly) MQTT message: shellies/shellyswitch-134D85/relay/power 21.37
2019-01-04 07:46:49.642 (Shelly) MQTT message: shellies/shellyswitch-134D85/relay/power 105.51
2019-01-04 07:46:52.060 (Shelly) MQTT message: shellies/shellyswitch-134D85/relay/power 97.82
2019-01-04 07:46:52.123 (Shelly) MQTT message: shellies/shellyswitch-134D85/roller/0/pos 100
2019-01-04 07:46:52.138 (Shelly) MQTT message: shellies/shellyswitch-134D85/relay/power 1.36
2019-01-04 07:46:52.153 (Shelly) MQTT message: shellies/shellyswitch-134D85/roller/0 stop
2019-01-04 07:46:52.367 (Shelly) MQTT message: shellies/shellyswitch-134D85/relay/power 0.0
5.) VENETIAN STOP WORKING
2019-01-04 07:48:27.213 (Shelly) MqttClient::Publish shellies/shellyswitch-134D85/roller/0/command (stop)
2019-01-04 07:48:27.264 (Shelly) MQTT message: shellies/shellyswitch-134D85/roller/0/command stop
2019-01-04 07:48:27.264 (Shelly) MQTT message: shellies/shellyswitch-134D85/roller/0/pos 29
2019-01-04 07:48:27.280 (Shelly) MQTT message: shellies/shellyswitch-134D85/roller/0 stop
2019-01-04 07:48:27.448 (Shelly) MQTT message: shellies/shellyswitch-134D85/relay/power 35.4
2019-01-04 07:48:27.510 (Shelly) MQTT message: shellies/shellyswitch-134D85/relay/power 0.0
6.) VENETIAN CLOSE WORKING BUT INVERTED
2019-01-04 07:48:14.751 (Shelly) MqttClient::Publish shellies/shellyswitch-134D85/roller/0/command (close)
2019-01-04 07:48:14.753 (Shelly) MQTT message: shellies/shellyswitch-134D85/roller/0/command close
2019-01-04 07:48:15.004 (Shelly) MQTT message: shellies/shellyswitch-134D85/roller/0 close
2019-01-04 07:48:15.220 (Shelly) MQTT message: shellies/shellyswitch-134D85/relay/power 119.33
Only command for OPEN is wrong in this case when Blinds percentage is used.
