Python Plugin: Shelly MQTT
nabru99
Re: Python Plugin: Shelly MQTT
Ok i will explain:
1.) if position is closed it means it is 100%
now i set position to example 69%- relay is triggered and shutter moves
than i set position to 30 % shutter moves. Then i set slider to 100 %-shutter moves to 100%.
If i set position to 1% shutter opens to 1 %.
If i set position to 0%- it means open- relay is not triggerd and the shutter stays closed.
EDIT:
i think command for 0% is wrong. mqtt
if state 0% is triggered from shelly web domoticz shows
right value 0% and status closed
U
EDIT:
U
lwolf
I see. Maybe i can bypass it somehow. If Command Set Level 0% arrives from Domoticz GUI, than the plugin can send:nabru99 wrote: Wednesday 02 January 2019 8:20 EDIT:
shellies/shellyswitch-<deviceid>/roller/0/command/pos
with payload: 0Code: Select all
with payload: open(0% means that blinder is fully opened?)
Or maybe i simply change incoming 0 to outgoing 1 percent in the mqtt payload. Ugly method.
nabru99
0% is fully opened
100% is fully closed
this can be changed - someone is using 100% for opened someone for closed.
100% command/slider is ok- it works open or close
0% command/slider IS NOT working open or close
ugly method i think is not ok- it will not show opened/closed
SET POSITION 100 %
2019-01-02 18:19:25.527 (Shelly) shellies/shellyswitch-134D85/roller/0/command/pos Set Level 100
2019-01-02 18:19:25.527 (Shelly) MqttClient::Publish shellies/shellyswitch-134D85/roller/0/command/pos (100)
2019-01-02 18:19:25.578 (Shelly) MQTT message: shellies/shellyswitch-134D85/roller/0/command/pos 100
2019-01-02 18:19:25.779 (Shelly) MQTT message: shellies/shellyswitch-134D85/roller/0 open
2019-01-02 18:19:25.893 (Shelly) MQTT message: shellies/shellyswitch-134D85/relay/power 14.55
2019-01-02 18:19:26.016 (Shelly) MQTT message: shellies/shellyswitch-134D85/relay/power 103.39
SET POSITION 1%
2019-01-02 18:21:05.217 (Shelly) shellies/shellyswitch-134D85/roller/0/command/pos Set Level 1
2019-01-02 18:21:05.217 (Shelly) MqttClient::Publish shellies/shellyswitch-134D85/roller/0/command/pos (1)
2019-01-02 18:21:05.267 (Shelly) MQTT message: shellies/shellyswitch-134D85/roller/0/command/pos 1
2019-01-02 18:21:05.468 (Shelly) MQTT message: shellies/shellyswitch-134D85/roller/0 close
2019-01-02 18:21:05.633 (Shelly) MQTT message: shellies/shellyswitch-134D85/relay/power 24.72
2019-01-02 18:21:05.694 (Shelly) MQTT message: shellies/shellyswitch-134D85/relay/power 119.11
SET POSITION 0%
NO MQTT MSG
how can i test?
SET POSITION 100 %
SET POSITION 1%
SET POSITION 0%
NO MQTT MSG
how can i test?
Last edited by nabru99 on Wednesday 02 January 2019 18:06, edited 1 time in total.
lwolf
Now i think i finally understood it: Blinds percentage from Domoticz will never send a 0% with Set Level.. it's sending an Off command instead.
I am playing a little with this device type, and tried again... i hope that the open and close commands are not swapped.
Updated on github.
nabru99
NOW 0 IS WORKINGlwolf wrote: Wednesday 02 January 2019 20:30Now i think i finally understood it: Blinds percentage from Domoticz will never send a 0% with Set Level.. it's sending an Off command instead.
Updated on github.
yes command are swapped
In this picture blind is closed and status is correct. CLOSED.
If OPEN in pressed now means OFF- should be ON
If CLOSE in pressed now means ON-should be OFF
U
lwolf
Finally, some progress.nabru99 wrote: Wednesday 02 January 2019 21:20 NOW 0 IS WORKING![]()
yes command are swapped![]()
U
I had a bad feeling about commands based on your test results, but do not quite understand why it is working reversely as the venetian blind... Updated on github.
nabru99
CLOSED -command is working
2019-01-03 07:13:04.515 (Shelly) MqttClient::Publish shellies/shellyswitch-134D85/roller/0/command (open)
2019-01-03 07:13:04.566 (Shelly) MQTT message: shellies/shellyswitch-134D85/roller/0/command open
2019-01-03 07:13:04.767 (Shelly) MQTT message: shellies/shellyswitch-134D85/roller/0 open
2019-01-03 07:13:04.886 (Shelly) MQTT message: shellies/shellyswitch-134D85/relay/power 26.02
2019-01-03 07:13:04.999 (Shelly) MQTT message: shellies/shellyswitch-134D85/relay/power 105.99
2019-01-03 07:13:07.065 (Shelly) MQTT message: shellies/shellyswitch-134D85/relay/power 71.78
2019-01-03 07:13:07.128 (Shelly) MQTT message: shellies/shellyswitch-134D85/roller/0/pos 100
2019-01-03 07:13:07.144 (Shelly) MQTT message: shellies/shellyswitch-134D85/relay/power 1.38
2019-01-03 07:13:07.160 (Shelly) MQTT message: shellies/shellyswitch-134D85/roller/0 stop
2019-01-03 07:13:07.373 (Shelly) MQTT message: shellies/shellyswitch-134D85/relay/power 0.0
OPEN- is not working- MQTT WRONG blind not opened
019-01-03 07:15:18.704 (Shelly) MqttClient::Publish shellies/shellyswitch-134D85/roller/0/command/pos (100) it should be command (close)
2019-01-03 07:15:18.755 (Shelly) MQTT message: shellies/shellyswitch-134D85/roller/0/command/pos 100
SLIDER 0-100% fully functional.
U
U
lwolf
Please set shelly plugin to Verbose debugging mode for a while, and describe the Command and Level(?) when issuing the Open command.nabru99 wrote: Thursday 03 January 2019 6:21 OPEN- is not working- MQTT WRONG blind not opened
With Domoticz v4.9701 i've got the following results with Verbose debugging:
1. Venetian Blind - "Open Blinds"
2019-01-03 20:15:05.672 (shelly) Command: Off (0) Color:
2019-01-03 20:15:05.672 (shelly) MqttClient::Publish shellies/shellyswitch-32BF87/roller/0/command (open)
2. Venetian Blind - "Stop Blinds"
2019-01-03 20:16:34.532 (shelly) Command: Stop (0) Color:
2019-01-03 20:16:34.532 (shelly) MqttClient::Publish shellies/shellyswitch-32BF87/roller/0/command (stop)
3. Venetian Blind - "Close Blinds"
2019-01-03 20:17:15.351 (shelly) Command: On (0) Color:
2019-01-03 20:17:15.351 (shelly) MqttClient::Publish shellies/shellyswitch-32BF87/roller/0/command (close)
4. Percentage Blind - "Open Blinds" (inverted??)
2019-01-03 20:18:22.085 (shelly) Command: Off (50) Color:
2019-01-03 20:18:22.085 (shelly) MqttClient::Publish shellies/shellyswitch-32BF87/roller/0/command (close)
5. Percentage Blind - "Close Blinds" (inverted??)
2019-01-03 20:19:04.968 (shelly) Command: On (50) Color:
2019-01-03 20:19:04.968 (shelly) MqttClient::Publish shellies/shellyswitch-32BF87/roller/0/command (open)
6. Percentage Blind - "0%"
2019-01-03 20:19:39.218 (shelly) Command: Off (0) Color:
2019-01-03 20:19:39.218 (shelly) shellies/shellyswitch-32BF87/roller/0/command/pos Off 0
2019-01-03 20:19:39.218 (shelly) MqttClient::Publish shellies/shellyswitch-32BF87/roller/0/command/pos (0)
7. Percentage Blind - "100%"
2019-01-03 20:20:30.686 (shelly) Command: Set Level (100) Color:
2019-01-03 20:20:30.686 (shelly) shellies/shellyswitch-32BF87/roller/0/command/pos Set Level 100
2019-01-03 20:20:30.686 (shelly) MqttClient::Publish shellies/shellyswitch-32BF87/roller/0/command/pos (100)
- Testing Shelly Blind devices
- shelly_sw.png (41.65 KiB) Viewed 5616 times
nabru99
DOMOTICZ version 4.9700 RPI
Blind is CLOSED
Settings SHELLY:
Status DOMOTICZ:
TEST:
1.)OPEN --NOT WORKING
2019-01-04 07:42:12.232 (Shelly) shellies/shellyswitch-134D85/roller/0/command/pos Off 100
2019-01-04 07:42:12.232 (Shelly) MqttClient::Publish shellies/shellyswitch-134D85/roller/0/command/pos (100)
2019-01-04 07:42:12.283 (Shelly) MQTT message: shellies/shellyswitch-134D85/roller/0/command/pos 100
2.) CLOSE WORKING
2019-01-04 07:44:01.863 (Shelly) MqttClient::Publish shellies/shellyswitch-134D85/roller/0/command (open)
2019-01-04 07:44:01.914 (Shelly) MQTT message: shellies/shellyswitch-134D85/roller/0/command open
2019-01-04 07:44:02.115 (Shelly) MQTT message: shellies/shellyswitch-134D85/roller/0 open
2019-01-04 07:44:02.230 (Shelly) MQTT message: shellies/shellyswitch-134D85/relay/power 9.98
2019-01-04 07:44:02.344 (Shelly) MQTT message: shellies/shellyswitch-134D85/relay/power 107.19
3.)SLIDER WORKING
2019-01-04 07:45:27.046 (Shelly) shellies/shellyswitch-134D85/roller/0/command/pos Set Level 85
2019-01-04 07:45:27.046 (Shelly) MqttClient::Publish shellies/shellyswitch-134D85/roller/0/command/pos (85)
2019-01-04 07:45:27.097 (Shelly) MQTT message: shellies/shellyswitch-134D85/roller/0/command/pos 85
2019-01-04 07:45:27.298 (Shelly) MQTT message: shellies/shellyswitch-134D85/roller/0 close
2019-01-04 07:45:27.412 (Shelly) MQTT message: shellies/shellyswitch-134D85/relay/power 11.49
2019-01-04 07:45:27.525 (Shelly) MQTT message: shellies/shellyswitch-134D85/relay/power 123.79
2019-01-04 07:45:29.841 (Shelly) MQTT message: shellies/shellyswitch-134D85/roller/0 stop
2019-01-04 07:45:29.905 (Shelly) MQTT message: shellies/shellyswitch-134D85/roller/0/pos 85
2019-01-04 07:45:29.970 (Shelly) MQTT message: shellies/shellyswitch-134D85/relay/power 100.21
2019-01-04 07:45:30.078 (Shelly) MQTT message: shellies/shellyswitch-134D85/relay/power 0.0
2019-01-04 07:45:40.704 (Shelly) MQTT message: shellies/shellyswitch-134D85/relay/power 1.02
2019-01-04 07:45:40.818 (Shelly) MQTT message: shellies/shellyswitch-134D85/relay/power 0.0
4.)VENETIAN OPEN WORKING BUT INVERTED
2019-01-04 07:46:49.163 (Shelly) MqttClient::Publish shellies/shellyswitch-134D85/roller/0/command (open)
2019-01-04 07:46:49.214 (Shelly) MQTT message: shellies/shellyswitch-134D85/roller/0/command open
2019-01-04 07:46:49.415 (Shelly) MQTT message: shellies/shellyswitch-134D85/roller/0 open
2019-01-04 07:46:49.580 (Shelly) MQTT message: shellies/shellyswitch-134D85/relay/power 21.37
2019-01-04 07:46:49.642 (Shelly) MQTT message: shellies/shellyswitch-134D85/relay/power 105.51
2019-01-04 07:46:52.060 (Shelly) MQTT message: shellies/shellyswitch-134D85/relay/power 97.82
2019-01-04 07:46:52.123 (Shelly) MQTT message: shellies/shellyswitch-134D85/roller/0/pos 100
2019-01-04 07:46:52.138 (Shelly) MQTT message: shellies/shellyswitch-134D85/relay/power 1.36
2019-01-04 07:46:52.153 (Shelly) MQTT message: shellies/shellyswitch-134D85/roller/0 stop
2019-01-04 07:46:52.367 (Shelly) MQTT message: shellies/shellyswitch-134D85/relay/power 0.0
5.) VENETIAN STOP WORKING
2019-01-04 07:48:27.213 (Shelly) MqttClient::Publish shellies/shellyswitch-134D85/roller/0/command (stop)
2019-01-04 07:48:27.264 (Shelly) MQTT message: shellies/shellyswitch-134D85/roller/0/command stop
2019-01-04 07:48:27.264 (Shelly) MQTT message: shellies/shellyswitch-134D85/roller/0/pos 29
2019-01-04 07:48:27.280 (Shelly) MQTT message: shellies/shellyswitch-134D85/roller/0 stop
2019-01-04 07:48:27.448 (Shelly) MQTT message: shellies/shellyswitch-134D85/relay/power 35.4
2019-01-04 07:48:27.510 (Shelly) MQTT message: shellies/shellyswitch-134D85/relay/power 0.0
6.) VENETIAN CLOSE WORKING BUT INVERTED
2019-01-04 07:48:14.751 (Shelly) MqttClient::Publish shellies/shellyswitch-134D85/roller/0/command (close)
2019-01-04 07:48:14.753 (Shelly) MQTT message: shellies/shellyswitch-134D85/roller/0/command close
2019-01-04 07:48:15.004 (Shelly) MQTT message: shellies/shellyswitch-134D85/roller/0 close
2019-01-04 07:48:15.220 (Shelly) MQTT message: shellies/shellyswitch-134D85/relay/power 119.33
Only command for OPEN is wrong in this case when Blinds percentage is used.
Blind is CLOSED
Settings SHELLY:
Status DOMOTICZ:
TEST:
2.) CLOSE WORKING
3.)SLIDER WORKING
lwolf
I see, posted code updates to github.nabru99 wrote: Friday 04 January 2019 8:18 Only command for OPEN is wrong in this case when Blinds percentage is used.
nabru99
is it possible to measure power usage as in tasmota with mqtt.
shelly is recognized as usage,electric
sonoff with tasmota fw as general,kwh
diffeence is in logging and data.
u
u
lwolf
I can modify the device type as you wish.nabru99 wrote: Monday 07 January 2019 16:28 is it possible to measure power usage as in tasmota with mqtt.
Shelly reports two values :
1. shellies/shellyswitch-<deviceid>/relay/power reports instantaneous power consumption rate in Watts
- I saw that "Usage" has a unit of Watt so it was a logical decision to add a Usage device.. what is the benefit of the "General" device type?
2. shellies/shellyswitch-<deviceid>/relay/energy reports amount of energy consumed in [10 * Wh]
- plugin creates a device with TypeName="kWh" so i do not see any problem. You can see yourself at https://github.com/enesbcs/Shelly_MQTT/ ... /plugin.py in line 179.
nabru99
this is difference:
you can leave that both devices are created..
GENERAL TASMOTA ______________________________ ______________ SHELLY2
GENERAL TASMOTA:
SHELLY2:
this is difference:
GENERAL TASMOTA:
SHELLY2:
lwolf
Interesting. But i have no idea, how to solve it.nabru99 wrote: Monday 07 January 2019 19:03 Hello,
this is difference:
https://github.com/enesbcs/Shelly_MQTT/issues/2
nabru99
Tasmota:
04:57:29 MQT: domoticz/in = {"idx":115,"nvalue":0,"svalue":"233;1144498.4","Battery":88,"RSSI":9}
04:57:29 MQT: tele/sonoff_RACK/SENSOR = {"Time":"2019-01-08T04:57:29","ENERGY":{"TotalStartTime":"2018-12-23T06:31:08","Total":1144.498,"Yesterday":5.811,"Today":1.214,"Period":4,"Power":233,"ApparentPower":259,"ReactivePower":112,"Factor":0.90,"Voltage":220,"Current":1.174}}
Domoticz:
2019-01-08 05:02:29.396 MQTT: Topic: domoticz/in, Message: {"idx":115,"nvalue":0,"svalue":"238;1144518.7","Battery":88,"RSSI":9}
lwolf
idx:115 is what kind of Device in Domoticz?nabru99 wrote: Tuesday 08 January 2019 5:04 Domoticz:
nabru99
i noticed that value is recived from device:
leby
- Domoticz version: 2020.2
Hi, @Iwolf I'm new to MQTT and how to set it up.
In point 4 you say "Set your MQTT server address and port to plugin settings" how do I know what that is, Localhost? port: 1883?
Thx/Leby
Thx/Leby
/lennart
lwolf
If you do not know your MQTT server address, then you do not have an MQTT server, so install one, for example mosquitto. Default port is 1883, yes, after installation.leby wrote: Sunday 20 January 2019 11:13 In point 4 you say "Set your MQTT server address and port to plugin settings" how do I know what that is, Localhost? port: 1883?
http://mosquitto.org/blog/2013/01/mosqu ... epository/
