Somfy Alarm Script not running
All kinds of 'OS' scripts
MikeyMan
Re: Somfy Alarm Script
Post by MikeyMan »
Well to be honest...
Nothing is really happening. The script ran something one time, for whathever reason.
Havent been able to get any response whatsoever after that.
The switches is a bug i guess in domoticz, where an empty switch keeps switching.
But i think i'll have to give up and stop bothering you. Wasting your time :)
Thanks for the support anyhow!
clumpton
Domoticz version: 2023.2
Re: Somfy Alarm Script not running
Post by clumpton »
Before we give up I have been taking a look at the code.
The "CarteAuthentification" variable is a lookup table for passcodes - is this something that is supplied with the alarm?
Just before your script fails it tries to contact the somfy server and gets an "Access Code" back (which looks like it can be A1 to A5 through to F1 to F5). The script then looks in the CarteAuthentification array and returns a 4 letter (or digit?) code which is then used to log in to the server.
The script is not getting back the access code prompt from the server so it is trying to read a member of the array indexed by blank - obviously this fails. (I told you that error checking was minimal).
The script is looking for a prompt of "authentification" on the login page - is this word there or is it some other text?
MikeyMan
Post by MikeyMan »
@clumpton; the lookup table is provided and has been adapted by me. It consists of numbers.
It can ineed be from A1 to F5.
10.0.0.112/gb/login.htm looks like this:
login page.png (374.63 KiB) Viewed 2194 times
Dont know if it helps, but this is the html:
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Strict//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-strict.dtd">
<html xmlns="http://www.w3.org/1999/xhtml" xml:lang="en" lang="en">
  <head>
    <meta http-equiv="content-type" content="text/html; charset=UTF-8" />
    <meta http-equiv="content-style-type" content="text/css" />
    <title>Central unit</title>
    <link rel="shortcut icon" href="/domis.ico" type="image/x-icon"/>
    <meta name="language" content="en" />
    <meta http-equiv="expires" content="0">
    <meta http-equiv="pragma" content="no-cache">
    <meta http-equiv="cache-control" content="no-cache, must-revalidate">
<link href="/domis_welcome.css" rel="stylesheet" type="text/css" /><style type="text/css">img{border:none;};#menu a{border-bottom:none;}</style></head><body><div id="page"><div id="fond"><div id="menu"><div class="logohmb">&nbsp;</div><div id="filler"></div></div><div id="titlebar"><div class="widetitlevoid">Welcome</div><div class="titlecorner"></div></div><div id="content"><div class="loginhouse">My Somfy alarm system</div><form id="form_id" method="post" action="login.htm"><table><col width="165px"><tr><td>Account</td><td><select name="login" class="skinnedselectinput"> <option value="u">User1 </option><option value="i">Installer </option><option value="t">Remote mon. </option></select></td></tr><tr><td>Access code</td><td><input type="password" name="password" value="" class="skinnedtextinput" maxlength="12" size="16"/></td></tr><tr><td>Authentication code <b>B1</b></td><td><input type="password" name="key" value="" class="skinnedtextinput" maxlength="6" size="16"/></td></tr></table><div id="content_footer"><input type="submit" name="btn_login" value="Login" class="arrowdark"/></div></form></div>        <!--content -->
        <div id="spacer">
          <!--[if IE]>&nbsp;
          <![endif]-->
        </div>
        <div id="menu_footerflag">
Select language:<br><br>
<a href="/gb/login.htm"><img src="/img/gb.gif" alt="gb"/></a>&nbsp;&nbsp;&nbsp;
<a href="/fr/login.htm"><img src="/img/fr.gif" alt="fr"/></a>&nbsp;&nbsp;&nbsp;
<a href="/nl/login.htm"><img src="/img/nl.gif" alt="nl"/></a><br>
<a href="/it/login.htm"><img src="/img/it.gif" alt="it"/></a>&nbsp;&nbsp;&nbsp;
<a href="/de/login.htm"><img src="/img/de.gif" alt="de"/></a>&nbsp;&nbsp;&nbsp;
<a href="/sp/login.htm"><img src="/img/sp.gif" alt="sp"/></a><br>
          Copyright &copy;2013 Somfy
        </div>
      </div>
      <!-- fond -->
    </div>
    <!-- page -->
  </body>
  </html>
clumpton
Post by clumpton »
OK, so it's not picking up the "B1", mainly because it's looking for "Code d'authentification" rather than "Authentication code".
So you can replace this bit of code:
# Ophalen toegangscode
	if [ "$Debug" = "True" ]; then
		echo " Toegangscode ophalen"
		CodeAcces="$(curl $SrvSomfyIp $UrlLogin | grep -Eoi 'authentification <b>.*</b>')"
		CodeAcces="$(echo "${CodeAcces:20:2}")"
		echo " Code d'accès = "$CodeAcces
		CodeAcces="$(curl -s $SrvSomfyIp $UrlLogin | grep -Eoi 'authentification <b>.*</b>')"
	fi
by:
# Get access code
		echo " Retrieving access code""
		CodeAcces="$(curl $SrvSomfyIp $UrlLogin | grep -Eoi 'code <b>.*</b>')"
		CodeAcces="$(echo "${CodeAcces:9:2}")"
		echo " Access code = "$CodeAcces
		CodeAcces="$(curl -s $SrvSomfyIp $UrlLogin | grep -Eoi 'code <b>.*</b>')"
	fi
It should echo the access code reference (A1, B5 etc.).
MikeyMan
Post by MikeyMan »
Haha, really? The code is actually searching the screen for a term?
So a translation issue... I'll crack on it tomorrow.
Again, much appreciated!
MikeyMan
Post by MikeyMan »
Well, at least there is some response now:
pi@raspberrypi:~/domoticz/scripts $ sudo ./somfy.sh
Starting script in file: ./somfy.sh
./somfy.sh: line 856: syntax error: unexpected end of file
No code echo by the way
code looks like this now:
#!/bin/bash
echo "Starting script in file: "$0
# Script alarme_Somfy.sh
# Date : 11/2016
# Version : 2.0
# Par : jcjames_13009 <jcjames_13009 at yahoo.fr>
# Description : Script de pilotage de l'alarme Somfy Protexiom 5000 via Domoticz sur Raspberry Pi
# - Adapatation du script de Seb13 du forum easydomoticz.com pour Alarme Somfy Protexion 600 au modèle Protexion 5000
#   * Lecture des états du système et mise à jour dans Domoticz
#   * Mise en marche de l'alarme Zone A
#   * Mise en marche de l'alarme Zone B
#   * Mise en marche de l'alarme Zone C
#   * Mise en marche de l'alarme Zones A B C
#   * Arret de l'alarme Zones A B C
#   * Reset defauts piles, liaisons et alarmes
#	* Gestion liste des Elements et mise à jour dans Domoticz
# Appel du script
# - Mise à jour des états de l'alarme toutes les 15min via le crontab :
#   */15 * * * * sudo /home/pi/domoticz/scripts/somfy.sh --Status
# - Pilotage de l'alarme à partir de DOMOTICZ :
#   Ex pour la mise en marche Zone A ajouter dans l'onglet "Action On" du capteur virtuel:
#   script:///home/pi/domoticz/scripts/somfy.sh --ZoneAOn
# Version : 2.1
# Date : 25/11/2016
# - Ajout d'un "sleep 1" pour éviter les pertes de retour d'état de l'alarme entre chaque cde dans la lecture de l'état
#	du système et de la liste des Elements
# Version : 2.2
# Date : 27/11/2016
# - Ajout cde reset defauts piles, liaisons et alarmes
# Version : 2.3
# Date : 10/12/2016
# - Gestion liste des Elements et mise à jour dans Domoticz
# Version : 2.4
# Date : 04/01/2017
# - Envoie d'une seule commande pour éviter les pertes de retour d'état de l'alarme entre chaque cde dans la lecture de
#	l'état du système et de la liste des Elements
# Version 2.5
# Date : 21/12/2017
# - Adaptation du script à Domoticz sur NAS Synology
#   Remplacement de iconv qui n'existe pas sur Synology par uconv
Debug=True
#Debug=False
# PARAMETRES ALARME
# Carte d'authentification perso
declare -A CarteAuthentification
CarteAuthentification=( 	["A1"]="7092" ["B1"]="2220" ["C1"]="4790" ["D1"]="5830" ["E1"]="0920" ["F1"]="0912"
				["A2"]="7402" ["B2"]="5242" ["C2"]="2044" ["D2"]="5284" ["E2"]="4478" ["F2"]="8110"
				["A3"]="2992" ["B3"]="9928" ["C3"]="9394" ["D3"]="9250" ["E3"]="7988" ["F3"]="4348"
				["A4"]="3830" ["B4"]="5174" ["C4"]="9560" ["D4"]="8672" ["E4"]="0090" ["F4"]="0698"
				["A5"]="3004" ["B5"]="1332" ["C5"]="5390" ["D5"]="7870" ["E5"]="0848" ["F5"]="3528" )
# Adresse IP alarme Somfy
SrvSomfyIp="http://10.0.0.112/"
# Code Utilisateur1
CodeUtilisateur1=9859
# URLs alarme SOMFY PROTEXION 5000 GSM
UrlLogin=$SrvSomfyIp"gb/login.htm"			# Connect
UrlLogout=$SrvSomfyIp"logout.htm"			# Log out
UrlEtat=$SrvSomfyIp"status.xml"				# Status
UrlPilotage=$SrvSomfyIp"gb/u_pilotage.htm"		# Control of alarm and automatic devices
UrlElements=$SrvSomfyIp"gb/u_listelmt.htm"		# List of system devices
# PARAMETRES DOMOTICZ
# ID's Domoticz
AlarmeSomfyPilesIdx=18  	#Batteries
AlarmeSomfyRadioIdx=19		#Radio link
AlarmeSomfyPorteIdx=20		#Door
AlarmeSomfyAlarmeIdx=21		#Alarm
AlarmeSomfyBoitierIdx=22	#Status
AlarmeSomfyGSMIdx=26		#GSM
AlarmeSomfySignalGSMIdx=24	#Signal
AlarmeSomfyOperateurGSMIdx=25	#Provider
#AlarmeSomfyCameraIdx=xxx	#Camera
AlarmeSomfyZoneAIdx=15		#Zone A
AlarmeSomfyZoneBIdx=16		#Zone B
AlarmeSomfyZoneCIdx=17		#Zone C
#AlarmeSomfyDOEntreeIdx=xxx
#AlarmeSomfyDOAtelierIdx=xxx
# Domoticz IP Address
SrvDomoticzIp="10.0.0.30:8080"
# Functions
# Function Help Menu
Aide() {
	echo -e "\tScript Domoticz Alarme Somfy Protexion 5000"
	echo -e "\t--help or -h  \t\tMenu d'aide"
	echo -e "\t--Status      \t\tLecture de l'état du système"
	echo -e "\t--Elements    \t\tListe des Elements"
	echo -e "\t--ZoneAOn     \t\tMise en marche de l'alarme Zone A"
	echo -e "\t--ZoneBOn     \t\tMise en marche de l'alarme Zone B"
	echo -e "\t--ZoneCOn     \t\tMise en marche de l'alarme Zone C"
	echo -e "\t--ZonesABCOn  \t\tMise en marche de l'alarme Zones A B C"
	echo -e "\t--AlarmeOff   \t\tArret de l'alarme Zones A B C"
	echo -e "\t--RSTPiles    \t\tReset defauts piles"
	echo -e "\t--RSTAlarmes  \t\tReset defauts alarmes"
	echo -e "\t--RSTLiaisons \t\tReset defauts liaisons"
# Function Alarm Connection
login_alarme () {
	# Affichage des URLs
		echo " ********************************* "
		echo " Liste des URLs"
		echo " UrlLogin    = "$UrlLogin
		echo " UrlLogout   = "$UrlLogout
		echo " UrlEtat     = "$UrlEtat
		echo " UrlPilotage = "$UrlPilotage
		echo " UrlElements = "$UrlElements
	fi
	# Get access code
	fi
	# Get access code from table
	CodeAuthentification="${CarteAuthentification["$CodeAcces"]}"
		echo " Ophalen Authentificatiecode"
		echo " Authenticatiecode = "$CodeAuthentification
	fi
	# De user1-code en de authenticatiecode verzenden in de aanmeldings-URL voor Inloggen
		echo " Gebruiker1-code en verificatiecode verzenden"
		curl -L --cookie cjar --cookie-jar cjar --data "password="$CodeUtilisateur1"&key="$CodeAuthentification"&btn_login=Connexion" $UrlLogin | iconv -f iso8859-1 -t utf-8
		#curl -L --cookie cjar --cookie-jar cjar --data "password="$CodeUtilisateur1"&key="$CodeAuthentification"&btn_login=Connexion" $UrlLogin | uconv -f iso8859-1 -t utf-8
		curl -s -L --cookie cjar --cookie-jar cjar --data "password="$CodeUtilisateur1"&key="$CodeAuthentification"&btn_login=Connexion" $UrlLogin  | iconv -f iso8859-1 -t utf-8 > /dev/null
		#curl -s -L --cookie cjar --cookie-jar cjar --data "password="$CodeUtilisateur1"&key="$CodeAuthentification"&btn_login=Connexion" $UrlLogin  | uconv -f iso8859-1 -t utf-8 > /dev/null
	fi
# Functie verbinden met Alarm
logout_alarme () {
		echo " Verbinden met alarm"
		curl -L --cookie cjar --cookie-jar cjar $UrlLogout | iconv -f iso8859-1 -t utf-8
		#curl -L --cookie cjar --cookie-jar cjar $UrlLogout | uconv -f iso8859-1 -t utf-8
		curl -s -L --cookie cjar --cookie-jar cjar $UrlLogout | iconv -f iso8859-1 -t utf-8 > /dev/null
		#curl -s -L --cookie cjar --cookie-jar cjar $UrlLogout | uconv -f iso8859-1 -t utf-8 > /dev/null
	fi
# Functie update Domoticz sensoren
# Parameters: $1 Sensornaam / $2 On / Off / $3 Idx sensor
maj_capteur () {
		echo " Staat "$1
		if [ "$2" = "On" ]; then
			curl "http://$SrvDomoticzIp/json.htm?type=command&param=switchlight&idx=$3&switchcmd=On"
			curl "http://$SrvDomoticzIp/json.htm?type=command&param=switchlight&idx=$3&switchcmd=Off"
		fi
			curl -s "http://$SrvDomoticzIp/json.htm?type=command&param=switchlight&idx=$3&switchcmd=On" > /dev/null
			curl -s "http://$SrvDomoticzIp/json.htm?type=command&param=switchlight&idx=$3&switchcmd=Off" > /dev/null
		fi
	fi
# Menu des options de lancement du script
while [[ $1 == -* ]]; do
	case "$1" in
		--help|-h) Aide; exit 0;;
		--Status) Status="1"; break;;
		--Elements) Elements="1"; break;;
		--ZoneAOn) ZoneAOn="1"; break;;
		--ZoneBOn) ZoneBOn="1"; break;;
		--ZoneCOn) ZoneCOn="1"; break;;
		--ZonesABCOn) ZonesABCOn="1"; break;;
		--AlarmeOff) AlarmeOff="1"; break;;
		--RSTPiles) RSTPiles="1"; break;;
		--RSTAlarmes) RSTAlarmes="1"; break;;
		--RSTLiaisons) RSTLiaisons="1"; break;;
		--*|-*) shift; break;;
	esac
done
# Lecture de l'état du système
if [ "$Status" = "1" ]; then
	# Connexion à l'alarme
	login_alarme
	# Lecture de l'état du système et récupération dans les variables
	# Envoie URL http://IPAlarme/status.xml
	# Retour:
	#	<zone0>off</zone0>					-> Zone A
	#	<zone1>off</zone1>					-> Zone B
	#	<zone2>off</zone2>					-> Zone C
	#	<defaut0>ok</defaut0>				-> Piles
	#	<defaut1>ok</defaut1>				-> Radio
	#	<defaut2>ok</defaut2>				-> Porte/Fenêtre
	#	<defaut3>ok</defaut3>				-> Alarme
	#	<defaut4>ok</defaut4>				-> Boitier
	#	<gsm>GSM connecté au réseau</gsm> 	-> GSM
	#	<recgsm>4</recgsm>					-> Signal GSM
	#	<opegsm>"Orange</opegsm>			-> Opérateur GSM
	#	<camera>disabled</camera>			-> Caméra
	# Lecture de l'état du système et stockage dans fichier temporaire
		echo " Lecture de l'état du système"
		curl -L --cookie cjar --cookie-jar cjar $UrlEtat | iconv -f iso8859-1 -t utf-8 > status
		#curl -L --cookie cjar --cookie-jar cjar $UrlEtat | uconv -f iso8859-1 -t utf-8 > status
		curl -s -L --cookie cjar --cookie-jar cjar $UrlEtat | iconv -f iso8859-1 -t utf-8 > status
		#curl -s -L --cookie cjar --cookie-jar cjar $UrlEtat | uconv -f iso8859-1 -t utf-8 > status
	fi
	# Deconnexion de l'alarme
	logout_alarme
	# Récupération dans les variables
	EtatZoneA="$(grep -Eoi '<zone0>.*' status)"
	EtatZoneA="$(echo "${EtatZoneA:7:-9}")"
	EtatZoneB="$(grep -Eoi '<zone1>.*' status)"
	EtatZoneB="$(echo "${EtatZoneB:7:-9}")"
	EtatZoneC="$(grep -Eoi '<zone2>.*' status)"
	EtatZoneC="$(echo "${EtatZoneC:7:-9}")"
	EtatPiles="$(grep -Eoi '<defaut0>.*' status)"
	EtatPiles="$(echo "${EtatPiles:9:-11}")"
	EtatRadio="$(grep -Eoi '<defaut1>.*' status)"
	EtatRadio="$(echo "${EtatRadio:9:-11}")"
	EtatPorte="$(grep -Eoi '<defaut2>.*' status)"
	EtatPorte="$(echo "${EtatPorte:9:-11}")"
	EtatAlarme="$(grep -Eoi '<defaut3>.*' status)"
	EtatAlarme="$(echo "${EtatAlarme:9:-11}")"
	EtatBoitier="$(grep -Eoi '<defaut4>.*' status)"
	EtatBoitier="$(echo "${EtatBoitier:9:-11}")"
	EtatGSM="$(grep -Eoi '<gsm>.*' status)"
	EtatGSM="$(echo "${EtatGSM:5:-7}")"
	SignalGSM="$(grep -Eoi '<recgsm>.*' status)"
	SignalGSM="$(echo "${SignalGSM:8:-10}")"
	OperateurGSM="$(grep -Eoi '<opegsm>.*' status)"
	OperateurGSM="$(echo "${OperateurGSM:9:-10}")"
	EtatCamera="$(grep -Eoi '<camera>.*' status)"
	EtatCamera="$(echo "${EtatCamera:8:-10}")"
		# Statusoverzicht
		echo " ******************************************* "
		echo "  Status van het systeem"
		echo " Zone A                   = "$EtatZoneA
		echo " Zone B                   = "$EtatZoneB
		echo " Zone C                   = "$EtatZoneC
		echo ""
		echo " Status Batterijen	= "$EtatPiles
		echo " Status communicatie 	= "$EtatRadio
		echo " Status Ramen/Deuren	= "$EtatPorte
		echo " Status Alarm		= "$EtatAlarme
		echo " Status Behuizing		= "$EtatBoitier
		echo ""
		echo " Status GSM      	        = "$EtatGSM
		echo " Signal GSM               = "$SignalGSM
		echo " GSM Provider		= "$OperateurGSM
		echo ""
		echo " Status Camera		= "$EtatCamera
	fi
	# Mise à jour capteurs Domoticz
		echo " Mise à jour capteurs Domoticz"
	fi
	# Zone A
	if [ "$EtatZoneA" = "off" ]; then
		maj_capteur ZoneA Off $AlarmeSomfyZoneAIdx
		maj_capteur ZoneA On $AlarmeSomfyZoneAIdx
	fi
	# Zone B
	if [ "$EtatZoneB" = "off" ]; then
		maj_capteur ZoneB Off $AlarmeSomfyZoneBIdx
		maj_capteur ZoneB On $AlarmeSomfyZoneBIdx
	fi
	# Zone C
	if [ "$EtatZoneC" = "off" ]; then
		maj_capteur ZoneC Off $AlarmeSomfyZoneCIdx
		maj_capteur ZoneC On $AlarmeSomfyZoneCIdx
	fi
	# Status Batterijen
	if [ "$EtatPiles" = "ok" ]; then
		maj_capteur Piles On $AlarmeSomfyPilesIdx
		maj_capteur Piles Off $AlarmeSomfyPilesIdx
	fi
	# Status Communicatie
	if [ "$EtatRadio" = "ok" ]; then
		maj_capteur Radio On $AlarmeSomfyRadioIdx
		maj_capteur Radio Off $AlarmeSomfyRadioIdx
	fi
	# Status Ramen/Deuren
	if [ "$EtatPorte" = "ok" ]; then
		maj_capteur Porte/Fenetre Off $AlarmeSomfyPorteIdx
		maj_capteur Porte/Fenetre On $AlarmeSomfyPorteIdx
	fi
	# Status Alarm
	if [ "$EtatAlarme" = "ok" ]; then
		maj_capteur Alarme Off $AlarmeSomfyAlarmeIdx
		maj_capteur Alarme On $AlarmeSomfyAlarmeIdx
	fi
	# Status Behuizing
	if [ "$EtatBoitier" = "ok" ]; then
		maj_capteur Boitier Off $AlarmeSomfyBoitierIdx
		maj_capteur Boitier On $AlarmeSomfyBoitierIdx
	fi
	# Status GSM
	if [ "$EtatGSM" = "GSM connecté au réseau" ]; then
		maj_capteur GSM On $AlarmeSomfyGSMIdx
		maj_capteur GSM Off $AlarmeSomfyGSMIdx
	fi
	# GSM Signaal
		echo " Niveau Signal GSM"
		curl "http://$SrvDomoticzIp/json.htm?type=command&param=udevice&idx=$AlarmeSomfySignalGSMIdx&nvalue=0&svalue=$SignalGSM"
		curl -s "http://$SrvDomoticzIp/json.htm?type=command&param=udevice&idx=$AlarmeSomfySignalGSMIdx&nvalue=0&svalue=$SignalGSM" > /dev/null
	fi
	# GSM Provider
		echo " Opérateur GSM"
		curl "http://$SrvDomoticzIp/json.htm?type=command&param=udevice&idx=$AlarmeSomfyOperateurGSMIdx&nvalue=0&svalue=$OperateurGSM"
		curl -s "http://$SrvDomoticzIp/json.htm?type=command&param=udevice&idx=$AlarmeSomfyOperateurGSMIdx&nvalue=0&svalue=$OperateurGSM" > /dev/null
	fi
	# Camera
	#if [ "$EtatCamera" = "disabled" ]; then
	#	maj_capteur Camera Off $AlarmeSomfyCameraIdx
	#else
	#	maj_capteur Camera On $AlarmeSomfyCameraIdx
	#fi
fi
# Mise en marche de l'alarme Zones A B C
if [ "$ZonesABCOn" = "1" ]; then
	login_alarme
		echo "Mise en marche de l'alarme Zones A B C"
		curl -L --cookie cjar --cookie-jar cjar --data "hidden=hidden&hidden=hidden&btn_zone_on_ABC=Marche A B C" $UrlPilotage | iconv -f iso8859-1 -t utf-8
		#curl -L --cookie cjar --cookie-jar cjar --data "hidden=hidden&hidden=hidden&btn_zone_on_ABC=Marche A B C" $UrlPilotage | uconv -f iso8859-1 -t utf-8
		curl -s -L --cookie cjar --cookie-jar cjar --data "hidden=hidden&hidden=hidden&btn_zone_on_ABC=Marche A B C" $UrlPilotage | iconv -f iso8859-1 -t utf-8 > /dev/null
		#curl -s -L --cookie cjar --cookie-jar cjar --data "hidden=hidden&hidden=hidden&btn_zone_on_ABC=Marche A B C" $UrlPilotage | uconv -f iso8859-1 -t utf-8 > /dev/null
	fi
	logout_alarme
	fi
fi
# Mise en marche de l'alarme Zone A
if [ "$ZoneAOn" = "1" ]; then
	login_alarme
		echo "Mise en marche de l'alarme Zone A"
		curl -L --cookie cjar --cookie-jar cjar --data "hidden=hidden&hidden=hidden&btn_zone_on_A=Marche A" $UrlPilotage | iconv -f iso8859-1 -t utf-8
		#curl -L --cookie cjar --cookie-jar cjar --data "hidden=hidden&hidden=hidden&btn_zone_on_A=Marche A" $UrlPilotage | uconv -f iso8859-1 -t utf-8
		curl -s -L --cookie cjar --cookie-jar cjar --data "hidden=hidden&hidden=hidden&btn_zone_on_A=Marche A" $UrlPilotage | iconv -f iso8859-1 -t utf-8 > /dev/null
		#curl -s -L --cookie cjar --cookie-jar cjar --data "hidden=hidden&hidden=hidden&btn_zone_on_A=Marche A" $UrlPilotage | uconv -f iso8859-1 -t utf-8 > /dev/null
	fi
	logout_alarme
	fi
fi
# Mise en marche de l'alarme Zone B
if [ "$ZoneBOn" = "1" ]; then
	login_alarme
		echo "Mise en marche de l'alarme Zone B"
		curl -L --cookie cjar --cookie-jar cjar --data "hidden=hidden&hidden=hidden&btn_zone_on_B=Marche B" $UrlPilotage | iconv -f iso8859-1 -t utf-8
		#curl -L --cookie cjar --cookie-jar cjar --data "hidden=hidden&hidden=hidden&btn_zone_on_B=Marche B" $UrlPilotage | uconv -f iso8859-1 -t utf-8
		curl -s -L --cookie cjar --cookie-jar cjar --data "hidden=hidden&hidden=hidden&btn_zone_on_B=Marche B" $UrlPilotage | iconv -f iso8859-1 -t utf-8 > /dev/null
		#curl -s -L --cookie cjar --cookie-jar cjar --data "hidden=hidden&hidden=hidden&btn_zone_on_B=Marche B" $UrlPilotage | uconv -f iso8859-1 -t utf-8 > /dev/null
	fi
	logout_alarme
	fi
fi
# Mise en marche de l'alarme Zone C
if [ "$ZoneCOn" = "1" ]; then
	login_alarme
		echo "Mise en marche de l'alarme Zone C"
		curl -L --cookie cjar --cookie-jar cjar --data "hidden=hidden&hidden=hidden&btn_zone_on_C=Marche C" $UrlPilotage | iconv -f iso8859-1 -t utf-8
		#curl -L --cookie cjar --cookie-jar cjar --data "hidden=hidden&hidden=hidden&btn_zone_on_C=Marche C" $UrlPilotage | uconv -f iso8859-1 -t utf-8
		curl -s -L --cookie cjar --cookie-jar cjar --data "hidden=hidden&hidden=hidden&btn_zone_on_C=Marche C" $UrlPilotage | iconv -f iso8859-1 -t utf-8 > /dev/null
		#curl -s -L --cookie cjar --cookie-jar cjar --data "hidden=hidden&hidden=hidden&btn_zone_on_C=Marche C" $UrlPilotage | uconv -f iso8859-1 -t utf-8 > /dev/null
	fi
	logout_alarme
	fi
fi
# Arret de l'alarme Zones A B C
if [ "$AlarmeOff" = "1" ]; then
	login_alarme
		echo "Arret de l'alarme Zones A B C"
		curl -L --cookie cjar --cookie-jar cjar --data "hidden=hidden&btn_zone_off_ABC=Arret A B C" $UrlPilotage | iconv -f iso8859-1 -t utf-8
		#curl -L --cookie cjar --cookie-jar cjar --data "hidden=hidden&btn_zone_off_ABC=Arret A B C" $UrlPilotage | uconv -f iso8859-1 -t utf-8
		curl -s -L --cookie cjar --cookie-jar cjar --data "hidden=hidden&btn_zone_off_ABC=Arret A B C" $UrlPilotage | iconv -f iso8859-1 -t utf-8 > /dev/null
		#curl -s -L --cookie cjar --cookie-jar cjar --data "hidden=hidden&btn_zone_off_ABC=Arret A B C" $UrlPilotage | uconv -f iso8859-1 -t utf-8 > /dev/null
	fi
	logout_alarme
	fi
fi
# Reset defauts piles
if [ "$RSTPiles" = "1" ]; then
	login_alarme
		echo "Reset defauts piles"
		curl -L --cookie cjar --cookie-jar cjar --data "btn_del_pil=Piles" $UrlElements | iconv -f iso8859-1 -t utf-8
		#curl -L --cookie cjar --cookie-jar cjar --data "btn_del_pil=Piles" $UrlElements | uconv -f iso8859-1 -t utf-8
		curl -s -L --cookie cjar --cookie-jar cjar --data "btn_del_pil=Piles" $UrlElements | iconv -f iso8859-1 -t utf-8 > /dev/null
		#curl -s -L --cookie cjar --cookie-jar cjar --data "btn_del_pil=Piles" $UrlElements | uconv -f iso8859-1 -t utf-8 > /dev/null
	fi
	logout_alarme
fi
# Reset defauts alarmes
if [ "$RSTAlarmes" = "1" ]; then
	login_alarme
		echo "Reset defauts alarmes"
		curl -L --cookie cjar --cookie-jar cjar --data "btn_del_alm=Alarmes" $UrlElements | iconv -f iso8859-1 -t utf-8
		#curl -L --cookie cjar --cookie-jar cjar --data "btn_del_alm=Alarmes" $UrlElements | uconv -f iso8859-1 -t utf-8
		curl -s -L --cookie cjar --cookie-jar cjar --data "btn_del_alm=Alarmes" $UrlElements | iconv -f iso8859-1 -t utf-8 > /dev/null
		#curl -s -L --cookie cjar --cookie-jar cjar --data "btn_del_alm=Alarmes" $UrlElements | uconv -f iso8859-1 -t utf-8 > /dev/null
	fi
	logout_alarme
fi
# Reset defauts liaisons
if [ "$RSTLiaisons" = "1" ]; then
	login_alarme
		echo "Reset defauts liaisons"
		curl -L --cookie cjar --cookie-jar cjar --data "btn_del_lia=Liaisons" $UrlElements | iconv -f iso8859-1 -t utf-8
		#curl -L --cookie cjar --cookie-jar cjar --data "btn_del_lia=Liaisons" $UrlElements | uconv -f iso8859-1 -t utf-8
		curl -s -L --cookie cjar --cookie-jar cjar --data "btn_del_lia=Liaisons" $UrlElements | iconv -f iso8859-1 -t utf-8 > /dev/null
		#curl -s -L --cookie cjar --cookie-jar cjar --data "btn_del_lia=Liaisons" $UrlElements | uconv -f iso8859-1 -t utf-8 > /dev/null
	fi
	logout_alarme
fi
# Gestion de la liste des Elements
if [ "$Elements" = "1" ]; then
	login_alarme
	# Lecture de la liste des Elements et stockage dans fichier temporaire
		echo "Gestion liste des Elements"
		curl -L --cookie cjar --cookie-jar cjar $UrlElements | iconv -f iso8859-1 -t utf-8 > elements
		#curl -L --cookie cjar --cookie-jar cjar $UrlElements | uconv -f iso8859-1 -t utf-8 > elements
		curl -s -L --cookie cjar --cookie-jar cjar $UrlElements | iconv -f iso8859-1 -t utf-8 > elements
		#curl -s -L --cookie cjar --cookie-jar cjar $UrlElements | uconv -f iso8859-1 -t utf-8 > elements
	fi
	logout_alarme
	TypeElements="$(grep -Eoi 'var item_label.*' elements)"
	NomElements="$(grep -Eoi 'var elt_name.*' elements)"
	EtatElements="$(grep -Eoi 'var item_pause.*' elements)"
	EtatPiles="$(grep -Eoi 'var elt_pile.*' elements)"
	EtatLiaison="$(grep -Eoi 'var elt_onde.*' elements)"
	EtatPortes="$(grep -Eoi 'var elt_porte.*' elements)"
	EtatBoitiers="$(grep -Eoi 'var elt_as.*' elements)"
	EtatAlarme="$(grep -Eoi 'var elt_maison.*' elements)"
	# Affichage des Elements
		echo " Type des Elements"
		echo $TypeElements
		echo " Nom des Elements"
		echo $NomElements
		echo " Etat des Elements"
		echo $EtatElements
		echo " Etat des piles"
		echo $EtatPiles
		echo " Etat liaison radio"
		echo $EtatLiaison
		echo " Etat détecteurs ouverture"
		echo $EtatPortes
		echo " Etat ouverture boitiers"
		echo $EtatBoitiers
		echo " Etat alarme"
		echo $EtatAlarme
	fi
	# Formatage du type des Elements
	# Suppression des 21 1er caractères et 2 derniers
	TypeElements="$(echo "${TypeElements:21:-2}")"
	# Suppression des "
	TypeElements="$(echo "$TypeElements" | sed s/\"//g)"
	# Suppression des espaces entre les ,
	TypeElements="$(echo "$TypeElements" | sed s/\,\ /\,/g)"
	# Déclaration , comme séparateur
	IFS=","
	# Stockage dans le tableau
	TabTypeElements=($TypeElements)
	# Formatage des noms des Elements
	NomElements="$(echo "${NomElements:21:-2}")"
	# Suppression des "
	NomElements="$(echo "$NomElements" | sed s/\"//g)"
	NomElements="$(echo "$NomElements" | sed s/\,\ /\,/g)"
	IFS=","
	TabNomElements=($NomElements)
	# Formatage état des Elements
	EtatElements="$(echo "${EtatElements:21:-2}")"
	# Suppression des "
	EtatElements="$(echo "$EtatElements" | sed s/\"//g)"
	EtatElements="$(echo "$EtatElements" | sed s/\,\ /\,/g)"
	IFS=","
	TabEtatElements=($EtatElements)
	# Modification valeurs tableau
	TailleTab=${#TabEtatElements[@]}
	for (( i=0; i<$TailleTab; i++ ))
	do
		if [ ${TabEtatElements["$i"]} = "running" ]; then TabEtatElements["$i"]="Activé"
			TabEtatElements["$i"]="Désactivé"
		fi
	done
	# Formatage état des piles
	EtatPiles="$(echo "${EtatPiles:21:-2}")"
	# Suppression des "
	EtatPiles="$(echo "$EtatPiles" | sed s/\"//g)"
	EtatPiles="$(echo "$EtatPiles" | sed s/\,\ /\,/g)"
	IFS=","
	TabEtatPiles=($EtatPiles)
	# Modification des valeurs du tableau
	TailleTab=${#TabEtatPiles[@]}
	do
		if [ ${TabEtatPiles["$i"]} = "itemhidden" ]; then TabEtatPiles["$i"]="NA"
			if [ ${TabEtatPiles["$i"]} = "itembattok" ]; then TabEtatPiles["$i"]="OK"
				TabEtatPiles["$i"]="NOK"
			fi
		fi
	done
	# Formatage état liaison radio
	EtatLiaison="$(echo "${EtatLiaison:21:-2}")"
	# Suppression des "
	EtatLiaison="$(echo "$EtatLiaison" | sed s/\"//g)"
	EtatLiaison="$(echo "$EtatLiaison" | sed s/\,\ /\,/g)"
	IFS=","
	TabEtatLiaison=($EtatLiaison)
	TailleTab=${#TabEtatLiaison[@]}
	do
		if [ ${TabEtatLiaison["$i"]} = "itemhidden" ]; then TabEtatLiaison["$i"]="NA"
			if [ ${TabEtatLiaison["$i"]} = "itemcomok" ]; then TabEtatLiaison["$i"]="OK"
				TabEtatLiaison["$i"]="NOK"
			fi
		fi
	done
	# Récup état détecteurs ouverture
	EtatPortes="$(echo "${EtatPortes:21:-2}")"
	# Suppression des "
	EtatPortes="$(echo "$EtatPortes" | sed s/\"//g)"
	EtatPortes="$(echo "$EtatPortes" | sed s/\,\ /\,/g)"
	IFS=","
	TabEtatPortes=($EtatPortes)
	TailleTab=${#TabEtatPortes[@]}
	do
		if [ ${TabEtatPortes["$i"]} = "itemhidden" ]; then TabEtatPortes["$i"]="NA"
			if [ ${TabEtatPortes["$i"]} = "itemdoorok" ]; then TabEtatPortes["$i"]="Fermée"
				TabEtatPortes["$i"]="Ouverte"
			fi
		fi
	done
	# Récup état ouverture boitiers
	EtatBoitiers="$(echo "${EtatBoitiers:21:-2}")"
	# Suppression des "
	EtatBoitiers="$(echo "$EtatBoitiers" | sed s/\"//g)"
	EtatBoitiers="$(echo "$EtatBoitiers" | sed s/\,\ /\,/g)"
	IFS=","
	TabEtatBoitiers=($EtatBoitiers)
	TailleTab=${#TabEtatBoitiers[@]}
	do
		if [ ${TabEtatBoitiers["$i"]} = "itemhidden" ]; then TabEtatBoitiers["$i"]="NA"
			if [ ${TabEtatBoitiers["$i"]} = "itemboxok" ]; then TabEtatBoitiers["$i"]="Fermé"
				TabEtatBoitiers["$i"]="Ouvert"
			fi
		fi
	done
	# Récup état alarme
	EtatAlarme="$(echo "${EtatAlarme:21:-2}")"
	# Suppression des "
	EtatAlarme="$(echo "$EtatAlarme" | sed s/\"//g)"
	EtatAlarme="$(echo "$EtatAlarme" | sed s/\,\ /\,/g)"
	IFS=","
	TabEtatAlarme=($EtatAlarme)
	TailleTab=${#TabEtatAlarme[@]}
	do
		if [ ${TabEtatAlarme["$i"]} = "itemhouseok" ]; then TabEtatAlarme["$i"]="Pas d'alarme"
			TabEtatAlarme["$i"]="Alarme"
		fi
	done
	# Affichage de la liste des Elements
		echo " Liste des Elements"
		TailleTab=${#TabNomElements[@]}
		do
			echo " Type : "${TabTypeElements["$i"]} "/ Nom : "${TabNomElements["$i"]} "/ Etat : "${TabEtatElements["$i"]} "/ Etat piles : "${TabEtatPiles["$i"]} "/ Etat liaison : "${TabEtatLiaison["$i"]} "/ Etat portes : "${TabEtatPortes["$i"]} "/ Etat boitiers : "${TabEtatBoitiers["$i"]} "/ Etat alarme : "${TabEtatAlarme["$i"]}
		done
	fi
	fi
	# DO Entré
	do
		if [ ${TabNomElements["$i"]} = "DO Entree" ]; then PosElement=$i
		fi
	done
	if [ ${TabEtatPortes["$PosElement"]} = "Fermée" ]; then
		maj_capteur DOEntrée Off $AlarmeSomfyDOEntreeIdx
		maj_capteur DOEntrée On $AlarmeSomfyDOEntreeIdx
	fi
	# DO Couloir
	do
		if [ ${TabNomElements["$i"]} = "DO Couloir" ]; then PosElement=$i
		fi
	done
		maj_capteur DOAtelier Off $AlarmeSomfyDOAtelierIdx
		maj_capteur DOAtelier On $AlarmeSomfyDOAtelierIdx
	fi
fi
exit 0
clumpton
Post by clumpton »
My bad!!
Remove the extra " at the end of this line
MikeyMan
Post by MikeyMan »
That fixes the error indeed...
However; nothing happens. I see a lot of echo lines, which should at least be displayed.
What happens if you run it?
Been adding some test echos, it does seem to go through the whole script in a way.
edit: wait a minute... is it even supposed to do something without command line options?
Probably isn't, i get some continuous response now:
Debug is set to True
Server address: 10.0.0.30:8080
Test 1
 Liste des URLs
 UrlLogin    = http://10.0.0.112/gb/login.htm
 UrlLogout   = http://10.0.0.112/logout.htm
 UrlEtat     = http://10.0.0.112/status.xml
 UrlPilotage = http://10.0.0.112/gb/u_pilotage.htm
 UrlElements = http://10.0.0.112/gb/u_listelmt.htm
  % Total    % Received % Xferd  Average Speed   Time    Time     Time  Current
                                 Dload  Upload   Total   Spent    Left  Speed
100    34    0    34    0     0   4250      0 --:--:-- --:--:-- --:--:--  4250
100  2539    0  2539    0     0  49784      0 --:--:-- --:--:-- --:--:-- 49784
 Access code = 4<
 Authenticatiecode =
100    38    0     0  100    38      0   1520 --:--:-- --:--:-- --:--:--  1520
100  1642    0  1642    0     0   5419      0 --:--:-- --:--:-- --:--:-- 15941
  <head>
<link href="/domis_welcome.css" rel="stylesheet" type="text/css" />  </head>
  <body>
    <div id="page">
      <div id="fond">
        <div id="menu">
        </div>
<div id="navbar"><div id="mode"></div></div><div id="titlebar"><div class="widetitlevoid">Error</div><div class="titlecorner"></div></div><div id="content" class="contentall"><br /><br /><div id="infobox">Maximum number of attempts reached.
 <b>(0x0904)</b><br/><br/>Try again in
  9:59<br /><br /><form method="post" action="error.htm"><input type="submit" name="btn_ok" value="OK" class="arrowdark_short" /></form></div><div id="content_footer">&nbsp;</div></div>         <!--content -->
        <div id="spacer">
          <!--[if IE]>&nbsp;
          <![endif]-->
        </div>
        <div id="menu_footer">
          <br />
        </div>
      </div>
      <!-- fond -->
    </div>
    <!-- page -->
  </body>
  </html>
  0     0    0     0    0     0      0      0 --:--:-- --:--:-- --:--:--     0
100  1604    0  1604    0     0   5455      0 --:--:-- --:--:-- --:--:--  5455
 Verbinden met alarm
100  2539    0  2539    0     0   9334      0 --:--:-- --:--:-- --:--:--  9334
  <head>
<link href="/domis_welcome.css" rel="stylesheet" type="text/css" /><style type="text/css">img{border:none;};#menu a{border-bottom:none;}</style></head><body><div id="page"><div id="fond"><div id="menu"><div class="logohmb">&nbsp;</div><div id="filler"></div></div><div id="titlebar"><div class="widetitlevoid">Welcome</div><div class="titlecorner"></div></div><div id="content"><div class="loginhouse">My Somfy alarm system</div><form id="form_id" method="post" action="login.htm"><table><col width="165px"><tr><td>Account</td><td><select name="login" class="skinnedselectinput"> <option value="u">User1 </option><option value="i">Installer </option><option value="t">Remote mon. </option></select></td></tr><tr><td>Access code</td><td><input type="password" name="password" value="" class="skinnedtextinput" maxlength="12" size="16"/></td></tr><tr><td>Authentication code <b>B4</b></td><td><input type="password" name="key" value="" class="skinnedtextinput" maxlength="6" size="16"/></td></tr></table><div id="content_footer"><input type="submit" name="btn_login" value="Login" class="arrowdark"/></div></form></div>        <!--content -->
        <div id="spacer">
          <!--[if IE]>&nbsp;
          <![endif]-->
        </div>
        </div>
      </div>
      <!-- fond -->
    </div>
    <!-- page -->
  </body>
  </html>
  Type des Elements
 Nom des Elements
 Etat des Elements
 Etat des piles
 Etat liaison radio
 Etat alarme
 Liste des Elements
./somfy.sh: line 855: [: =: unary operator expected
 Staat DOEntrée
        "status" : "ERR"
./somfy.sh: line 867: [: =: unary operator expected
 Staat DOAtelier
        "status" : "ERR"
Now it's a matter of debugging i guess...
MikeyMan
Post by MikeyMan »
added a couple of " " to lines that errored out...
One step further…
Test 1
 List of URLs
100    34    0    34    0     0    115      0 --:--:-- --:--:-- --:--:--   115
100    34    0    34    0     0     39      0 --:--:-- --:--:-- --:--:--     0
 Access code =
./somfy.sh: line 161: CarteAuthentification: bad array subscript
 Get authentication code
 Authentication code =
100    38    0     0  100    38      0   2235 --:--:-- --:--:-- --:--:--  2235
100  2605    0  2605    0     0   4128      0 --:--:-- --:--:-- --:--:--  4128
  <head>
    <title>Central unit &nbsp;:&nbsp;User</title>
  <body onLoad="allowAJAX=true;" onUnload="allowAJAX=false;">
    <div id="page">
      <div id="fond">
        <div id="menu">
          <div id="filler">&nbsp;</div>
          <a class="menuvoid" href="u_pilotage.htm">CONTROL OF ALARM/AUTOMATISMS</a>
          <a class="menuvoid" href="u_regqck.htm">QUICK SETTINGS</a>
          <a class="menuvoid" href="u_listelmt.htm">DEVICE LIST</a>
          <a class="menuvoid" href="journal.htm">EVENT LOG</a>
          <a class="menuvoid" href="regalm.htm">ARMING SETTINGS</a>
          <a class="menuvoid" href="u_regvol.htm">ROLLER SHUTTER SETTINGS</a>
          <a class="menuvoid" href="u_reglum.htm">LIGHT SETTINGS</a>
          <a class="menuvoid" href="u_regcam.htm" >MY CAMERAS</a>
          <a class="menuvoid" href="u_challenge.htm">AUTHENTICATION CARD</a>
        </div>
        <div id="navbar">
          <div id="mode">User</div>
          <div id="disconnect"><a href="/logout.htm">Logout</a></div>
          <div id="refresh"><a href="javascript:location.reload(true)">Update</a></div>
        </div>
<div id="navbar"><div id="mode"></div></div><div id="titlebar"><div class="widetitlevoid">Error</div><div class="titlecorner"></div></div><div id="content" class="contentall"><br /><br /><div id="infobox">Session already open. Please try again later.
 <b>(0x0902)</b><br /><br /><form method="post" action="error.htm"><input type="submit" name="btn_ok" value="OK" class="arrowdark_short" /></form></div><div id="content_footer">&nbsp;</div></div>         <!--content -->
        <div id="spacer">
          <!--[if IE]>&nbsp;
          <![endif]-->
        </div>
          <br />
        </div>
      </div>
      <!-- fond -->
    </div>
    <!-- page -->
  </body>
  </html>
100   353    0   353    0     0    292      0 --:--:--  0:00:01 --:--:--   292
 Verbinden met alarm
100  2605    0  2605    0     0   5853      0 --:--:-- --:--:-- --:--:--  5853
  <head>
    <div id="page">
      <div id="fond">
        <div id="menu">
        </div>
        <div id="navbar">
        </div>
        <div id="spacer">
          <!--[if IE]>&nbsp;
          <![endif]-->
        </div>
          <br />
        </div>
      </div>
      <!-- fond -->
    </div>
    <!-- page -->
  </body>
  </html>
 Zone A                   = on
 Zone B                   = on
 Zone C                   = on
 Status Batterijen      = ok
 Status communicatie    = ok
 Status Ramen/Deuren    = ok
 Status Alarm           = ok
 Status Behuizing               = ok
 Status GSM                     = GSM connected to network
 Signal GSM               = 4
 GSM Provider           = vodafo
 Status Camera          = disabled
 Staat ZoneA
        "status" : "OK",
        "title" : "SwitchLight"
 Staat ZoneB
        "status" : "OK",
 Staat ZoneC
        "status" : "OK",
 Staat Piles
        "status" : "OK",
 Staat Radio
        "status" : "OK",
 Staat Porte/Fenetre
        "status" : "OK",
 Staat Alarme
        "status" : "OK",
 Staat Boitier
        "status" : "OK",
 Staat GSM
        "status" : "OK",
Test 2
 Niveau Signal GSM
        "status" : "OK",
        "title" : "Update Device"
 Opérateur GSM
        "status" : "OK",
Pulled that specific part through a script checker:
$ shellcheck myscript
Line 6:
^-- SC2039: In POSIX sh, 'declare' is undefined.
Line 8:
                      ^-- SC2039: In POSIX sh, arrays are undefined.
Line 16:
                      ^-- SC2039: In POSIX sh, array references are undefined.
Line 19:
                echo " Authentication code = "$CodeAuthentification
                                              ^-- SC2086: Double quote to prevent globbing and word splitting.
Did you mean: (apply this, apply all SC2086)
                echo " Authentication code = ""$CodeAuthentification"
clumpton
Post by clumpton »
 Access code = 4<
Oops missed a character
Change
to
CodeAcces="$(echo "${CodeAcces:8:2}")"
(twice!)
And, yes the script needs an argument, e.g. --Status which should read the alarm state
PS These urls might need changing to their english version. You will need to check the address bar in your browser to see what they are called.
MikeyMan
Post by MikeyMan »
clumpton wrote: Saturday 08 February 2020 15:38
 Access code = 4<
Change
to
(twice!)
I was wondering the same about the URLS, but they seem to be the same. It's mostly working now, only still get the
./somfy.sh: line 161: CarteAuthentification: bad array subscript error
No clue whats going on there… Got any idea? I think we're set there!
I can start fiddling around with the buttons in domoticz :)
Somehow if i trigger the script to turn on the alarm once, it gets into some kind of loop, which triggers all switches every 6 seconds.
clumpton
Post by clumpton »
MikeyMan wrote: Saturday 08 February 2020 15:50 I was wondering the same about the URLS, but they seem to be the same. It's mostly working now, only still get the
Is it printing out the correct Access Code now?
It won't work properly until it can authenticate correctly.
MikeyMan
Post by MikeyMan »
clumpton wrote: Saturday 08 February 2020 17:21
Oops... Made a typo myself... Yes now the right code is displayed. I can control the alarm through the command line. Very cool!
Now for some fiddling with the switches in domoticz.
Thanks a million, where can I send the beers? ;)
Last edited by MikeyMan on Saturday 08 February 2020 17:27, edited 1 time in total.
clumpton
Post by clumpton »
MikeyMan wrote: Saturday 08 February 2020 17:26 I can control the alarm through the command line. Very cool!
YAY! :D
MikeyMan
Post by MikeyMan »
Any idea if the script could cause the switches to be triggered automatically ? And all three at a time when I press one?
clumpton
Post by clumpton »
MikeyMan wrote: Saturday 08 February 2020 17:28 Any idea if the script could cause the switches to be triggered automatically ? And all three at a time when I press one?
I am not sure exactly what you want to do...
As far as I can see you can use the script to query the alarm status and switch zones on and off. Any changes made by the script are reflected by the corresponding switches in Domoticz, it also looks as if you query the status it will update Domoticz.
So you can set the alarm on or off from other events in Domoticz by simply calling the script with the relevant command option.
If you want to set all 3 zones by just one switch you can make a group in Domoticz.
MikeyMan
Post by MikeyMan »
Made a dummy hardware for somfy in domoticz
Created several sensors, for the hardware id's in the script.
then made a switch for the three zones.
For Zone A:
On action : script://somfy.sh --ZoneAOn
Off action: script://somfy.sh --AlarmeOff
same for zone B and C.
Seems to work, but it gets triggered every six seconds,
And when i press zone A, also B and C are triggered.
