Re: Script LUA to read value on a webpage ?
Posted: Sunday 11 October 2020 11:00
Thank for the help,
When is use the script from the lake level, i get the next response.
Some were in here the value is hidden can anyone help mee to extract it?
Tinus
Tinus
* string: <!DOCTYPE html>
<!--[if lt IE 7]> <html class="no-js lt-ie9 lt-ie8 lt-ie7"> <![endif]-->
<!--[if IE 7]> <html class="no-js lt-ie9 lt-ie8"> <![endif]-->
<!--[if IE 8]> <html class="no-js lt-ie9"> <![endif]-->
<!--[if gt IE 8]><!-->
<html class="no-js">
<!--<![endif]-->
<head>
<title>VBus.net Scheme-Designer</title>
<meta charset="utf-8">
<meta name="viewport" content="width=device-width, initial-scale=1">
<!-- build:css styles/main.css -->
<!--<link href="../../../bower_components/font-awesome-animation/dist/font-awesome-animation.css" type="text/css" rel="stylesheet" /> // bower lib has not all animations included -->
<link href="bower_components/jquery-ui/themes/base/jquery-ui.min.css" type="text/css" rel="stylesheet" />
<link href="bower_components/colorpicker/jquery.colorpicker.css" type="text/css" rel="stylesheet" />
<link href="bower_components/weather-icons/css/weather-icons.css" type="text/css" rel="stylesheet" />
<link href="bower_components/weather-icons/css/weather-icons-wind.css" type="text/css" rel="stylesheet" />
<link href="bower_components/font-awesome/css/font-awesome.css" type="text/css" rel="stylesheet" />
<link href="css/main-built.min.css" type="text/css" rel="stylesheet" />
<link rel="shortcut icon" type="image/x-icon" href="images/favicon.ico">
<link rel="apple-touch-icon" sizes="180x180" href="images/apple-touch-icon.png">
<meta name="application-name" content="VBus.net" />
<meta name="msapplication-TileColor" content="#009900" />
<!--<link href='http://fonts.googleapis.com/css?family=Lobster' rel='stylesheet' type='text/css'>-->
<!-- endbuild -->
<!-- build:js scripts/vendor/modernizr.js -->
<!--<script src="./bower_components/modernizr/src/Modernizr.js"></script>-->
<!-- endbuild -->
<style>
</style>
</head>
<body>
<!--[if lt IE 11]>
<p class="browsehappy">You are using an <strong>outdated</strong> browser. Please <a href="http://browsehappy.com/">upgrade your browser</a> to improve your experience.</p>
<![endif]-->
<div class="navbar navbar-inverse navbar-fixed-top hide" role="navigation">
<div class="container-fluid">
<div class="navbar-header" style="margin-top:4px">
<a href="/#visualization/schemes">
<img src="./images/vbus.png" alt="logo" style="height:22px;border:none;margin-right:10px;" />
</a>
<i class="fa fa-sun-o"></i>
<b class="navbar-scheme-name"></b>
<input type="hidden" id="scheme_id" />
<small class="hide">
<i class="fa fa-picture-o"></i>
<span class="navbar-image-name"></span>
<i class="fa fa-filter"></i>
<span class="navbar-filter-name"></span>
</small>
</div>
<div class="navbar-collapse collapse">
<ul class="nav navbar-nav navbar-right">
<div id="togglebar"></div>
</ul>
</div>
</div>
</div>
<div id="resol-vbus-visualization-scheme" class="resol-vbus-visualization-scheme"></div>
<!-- build:js scripts/main.js -->
<script data-main="scripts/main" src="bower_components/requirejs/require.js"></script>
<!-- <script src="lib/require.min.js"></script>
<script>
require.config({
paths: {
//Comment out this line to go back to loading
//the non-optimized main.js source file.
"main": "scripts/main-built"
require(["main"]);
</script>
<!-- endbuild -->
<div class="modal fade" id="modal-energy" tabindex="-1" role="dialog">
<div class="modal-dialog">
<div class="modal-content">
<div class="modal-header">
<button type="button" class="close" data-dismiss="modal" aria-label="Close"><span aria-hidden="true">×</span></button>
<h2 class="modal-title">∑ / <i class="fa fa-bar-chart"></i> <span class="energyValues"></span></h2>
</div>
<div class="modal-body">
<table class="table">
<tbody>
<tr>
<td valign="top" width="120px">
<label class="energy-label-year"></label>:
</td>
<td>
<div>
<input type="radio" name="energy-range-year" class="energy-range-year-current" checked />
<span class="energy-current-year"></span>
</div>
<div>
<input type="radio" name="energy-range-year" class="energy-range-year-previous" />
<span class="energy-previous-year"></span>
</div>
</td>
</tr>
<tr>
<td valign="top">
<label class="energy-label-energyValuesRange"></label>:
</td>
<td>
<div>
<input type="radio" name="energy-range-month" class="energy-range-month-current" checked />
<span class="energy-range-month"></span>
</div>
<div>
<input type="radio" name="energy-range-month" value="selected" id="energy-range-month-selected" />
<select class="form-control" id="energy-selected-month" style="height:20px;width:120px;display:inline"></select>
</div>
<div>
<input type="radio" name="energy-range-month" value="year" />
<span class="energy-label-wholeYear"></span>
</div>
</td>
</tr>
<tr>
<td valign="top">
<label class="energy-label-view"></label>:
</td>
<td>
<div>
<input type="radio" name="energy-view" value="T" checked />
<span class="energy-label-textForm"></span>
</div>
<div>
<input type="radio" name="energy-view" value="D" />
<span class="energy-label-diagram"></span>
</div>
<div style="margin-top:10px;width:300px;">
<div style="margin-bottom:10px">
<input type="checkbox" id="energy-automatic-title" value="1" checked />
<span class="energy-automatic-title"></span>
</div>
<div style="margin-bottom:20px">
<input id="energy-width" type="range" min="140" max="500" step="10" value="280" />
<span class="energy-label-width"></span>
<span class="energy-width">280</span>px
</div>
<div>
<input id="energy-height" type="range" min="70" max="300" step="10" value="160" />
<span class="energy-label-height"></span>
<span class="energy-height">160</span>px
</div>
</div>
</td>
</tr>
</tbody>
</table>
</div>
<div class="modal-footer">
<button type="button" class="btn btn-default btn-reset-energy-format filteredId" data-dismiss="modal"></button>
<button type="button" class="btn btn-primary btn-set-energy-format filteredId"></button>
</div>
</div>
</div>
</div>
</body>
</html>
