Pushnotification when dishwasher/washing machine is ready?
ThinkPad
Re: Create a Event or Lua to get push notification when dish
Post by ThinkPad »
I took some time to rewrite it to a more 'logical' version:
script_time_washingmachine.lua
-- The name of the virtual washing machine switch
local switch_washingmachine = 'virt_wasmachine'
--If actual consumption of measured by Z-Wave plug is higher than or equal to 4W, washingmachine is on
if (otherdevices_svalues['Actual_wasmachine'] >= '4' and otherdevices[switch_washingmachine] == 'Off') then
   commandArray[switch_washingmachine]='On'
   print('Wasmachine staat AAN')
   commandArray['Variable:washingmachine_dummyCounter']='10'
	if (otherdevices_svalues['Actual_wasmachine'] < '3' and otherdevices[switch_washingmachine] == 'On') then
      commandArray['Variable:washingmachine_dummyCounter']=tostring(math.max(uservariables['washingmachine_dummyCounter'] - 1, 0))
if (otherdevices[switch_washingmachine] == 'On' and uservariables['washingmachine_dummyCounter'] == 0) then
   print('Wasmachine is KLAAR')
   commandArray['SendNotification']='Wasmachine#Wasmachine is klaar!#0'
   commandArray[switch_washingmachine]='Off'
(Credits for the basic 'structure' of the script go to nickyb2, who is always great in helping me out)
What you need:
- A virtual switch ('virt_wasmachine')
- A user variable ('wasmachine_dummyCounter')
How it works:
It checks if the power usage is higher than or equal to 4W, if yes: washing machine is on. It will set the virtual switch to on and set the counter (user variable) to a defined value.
It will then check if the virtual switch is on and get the counter value and updates the counter with the value MINUS 1 (this is a sort of timer, because the script will be initiated every minute).
If the counter reaches zero and the virtual switch = on then send a pushmessage and turn switch off
First test with a lightbulb worked fine, after about 5 minutes after turning off the light i received a message.
The value (>10W) and the time (5 minutes) are values i have to measure in real life, and adjust the script to. I don't know how much Watt my washing machine uses when it is waiting (between spinning, heating and pumping). I also don't know how much time it will 'wait' while doing this. But i can just measure it :)
I also don't know if the 'if/elseif/else' structure is correct. I first left out the last 'else', but then i got errors.
ropske
Domoticz version: V3_8394
Post by ropske »
if your script is working fine for your application, i'm glad your you ;-)
mine is working ok for my application ;-)
if you need any help, please ask.
ThinkPad
Re: Pushnotification when dishwasher/washing machine is read
Post by ThinkPad »
Today the washing machine is on, and i already received 8 pushnotifications... but the washing machine is still runing....
So my script is not good yet...
Will try and see if i can adjust it
tlpeter
Post by tlpeter »
I think it now has some data which you can look back on how much it used.
I guess the lowest usage will be when it is doing very little like letting out water.
You could measure the time if the usage is too low to use.
Then build a script which uses usage and time.
ThinkPad
Post by ThinkPad »
Downside is that the graphs in Domoticz accumulate data by every 5 minutes... So my graph jumps from 10:40 to 10:45. This makes it harder to determine what the washing machine was doing.
But it seems that when it is 'idle' (not pumping, heating water, or tumbling) it uses 3W. This always takes under a minute
matthijs
Post by matthijs »
ThinkPad wrote:I took some time to rewrite it to a more 'logical' version:
What you need:
How it works:
I tried this script with my washing machine, but I got also a lot of notifications. After checking the lua documentation (I'm not a real scripter) I discovered the function tonumber(). This converts a string to a number. I think the script was not converting the string correctly to a number (something lua tries to do automatically). Now it's working like a charm. My washing machine has a maximum value of 2 watt when it's on but not in a program and when a program is running the lowest value is 3 watt which is easy to program. I added the code with tonumber() added.
--If actual consumption of measured by Z-Wave plug is higher than 2W, washingmachine is on
if (tonumber(otherdevices_svalues['Wasmachine'])) > 2.0 and otherdevices[switch_washingmachine] == 'Off' then
   if (tonumber(otherdevices_svalues['Wasmachine'])) <= 2.0 and otherdevices[switch_washingmachine] == 'On' then
ThinkPad
Post by ThinkPad »
Thanks, will try it again soon.
Script has a high WAF (Wife Acceptance Factor) so would be nice if i could get it working reliable.
But i'm not sure, because it seems you don't use the counter part. I think i need that, because the washing machine has the same low usage when it is waiting between rotating the other way round as when it is done with everything.
matthijs
Post by matthijs »
I suppose you can just use your script and add the tonumber() function and use the timer. I noticed that that right values where there, but the equation was not always done right. If lua can't read the value as a number it is nill. That is always lower than 2 or 3 watt so the script thinks the washing machine is ready. It's strange because lua normally transforms this automatically but in this case it doesn't.
Plaagje
Domoticz version: Latest
Post by Plaagje »
Thanks for the script,
i changed it a bit,,, check it out:
sWasmachine = otherdevices_svalues['Wasmachine']:match("([^;]+)")
sWasmachine = tonumber(sWasmachine);
print("Wasmachine: Wasmachine load is: " .. sWasmachine .. " ");
if sWasmachine > 2.0 and otherdevices['switch_washingmachine'] == 'Off' then
	commandArray['switch_washingmachine']='On'
   elseif sWasmachine <= 2.0 and otherdevices['switch_washingmachine'] == 'On' then
		commandArray['switch_washingmachine']='Off'
name is script_device_Wasmachine.lua
I have a Fibaro wall switch (the small one with the led ring), and it gives me 3 devices, 1 switch and 2 energy devices,,, i named the energy device that showed the power usage Wasmachine and i created the virtual switch as mentioned above.
Plaagje
Post by Plaagje »
matthijs wrote: commandArray[switch_washingmachine]=
should be:
dont forget the quotes ;-)
matthijs
Post by matthijs »
Plaagje wrote:dont forget the quotes
Thank you for cleaning up the script. My coding skills aren't that good but I try and learn. I made switch_washingmachine local, because my real switch is called virt_wasmachine ( I used the script Thinkpad provided and edited it after I got the same problem with the push notifications). I thought you don't need the quotes when you make it local, but your script is much cleaner.
ivom74
Post by ivom74 »
Which energy reading device you used ?
ThinkPad
Post by ThinkPad »
NiklasO
Post by NiklasO »
This is my solution using Blockly. Works every time and no dual notifications.
I use a virtual device to see if the machine is running a program or not, great for visible confirmation:
Over 2,2W: washing machine running a program.
1,8W or less: washing machine not running a program or off/stand-by.
You mileage may vary. ;)
ThinkPad
Post by ThinkPad »
My washingmachine uses the same when it is waiting before reversing spinning direction as when it is totally done. So a solution like your Blockly isn't going to work for me :(
djoeney
Post by djoeney »
ThinkPad wrote:My washingmachine uses the same when it is waiting before reversing spinning direction as when it is totally done. So a solution like your Blockly isn't going to work for me :(
Thinkpad can you confirm the script is running stable? with the version you applied above?
Compute RPi 2 : Domoticz latest beta, Synology : Domoticz tested beta on failover system.
Peripherals RFXCOM - RFXtrx433, Z-Wave.Me ZME_UZB1 USB Stick,P1 cable on smartmeter, Logitech Harmony Hub, 3 IP camera's
ThinkPad
Post by ThinkPad »
I am not using it, couldn't get this working because of the reason you quoted in your post.
djoeney
Post by djoeney »
To bad, is has a high WAF. Like you mentioned. I'm hoping to get this stable with my wash machine.
D'rMorris
Post by D'rMorris »
You can still use the script, you just would need to add a timeout to it.
I assume the washing machine needs perhaps 10 seconds or so to go into reverse spinning mode, so if you add another clause to the script, you can circumvent that issue.
For example, create a uservariable called "dishwasher_timeout" and fill in the timeout that the dishwasher needs to reverse.
Then, in your code check whether this timeout has passed with a function, like this:
print('<b style="color:Blue">>   Monitoring Dishwasher</b>')
------------- Begin time functions -------------
function timedifference_dishwasher (s)
  year = string.sub(s, 1, 4)
  month = string.sub(s, 6, 7)
  day = string.sub(s, 9, 10)
  hour = string.sub(s, 12, 13)
  t1 = os.time()
  difference_dishwasher = os.difftime (t1, t2)
  return difference_dishwasher
------------- End time functions -------------
------------- Begin local variables -------------
-- Debug variables:
debug                   = uservariables["debug_general"]
dishwasher_timeout      = uservariables["dishwasher_timeout"]
difference_dishwasher   = timedifference_dishwasher(otherdevices_lastupdate['dishwasher_on_off_switch'])
------------- End local variables -------------
------------- Begin debug statements -------------
if debug=="Y"
  then
  print('<b style="color:Red">>> Debug is set to: ' .. debug .. '</b>')
  print('<b style="color:Red">>> Dishwasher timeout is set to: ' .. dishwasher_timeout .. '</b>')
------------- End debug statements -------------
------------- Begin code -------------
if (otherdevices['PowerUsageDishwasher'] >= '2' and
    difference_dishwasher > dishwasher_timeout)
    then
        action
        print('<b style="color:Red">>> Dishwasher still running. Dishwasher last seen: ' .. difference_dishwasher .. ' seconds ago</b>')
------------- End code -------------
djoeney
Post by djoeney »
Thanks Can't wait for my order to get delivered. Will post the outcome when done!
