Page 2 of 18
Re: Python Plugin: Zigbee2Mqtt
Posted: Monday 15 October 2018 14:49
by MarFan
upwindanderl wrote: Sunday 14 October 2018 18:32
No Zigbee Hardware Device at all ... any debug ideas anyone??
Do you have messages regarding the python library installed correctly (or missing).
Posted: Monday 15 October 2018 22:50
by upwindanderl
MarFan wrote: Monday 15 October 2018 14:49
How can i figure this out
I only did the python library install like this way:
Installation
Posted: Tuesday 16 October 2018 3:06
by Dnpwwo
@upwindanderl,
Go to the 'About' page in the Web UI or look at the Domoticz log during startup. If Domoticz finds a version it can use it will report it in both of those places. If Domoticz reports a Python version then that is not the problem here.
If the Python version is not reported then have a look at this:
https://www.domoticz.com/wiki/Using_Python_plugins
Posted: Tuesday 16 October 2018 14:47
by MarFan
Good news, the latest Zigbee2Mqtt Main version (0.1.7) contains the include_device_information setting.
So DEV is not needed anymore
Posted: Tuesday 16 October 2018 21:13
by prelude
I try to take Zigbee2Mqtt plugin on the use but something is wrong and i cannot figure out what so maybe someone can help me a bit.
Im running domosticz on docker as well as rabbitmq and zigbee2mqtt. Currently seems that zigbee2mqtt talks with a rabitmq (i see xiaomi temp sensor messages on log files) and also i see from Domosticz log files (zigbee2mqtt) Heartbeating...(zigbee2mqtt) MqttClient::Ping seems to work fine.
But i do not get any devise to visible on domosticz device page.
Logs and configs:
zigbee2mqtt configuration.yaml
homeassistant: false
permit_join: true
mqtt:
base_topic: zigbee2mqtt
server: 'mqtt://rabbitmq'
include_device_information: true
serial:
port: /dev/ttyACM0
devices:
'0x00158d0002320bef':
friendly_name: '0x00158d0002320bef'
retain: false
domosticz setup:
Domosticz log:
2018-10-16 22:04:02.658 (zigbee2mqtt) Heartbeating...
2018-10-16 22:04:02.658 (zigbee2mqtt) MqttClient::Ping
2018-10-16 22:04:12.681 (zigbee2mqtt) Heartbeating...
2018-10-16 22:04:12.681 (zigbee2mqtt) MqttClient::Ping
zigbee2mqtt log:
zigbee2mqtt:info 2018-10-16 19:06:19 MQTT publish, topic: 'zigbee2mqtt/0x00158d0002320bef', payload: '{"humidity":92.88,"linkquality":86,"pressure":1015,"device":{"ieeeAddr":"0x00158d0002320bef","friendlyName":"0x00158d0002320bef","type":"EndDevice","nwkAddr":23243,"manufId":4151,"manufName":"LUMI","powerSource":"Battery","modelId":"lumi.weather","status":"online"}}'
Any idea what i should to check first?
Posted: Tuesday 16 October 2018 22:35
by upwindanderl
Dnpwwo wrote: Tuesday 16 October 2018 3:06
@upwindanderl,
@Dnpwwo THANK YOU SO SO MUCH !!!!!
Exactly this was my problem at all, and your wiki link helped out.
In the end everything like in the wiki mentioned was ok, but then i tried the python3-DEV and now i got the ZIGBEE2MQTT Hardware thing
THANKS !!!!
Posted: Tuesday 16 October 2018 22:53
by gerbenvanasselt
I am experiencing the same as Prelude. Does anyone have any suggestions?
Verstuurd vanaf mijn ONEPLUS A6003 met Tapatalk
Posted: Tuesday 16 October 2018 23:17
by MikeF
Have you ticked 'Accept new Hardware Devices Allow for 5 Minutes' in Settings?
Posted: Wednesday 17 October 2018 9:19
by EddyG
It works perfectly, but I have a few questions/remarks.
The WSDCGQ11LM (Xiaomi Aqara temperature, humidity and pressure sensor) is setup as device "Pressure", it should be setup as device "Barometer".
Request: from the same device there should be a possibility to setup Temp and Hum as 1 device.
Only the "Cube" has a signal strenght in Domoticz.
It would be nice it state and linkquality of router could be vissible as custom device in Domoticz.
Posted: Wednesday 17 October 2018 11:33
by MiloshCZ
@EddyG: I have allready reported issue about Signal Quality:
https://github.com/stas-demydiuk/domoti ... n/issues/5
Posted: Wednesday 17 October 2018 12:34
by gerbenvanasselt
Hey MikeF, yes I tried allow option in setting. But nothing happens. I am trying it with tradfri bulbs. They are listed in the configuration.yaml and domoticz says it is reading the devicelist. But there no devices available.
Anyone has any clue's? Would be very helpful.
MikeF wrote:Have you ticked 'Accept new Hardware Devices Allow for 5 Minutes' in Settings?
Posted: Wednesday 17 October 2018 21:03
by misko903
Maybe a
Nuki lock support?
https://nuki.io/en/shop/nuki-bridge/
works on Zigbee too...
Posted: Wednesday 17 October 2018 22:04
by upwindanderl
Wooohoo! I love this plugin... so much easier now to handle the aqara devices!
Thanks for the help.
How is it now with some devices which are already in the zigbee list but not in the plugin?!
I'm definitly someone who would give some donation or at least two three four beers (paypal...) if there would be some work on
For me it would be fine with:
OSRAM SMART+ (
devicelist model: AB3257001NJ)
and the
Xiaomi Aqara wireless switch (
devicelist model: WXKG11LM)
Posted: Wednesday 17 October 2018 22:15
by prelude
MikeF wrote: Tuesday 16 October 2018 23:17
I try it and it did something but still no devices on domosticz:
2018-10-17 23:08:50.781 (zigbee2mqtt) MqttClient::Ping
2018-10-17 23:08:53.357 Status: New sensors allowed for 5 minutes...
2018-10-17 23:09:00.806 (zigbee2mqtt) Heartbeating...
2018-10-17 23:09:00.806 (zigbee2mqtt) MqttClient::Ping
2018-10-17 23:09:10.781 (zigbee2mqtt) Heartbeating...
2018-10-17 23:09:10.781 (zigbee2mqtt) MqttClient::Ping
2018-10-17 23:09:20.803 (zigbee2mqtt) Heartbeating...
2018-10-17 23:09:20.804 (zigbee2mqtt) MqttClient::Ping
2018-10-17 23:09:30.774 (zigbee2mqtt) Heartbeating...
2018-10-17 23:09:30.774 (zigbee2mqtt) MqttClient::Ping
2018-10-17 23:09:40.795 (zigbee2mqtt) Heartbeating...
2018-10-17 23:09:40.795 (zigbee2mqtt) MqttClient::Ping
2018-10-17 23:09:50.814 (zigbee2mqtt) Heartbeating...
2018-10-17 23:09:50.814 (zigbee2mqtt) MqttClient::Ping
2018-10-17 23:10:00.783 (zigbee2mqtt) Heartbeating...
2018-10-17 23:10:00.784 (zigbee2mqtt) MqttClient::Ping
2018-10-17 23:10:10.806 (zigbee2mqtt) Heartbeating...
2018-10-17 23:10:10.806 (zigbee2mqtt) MqttClient::Ping
2018-10-17 23:10:15.472 (zigbee2mqtt) MQTT message: zigbee2mqtt/bridge/log {'type': 'pairing', 'message': 'device incoming'}
2018-10-17 23:10:20.832 (zigbee2mqtt) Heartbeating...
and bit better log from dockers:
zigbee2mqtt | zigbee2mqtt:info 2018-10-17 20:10:15 Device incoming...
zigbee2mqtt | zigbee2mqtt:info 2018-10-17 20:10:15 MQTT publish, topic: 'zigbee2mqtt/bridge/log', payload: '{"type":"pairing","message":"device incoming"}'
domoticz_1 | 2018-10-17 23:10:15.472 (zigbee2mqtt) MQTT message: zigbee2mqtt/bridge/log {'type': 'pairing', 'message': 'device incoming'}
zigbee2mqtt | zigbee2mqtt:info 2018-10-17 20:10:15 MQTT publish, topic: 'zigbee2mqtt/0x00158d0002320bef', payload: '{"pressure":1012,"linkquality":52,"temperature":25.46,"device":{"ieeeAddr":"0x00158d0002320bef","friendlyName":"0x00158d0002320bef","type":"EndDevice","nwkAddr":59898,"manufId":4151,"manufName":"LUMI","powerSource":"Battery","modelId":"lumi.weather","status":"online"}}'
zigbee2mqtt | zigbee2mqtt:info 2018-10-17 20:10:15 MQTT publish, topic: 'zigbee2mqtt/0x00158d0002320bef', payload: '{"temperature":25.46,"linkquality":52,"humidity":48.39,"device":{"ieeeAddr":"0x00158d0002320bef","friendlyName":"0x00158d0002320bef","type":"EndDevice","nwkAddr":59898,"manufId":4151,"manufName":"LUMI","powerSource":"Battery","modelId":"lumi.weather","status":"online"}}'
zigbee2mqtt | zigbee2mqtt:info 2018-10-17 20:10:15 MQTT publish, topic: 'zigbee2mqtt/0x00158d0002320bef', payload: '{"humidity":48.39,"linkquality":52,"pressure":1012,"device":{"ieeeAddr":"0x00158d0002320bef","friendlyName":"0x00158d0002320bef","type":"EndDevice","nwkAddr":59898,"manufId":4151,"manufName":"LUMI","powerSource":"Battery","modelId":"lumi.weather","status":"online"}}'
Posted: Friday 19 October 2018 10:46
by MarFan
Before it is posible to have this in the plugin, it must have support in the Ziggbee2MQTT stick.
So please start first here
https://github.com/Koenkk/zigbee2mqtt/w ... ew-devices
Posted: Friday 19 October 2018 10:48
by MarFan
prelude wrote: Wednesday 17 October 2018 22:15
Did you restart Domoticz (sudo service domoticz restart) ?
I sometimes also have the behaviour that I have to restart first before a new device is added.
Posted: Friday 19 October 2018 21:14
by prelude
Yep, no help from there.
Posted: Sunday 21 October 2018 17:17
by gerbenvanasselt
I am going to try this solution with node-red. Because the python plugin is not working yet. Hope it will in the nearby future.
https://diyprojects.io/test-zigbee2mqtt ... 8yXKk9Nfqs
Posted: Wednesday 24 October 2018 9:12
by dextm80
Difference about your diy and original Xiaomi Gateway? It s costs 20 euros
Posted: Wednesday 24 October 2018 13:17
by gerbenvanasselt
But what, if you don't want to put you're data on a Chinese server? As far as I know you can not control the sensors without using the Xiaomi server. All traffic goes through the're servers.
!Update!
Found out that I had an old version of the plug-in installed. Pulled the update from Git and now I can control my tradfri dimmed bulb. I Hope the others Tradfri devices will be supported as well.
Thanks @Stan for this amazing plugin.
