Re: plugin Zigate (USB+WiFi) - 2.4.0
Posted: Wednesday 31 October 2018 23:13
by pipiche
@hkhk if you have the wall plug it could go to try to pair it.
Posted: Saturday 03 November 2018 20:05
by hkhk
Tried to do that but it's unclear to me how to do that.
Read somewhere to put a paperclip in the 'reset' button and that indeed resets the plug. Then you should keep it pressed for a few more seconds until the led fades.
But no device is added in Domoticz.
But also don't know how to read DeviceList.txt (see below) so maybe it is already in there but not recognized?
The 3 Ampoule.LED1622G12.Tradfri are the 3 Ikea Leds I have and those work.
I have 2 Tradfri wall plugs, one Tradfri Motion sensor and one Tradfri remote
541c : {'Model': 'Ampoule.LED1622G12.Tradfri', 'RSSI': {}, 'Battery': {}, 'IEEE': '90fd9ffffe13f8fe', 'RIA': '0', 'MacCapa': '8e', 'Type': {}, 'Status': 'inDB', 'Ep': {'01': {'0b05': {}, '0006': {}, '0005': {}, '0004': {}, '0003': {}, '0000': {}, '1000': {}, '0008': {}}}, 'Heartbeat': '1810', 'ZDeviceID': '0100', 'ProfileID': 'c05e'}
287f : {'Model': {}, 'RSSI': {}, 'Battery': {}, 'IEEE': 'd0cf5efffe6d3215', 'RIA': '10', 'MacCapa': '8e', 'Type': {}, 'Status': '004d', 'Ep': {}, 'Heartbeat': '0', 'ZDeviceID': {}, 'ProfileID': {}}
e12a : {'Model': 'Ampoule.LED1622G12.Tradfri', 'RSSI': {}, 'Battery': {}, 'IEEE': '90fd9ffffe15a28c', 'RIA': '0', 'MacCapa': '8e', 'Type': {}, 'Status': 'inDB', 'Ep': {'01': {'0b05': {}, '0006': {}, '0005': {}, '0004': {}, '0003': {}, '0000': {}, '1000': {}, '0008': {}}}, 'Heartbeat': '1810', 'ZDeviceID': '0100', 'ProfileID': 'c05e'}
c8ed : {'Model': {}, 'RSSI': {}, 'Battery': {}, 'IEEE': 'd0cf5efffe11b2bf', 'RIA': '10', 'MacCapa': '80', 'Type': {}, 'Status': 'UNKNOW', 'Ep': {'01': {'0b05': {}, '0003': {}, '0001': {}, '0000': {}, '0700': {}, '1000': {}, '0009': {}}}, 'Heartbeat': '1800', 'ZDeviceID': '0830', 'ProfileID': 'c05e'}
13e5 : {'Model': {}, 'RSSI': 194, 'Battery': {}, 'IEEE': 'd0cf5efffe11b2bf', 'RIA': '10', 'MacCapa': '80', 'Type': {}, 'Status': 'UNKNOW', 'Ep': {'01': {'0b05': {}, '0003': {}, '0001': {}, '0000': {}, '0700': {}, '1000': {}, '0009': {}}}, 'Heartbeat': '1800', 'ZDeviceID': '0830', 'ProfileID': 'c05e'}
4d76 : {'Model': {}, 'RSSI': {}, 'Battery': {}, 'IEEE': 'd0cf5efffe11b2bf', 'RIA': '10', 'MacCapa': '80', 'Type': {}, 'Status': '004d', 'Ep': {}, 'Heartbeat': '0', 'ZDeviceID': {}, 'ProfileID': {}}
44f8 : {'Model': 'Ampoule.LED1622G12.Tradfri', 'RSSI': {}, 'Battery': {}, 'IEEE': '000b57fffed4f4ee', 'RIA': '0', 'MacCapa': '8e', 'Type': {}, 'Status': 'inDB', 'Ep': {'01': {'0b05': {}, '0006': {}, '0005': {}, '0004': {}, '0003': {}, '0000': {}, '1000': {}, '0008': {}}}, 'Heartbeat': '1810', 'ZDeviceID': '0100', 'ProfileID': 'c05e'}
19d6 : {'Model': {}, 'RSSI': {}, 'Battery': {}, 'IEEE': 'd0cf5efffe11b2bf', 'RIA': '10', 'MacCapa': '80', 'Type': {}, 'Status': '004d', 'Ep': {}, 'Heartbeat': '0', 'ZDeviceID': {}, 'ProfileID': {}}
Posted: Saturday 03 November 2018 21:13
by pipiche
Let me try to help you a bit.
(1) Some entries can be remove, but do that after stoping domoticz.
(2) When you do the reset + pairing of the wall plug, you must have the Zigate Plugin with Permit join time on start set.
hkhk wrote: Saturday 03 November 2018 20:05
Here after is one of your Ikea LEAD
This one can be remove, looks like an uncompleted pairing.
Posted: Sunday 04 November 2018 15:22
by hkhk
I removed the 'bogus' entries and tried again.
When resetting the TradFri wall plug with paperclip, it indeed seems to go into announce mode.
The mac addresses of led's already know are:
90fd9ffffe15a28c
000b57fffed4f4ee
90fd9ffffe13f8fe
The new one (wall plug) has mac address d0cf5efffe6d3215
Log with zigate full log attached
Posted: Sunday 04 November 2018 17:25
by pipiche
You need to let the process going to the end , It looks from what I saw in the log that you did several reset/pairing.
If you have the possibility to restart from scratch , I would encourage you to use the beta-3.1.x version of the plugin. I cannot promise that the plug will work , but it will be easier to debug ...
You need to remove all Zigate from Domoticz. Basically delete them from the Devices list
to get the beta branch.
The beta version is much reliable and resiliant
