UV index readings realtime Topic is solved
Jan Jansen
Domoticz version: Stable
Re: UV index readings realtime
Post by Jan Jansen »
@ Waaren,
Thanks for your quick reply, the script now works as desired.
Jan
Derik
Post by Derik »
Thanks for the great work.
Try to get the flow working from @firewizard.. Only my nr is not so good..:=-(
So i see this option looks easer to me. [ dz vents..:-)
Set the code.
Make all the dummys.
Only i see differents here in the topic.
Sunpower ozon/uv etc.
In the flow from Firewizard i see a a Alarm for the next day?
Is there a perhaps som option to set the exact dummys i need for the vaulue OpenUV is using.
I see a lot of options.
In the flow i see:
https://www.domoticz.com/forum/viewtopi ... 38#p247462
On this topic i see:
4 Devices: From @waaren
https://www.domoticz.com/forum/viewtopi ... uv#p249016
And two other? from @janjansen
https://www.domoticz.com/forum/viewtopi ... v#p249126
Sorry i am a noob in the value's
This option is looking great in this extrem warm period.. To protect my childs..
So is the alarm also possible in Dz vents?
Stil have errors?
2020-06-01 16:19:20.052 Error: dzVents: Error: (3.0.8) module 'D.M.: UV - Ozon DZ 2' not found:
2020-06-01 16:19:20.052 no field package.preload['D.M.: UV - Ozon DZ 2']
2020-06-01 16:19:20.052 no file '/home/pi/domoticz/scripts/dzVents/D/M/: UV - Ozon DZ 2.lua'
2020-06-01 16:19:20.052 no file '/home/pi/domoticz/dzVents/runtime/D/M/: UV - Ozon DZ 2.lua'
2020-06-01 16:19:20.052 no file '/home/pi/domoticz/dzVents/runtime/device-adapters/D/M/: UV - Ozon DZ 2.lua'
2020-06-01 16:19:20.052 no file '/home/pi/domoticz/scripts/dzVents/dzVents/D/M/: UV - Ozon DZ 2.lua'
2020-06-01 16:19:20.052 no file '/home/pi/domoticz/scripts/dzVents/scripts/D/M/: UV - Ozon DZ 2.lua'
2020-06-01 16:19:20.052 no file '/home/pi/domoticz/scripts/dzVents/../lua/D/M/: UV - Ozon DZ 2.lua'
2020-06-01 16:19:20.052 no file '/home/pi/domoticz/scripts/dzVents/scripts/modules/D/M/: UV - Ozon DZ 2.lua'
2020-06-01 16:19:20.052 no file '/home/pi/domoticz/scripts/dzVents/generated_scripts/D/M/: UV - Ozon DZ 2.lua'
2020-06-01 16:19:20.052 no file '/home/pi/domoticz/scripts/dzVents/data/D/M/: UV - Ozon DZ 2.lua'
2020-06-01 16:19:20.052 no file '/home/pi/domoticz/scripts/dzVents/modules/D/M/: UV - Ozon DZ 2.lua'
2020-06-01 16:19:20.052 no file '/usr/local/share/lua/5.3/D/M/: UV - Ozon DZ 2.lua'
2020-06-01 16:19:20.052 no file '/usr/local/share/lua/5.3/D/M/: UV - Ozon DZ 2/init.lua'
2020-06-01 16:19:20.052 no file '/usr/local/lib/lua/5.3/D/M/: UV - Ozon DZ 2.lua'
2020-06-01 16:19:20.052 no file '/usr/local/lib/lua/5.3/D/M/: UV - Ozon DZ 2/init.lua'
2020-06-01 16:19:20.052 no file '/usr/share/lua/5.3/D/M/: UV - Ozon DZ 2.lua'
2020-06-01 16:19:20.052 no file '/usr/share/lua/5.3/D/M/: UV - Ozon DZ 2/init.lua'
2020-06-01 16:19:20.052 no file './D/M/: UV - Ozon DZ 2.lua'
2020-06-01 16:19:20.052 no file './D/M/: UV - Ozon DZ 2/init.lua'
2020-06-01 16:19:20.052 no file '/usr/local/lib/lua/5.3/D/M/: UV - Ozon DZ 2.so'
2020-06-01 16:19:20.052 no file '/usr/lib/aarch64-linux-gnu/lua/5.3/D/M/: UV - Ozon DZ 2.so'
2020-06-01 16:19:20.052 no file '/usr/lib/lua/5.3/D/M/: UV - Ozon DZ 2.so'
2020-06-01 16:19:20.052 no file '/usr/local/lib/lua/5.3/loadall.so'
2020-06-01 16:19:20.052 no file './D/M/: UV - Ozon DZ 2.so'
2020-06-01 16:19:20.052 no file '/usr/local/lib/lua/5.3/D.so'
2020-06-01 16:19:20.052 no file '/usr/lib/aarch64-linux-gnu/lua/5.3/D.so'
2020-06-01 16:19:20.052 no file '/usr/lib/lua/5.3/D.so'
2020-06-01 16:19:20.052 no file './D.so'
Derik wrote: Monday 01 June 2020 16:03 Stil have errors?
Try to use names without . and /
Derik
Post by Derik »
I do not have names like that:
j settings [ changed api and others ]
    data    =   {   openUV_Longitude          = {initial = "6.823890"                           },  -- I store my longitude, latitude, APIkey, filename in data
                    openUV_Latitude           = {initial = "81.879560"                          },  -- You can get them from domoticz settings
                    openUV_Filename           = {initial = "/home/pi/domoticz/scripts/dzVents/data/OpenUV.json"   },  -- path relative to domoticz directory
                    openUV_APIKey             = {initial = "5f1327281a5c967a6e333ee91652"   },  -- get your free API key from https://www.openuv.io/
                    openUV_currentUV_device   = {initial = 13573                                },  -- Oosterhout: UV
                    openUV_maxUV_device       = {initial = 13575                                },  --Oosterhout: UV Max
                    openUV_UV_Alert_device    = {initial = 13574                                },  -- Oosterhout: UV Alarm
                    openUV_ozone_Alert_device = {initial = 13577                                },  -- Oosterhout: UV Max Tijd
I think i ms the path?
What is the path going to? i do not see a json file?
Derik wrote: Monday 01 June 2020 17:09 I do not have names like that:
You scriptName does contain these characters.
you can remove this line. It is no longer in use
Derik
Post by Derik »
Sorry will chance that.
I use the intern editor..
Is that a problem?
Derik wrote: Monday 01 June 2020 17:51 Sorry will change that.
Is that a problem?
No that's ok.
EdwinK
Post by EdwinK »
Still can't get it to work. Ready to quit.
Derik
Post by Derik »
Look there is something a live...
Only not all think they are waiting when value is changing?
Is there realy a great problem when i use some -_ ? : - or something like that?
That could explane a lot of other strange stuf in my system...
Edit:
See the errors in the log:
2020-06-01 18:20:04.583 Error: dzVents: Error: (3.0.8) openUV: Method updateUV is not available for device "Oosterhout: UV" (deviceType=General, deviceSubType=Custom Sensor). If you believe this is not correct, please report.
2020-06-01 18:20:04.584 Error: dzVents: Error: (3.0.8) openUV: Method updateUV is not available for device "Oosterhout: UV Max" (deviceType=General, deviceSubType=Alert). If you believe this is not correct, please report.
2020-06-01 18:20:04.654 Error: dzVents: Error: (3.0.8) openUV: Method updateAlertSensor is not available for device "Oosterhout: UV Max Tijd" (deviceType=General, deviceSubType=Custom Sensor). If you believe this is not correct, please report.
2020-06-01 18:30:08.937 Error: dzVents: Error: (3.0.8) openUV: Method updateUV is not available for device "Oosterhout: UV" (deviceType=General, deviceSubType=Custom Sensor). If you believe this is not correct, please report.
2020-06-01 18:30:08.938 Error: dzVents: Error: (3.0.8) openUV: Method updateUV is not available for device "Oosterhout: UV Max" (deviceType=General, deviceSubType=Alert). If you believe this is not correct, please report.
2020-06-01 18:30:09.020 Error: dzVents: Error: (3.0.8) openUV: Method updateAlertSensor is not available for device "Oosterhout: UV Max Tijd" (deviceType=General, deviceSubType=Custom Sensor). If you believe this is not correct, please report.
2020-06-01 18:40:05.209 Error: dzVents: Error: (3.0.8) openUV: Method updateUV is not available for device "Oosterhout: UV" (deviceType=General, deviceSubType=Custom Sensor). If you believe this is not correct, please report.
2020-06-01 18:40:05.210 Error: dzVents: Error: (3.0.8) openUV: Method updateUV is not available for device "Oosterhout: UV Max" (deviceType=General, deviceSubType=Alert). If you believe this is not correct, please report.
2020-06-01 18:40:05.280 Error: dzVents: Error: (3.0.8) openUV: Method updateAlertSensor is not available for device "Oosterhout: UV Max Tijd" (deviceType=General, deviceSubType=Custom Sensor). If you believe this is not correct, please report.
Derik wrote: Monday 01 June 2020 18:42 Look there is something a live...
Edit:
If you look at the script I Posted, you will see that
-- You have to create a couple of virtual devices
-- (first two as UV sensors and other two as Alert)
You used other device types and therefore the commands do not work.
Derik
Post by Derik »
Changed the dummy's
Now i get a login error?
2020-06-02 07:19:01.037 Error: Error opening url: https://api.openuv.io/api/v1/uv?lat=51.879560&lng=5.823890
2020-06-02 07:19:04.186 Status: dzVents: Info: Handling httpResponse-events for: "openUV_Response"
2020-06-02 07:19:04.186 Error: dzVents: Error: (3.0.8) openUV: HTTP/1.1 response: 403 ==>> Forbidden
2020-06-02 07:19:04.187 Error: dzVents: Error: (3.0.8) openUV: An error occurred when calling event handler Weer UV Ozon DZ 2
2020-06-02 07:19:04.187 Error: dzVents: Error: (3.0.8) openUV: .../scripts/dzVents/generated_scripts/Weer UV Ozon DZ 2.lua:61: attempt to index a nil value (field 'result')
2020-06-02 07:19:05.109 (D.M.: RFXcomE) Temp (D.M.: Garage)
I use the token on the site. [ copy paste ]
only a nill?
EdwinK
Post by EdwinK »
Because I didn't get any readings from Openuv.io I tried what would happen if I ping their service
MacBook-van-Edwin:~ edwin$ ping www.openuv.io
PING www.openuv.io.herokudns.com (52.21.175.83): 56 data bytes
Request timeout for icmp_seq 0
Request timeout for icmp_seq 1
Request timeout for icmp_seq 2
Request timeout for icmp_seq 3
Request timeout for icmp_seq 4
Request timeout for icmp_seq 5
Request timeout for icmp_seq 6
Request timeout for icmp_seq 7
Request timeout for icmp_seq 8
Request timeout for icmp_seq 9
^C
--- www.openuv.io.herokudns.com ping statistics ---
11 packets transmitted, 0 packets received, 100.0% packet loss
ping openuv.io
PING openuv.io (192.64.119.115): 56 data bytes
64 bytes from 192.64.119.115: icmp_seq=0 ttl=49 time=152.101 ms
64 bytes from 192.64.119.115: icmp_seq=1 ttl=49 time=150.968 ms
64 bytes from 192.64.119.115: icmp_seq=2 ttl=49 time=150.800 ms
64 bytes from 192.64.119.115: icmp_seq=3 ttl=49 time=149.631 ms
64 bytes from 192.64.119.115: icmp_seq=4 ttl=49 time=151.367 ms
64 bytes from 192.64.119.115: icmp_seq=5 ttl=49 time=154.374 ms
^C
--- openuv.io ping statistics ---
6 packets transmitted, 6 packets received, 0.0% packet loss
round-trip min/avg/max/stddev = 149.631/151.540/154.374/1.466 ms
Traceroute gives the folllowing.
1  192.168.0.1 (192.168.0.1)  4.285 ms  0.989 ms  1.591 ms
 2  002-112-158-163.dynamic.caiway.nl (163.158.112.2)  3.857 ms  4.676 ms  4.010 ms
 3  cn-asd-kl-cr15-be2003-2010.caiw.net (62.45.30.229)  4.033 ms  3.614 ms  5.515 ms
 4  et-0-0-47.cr3-ams2.ip4.gtt.net (92.60.243.125)  3.205 ms  3.144 ms  3.306 ms
 5  ae3.cr4-ams1.ip4.gtt.net (89.149.181.54)  14.783 ms
    ae7.cr4-ams1.ip4.gtt.net (213.200.117.170)  21.421 ms  30.869 ms
 6  ip4.gtt.net (46.33.83.250)  6.365 ms  4.635 ms  4.913 ms
 7  ae-18.r25.amstnl02.nl.bb.gin.ntt.net (129.250.2.108)  4.692 ms  4.693 ms  11.416 ms
 8  ae-5.r23.asbnva02.us.bb.gin.ntt.net (129.250.6.162)  84.028 ms  90.513 ms  89.984 ms
 9  ae-0.r22.asbnva02.us.bb.gin.ntt.net (129.250.3.84)  84.176 ms  90.008 ms  88.885 ms
10  ae-5.r23.lsanca07.us.bb.gin.ntt.net (129.250.3.189)  148.441 ms  181.022 ms  155.696 ms
11  ae-2.r01.lsanca07.us.bb.gin.ntt.net (129.250.4.107)  145.726 ms  150.245 ms  149.278 ms
12  192.80.17.102 (192.80.17.102)  155.166 ms  153.422 ms  148.759 ms
13  * * *
14  * * *
15  * * *
16  * * *
17  * * *
18  * * *
19  * * *
20  * * *
21  * * *
22  * * *
23  * * *
24  * * *
25  * * *
26  * * *
27  * * *
28  * * *
29  * * *
30  * * *
31  * * *
32  * * *
33  * * *
34  * * *
35  * * *
36  * * *
37  * * *
38  * * *
39  * * *
40  * * *
41  * * *
42  * * *
43  * * *
44  * * *
45  * * *
46  * * *
and so on
FireWizard
Post by FireWizard »
@EdwinK
If you want to show, that www.openuv.io is not available and that this explains that you don't get an answer, this is the wrong method.
A network administrator has the possibility to disable an ICMP request, so that a host will not respond to a ping request.
Beside that there might be other reasons that a ping fails.
To test it, you may want to use another tool, such as Angry IP Scanner, which uses a different method.
You will see, that the site is alive.
See: https://angryip.org/
Derik wrote: Tuesday 02 June 2020 7:23 Changed the dummy's
only a nill?
If you send the script as you have it now via PM I will have a look
EdwinK
Post by EdwinK »
I guess i then better give up.
Toulon7559
Domoticz version: <2025
Post by Toulon7559 »
Experiments sometimes leave undesired components.
Now running the dzVents-script to get the info & json-file from OpenUV.
Also tried the plugin: OK, but means double rate of calling, and therefore deleted.
During deletion of the plugin first removed the related devices and then deleted the folder with plugin.py
After subsequent reboot however a repeating error-report in the Log:
2020-06-08 18:07:10.383 Error: OpenUV2 hardware (15) thread seems to have ended unexpectedly
How to get rid of that error report ( other ;-) than by installation of the plugin)?
Toulon7559 wrote: Monday 08 June 2020 18:15
Did you also remove the plugin from the hardware tab?
Toulon7559
:oops: Thanks for the hint
Benneton
Post by Benneton »
@Waaren,
Super script you wrote thank you. I just copied and paste it and updated with my config details.
Working like a charm :)
@Jan Jansen
I see in your post that you have the "Zonnekracht in watt/m2, is there a conversion done or is this value available from the OpenUV.io?
I would like to have this one too, with it I can calculate what my solar panels should do (approx.)
Thank you for letting me know, how that is done.
Bernard
Jan Jansen
Benneton wrote: Wednesday 05 August 2020 20:27
@Jan Jansen
Bernard
Bernard,
I switched from Darksky to OpenWeatherMap via Buienradar. On that route I lost the sensor 'Zonnekracht'.
Jan
