Page 2 of 2
Re: 433Mhz Touch Remote -> Sonoff RF Bridge -> Domoticz
Posted: Monday 17 December 2018 9:24
by peterdr
Ok i will try that this evening.
Ah the if rfkey1 ==idx1 is looking to the idx1 more to the top where i fill in the idx of the light i try to switch on (idx7)
The import line i had before good. Why the as mqtt is away i don't know.
I will add this tonight also again.
But also with i had also no paho client.
But i will test it this evening.
I want to thank you for your help so far.
:D
Posted: Monday 17 December 2018 20:00
by peterdr
I still got this
2018-12-17 19:57:00.374 Error: EventSystem: Failed to execute python event script "Bridge-test"
2018-12-17 19:57:00.374 Error: EventSystem: Traceback (most recent call last):
2018-12-17 19:57:00.375 Error: EventSystem: File "<string>", line 10, in <module>
2018-12-17 19:57:00.375 Error: EventSystem: ImportError: No module named 'paho'
This is the file now
'<#!/usr/local/python3
Python script to read rfkey number from Sonoff 433MHz RF Bridge
and control corresponding Domoticz.
This example only set up for 2 devices; extend by adding idx's in on_message.
(Not very pretty code!)
import paho.mqtt.client as mqtt
import time
import json
import requests
### substitute your values here ###
broker_address="localhost" # port = 1883 by default
topic = "sonoffbridge"
dom_cmd = "http://127.0.0.1:8080/json.htm?type=com ... cmd=Toggle"
idx1 = 7
idx2 = 0
def on_message(client, userdata, message):
print ("message received " ,str(message.payload.decode("utf-8")))
jsonData = json.loads(message.payload)
rfkey = jsonData['RfReceived']['RfKey']
print ("rfkey")
if rfkey == 1:
idx = idx1
elif rfkey == 2:
idx = idx2
else:
return
url = dom_cmd + "&idx=" + str(idx)
print ("url")
r = requests.get(url)
#print "message topic=",message.topic
#print "message qos=",message.qos
#print "message retain flag=",message.retain
print("creating new instance")
client = mqtt.Client("P1") #create new instance
client.on_message=on_message #attach function to callback
print("connecting to broker")
client.connect(broker_address) #connect to broker
client.loop_start() #start the loop
print("Subscribing to topic ") + topic
client.subscribe("tele/" + topic + "/RESULT")
time.sleep(2) # wait
client.loop_forever() #loop forever
client.loop_forever() #loop forever>'
Posted: Monday 17 December 2018 21:06
by peterdr
The paho is runnung.
From cmd it is working.
I think domoticz doesn't look in the right folder.
The python is here
/usr/lib/python2.7/dist-packages/
also the version 3 is in this folder.
So how can i tell the script where to look?
Posted: Monday 17 December 2018 22:11
by MikeF
In my script, the ‘shebang’ (line 1) is
#!/usr/bin/env python
(or python3, if you’re using that).
I think (not sure) that the use of env ensures that the right path is used to find installed modules (such as paho).
Posted: Monday 17 December 2018 23:15
by peterdr
I had it also on python3 but it says the same.
Pfff I don't know anymore.
Posted: Monday 17 December 2018 23:36
by peterdr
I changed the path to what you wrote.
The python is there as there is also the 3
Posted: Saturday 22 December 2018 19:45
by peterdr
Domoticz is going to be a dissapointing thing.
After christmas i am going to look how Homeassistant works.
I just cannot let a light switch on and off with a 433mhz 2 remote button.
The python on the raspbery is not accessable through home assistant.
In command screen it works.
So the python scripts in Domoticz are just not working.
Posted: Sunday 06 January 2019 22:25
by peterdr
So everybody a good newyear.
Today i decided to go back to my domoticz project.
I have made also a raspberry server with homeassistant.
This is working also with everything but also here no bridge.
Now i decided to focus on domoticz and go on with this.
I deinstaled all the python and autoremove for cleanup.
After this i installed python back and install pip and at last the paho-mqtt client.
From the command screen it seems to be working correct.
But when i start the scrypt again i got again paho client no module with this name.
How is this possible?
The first row i tried everything witn python and python3 and env python and env python3 but no result.
2019-01-06 18:29:00.418 Error: EventSystem: Failed to execute python event script "Bridge-test"
2019-01-06 18:29:00.419 Error: EventSystem: Traceback (most recent call last):
2019-01-06 18:29:00.419 Error: EventSystem: File "<string>", line 10, in <module>
2019-01-06 18:29:00.419 Error: EventSystem: ImportError: No module named 'paho'
import time
import json
import requests
Posted: Saturday 09 March 2019 15:28
by omega001
You can check this, maybe is this easiest
https://www.domoticz.com/forum/viewtopi ... 74&t=27284
Posted: Tuesday 19 March 2019 19:41
by peterdr
Thanks i will try this.
Posted: Tuesday 26 March 2019 18:36
by peterdr
Ok thank you for the reactions.
@omega001
Now i have the bridge working with blocky.
The fun is coming back.
Thank you so much.
