433Mhz Touch Remote -> Sonoff RF Bridge -> Domoticz
peterdr
Re: 433Mhz Touch Remote -> Sonoff RF Bridge -> Domoticz
Post by peterdr »
Ok i will try that this evening.
Ah the if rfkey1 ==idx1 is looking to the idx1 more to the top where i fill in the idx of the light i try to switch on (idx7)
The import line i had before good. Why the as mqtt is away i don't know.
I will add this tonight also again.
But also with i had also no paho client.
But i will test it this evening.
I want to thank you for your help so far.
:D
peterdr
Post by peterdr »
I still got this
2018-12-17 19:57:00.374 Error: EventSystem: Failed to execute python event script "Bridge-test"
2018-12-17 19:57:00.374 Error: EventSystem: Traceback (most recent call last):
2018-12-17 19:57:00.375 Error: EventSystem: File "<string>", line 10, in <module>
2018-12-17 19:57:00.375 Error: EventSystem: ImportError: No module named 'paho'
This is the file now
'<#!/usr/local/python3
Python script to read rfkey number from Sonoff 433MHz RF Bridge
and control corresponding Domoticz.
This example only set up for 2 devices; extend by adding idx's in on_message.
(Not very pretty code!)
import paho.mqtt.client as mqtt
import time
import json
import requests
### substitute your values here ###
broker_address="localhost" # port = 1883 by default
topic = "sonoffbridge"
dom_cmd = "http://127.0.0.1:8080/json.htm?type=com ... cmd=Toggle"
idx1 = 7
idx2 = 0
def on_message(client, userdata, message):
print ("message received " ,str(message.payload.decode("utf-8")))
jsonData = json.loads(message.payload)
rfkey = jsonData['RfReceived']['RfKey']
print ("rfkey")
if rfkey == 1:
idx = idx1
elif rfkey == 2:
idx = idx2
else:
return
url = dom_cmd + "&idx=" + str(idx)
print ("url")
r = requests.get(url)
#print "message topic=",message.topic
#print "message qos=",message.qos
#print "message retain flag=",message.retain
print("creating new instance")
client = mqtt.Client("P1") #create new instance
client.on_message=on_message #attach function to callback
print("connecting to broker")
client.connect(broker_address) #connect to broker
client.loop_start() #start the loop
print("Subscribing to topic ") + topic
client.subscribe("tele/" + topic + "/RESULT")
time.sleep(2) # wait
client.loop_forever() #loop forever
client.loop_forever() #loop forever>'
peterdr
Post by peterdr »
The paho is runnung.
From cmd it is working.
I think domoticz doesn't look in the right folder.
The python is here
/usr/lib/python2.7/dist-packages/
also the version 3 is in this folder.
So how can i tell the script where to look?
MikeF
Domoticz version: V2022.2
Post by MikeF »
In my script, the ‘shebang’ (line 1) is
#!/usr/bin/env python
(or python3, if you’re using that).
I think (not sure) that the use of env ensures that the right path is used to find installed modules (such as paho).
peterdr
Post by peterdr »
I had it also on python3 but it says the same.
Pfff I don't know anymore.
peterdr
Post by peterdr »
I changed the path to what you wrote.
The python is there as there is also the 3
peterdr
Post by peterdr »
Domoticz is going to be a dissapointing thing.
After christmas i am going to look how Homeassistant works.
I just cannot let a light switch on and off with a 433mhz 2 remote button.
The python on the raspbery is not accessable through home assistant.
In command screen it works.
So the python scripts in Domoticz are just not working.
peterdr
Post by peterdr »
So everybody a good newyear.
Today i decided to go back to my domoticz project.
I have made also a raspberry server with homeassistant.
This is working also with everything but also here no bridge.
Now i decided to focus on domoticz and go on with this.
I deinstaled all the python and autoremove for cleanup.
After this i installed python back and install pip and at last the paho-mqtt client.
From the command screen it seems to be working correct.
But when i start the scrypt again i got again paho client no module with this name.
How is this possible?
The first row i tried everything witn python and python3 and env python and env python3 but no result.
2019-01-06 18:29:00.418 Error: EventSystem: Failed to execute python event script "Bridge-test"
2019-01-06 18:29:00.419 Error: EventSystem: Traceback (most recent call last):
2019-01-06 18:29:00.419 Error: EventSystem: File "<string>", line 10, in <module>
2019-01-06 18:29:00.419 Error: EventSystem: ImportError: No module named 'paho'
import time
import json
import requests
omega001
Post by omega001 »
You can check this, maybe is this easiest
https://www.domoticz.com/forum/viewtopi ... 74&t=27284
peterdr
Post by peterdr »
Thanks i will try this.
peterdr
Post by peterdr »
Ok thank you for the reactions.
@omega001
Now i have the bridge working with blocky.
The fun is coming back.
Thank you so much.
