dzVents get garbage collection dates (various)  [SOLVED]
Re: dzVents get garbage collection dates from inzamelkalender.hvcgroep.nl
Huntback wrote: Friday 14 September 2018 12:36
waaren wrote: Tuesday 11 September 2018 21:24
Superpjeter wrote: Tuesday 11 September 2018 19:42 Thanks for your offer but I already figured it out
Good to read. Can you please share your solution for the benefit of other forum users ?
Thx
.. So would you please, if you have time for it, take a to look at the script so that this can also work for https://afvalkalender.circulus-berkel.nl?
Will do but still traveling so please don't expect anything until late next week
Huntback wrote: Friday 14 September 2018 12:36 So would you please, if you have time for it, take a to look at the script so that this can also work for https://afvalkalender.circulus-berkel.nl?
Some adjustments were needed to the original script because circulus-berkel return a JSON that must be reformatted before it can be used as a Lua table with consecutive record numbers.
Also introduced an extra initial step to get the bagId automatically based on zipCode / houseNumber
Could you please test this and report your findings ?
--[[ getGarbageDates.lua for [ dzVents >= 2.4 ]
this script is only useful in those  areas of the Netherlands where circulus-berkel is the garbage collector
Enter your zipcode and housenumber and your virtual text and or virtual alert device in the
appropriate place between the lines starting with --++++
the text device will contain the most nearby collectdates for the four types of household garbage
the alert device will contain the date and type for the garbagecollection that will arrive first
local prefix        = "getGarbageDates"
local httpresponse  = prefix .. "Response"
local triggerDevice = prefix .. "Trigger"
local logMarker     = prefix .. "Marker"
return
     on      =  {   devices        =   { triggerDevice },            -- Just for development and test ; ignored when live
                    timer          =   { "at 00:05","at 08:00" },    -- daily run twice
                    httpResponses  =  { httpresponse }               -- Trigger the handle Json part
--    logging =   {   level       =   domoticz.LOG_DEBUG,              -- Remove the "-- at the beginning of this and next line for debugging the script
--                  marker        =   logMarker      },
    data    =   {   garbage     = { initial = {} },                  -- Keep a copy of last json just in case
                    bagID       = { initial = "Not set yet" },
                    ZipCode     = { initial = "not set yet" },
                    HouseNumber = { initial = "not set yet" },
    execute = function(dz, triggerObject)
        --++++--------------------- Mandatory: Set your values and device names below this Line --------------------------------------
        local myZipCode     = "7328CK"
        local myHouseNumber = 46
        local myTextDevice  = "GarbageText"       -- Name with quotes or idx without when created as virtual text device
        local myAlertDevice = "GarbageAlert"      -- Name with quotes or idx without when created as virtual alert device
        --++++---------------------------- Set your values and device names above this Line --------------------------------------------
        local myProvider    = "https://afvalkalender.circulus-berkel.nl"
        local myYear        = os.date("%Y")
        garbageTypes  = {13,7,8,10}                -- Valid for circulus-berkelfor but these numbers vary per garbageCollector; Why ??
         -- ("13","  Boeken, Elektrische apparaten, Speelgoed en Textiel  ")
         -- ("7","  Groente-, fruit- en tuin afval            ")
         --  ("10","  Papier en kartonnen verpakkingen          ")
         --  ("8","  Restafval                                ")
        -- get BagId based on Zipcode / Housenumber
        local function collectBagId(secondsFromNow)
            local getBagId_url  = myProvider .. "/rest/adressen/" .. myZipCode .."-" .. myHouseNumber
            dz.openURL  ({  url         = getBagId_url ,
                            method      = "GET",
                            callback    = httpresponse}).afterSec(secondsFromNow)
        -- get garbage collect Year calendar
        local function collectGarbageDates(secondsFromNow)
            local getGarbage_url  = myProvider .. "/rest/adressen/" .. dz.data.bagID .. "/kalender/" .. myYear
            dz.openURL  ({  url         = getGarbage_url ,
                            method      = "GET",
        -- Add entry to log and notify to all subsystems
        local function errorMessage(message)
            dz.log(message,dz.LOG_ERROR)
            dz.notify(message)
        local function string2Epoch(dateString) -- seconds from epoch based on stringdate (used by string2Date)
            -- Assuming a date pattern like: yyyy-mm-dd
            local pattern = "(%d+)-(%d+)-(%d+)"
            local runyear, runmonth, runday= dateString:match(pattern)
            local convertedTimestamp = os.time({year = runyear, month = runmonth, day = runday})
            return convertedTimestamp
        local function string2Date(str,fmt)             -- convert string from json into datevalue
            if fmt then return os.date(fmt,string2Epoch(str)) end
            return os.date(" %A %d %B, %Y",string2Epoch(str))
        local function alertLevel(delta)
            if delta < 2 then return dz.ALERTLEVEL_RED end
            if delta < 3 then return dz.ALERTLEVEL_YELLOW end
            if delta < 4 then return dz.ALERTLEVEL_ORANGE end
            return dz.ALERTLEVEL_GREEN
        local function setGarbageAlertDevice(alertDevice,alertText,alertDate)
            local delta = tonumber(string2Date(alertDate,"%d")) - tonumber(os.date("%d"))  -- delta in days between today and first garbage collection date
            dz.devices(alertDevice).updateAlertSensor(alertLevel(delta),alertText)
            return (delta == 0)
        local function longGarbageName(str)                                        -- Use descriptive strings
            str = tostring(str)
            str = str:gsub("13","  Boeken, Elektrische apparaten, Speelgoed en Textiel  ")
            str = str:gsub("7","  Groente-, fruit- en tuin afval            ")
            str = str:gsub("10","  Papier en kartonnen verpakkingen          ")
            str = str:gsub("8","  Restafval                                ")
            return str
        -- extract bafId from json and store in persistent data
        local function getBagID()
            rt = dz.utils.fromJSON(triggerObject.data)
            dz.data.bagID = rt[1].bagId
            collectGarbageDates(1)
        local function handleResponse()
            dz.log(dz.data.bagID,dz.LOG_DEBUG)
            if dz.data.bagID == "Not set yet"  then
               getBagID()
               return
            rt , rtRaw = {}
            rtRaw = dz.utils.fromJSON(triggerObject.data)         -- dzVents does nor recognize the response as pure JSON so conversion is required
            if rtRaw["1"] ~=  nil then
                for k, v in pairs(rtRaw) do                        -- Extra step is necessary because json is not standard and some records are missing
                    table.insert( rt, { ophaaldatum = v.ophaaldatum , afvalstroom_id = v.afvalstroom_id })
                dz.data.garbage = rt
                errorMessage("Problem with response from  (no data) using data from earlier run")
                rt  = dz.data.garbage                       -- json empty. Get last valid from dz.data
                if #rt < 1 then                              -- No valid data in dz.data either
                    errorMessage("No previous data. are zipcode and housenumber ok and in circulus-berkel area?")
                    return false
            local garbageLines = ""
            local typeEarliestDate
            local typeEarliestKind
            local overallEarliestDate   = "2999-12-31"       -- Hopefully we will have a different garbage collection system by then
            local garbageToday = false
            local today = os.date("%Y-%m-%d")
            for i = 1,#garbageTypes do --walk the the type Table
                 dz.log("Checking " .. garbageTypes[i],dz.LOG_DEBUG)
                typeEarliestDate      = "2999-12-31"
                for j = 1, #rt do                                 -- walk the result Table
                            -- walk the response table
                    if  rt[j].ophaaldatum >= today and rt[j].ophaaldatum < typeEarliestDate and
                        rt[j].afvalstroom_id == garbageTypes[i] then  -- Keep date closest to today per type
                        typeEarliestDate =  rt[j].ophaaldatum
                        typeEarliestKind =  rt[j].afvalstroom_id
                        if  typeEarliestDate < overallEarliestDate then  -- date closest to today overall ?
                            overallEarliestDate = typeEarliestDate      -- keep date
                            overallEarliestType =  garbageTypes[i]            -- keep type
                garbageLines = garbageLines .. string2Date(typeEarliestDate,"%a %e %b" ) .. longGarbageName(typeEarliestKind) .. " " .. "\n"
            if myAlertDevice then   -- Update AlertDevice with nearby date / type
                garbageToday = setGarbageAlertDevice(  myAlertDevice,
                                                        longGarbageName(overallEarliestType) .. "\n" ..
                                                        string2Date(overallEarliestDate),
            if myTextDevice then       -- Update defined virtual text device with dates / types
                dz.devices(myTextDevice).updateText(garbageLines)
            if dz.time.matchesRule("at 08:00-17:00") and garbageToday then
                dz.notify(longGarbageName(overallEarliestType) .. "will be collected today")
        -- Main
        if triggerObject.isHTTPResponse then
            if triggerObject.ok then
                handleResponse()
                errorMessage("Problem with response from " .. myProvider .. " (not ok)")
                collectGarbageDates(600)                            -- response not OK, try again after 10 minutes
            if dz.data.bagID == "Not set yet"  or dz.data.ZipCode ~= myZipCode or dz.data.HouseNumber ~= myHouseNumber then
            -- Initial or something changed in zipCode / HouseNumebr
                dz.data.ZipCode     = myZipCode
                dz.data.HouseNumber = myHouseNumber
                dz.data.bagID       = "Not set yet"
                collectBagId(1)
Huntback
Domoticz version: 2024.2
Re: dzVents get garbage collection dates (various)
Post by Huntback »
hello waaren,
The script is now working :)
'myTextDevice' and 'myAlertDevice' were updated immediately.
First garbage collection day is here next Thursday, on that day also the notification in the 'myAlertDevice' must be updated with "will be collected today".
I now assume that this also works.
If not or with other problems with the script then I report again.
For now thank you very much for the quick response and the modification of the script.
Synology - DS411+II
Synology - DS918+
RFXCOM - RFXtrx433XL (LAN)
Oregon - Weatherstation
Some KAKU, Impuls, TFA, etc.
delcara
Domoticz version: 4.10171
Post by delcara »
Hello Waaren,
I'm trying to create a script to get garbage collection dates from ROVA. I've discovered how to get the dates through a curl command. But I've no idea how to translate this to a dzVents script. I've just started with DzVents and have now translated all my blockly to DzVents (relatively simple scripts to control lights etc.). Can you help to translate this curl command to a DzVents script?
curl -v --cookie "RovaLc_inwoners={\"Id\":160267,\"ZipCode\":\"8103JB\",\"HouseNumber\":\"15\",\"HouseAddition\":null,\"Municipality\":\"Raalte\",\"Province\":null,\"Firstname\":null,\"Lastname\":null,\"UserAgent\":\"\",\"School\":null,\"Street\":null,\"Country\":null,\"Portal\":null,\"AreaLevel\":5,\"City\":\"Raalte\",\"Ip\":null}" https://www.rova.nl/api/TrashCalendar/GetCalendarItems?portal=inwoners
Then the output lookes like this:
*   Trying 141.138.194.225...
* TCP_NODELAY set
* Connected to www.rova.nl (141.138.194.225) port 443 (#0)
* ALPN, offering h2
* ALPN, offering http/1.1
* Cipher selection: ALL:!EXPORT:!EXPORT40:!EXPORT56:!aNULL:!LOW:!RC4:@STRENGTH
* successfully set certificate verify locations:
*   CAfile: /etc/ssl/certs/ca-certificates.crt
  CApath: /etc/ssl/certs
* TLSv1.2 (OUT), TLS header, Certificate Status (22):
* TLSv1.2 (OUT), TLS handshake, Client hello (1):
* TLSv1.2 (IN), TLS handshake, Server hello (2):
* TLSv1.2 (IN), TLS handshake, Certificate (11):
* TLSv1.2 (IN), TLS handshake, Server key exchange (12):
* TLSv1.2 (IN), TLS handshake, Server finished (14):
* TLSv1.2 (OUT), TLS handshake, Client key exchange (16):
* TLSv1.2 (OUT), TLS change cipher, Client hello (1):
* TLSv1.2 (OUT), TLS handshake, Finished (20):
* TLSv1.2 (IN), TLS change cipher, Client hello (1):
* TLSv1.2 (IN), TLS handshake, Finished (20):
* SSL connection using TLSv1.2 / ECDHE-RSA-AES256-SHA384
* ALPN, server did not agree to a protocol
* Server certificate:
*  subject: CN=www.rova.nl
*  start date: Oct 30 06:51:49 2018 GMT
*  expire date: Jan 28 06:51:49 2019 GMT
*  subjectAltName: host "www.rova.nl" matched cert's "www.rova.nl"
*  issuer: C=US; O=Let's Encrypt; CN=Let's Encrypt Authority X3
*  SSL certificate verify ok.
> GET /api/TrashCalendar/GetCalendarItems?portal=inwoners HTTP/1.1
> Host: www.rova.nl
> User-Agent: curl/7.52.1
> Accept: */*
> Cookie: RovaLc_inwoners={"Id":160267,"ZipCode":"8103JB","HouseNumber":"15","HouseAddition":null,"Municipality":"Raalte","Province":null,"Firstname":null,"Lastname":null,"UserAgent":"","School":null,"Street":null,"Country":null,"Portal":null,"AreaLevel":5,"City":"Raalte","Ip":null}
< HTTP/1.1 200 OK
< Cache-Control: no-cache
< Pragma: no-cache
< Content-Type: application/json; charset=utf-8
< Expires: -1
< Server: Microsoft-IIS/8.5
< X-AspNet-Version: 4.0.30319
< X-Powered-By: ASP.NET
< Date: Wed, 07 Nov 2018 10:20:55 GMT
< Content-Length: 286
* Curl_http_done: called premature == 0
* Connection #0 to host www.rova.nl left intact
[{"GarbageTypeCode":"GFT","GarbageType":"GFT","Date":"2018-11-12T00:00:00","Regular":true},{"GarbageTypeCode":"REST","GarbageType":"Restafval","Date":"2018-11-16T00:00:00","Regular":true},{"GarbageTypeCode":"PLASTICPLUS","GarbageType":"PMD","Date":"2018-11-19T00:00:00","Regular":true}]
The ID can be everything doesn't matter if I change this, I still got the correct dates for my address.
Raspberry pi 3, Domoticz Beta, Nginx, dzVents 2.7.4, RFXtrx433e, P1 smart meter, Harmony, Hue, Zwave, Amazon echo, Sonos, Synology DS413, HomeBridge, HA Bridge, Ubiquiti.
Just sent a PM
delcara wrote: Wednesday 07 November 2018 11:24 I'm trying to create a script to get garbage collection dates from ROVA. I've discovered how to get the dates through a curl command. But I've no idea how to translate this to a dzVents script. I've just started with DzVents and have now translated all my blockly to DzVents (relatively simple scripts to control lights etc.). Can you help to translate this curl command to a DzVents script?
Please have a look at the script below.
I tried to translate the curl command into a domoticz.openUrl but I failed in finding the working syntax (the cookie table seems to mess up the openUrl internally). If someone else has found a solution for this I would be much obliged if that solution could be shared here.
So had to use the curl command itself. To ensure that a wait time for the JSON return would not stall the event thread, the command is processed in the background and the script will come back every couple of seconds to check if it is already there.
(In practice I have not seen that the return have taken more then 2 seconds, but just to be sure)
--[[ getGarbage.lua for [ dzVents >= 2.4 ]
    this script is only useful in those  areas of the Netherlands where the household garbage collector is rova
    Tested on debian stretch but probably also working on other Linux variants.
    needs curl command
    needs to be able to process commands in the background ( by using leading &)
    Enter your zipcode, housenumber and garbageID in the appropriate places between the lines starting with -- ***
    Next is to set your virtual text and or virtual alert device.
    the text device will contain the most nearby collectdates for the types of household garbage
    notification system will be called when collect will be today
         on =   {   timer           =   { "at 00:05","at 08:00" },    -- daily run twice
                    devices         =   { "getGarbage"          },    -- Ignore just for test
                    httpResponses   =   { "delay_Response"      },    -- (re)triggers the script
    logging =   {   level   = domoticz.LOG_DEBUG ,              -- Change to ERROR when script is behaving as expected
                    marker  = ""},                              -- Will be set in execute = function block
    data    =   {   delay           =  { initial = 0 },
    execute = function(dz, item, info)
    -- ************************* Mandatory: Set your values and device names below this Line
        local myZipcode     = "0000AA"            -- Your zipcode like "3085RA"
        local myHousenumber = "99"                -- Your housenumber like 38
        local myGarbageID   = "9999999"            -- Your GarbageID
    -- **************************************************************** No changes required below this
       local initialDelay           = 2
       local repeatDelay            = 10
       local maxDelay               = 60
       local outFile                = "/tmp/garbageCollectionDates.json"
       local catCommand             = "cat"
        _G.logMarker                = info.scriptName     -- sets the logmarker for dz.log
        local function logWrite(str,level)
            dz.log(str,level or dz.LOG_DEBUG)
        local function setGarbageAlertDevice(alertDevice,alertText, delta)
            return (delta == 0)
            str = tostring(str)
            str = str:gsub("PMD","  Plastic verpakkingen, blik en drinkpakken ")
            str = str:gsub("GFT","  Groente-, fruit- en tuin afval ")
            str = str:gsub("Restafval" ,"  Restafval ")
            return str
        local function retriggerAfterSec(seconds)
            dz.openURL({
                url =  dz.settings['Domoticz url'] .. "/json.htm?type=command&param=getversion",
                method = "GET",
                callback = "delay_Response" }).afterSec(seconds)
        local function osCommand(cmd)
            local fileHandle     = assert(io.popen(cmd, 'r'))
            local commandOutput  = assert(fileHandle:read('*a'))
            local returnTable    = {fileHandle:close()}
            return commandOutput,returnTable[3]            -- rc[3] contains returnCode
        function makeTimeStamp(dateString)
            local pattern = "(%d+)%-(%d+)%-(%d+)T(%d+):(%d+):(%d+)"
            local xyear, xmonth, xday, xhour, xminute, xseconds = dateString:match(pattern)
            local convertedTimestamp  = os.time({year = xyear, month = xmonth, day = xday, hour = xhour, min = xminute, sec = xseconds})
        local function procesJSON(resultJSON)
            keep    = {}
            rt      = dz.utils.fromJSON(resultJSON)
            local earliestDate   = "2999-12-31"       -- Hopefully we will have a different garbage collection system by then
            for i = 1,#rt do
                local fmtDate                 = os.date(" %A %d %B, %Y", makeTimeStamp(rt[i].Date))
                if  rt[i].Date >= today and rt[i].Date < earliestDate then
                    keep.Date           = rt[i].Date
                    keep.fmtDate        = fmtDate
                    keep.GarbageType    = longGarbageName(rt[i].GarbageType)
                    earliestDate        = rt[i].Date
                garbageLines = garbageLines .. fmtDate .. longGarbageName(rt[i].GarbageType) .. " " .. "\n"
                local delta  = os.date("%d",tonumber(makeTimeStamp(keep.Date))) - os.date("%d")
                garbageToday = setGarbageAlertDevice(  myAlertDevice, keep.GarbageType .. "\n" .. keep.fmtDate, delta )
                dz.notify(keep.GarbageType .. "will be collected today")
        local function triggerCurlInBackGround()
            local curlCommand  = "curl -v --cookie"
            local curlCookie  =  'RovaLc_inwoners={' ..
                                 '\\"Id\\":' ..             myGarbageID .. ',' ..
                                 '\\"ZipCode\\":\\"' ..     myZipcode .. '\\",' ..
                                 '\\"HouseNumber\\":\\"' .. myHousenumber .. '\\"}'
            local curlHTTP    = "https://www.rova.nl/api/TrashCalendar/GetCalendarItems?portal=inwoners"
            local backGround  = " & "  -- We don't want the script to wait for the result so process curl in background
            getGarbageCollectionDatesCommand = curlCommand .. " " .. curlCookie  .. " " .. curlHTTP .. " > " .. outFile .. backGround
            osCommand(getGarbageCollectionDatesCommand)
        local function waitForAndProcessResult()
            local result, returnCode = osCommand(catCommand .. " " .. outFile) -- is the output there ?
            if returnCode == 0 then                                 -- Yes
                -- logWrite(result)
                osCommand("rm " .. outFile)
                procesJSON(result)
            else                                                    -- Not yet. Come back in repeatDelay seconds
                logWrite("No result yet")
                dz.data.delay = dz.data.delay + repeatDelay                    -- Keep track of the delays
                if dz.data.delay > maxDelay then
                    logWrite("We are waiting > maxDelay seconds for the result. Giving up now",dz.LOG_ERROR)
                    retriggerAfterSec(repeatDelay)
        -- main
        if item.isDevice or item.isTimer then
            retriggerAfterSec(initialDelay) -- We will come back in initialDelay seconds to check if output has already arrived
            dz.data.delay = initialDelay
delcara
Post by delcara »
Thnx! Just read your PM and you're answer is already here. I'm going to try the script when i'm home tonight. Nice thinking and a creative solution!
akamming
Post by akamming »
delcara wrote: Wednesday 07 November 2018 11:24 Hello Waaren,
i was working on the same thing. a few weeks ago i created my own dzvents script for the ROVA afvalkalender. This one hopefully works for you!
		timer = {
		    'at 20:00',                -- The notification will be sent at this time on the day before ROVA arrives
		    'every 8 hours' ,           -- Update frequency of the  virtual device
    logging = {
	        level = domoticz.LOG_DEBUG,  -- adjust to your needs
	        marker = "Rova"
	    -- The name of your virtual text device which will contain the Afvalkalender
	    local DeviceName="Rova Afvalkalender"
	    -- Adress vars
	    local ZipCode="8103JB"
	    local HouseNumber="15"
	    local HouseAddition="null"
	    local Municipality="Raalte"
	    -- Notification params
	    local NotifyTitle="Rova"
	    local NotifyLine1="Zet container bij de weg, "
	    local NotifyLine2=" wordt opgehaald op "
		-- Get ROVA kalender by accessing the API using  curl
	    local command = 'curl --cookie "RovaLc_inwoners={\\"Id\\":160266,\\"ZipCode\\":\\"'..ZipCode..'\\",\\"HouseNumber\\":\\"'..HouseNumber..'\\",\\"HouseAddition\\":'..HouseAddition..',\\"Municipality\\":\\"'..Municipality..'\\",\\"Province\\":null,\\"Firstname\\":null,\\"Lastname\\":null,\\"UserAgent\\":\\"\\",\\"School\\":null,\\"Street\\":null,\\"Country\\":null,\\"Portal\\":null,\\"AreaLevel\\":5,\\"City\\":\\"Zwolle\\",\\"Ip\\":null}" https://www.rova.nl/api/TrashCalendar/GetCalendarItems?portal=inwoners'
	    domoticz.log("Command is ["..command.."]",domoticz.LOG_DEBUG)
	    local handle=io.popen(command..' || echo error')
        local result = handle:read("*a")
        handle:close()
        -- For debugging purposes: Log result
        domoticz.log ("JSON output Rova is "..result, domoticz.LOG_DEBUG)
        if(result ~= 'error\n') then
            -- convert JSON object to readable format
    	    local json = domoticz.utils.fromJSON(result)
            -- convert dates
    	    local RovaDate=string.sub(json[1].Date,1,-10)
    	    local RovaDate2=string.sub(json[2].Date,1,-10)
    	    local RovaDate3=string.sub(json[3].Date,1,-10)
            -- log result
    	    domoticz.log("Next Garbage Collection: ["..json[1].GarbageTypeCode..' at '..RovaDate..']',domoticz.LOG_FORCE)
    	    -- update device
    	    domoticz.devices(DeviceName).updateText(json[1].GarbageTypeCode.." "..RovaDate..", "..json[2].GarbageTypeCode.." "..RovaDate2..", "..json[3].GarbageTypeCode.." "..RovaDate3)
    	    -- check if we have to send notification
    	    if (item.isTimer) then
    	        local twoletters = string.sub(item.trigger,1,2)
    	        domoticz.log("1st to trigger letters are ["..twoletters.."]",domoticz.LOG_DEBUG)
    	        domoticz.log("Item is timer ("..item.trigger..")",domoticz.LOG_DEBUG)
        	    if (twoletters=="at") then -- we are at the notification timestamp
        	        -- prepare time comparison
            	    local Time = require('Time')
                    local t = Time(RovaDate..' 00:00:00')
                    domoticz.log("Secondsago = "..t.secondsAgo..", minutesAgo="..t.minutesAgo..", hoursago="..t.hoursAgo..", daysago="..t.daysAgo,domoticz.LOG_DEBUG)
                    -- check if we have to notify
                    if (t.daysAgo==0 and t.secondsAgo<0) then -- timestamp is within 1 day
                        -- Yes we do: notify
                        domoticz.log("Rova will be there within 1 day, sending notification", domoticz.LOG_DEBUG)
                        domoticz.notify(NotifyTitle,NotifyLine1..json[1].GarbageTypeCode..NotifyLine2..RovaDate,domoticz.PRIORITY_NORMAL)
                        -- no we don't
                        domoticz.log("no need to notify",domoticz.LOG_DEBUG)
	        domoticz.log("some kind of error accessing the Rova data API",domoticz.LOG_ERROR)
Make sure you create a virtual text sensor with the name "Rova Afvalkalender" before you run the script!
I am still testing this script. It seems to work fine for me now, so i would be happy to hear your findings ...
akamming wrote: Thursday 08 November 2018 16:13 i was working on the same thing. a few weeks ago i created my own dzvents script for the ROVA afvalkalender. This one hopefully works for you!
@akamming, we took more or less the same approach. The main difference is that in your script the event thread (which is single threaded) must wait until the curl command has finished. Potentially this could stall the event system.
I worked around this risk by executing curl in the background and retrigger the script to check every couple of seconds if the result has arrived. Another approach could be to use the option --connect-timeout <seconds> or -m, --max-time <seconds> in the curl command.
In my opinion the best way would be to use domoticz.openURL but I have not found a way to use this with the required cookie table/JSON.
akamming
Post by akamming »
waaren wrote: Thursday 08 November 2018 16:59 In my opinion the best way would be to use domoticz.openURL but I have not found a way to use this with the required cookie table/JSON.
Totally agree. This is why i tried to make a suggestion in the suggestion thread: viewtopic.php?f=31&t=25454&p=195745#p195745. So far no response.
Since this script is run only every 8 hours, i think it is a small risk. I have the same risk for another script where i run an os.execute statement. I like your workaround. maybe i'll implemented if this becomes a problem.
KR Arnold
akamming wrote: Friday 09 November 2018 9:16 Totally agree. This is why i tried to make a suggestion in the suggestion thread:
Maybe we need to look at the optional "headers =" in domoticz.openURL
So far I found that when you have the cookie generated by www.rova.nl already in chrome, the url
https://www.rova.nl/api/TrashCalendar/G ... %2215%22} , does return the requested JSON. So if there is a way to get this cookie on the domoticz system we might be a step further in the right direction
delcara
Post by delcara »
Already usesd the script from Waaren. So far it's working nice, adjusted the run times and notifications a little bit. I now receive a notification the evening before collection day and some nice notifications through google TTS on my Sonos speakers :D .
Strange thing is that i can't save the script when copy/paste in the domoticz web editor, checked it for weird characters or empty spaces. No problem with other scripts. And it runs fine when i copy it to the scripts folder. Didn't bother to look further for the cause of this issue. Running domoticz beta 4.10171.
delcara
Post by delcara »
Discovered why saving in the webeditor didn't work! I've got a reverse proxy (nginx) on the PI and it was a limitations in the HTTP GET request in my proxy config.
martijn333
Target OS: OS X
Post by martijn333 »
I tried the Circulus-Berkel script but what am i doing wrong.
The zipcode and housenumber are set correctly.
I activated debug to get more information.
Can someone help me?
2018-12-18 22:13:00.253 Status: dzVents: Debug: getGarbageDatesMarker: OpenURL: url = https://afvalkalender.circulus-berkel.n ... ender/2018
2018-12-18 22:13:00.253 Status: dzVents: Debug: getGarbageDatesMarker: OpenURL: method = GET
2018-12-18 22:13:00.253 Status: dzVents: Debug: getGarbageDatesMarker: OpenURL: post data = nil
2018-12-18 22:13:00.253 Status: dzVents: Debug: getGarbageDatesMarker: OpenURL: headers = nil
2018-12-18 22:13:00.253 Status: dzVents: Debug: getGarbageDatesMarker: OpenURL: callback = getGarbageDatesResponse
2018-12-18 22:13:00.254 Status: dzVents: Info: getGarbageDatesMarker: ------ Finished Script #1
2018-12-18 22:13:00.414 Status: EventSystem: Script event triggered: /home/pi/domoticz/dzVents/runtime/dzVents.lua
2018-12-18 22:13:02.603 Status: dzVents: Info: Handling httpResponse-events for: "getGarbageDatesResponse
2018-12-18 22:13:02.603 Status: dzVents: Info: getGarbageDatesMarker: ------ Start internal script: Script #1: HTTPResponse: "getGarbageDatesResponse"
2018-12-18 22:13:02.614 Status: dzVents: Debug: getGarbageDatesMarker: 0200200000011954
2018-12-18 22:13:02.618 Status: dzVents: Error (2.4.9): getGarbageDatesMarker: Problem with response from (no data) using data from earlier run
2018-12-18 22:13:02.618 Status: dzVents: Error (2.4.9): getGarbageDatesMarker: No previous data. are zipcode and housenumber ok and in circulus-berkel area?
2018-12-18 22:13:02.619 Status: dzVents: Info: getGarbageDatesMarker: ------ Finished Script #1
2018-12-18 22:13:02.619 Status: EventSystem: Script event triggered: /home/pi/domoticz/dzVents/runtime/dzVents.lua
2018-12-18 22:13:02.644 Status: Notification: Problem with response from (no data) using data from earlier run
2018-12-18 22:13:02.645 Status: Notification: No previous data. are zipcode and housenumber ok and in circulus-berkel area?
martijn333 wrote: Tuesday 18 December 2018 22:23 I tried the Circulus-Berkel script but what am i doing wrong.
For some reason the script does not like the data that came back from circulus-berkel
Can you try to enter https://afvalkalender.circulus-berkel.n ... ender/2018 in your browser and show the results. If that look more or less OK please add the line
dz.log(triggerObject.data,dz.LOG_FORCE)
right after the line
and show the relevant loglines
martijn333
Target OS: OS X
I added the line this are the results:
2018-12-19 11:58:00.423 Status: dzVents: Info: getGarbageDatesMarker: ------ Start internal script: Script #1:, trigger: at 11:58
2018-12-19 11:58:00.455 Status: dzVents: Debug: getGarbageDatesMarker: OpenURL: url = https://afvalkalender.circulus-berkel.nl/rest/adressen/0200200000011954/kalender/2018
2018-12-19 11:58:00.455 Status: dzVents: Debug: getGarbageDatesMarker: OpenURL: method = GET
2018-12-19 11:58:00.455 Status: dzVents: Debug: getGarbageDatesMarker: OpenURL: post data = nil
2018-12-19 11:58:00.455 Status: dzVents: Debug: getGarbageDatesMarker: OpenURL: headers = nil
2018-12-19 11:58:00.455 Status: dzVents: Debug: getGarbageDatesMarker: OpenURL: callback = getGarbageDatesResponse
2018-12-19 11:58:00.456 Status: dzVents: Info: getGarbageDatesMarker: ------ Finished Script #1
2018-12-19 11:58:00.598 Status: EventSystem: Script event triggered: /home/pi/domoticz/dzVents/runtime/dzVents.lua
2018-12-19 11:58:02.869 Status: dzVents: Info: Handling httpResponse-events for: "getGarbageDatesResponse
2018-12-19 11:58:02.869 Status: dzVents: Info: getGarbageDatesMarker: ------ Start internal script: Script #1: HTTPResponse: "getGarbageDatesResponse"
2018-12-19 11:58:02.879 Status: dzVents: Debug: getGarbageDatesMarker: 0200200000011954
2018-12-19 11:58:02.883 Status: dzVents: !Info: getGarbageDatesMarker: [{"afvalstroom_id":4,"ophaaldatum":"2018-01-04"},{"afvalstroom_id":55,"ophaaldatum":"2018-01-06"},{"afvalstroom_id":55,"ophaaldatum":"2018-01-15"},{"afvalstroom_id":55,"ophaaldatum":"2018-01-29"},{"afvalstroom_id":4,"ophaaldatum":"2018-02-01"},{"afvalstroom_id":55,"ophaaldatum":"2018-02-12"},{"afvalstroom_id":55,"ophaaldatum":"2018-02-26"},{"afvalstroom_id":4,"ophaaldatum":"2018-03-01"},{"afvalstroom_id":55,"ophaaldatum":"2018-03-12"},{"afvalstroom_id":55,"ophaaldatum":"2018-03-26"},{"afvalstroom_id":12,"ophaaldatum":"2018-04-04"},{"afvalstroom_id":4,"ophaaldatum":"2018-04-05"},{"afvalstroom_id":55,"ophaaldatum":"2018-04-09"},{"afvalstroom_id":55,"ophaaldatum":"2018-04-23"},{"afvalstroom_id":4,"ophaaldatum":"2018-05-03"},{"afvalstroom_id":55,"ophaaldatum":"2018-05-07"},{"afvalstroom_id":55,"ophaaldatum":"2018-05-19"},{"afvalstroom_id":55,"ophaaldatum":"2018-06-04"},{"afvalstroom_id":4,"ophaaldatum":"2018-06-07"},{"afvalstroom_id":55,"ophaaldatum":"2018-06-18"},{"afvalstroom_id":55,"ophaaldatum":"2018-07-02"},{"afvalstroom_id":4,"ophaaldatum":"2018-07-05"},{"afvalstroom_id":55,"ophaaldatum":"2018-07-16"},{"afvalstroom_id":55,"ophaaldatum":"2018-07-30"},{"afvalstroom_id":12,"ophaaldatum":"2018-08-01"},{"afvalstroom_id":4,"ophaaldatum":"2018-08-02"},{"afvalstroom_id":55,"ophaaldatum":"2018-08-13"},{"afvalstroom_id":55,"ophaaldatum":"2018-08-27"},{"afvalstroom_id":4,"ophaaldatum":"2018-09-06"},{"afvalstroom_id":55,"ophaaldatum":"2018-09-10"},{"afvalstroom_id":55,"ophaaldatum":"2018-09-24"},{"afvalstroom_id":4,"ophaaldatum":"2018-10-04"},{"afvalstroom_id":55,"ophaaldatum":"2018-10-08"},{"afvalstroom_id":55,"ophaaldatum":"2018-10-22"},{"afvalstroom_id":4,"ophaaldatum":"2018-11-01"},{"afvalstroom_id":55,"ophaaldatum":"2018-11-05"},{"afvalstroom_id":55,"ophaaldatum":"2018-11-19"},{"afvalstroom_id":55,"ophaaldatum":"2018-12-03"},{"afvalstroom_id":12,"ophaaldatum":"2018-12-05"},{"afvalstroom_id":4,"ophaaldatum":"2018-12-06"},{"afvalstroom_id":11,"ophaaldatum":"2018-12-11"},{"afvalstroom_id":55,"ophaaldatum":"2018-12-17"},{"afvalstroom_id":11,"ophaaldatum":"2018-12-22"},{"afvalstroom_id":55,"ophaaldatum":"2018-12-31"}]
2018-12-19 11:58:02.883 Status: dzVents: Error (2.4.9): getGarbageDatesMarker: Problem with response from (no data) using data from earlier run
2018-12-19 11:58:02.884 Status: dzVents: Error (2.4.9): getGarbageDatesMarker: No previous data. are zipcode and housenumber ok and in circulus-berkel area?
2018-12-19 11:58:02.884 Status: dzVents: Info: getGarbageDatesMarker: ------ Finished Script #1
2018-12-19 11:58:02.884 Status: EventSystem: Script event triggered: /home/pi/domoticz/dzVents/runtime/dzVents.lua
2018-12-19 11:58:02.924 Status: Notification: Problem with response from (no data) using data from earlier run
2018-12-19 11:58:02.925 Status: Notification: No previous data. are zipcode and housenumber ok and in circulus-berkel area?
Thank you for helping!
martijn333 wrote: Wednesday 19 December 2018 12:04 Thank you for helping!
Response from your provider again differs a bit from others.
script below should do it for you.
return
        garbageTypes  = {1,4,11,12,55}                -- Valid for circulus-berkelfor but these numbers vary per garbageCollector; Why ??
         -- ("55","  Groente-, fruit- en tuin afval            ")
         -- ("4", "  Papier en kartonnen verpakkingen          ")
         -- ("11","  Plastic, blik drankpakken                 ")
         -- ("12","  Boeken, speelgoed en textiel              ")
         -- ("1", "  Restafval                                 ")
                            method      = "GET",
                            method      = "GET",
            dz.notify(message)
            return (delta == 0)
            str = tostring(str)
            dz.log(str,dz.LOG_DEBUG)
            str = str:gsub("12","  Boeken, Elektrische apparaten, Speelgoed en Textiel")
            str = str:gsub("55","  Groente-, fruit- en tuin afval     ")
            str = str:gsub("4", "  Papier en kartonnen verpakkingen    ")
            str = str:gsub("11","  Plastic, blik drankpakken          ")
            str = str:gsub("1", "  Rest afval                          ")
            return str
           local function dumpTable(t, level)
            for attr, value in pairs(t) do
                if (type(value) ~= 'function') then
                    if (type(value) == 'table') then
                        io.write(level .. attr .. ':\n')
                        print(level .. attr )
                        dumpTable(value, level .. '    ')
                        io.write(level .. attr .. ': ' .. tostring(value) .. "\n")
                        print(level .. attr .. ': ' .. tostring(value) )
                    io.write(level .. attr .. '()\n')
                    print(level .. attr .. '()')
               getBagID()
               return
            rt , rtRaw = {}, {}
            if rtRaw[1] ~=  nil then
                    return false
            local foundFirst = false
                local foundOne = false
                        foundOne = true
                            foundFirst = true
                if foundOne then
            if myAlertDevice and foundFirst then   -- Update AlertDevice with nearby date / type
        -- Main
                handleResponse()
                collectBagId(1)
martijn333
Target OS: OS X
Thanks it is working!
imdos
Domoticz version: 2023.2
Post by imdos »
Great work. I got the script working on rmn. However I don't understand the logics for the notification of the alert. Could someone help me with that. I would like to receive a modification on the day itself in the morning, around 8 or something.
Sent from my MI 6 using Tapatalk
Making use of: Raspbian(SSD), dz Beta, Woonveilig, Z-Wave(alarm+multi-sensor), RFLink(blinds), P1, Yeelight, Xiaomi temp sensors, Tasmota(SonoFF, Blitzwolf SHP2, Shelly1)
imdos wrote: Monday 04 February 2019 22:37 Great work. I got the script working on rmn. However I don't understand the logics for the notification of the alert. Could someone help me with that. I would like to receive a modification on the day itself in the morning, around 8 or something.
If you can send me the script via PM as you use it now I will have a look.
