So your mini webserver is running now, which is nice. just try 127.0.0.1 instead local host.
yes, you are right, with edge i got immediately "Successful GET", with crome i got some header errors i domoticz log, after domotic restart it is ok
i found this in manual: Junction - Windows:
link/junction need to be created for c:\program files(x86)\Domoticz to avoid space problem when call cmd file
could it be problem?
because still no devices:(
moo2089 wrote: Friday 02 November 2018 0:42
No.. bug in the plugin that I have corrected now.
just download the new ical.py & plugin.py from dropbox.
thank you for your effort and patience!!!!
yes, finally i have devices!
should i wait for updating?
because seasons is "undefined"
anyway i dont see red error in domoticz log
moo2089 wrote: Friday 02 November 2018 1:40
verify timers created and just select the right actual season and it's finished, .. Not have implememented that yet.
Nice you have it running now.
Do you have all labels/messages, holidays, in your native language now ?
Strange thing is that I sometimes see : Succesfull GET. And other times a long spin.
I also set up a port forward in my router and if I go to my dyndns:9003, I immediately get "Succesfull GET"
But I see that I have to get the new ical.py. Thanx I try out (right now at work)
2 questions:
1) do i need a port forward in my router?
2) is it possible to use the plugin when I have a login name and password for domoticz?
tomdh76 wrote: Friday 02 November 2018 9:33
2 questions:
1) No, only if you plan to access the mini webserver from outside..; but not make sense !!
2) yes, but you need to set your local IP address range as no password requiring
hi,
no problem, as i use holiday infos only, manually set.
so far i see holidays in my language only, i have language file downloaded in plugin diredctory:
hi,
moo2089 wrote: Friday 02 November 2018 10:51
as i see this language file is 0 kB
just delete it and do the fix for googletrans module.And reload the plugin.
hi,
should it run under windows?
Error [WinError 2] A rendszer nem találja a megadott fájlt while executing command git clone -q https://github.com/BoseCorp/py-googletrans.git C:\Users\Zsolt\AppData\Local\Temp\pip-bgvh5adz-build
Cannot find command 'git'
the hungarian part is: "system cannot find file specified...
hi,
hi,
done, i see some hungarian changes,:)
i dont know if seasons should remain english or not, but anyway its fine, thank you man!!!
hi,
may i edit it simply under device properties from domoticz dash?
moo2089 wrote: Friday 02 November 2018 21:24
Device labels are created at first plugin initialisation only. So if translation error, the plugin fallback to english as default language.
Now, you can edit and modify them manually if you want.
so if i remove hardware and delete ical plugin folder and install it from scratch, should be ok?
moo2089 wrote: Saturday 03 November 2018 0:05
It's not necessary to remove ical plugin folder / files.
You can :
create another hardware and keep the existing one.
remove existing devices and reload the plugin ( see wiki )
You can :
followed wiki method, now everything is translated properly, thanks again!
I was just trying out this script on my Raspberry Pi, because of another script loosing it´s author and is no longer maintained.
After installation and I adding calendar to the hardware, when pressing the save button and switches should be created, domoticz crashes.
xxxx <--some time, didn´t get the copy/paste Status (Google Calendar) Started.
2018-11-03 07:11:20.866 Error: Domoticz(pid:32594, tid: 32609('PluginMgr')) received fatal signal 11 (Segmentation fault)
