Generic auto-off
Vondee
Re: Generic auto-off
Unfortunately I need the script also for turning lights off, is it possible to have a command like "auto_level_minutes" next to the command "auto_off_minutes"?
rrozema
Of course. Everything is possible. It just needs some time. I like your idea to first dim the light and then somewhat later switch it off completely. I'll see what i can do after i return home and let you know in a few days.
rrozema
Below code is not working yet. I get an error that I can't fix yet but I'm running out of time for the moment. Maybe @waaren can have a look at what I'm doing wrong? I've not even activated the new features yet; still using the original json values in the descriptions of my devices.Vondee wrote: Monday 27 January 2020 10:36 Unfortunately I need the script also for turning lights off, is it possible to have a command like "auto_level_minutes" next to the command "auto_off_minutes"?
2020-02-01 21:52:00.945 Error: dzVents: Error: (2.5.0) An error occurred when calling event handler Generic Auto Off
2020-02-01 21:52:00.945 Error: dzVents: Error: (2.5.0) ...z/scripts/dzVents/generated_scripts/Generic Auto Off.lua:105: attempt to compare number with tableCode: Select all
elseif motion_device.lastUpdate.compare(lastUpdate) > 0 thenCode: Select all
-- This script will run every minute and can automatically send an 'Off' command to turn off any device after
-- it has been on for some specified time. Each device can be individually configured by putting json coded
-- settings into the device's description field. The settings currently supported are:
-- - "auto_off_minutes" : <time in minutes>
-- - "auto_off_motion_device" : "<name of a motion detection device>"
-- If "auto_off_minutes" is not set, the device will never be turned off by this script. If
-- "auto_off_minutes" is set and <time in minutes> is a valid number, the device will be turned off when it
-- is found to be on plus the device's lastUpdate is at least <time in minutes> minutes old. This behavior
-- can be further modified by specifying a valid device name after "auto_off_motion_device". When a motion
-- device is specified and the device's lastUpdate is at least <time in minutes> old, the device will not
-- be turned off until the motion device is off and it's lastUpdate is also <time in minutes> old.
-- Specifying "auto_off_motion_device" without specifying "auto_off_minutes" does nothing.
-- Example 1: turn off the device after 2 minutes:
-- "auto_off_minutes": 2
-- Example 2: turn off the device when it has been on for 5 minutes and no motion has been detected for
-- at least 5 minutes:
-- "auto_off_minutes": 5,
-- "auto_off_motion_device": "Overloop: Motion"
-- Example 3: turn off the device when it has been on for 1 minute and not motion was detected for at least 1
-- minute on either one of a set of motion sensors.
--"auto_off_minutes": 1,
--"auto_off_motion_device": ["Overloop 1: Motion 1", "Overloop 1: Motion 2"]
-- timer triggers
timer = {
'every minute'
execute = function(domoticz, triggeredItem, info)
local cnt = 0
domoticz.devices().forEach(
function(device)
cnt = cnt + 1
local description = device.description
if description ~= nil and description ~= '' then
local ok, settings = pcall( domoticz.utils.fromJSON, description)
if ok and settings ~= nil then
-- Determine highest level available in the settings that is
-- lower than the current level where 'Off' equals level 0.
local dimlevel = nil;
-- Lowest dim level is 'Off', this I will represent as level == 0.
-- If auto_off_minutes was specified, I will use this to
-- initialise the dimlevel variable with a level of 0.
if settings.auto_off_minutes ~= nil then
dimlevel = { level = 0, minutes = settings.auto_off_minutes }
-- If one or more dimlevels were specified, the user must think our
-- device is a dimmer switch, so it should be safe to reference
-- its level attribute. We search for the dimlevel that has the
-- highest level below that of our device's level.
if settings.auto_off_dimlevel ~= nil then
dimlevel = settings.auto_off_dimlevel.reduce(
function(acc, dl)
if dl.level < device.level then
if acc == nil or dl.level > acc.level then
acc = dl
return acc -- always return the accumulator
end,
dimlevel ) -- Initial value for the accumulator is either nil
-- if no auto_off_minutes was specified or it is
-- {level = 0, minutes = <auto_off_minutes>}.
-- If we have found a new dim level then see if it is time yet to
-- set this new level.
if dimlevel ~= nil then
local minutes = dimlevel.minutes
-- Find the latest last modified date from our device plus
-- any motion devices that may have been specified. Initially
-- assume our device has the latest last modified date.
local lastUpdate = device.lastUpdate
-- We will skip setting a new level if either of the following is true:
-- one or more of the motion devices has state 'On' or the lastUpdate
-- on our device or any of the specified motion devices is less than
-- <minutes> ago. To accomplish this, lets find out if any of the
-- motion devices has a more recent lastUpdate than that of our device.
-- If a motion device has state 'On', we will set lastUpdate to nil,
-- indicating we can skip the check for lastUpdate completely.
if type(settings.auto_off_motion_device) == "string" then
-- a single motion device was specified
local motion_device = domoticz.devices(settings.auto_off_motion_device)
if motion_device.state ~= 'Off' then
lastUpdate = nil
lastUpdate = motion_device.lastUpdate
elseif type(settings.auto_off_motion_device) == "table" then
local motion_devices = domoticz.devices().filter(settings.auto_off_motion_device)
lastUpdate = motion_devices.reduce(
function(acc, md)
if md.timedOut ~= true then -- Ignore motion devices that have timed out, to
-- avoid leaving the light on because a sensor that
-- has an empty battery isn't updated to 'Off'.
if acc ~= nil then -- If a previous sensor was 'On', we will have set
-- lastUpdate to nil and we don't want to overwrite
-- this.
if md.state ~= 'Off' then
acc = nil -- Set lastUpdate to nil to indicate at least
-- one sensor is 'On'.
elseif md.lastUpdate.compare(acc) > 0 then
acc = md.lastUpdate -- We've found a more recent lastUpdate.
return acc -- Always return the accumulator.
end, lastUpdate)
if lastUpdate ~= nil and lastUpdate.minutesAgo > tonumber(minutes) then
if dimlevel.level > 0 then
domoticz.log(device.name .. ' is dimmed to level ' .. dimlevel.level .. ' after ' .. settings.auto_off_minutes .. ' minutes.', domoticz.LOG_INFO)
device.setLevel(tonumber(dimlevel.level))
domoticz.log(device.name .. ' is switched off after ' .. settings.auto_off_minutes .. ' minutes.', domoticz.LOG_INFO)
device.switchOff()
domoticz.log( 'Device description for '.. device.name ..' is not in json format. Ignoring this device.', domoticz.LOG_WARNING)
-- end
domoticz.log('Scanned ' .. tostring(cnt) .. ' devices.', domoticz.LOG_INFO)
-- -- Set ventilation back to automatic after 2 hours of manual control.
-- local hs = domoticz.devices('Humidity SetPoint')
-- if hs.state ~= 'On' and hs.lastUpdate.hoursAgo >= 2 then
-- hs.switchOn()
-- end
}- waaren
lastUpdate and motion_device.lastUpdate are both dzVents time objects... But 0 is a number and the result of the compare function is a time object.rrozema wrote: Saturday 01 February 2020 22:01 Below code is not working yet. I get an error that I can't fix yet but I'm running out of time for the moment. Maybe @waaren can have a look at what I'm doing wrong? I've not even activated the new features yet; still using the original json values in the descriptions of my devices.
Line 105 is the lineCode: Select all
2020-02-01 21:52:00.945 Error: dzVents: Error: (2.5.0) An error occurred when calling event handler Generic Auto Off 2020-02-01 21:52:00.945 Error: dzVents: Error: (2.5.0) ...z/scripts/dzVents/generated_scripts/Generic Auto Off.lua:105: attempt to compare number with tablebut I don't see how lastUpdate could suddenly be a number?Code: Select all
You can see how the result is structured by using the lodash _.print or dzVents dumpTable
dz.utils._.print(motion_device.lastUpdate.compare(lastUpdate))
{["mins"]=87, ["seconds"]=5228, ["secs"]=5228, ["minutes"]=87, ["compare"]=-1, ["milliseconds"]=5228811, ["ms"]=5228811, ["days"]=0, ["hours"]=1}
dz.utils.dumpTable(motion_device.lastUpdate.compare(lastUpdate))
> days: 0
> mins: 92
> hours: 1
> minutes: 92
> compare: -1
> seconds: 5557
> milliseconds: 5557487
> ms: 5557487
> secs: 5557Code: Select all
elseif motion_device.lastUpdate.compare(lastUpdate).minutes > 0 then
elseif motion_device.lastUpdate.compare(lastUpdate).seconds > 0 thenDebian buster, bullseye on RPI-4, Intel NUC.
rrozema
Thanks, that was helpful. I keep forgetting that compare() returns that structure. Not there yet, but this helped me further. What I needed was:waaren wrote: Sunday 02 February 2020 1:30 ...
so what you probably need is something likeorCode: Select all
elseif motion_device.lastUpdate.compare(lastUpdate).compare > 0 then-
rrozema
I am not completely satisfied yet, but here's a 1st version that does mostly what you asked for. I'm not putting the code in the opening post yet, but you can give it a try, see how you like it.Vondee wrote: Monday 27 January 2020 10:36 Unfortunately I need the script also for turning lights off, is it possible to have a command like "auto_level_minutes" next to the command "auto_off_minutes"?
The json to put into the description is like before. I've only added one new option: auto_off_dimlevel. Note the different brace types if you specify multiple dim levels. The code will search for the highest dim level below the current dim level. When then light has been on the current level for as long as the minutes specifies, the next level is set. Here's an example how to use it. When the light is set to 100%, this will dim the light to 50% after 2 minutes, then 2 minutes later it dims to 33% and finally 10 minutes after that it switches off.
"auto_off_dimlevel": [{ "level": 50, "minutes": 2 }, { "level": 33, "minutes": 2 }],
"auto_off_minutes": 10
}Code: Select all
"auto_off_dimlevel": { "level": 33, "minutes": 2 },
}Code: Select all
}Code: Select all
-- timer triggers
timer = {
'every minute'
data = {
triggers = {initial = {}}, -- Holds a list of (unique) motion devices and a list of devices it triggers.
triggered_by = {initial = {}} -- Holds a list of (unique) triggered devices and a list of motion devices that trigger it.
logging = {
level = domoticz.LOG_INFO,
marker = "Generic Auto Off v2"
local cnt = 0
--domoticz.dump(domoticz.utils)
--domoticz.utils.dumpTable(domoticz)
--domoticz.utils.dumpTable(domoticz.utils)
--local Time = require('Time')
local now = domoticz.time
-- if domoticz.data.triggers == nil then
domoticz.data.triggers = {}
-- end
-- if domoticz.data.triggered_by == nil then
domoticz.data.triggered_by = {}
-- end
function(device)
cnt = cnt + 1
local description
local motion_device_names -- If no settings are found we may still have to
-- remove some device's motion devices from the
-- trigger lists. So we start with an empty list.
motion_device_names = {}
-- Determine the list of motion devices configured for this
-- device in the settings.
table.insert( motion_device_names, settings.auto_off_motion_device)
for i,v in ipairs(settings.auto_off_motion_device) do
table.insert( motion_device_names, v)
-- If auto_off_minutes was specified and the device is not off, I
-- will use this to initialise the dimlevel variable with a level
-- of 0. If the device is off already, we don't need to change it.
if settings.auto_off_minutes ~= nil and device.state ~= 'Off' then
dimlevel = { level = 0, minutes = settings.auto_off_minutes}
if settings.auto_off_dimlevel ~= nil and type(settings.auto_off_dimlevel) == "table" then
-- if a single dimlevel was specified...
if settings.auto_off_dimlevel.level ~= nil then
if settings.auto_off_dimlevel.level < device.level then
if dimlevel == nil or settings.auto_off_dimlevel.level > dimlevel.level then
-- or when multiple dimlevels were specified as a table of tables.
for i,v in ipairs(settings.auto_off_dimlevel) do
if v.level < device.level then
if dimlevel == nil or v.level > dimlevel.level then
dimlevel = v
--domoticz.utils.dumpTable(lastUpdate)
-- at least one of the motion devices has state 'On' or the lastUpdate
local motion_devices = domoticz.devices().filter(motion_device_names)
function(acc, md)
-- this.
--domoticz.utils._.print( 'Sensor ' .. md.name .. ' is on')
elseif md.lastUpdate.compare(acc).compare < 0 then -- If acc < lastUpdate
domoticz.utils._.print( 'Found lastUpdate ' .. md.lastUpdate.raw .. ' on ' .. md.name .. ' to be more recent than ' .. acc.raw .. '.')
domoticz.log( 'Ignoring motion device ' .. md.name .. ' because it timed out. Do you need to replace it\'s battery?', domoticz.LOG_WARNING)
end, lastUpdate)
if lastUpdate ~= nil and lastUpdate.secondsAgo > tonumber(minutes * 60) then
domoticz.log(device.name .. ' is dimmed to level ' .. dimlevel.level .. ' after ' .. dimlevel.minutes .. ' minutes.', domoticz.LOG_INFO)
domoticz.log(device.name .. ' is switched off after ' .. dimlevel.minutes .. ' minutes.', domoticz.LOG_INFO)
device.switchOff()
-- Now see if we need to update our triggers lists. I keep a list of trigger devices that I
-- use to see 1) which devices are our motion devices and 2) which devices need to be
-- switched on for each motion device. Plus I keep an additional list of triggered devices
-- so I can determine that a motion device was removed from the settings. Because in this
-- case I need to remove it from the list of trigger devices too.
-- Do we need to add entries to the triggers lists?
-- For each of the motion devices in settings
-- If not exists data.triggers[ <settings.motion device> ]
-- Then
-- add a new entry in data.triggers with our current device in the list of devices to trigger.
-- Else
-- If our current device is not in the list of devices to trigger
-- Then
-- Add our device to the list of devices to trigger.
-- If data.triggered_by does not have our device
-- Then
-- add a new entry in data.triggered_by for our current device with our motion device in the triggered_by list.
-- Else
-- If our motion device is not in the list of trigger devices
-- Then
-- add the motion device to the list of trigger devices
for i,v in ipairs(motion_device_names) do
if domoticz.data.triggers[v] == nil then
--domoticz.log('adding trigger ' .. v .. '.', domoticz.LOG_DEBUG)
domoticz.data.triggers[v] = {}
-- TODO: This code keeps adding entries, even though following if exists. Why?
if domoticz.data.triggers[v][device.name] == nil then
--domoticz.log('adding triggered device ' .. device.name .. '.', domoticz.LOG_DEBUG)
table.insert(domoticz.data.triggers[v], device.name)
if domoticz.data.triggered_by[device.name] == nil then
domoticz.data.triggered_by[device.name] = {}
if domoticz.data.triggered_by[device.name][v] == nil then
table.insert(domoticz.data.triggered_by[device.name], v)
-- Do we need to remove entries from the triggers lists?
-- For each of the entries in the list of trigger devices from data.triggered_by[ <current device> ]
-- If settings does not have a motion device[ <listed motion device> ]
-- Then
-- remove data.triggered_by[<current device>][ <listed motion device> ]
-- If data.triggered_by[<current device>] has no more entries
-- Then
-- If exists data.triggers[ <listed motion device> ][ <current device> ]
-- Then
-- remove data.triggers[ <listed motion device> ][ <current device> ]
-- If data.triggers[ <listed motion device> ] has no more entries
if domoticz.data.triggered_by[device.name] ~= nil then
for i,v in ipairs(domoticz.data.triggered_by[device.name]) do
if motion_device_names[v] == nil then
domoticz.data.triggered_by[device.name][v] = nil
if #(domoticz.data.triggered_by[device.name]) <= 0 then
domoticz.data.triggered_by[device.name] = nil
if domoticz.data.triggers[v][device.name] ~= nil then
domoticz.data.triggers[v][device.name] = nil
if #(domoticz.data.triggers[v]) <= 0 then
domoticz.data.triggers[v] = nil
--domoticz.utils.dumpTable(domoticz.data.triggers)
--domoticz.utils.dumpTable(domoticz.data.triggered_by)
-- hs.switchOn()
-- end
Vondee
Nice!
Coming week I am traveling and have no time to try
Will keep you posted on the result!
Again, many thanks the work and as soon as I am back I will try it!
Vondee
I tried the script with only setting the dim-level.
"auto_off_dimlevel": { "level": 20, "minutes": 10 }
After the set time, Domoticz has an error:
2020-02-15 20:43:00.454 Error: dzVents: Error: (2.5.5) An error occurred when calling event handler Generec_Auto_Off
2020-02-15 20:43:00.454 Error: dzVents: Error: (2.5.5) ...z/scripts/dzVents/generated_scripts/Generec_Auto_Off.lua:143: attempt to concatenate a nil value (field 'auto_off_minutes')
When I add
"auto_off_minutes": 300
Then the script works! the light is dimmed to 20%:
2020-02-15 20:47:00.447 Status: dzVents: {["level"]=20, ["minutes"]=10}
2020-02-15 20:47:00.447 Status: dzVents: Info: Spots Keuken is dimmed to level 20 after 300 minutes.
So the code expect to always have the "auto_off_minutes" set.
Best regards,
When I add
Best regards,
Vondee
There is however another issue, now the normal switches having settings of 30 minutes and controlled by a PIR sensor now switch off after a minute.
rrozema
Thanks, you're right. I update the script in my previous post. I'm not done with it yet, so I'm not putting it in the opening post yet. As You may see from the code I'm trying to add auto_on functionality to it too: I would like to have the possibility to specify in the settings the name of the sensor(s) that should switch the device On too. This would reduce the number of scripts running in my system even more. Because dzvents doesn't have meta-data triggers I am building a list of trigger devices, which gets updated every minute. Using this list I can then have this script check for every device activation if a device needs to be switched "On" too. This would make the functionality of auto_dim more useful, as I've noticed that swithcing a dimmer "On", returns it to the last level set. So that will always be the lowest dim level specified for that device. I want auto_on to set it to a specified level so that the light for can example go on at 100%, dim to 20% after 5 minutes of no movement and only after another 10 minutes go Off. If however someone enters the room, the light should go back to 100% again, even if it hasn't gone Off yet. But I'm still trying to get this to work correctly and I don't have a lot a free time for it.Vondee wrote: Saturday 15 February 2020 20:51 After the set time, Domoticz has an error:
rrozema
Please post the settings you've used, because I don't see this happening for my settings.Vondee wrote: Saturday 15 February 2020 22:10 There is however another issue, now the normal switches having settings of 30 minutes and controlled by a PIR sensor now switch off after a minute.
Vondee
settings:
"auto_off_minutes": 30,
"auto_off_motion_device": "kamer sensor PIR",
"auto_off_motion_device": "Keuken Sensor PIR",
"auto_off_motion_device": "PIR Garage"
settings:
rrozema
ah, That's my mistake. These are the settings I initially described for when you have more than one (motion) sensor for a light. Waaren pointed out however, that when you put them like this, only one of the auto_motion_device entries is used. The correct way to list multiple motion devices is like this:Vondee wrote: Sunday 16 February 2020 20:06 Hi,
settings:
"auto_off_motion_device": ["kamer sensor PIR", "Keuken Sensor PIR", "PIR Garage"]
Vondee
Sorry for that, I did not read the whole post. I looked at the log's and found more strange things, so I suspect it all has to do with the wrong format of the motion detectors. I changed the descriptions to the new format and tomorrow I will try to run the new script.
The tip you had is an eyeopener for me and will take more care for naming new devices.
Many thanks so far for helping me. The script has great potential!
Again, thanks!
Again, thanks!
rrozema
I updated the auto_dim (test) version another time: a small improvement for the timing. It now looks for secondsAgo to be greater than minutes * 60. This should make the timing more accurate when you've set only a small delay like 1 or 2 minutes.
Vondee
I use now your latest script and seems to work OK now.
I do not think that I would use this functionality, since time / lux etc. is also an input to determine that a light should go on.If however someone enters the room, the light should go back to 100% again, even if it hasn't gone Off yet. But I'm still trying to get this to work correctly and I don't have a lot a free time for it.
Vondee
If I manually (or on time) turn the dimmed light off, then the script put it back at the level what was set by the '"auto_off_dimlevel".
The light was at the selected level for the "auto_off_dimlevel" when I turned off the light.
Or do I something wrong?
rrozema
That should not be possible: at every run the script searches in the settings for a dim level that is lower than the light's current level and only activates that dim level. In other words: if the light is off, it should not find a new dim level to set, i.e. it makes no changes to the light's settings. Please post your settings for this light, maybe something is still wrong with that. Please also post the type of dimmer you have installed and the domoticz & dzvents version you are running on.Vondee wrote: Thursday 20 February 2020 13:39 If I manually (or on time) turn the dimmed light off, then the script put it back at the level what was set by the '"auto_off_dimlevel".
Vondee
"auto_off_dimlevel": { "level": 20, "minutes": 30 },
"auto_off_motion_device": ["Keuken Sensor PIR"]
Vondee
Dzvents 2.5.5
Zwave PIR
Dzvents 2.5.5
Zwave PIR
