Page 2 of 2
Re: email notification when a user disarmed the alarm
Posted: Wednesday 13 June 2018 16:35
by jvdz
That means you are missing some LUA libraries.
I have them installed as described in the DTGBOT wiki:
https://www.domoticz.com/wiki/Remote_Co ... _Libraries
Jos
Posted: Wednesday 13 June 2018 21:30
by EricT
Aah, ok.
Thanks Jos I will have another go at it tomorrow!
Eric
Posted: Thursday 14 June 2018 9:48
by EricT
Hi Jos,
I have created the Lua libraries as described here:
https://www.domoticz.com/wiki/Remote_Co ... _Libraries and it
WORKS!
I only received the error
Error: EventSystem: in name test: [string "..."]:36: attempt to index global 'devicechanged' (a nil value) but changing the Lua type from
All to
Device solved the error.
Next step is using it in my email notification.
Thanks Jos! Thumbs Up!
Eric
Posted: Thursday 14 June 2018 12:41
by jvdz
You're welcome.
I've played a little more with the code and it is working pretty fast so no issues using it in the Event system thus far
I did set the domoticzurl to the below assuming it needs to stay on the same server:
DOMO_url = "http:///127.0.0.1:8080"
Jos
Posted: Thursday 14 June 2018 12:47
by EricT
I have added the email notification and it is working like a charm!
Tanks again Jos!
BTW, I have used the local Raspberry Pi IP address and it issues an email immidiately when the switch is turned On/Off. It is working and I do not know the difference when using http:///127.0.0.1:8080
Eric
For those who are interested, here is my completed script updated with loglevel2 for latest beta's:
-- This script requires the installation of Lua 5.2 and the libraries
-- https://www.domoticz.com/wiki/Remote_Control_of_Domoticz_by_Telegram_Bot#Installing_Lua_Libraries
-- JQ dependencie is not requiered
--- This script sends an email when a user has turned the Test Switch On/Off
--- !!! Make sure this Lua is set as "Device", NOT as "All".
http = require "socket.http";
socket = require "socket";
https = require "ssl.https";
json = require "JSON";
DOMO_url = "http://192.168.x.xx:8080" -- Raspberry Pi local IP address
-- Get information recent log entries for switch action
function getswitchedbyinfo(device)
local response, returncode = http.request(DOMO_url..'/json.htm?type=command¶m=getlog&loglevel=2') ---&loglevel=2 is required with the latest beta's.
local suser=""
local stime=""
local sidx=""
local sstatus=""
local input = json:decode(response)
local result_table = input['result']
local tc = #result_table
for i = 1, tc do
for ltime,luser,lidx,ldevice,lstatus in string.gmatch(input.result[i].message, '(.-)%sUser:%s(.-)%sinitiated a switch command.-%((.-)/(.-)/(.-)%)')
do
if ldevice==device then
suser=luser
stime=ltime
sidx=lidx
sstatus=lstatus
return suser,stime,sidx,sstatus
device = "Test Switch" -- define the switch you want to use
if devicechanged[device] == 'On' then
user,timeinfo,idx,status = getswitchedbyinfo(device)
if user ~= "" then
commandArray['SendEmail'] = 'The Test Switch is turned On by '..user..', blabla # The Test Switch was turned On by '..user..' , blabla.#[email protected]'
if devicechanged[device] == 'Off' then
if user ~= "" then
commandArray['SendEmail'] = 'The Test Switch is turned Off by '..user..', blabla # The Test Switch was turned Off by '..user..' , blabla.#[email protected]'
Re: [another one solved] email notification when a user disarmed the alarm
Posted: Thursday 14 June 2018 22:49
by waaren
@EricT @jvdz,
could you please share the logline with the username that you get using the getlog json ?
For some reason I only get the username on a "Status:" logline and these lines are not returned by the json command (on my system)
(I do see them in my os logfile so I can go ahead and create a dzVents version of this method but I like my initial idea more)
Thanks in advance !
Posted: Thursday 14 June 2018 23:11
by EricT
Here it is:
2018-06-14 23:09:29.822 User: Eric initiated a switch command (52/Activity Main Switch/Off)
Posted: Thursday 14 June 2018 23:13
by jvdz
I am still running on version V3.8793 on the systems I worked with. That is returneing both Level 1 & 2 messages with the getlog JSON request.
Checked now also an other domoticz setup for development which is running on V3.9625 and there it defaults to level 1 only. You can change this to get level 2 by adding this to the URL: /json.htm?type=command¶m=getlog&loglevel=2
Jos
Posted: Thursday 14 June 2018 23:17
by waaren
EricT wrote: Thursday 14 June 2018 23:11
Here it is:
Many thanks Eric,
please be aware that if you move on to a later version the way this is logged will change and therefore you then will need to add &loglevel=2 to the getlog json to get this type of message. Not sure with what version is starts but I know for sure >= V3.9580
Posted: Thursday 14 June 2018 23:20
by jvdz
I have added it to the earlier posted code as the older domoticz version simply ignores it and it's required for the latest versions.
Jos
Posted: Thursday 14 June 2018 23:38
by EricT
Thanks guys!
I do not have plans to update to a newer Domoticz version any time soon (last time I did I had to roll back due to issues) but just in case I have updated my script.
Just a little advice to whom it may concern; make sure you have an image of your Raspberry Pi when updating to a newer version. I only had an old image thus I had some work to get it back where I left before the update.
Eric
Posted: Friday 15 June 2018 14:54
by jvdz
This is now the function i have in my general lua library file. It also limits the retrieval period of the log records to the last 15 seconds:
-- Get information from the last 15 seconds of log entries for the switch action details, returning User&Time and IDX&Status of the device
local LastXXsecs = os.time()-15
local response, returncode = http.request('http://127.0.0.1:8080/json.htm?type=command¶m=getlog&loglevel=2&lastlogtime='..tostring(LastXXsecs))
local suser=""
local stime=""
local sidx=""
local sstatus=""
for i = 1, tc
do
do
suser=luser
stime=ltime
sidx=lidx
sstatus=lstatus
Jos
Posted: Friday 15 June 2018 15:25
by EricT
by jvdz ยป Friday 15 June 2018 14:54
Thanks Jos!
Eric
