Page 2 of 2
Re: Daily Energy usage cost
Posted: Wednesday 04 April 2018 10:12
by MikeF
Run it at the command line (e.g., python </path to script/>energy_cost.py ) and see if you get any errors.
Posted: Wednesday 04 April 2018 17:59
by EdwinK
When I run the script from command line there are no errors.
Posted: Wednesday 04 April 2018 18:01
by EdwinK
These are the costs I find at the Eneco site.
fixed = 0 # fixed cost in euro
unit = 0.2032 # unit cost in eurocents
Posted: Wednesday 04 April 2018 23:27
by MikeF
Wow, that's cheap!
My unit rate is 13.94p = 16.03 cents (approx.)
- are you sure your rate isn't 20.32 cents? (my script divides by 100, to convert to pounds / euros)
Mike
Posted: Thursday 05 April 2018 9:14
by EdwinK
Yes, you are right.
€ 0,2271 Per kwh High
€ 0,2130 Per kwh Low
Fixed costs € 3,46 month
Posted: Sunday 03 June 2018 23:12
by astrapowerrr
Edwink
I have also toon can i copy your script so i can change it to my own costs.
I am very interested in using daily cost just like toon.
And use this in dashticz too.
Can you help me with this one?
Posted: Friday 04 January 2019 20:41
by garethiowc
Hi All,
recently rebuild my computer and have run into the following problem -
/usr/bin/python2.7 energy_cost.py
File "energy_cost.py", line 36, in <module>
kW = domoticzread(OwlIdx, 'CounterToday')
File "energy_cost.py", line 32, in domoticzread
jsonData = json.loads(response.text)
File "/usr/lib/python2.7/json/__init__.py", line 339, in loads
return _default_decoder.decode(s)
File "/usr/lib/python2.7/json/decoder.py", line 364, in decode
obj, end = self.raw_decode(s, idx=_w(s, 0).end())
File "/usr/lib/python2.7/json/decoder.py", line 382, in raw_decode
raise ValueError("No JSON object could be decoded")
ValueError: No JSON object could be decoded
any ideas?
Posted: Sunday 13 January 2019 16:52
by simon_rb
This looks good.
I am looking for a way to calculate the cost which takes into account dual tariffs like Economy 7? Some how add a time calculation into the equation or rely on a dummy switch/VAR which could be timed with the ECO 7 timings?
Would also love the monthly cost also..
Any help would be great.
Many Thanks
