New RFXCOM FW available
fotogen
Re: New RFXCOM FW available
Post by fotogen »
Bumping this, I have RFXTRX433 and just installed a Dooya motor on a vertikal sunshade. Talked to the guy who distribute them and they are re-branded but not changed in the terms of protokoll etc. According to the userguide the latest firmware should support dooya enginge but i cannot get it to work.
Really strive to control this through my Rasp Domoticz.... Help very much appreciated :D
Skärmavbild 2015-05-13 kl. 17.59.25.png (14.18 KiB) Viewed 9292 times
b_weijenberg
Post by b_weijenberg »
Have you flashed the RFXtrx with Type1 firmware?
Try with RFXmngr to pair a new remote in the motor using Blinds1 - T6 DC106.
Select a random ID and unit code,
Put the motor in learning mode,
Transmit a Confirm command.
RFX-433, RFX-433EMC, RFX-868
fotogen
Post by fotogen »
Currently running Type 2 FW, Have runned Domoticz for some years now, and is new to RFXMngr. Anyhow - Maybe a stupid question, if i program the motor for the new Blinds T1 DC106 code. Will i be able to use my remote control? I want to use both and?
What would requrie if the answer is no?
Cheers
b_weijenberg
Normally blind motors can have multiple remotes paired.
Check the user guide of the motor how to add an additional remote.
sebitop
Post by sebitop »
Hi guys
did someone get a dooya motor coupled with domoticz ?
cheers
sebastien
domoticz on Raspberry Pi + RFXcom LAN moded
Blyss / DI.O / ESP / Arduino
Dlanor
Post by Dlanor »
I have tried to pair with my Dooya motor but it fails. It won't connect.
Packettype        = UNDECODED RF Message
UNDECODED ARC:11000000
Blinds command
Packettype    = BLINDS1
subtype       = DC106
Sequence nbr  = 31
id1-4         = 05040B6
Unit          = 0
Command       = Confirm/Pair
Signal level  = 0
Packettype        = Receiver/Transmitter Message
subtype           = Transmitter Response
Sequence nbr      = 31
response          = ACK, data correct transmitted
Blinds command
subtype       = DC106
Sequence nbr  = 32
id1-4         = 05040B6
Unit          = 0
Command       = Open
Signal level  = 0
Sequence nbr      = 32
Domoticz| Zigbee | SONOFF
b_weijenberg
Dlanor: Try Dooya with unit code 1.
Unit code 0 has sometimes a special meaning. The type of your Dooya remote should start with DC.
If you can't get it operational with RFXmngr contact RFXCOM.
Dynamic
Post by Dynamic »
Got a Dooya too, but I can't get it paired neither.
I think I don't understand how to put my Dooya-motor in learning mode (horizontal sunscreen). I can't find the right way to do it, Google isn't helping me out. I removed the powercord, put it back in. And send 3 times the command 'confirm' using RFXmngr.
Blinds command
subtype       = DC106
Sequence nbr  = 7
id1-4         = DC01011
Unit          = 3
Signal level  = 0
Sequence nbr      = 7
Blinds command
subtype       = DC106
Sequence nbr  = 8
id1-4         = DC01011
Unit          = 3
Command       = Open
Signal level  = 0
Sequence nbr      = 8
Edit: I managed to pair RFXmngr with my Dooya-motor. However, after pairing it removes my remote control. And for the WAF i need the remote control also to work. Is there a way to 'sniff' the code that my remote is sending? Then I can 'clone' this into domoticz.
I got a Spanish manual, but my Spanish is not that good: https://adbarbieri2.files.wordpress.com ... rte-11.pdf
b_weijenberg
Try this:
1 remove all remotes to be able to add the original remote as main remote
2 add the original Dooya remote as described in the Dooya user guide
3 press the pair button on the Dooya remote twice
4 transmit 1 confirm/pair command using RFXmngr to add the RFXtrx "remote"
Note: The ID can be anything except all zeroes and do not use unit code zero.
My previous message about the remote type DC is the type indication written on the Dooya remote.
Dynamic
Post by Dynamic »
Makes sense. I will try this tomorrow and post the result.
For other users who don't know how to put your Dooya motor in learning mode:
- disconnect power for at least 10 seconds
- connect power again and proceed with the pairing-procedure within 10 seconds
Pairing procedure:
- press confirm twice
- press UP once
Time delay between pressing the buttons should be below 6 seconds.
Dynamic
Post by Dynamic »
b_weijenberg wrote:Try this:
It worked, but i didn't follow steps 1 and 2. Just step 3 and for made it work for me.
Thank you very much! :)
bewo
Domoticz version: 2021.1
Post by bewo »
Dynamic wrote: It worked, but i didn't follow steps 1 and 2. Just step 3 and for made it work for me.
Worked for me in the same way! Thanks a lot! :D
Individual projects:
Domoticz on a Intel Xeon Server | AeonLabs Z-Wave Gen.5 | RFXCOM RFXtrx433E USB | ESP-Wifi-Modules | Shellys
Wall-mounted 22" Touch Control Display (self construct) | LUA wind monitor| LUA heating control | and many many more :)
sanderjohan
Domoticz version: 3.4834
Post by sanderjohan »
It does not seems to work for me. I have a DOOYA DC305 remote which I already paired to the DOOYA curtain motor DT82TN.
I have updated the RFXCOM RFXtrx433E with the latest Ext2 Firmware (1004). After that I used the following settings in RFXmngr:
Type = T6 DC106,......
ID = 01 01 01 1
Unit code = 2
Command = Confirm
The transmit button is pressed after that I pressed the P2 button on the back of the remote.
Blinds command
subtype = DC106
Sequence nbr = 11
id1-4 = 0101011
Unit = 2
Signal level = 0 -120dBi
21-5-2016 14:55:09
Sequence nbr = 11
But still it does not seems to work.
Please advise.
b_weijenberg
Did you press the P2 button twice? Some motors will respond with a beep or a small up/down left/right move indicating the motor is in learning mode.
EdddieN
Domoticz version: 4.9700
Post by EdddieN »
I have several devices connected to RFXcom, including 2 Raex motors for roller blinds. All working fine since about 1-2 years.
Today I added a 3rd Raex motor, it is a slightly new model quieter, not it seems the RFXcom / Domoticz cannot see the new device. I have tried manger and after a fair bit of reset I g, unplugging, etc, eventually it seemed to pick up a signal (this was with the remote next to the transceiver).
A tried a few times to transmit that signal, some odd times would work, others won’t, more not than yes.
The remote is the one specified on RFXcom manual for Raex motors
Running type2 and T4 enabled.
Here is the odd thing, the old motors work perfectly, but the new one doesn’t. Is there a chance the signal on the new motors has changed slightly?
Motor is TQL25
Remote is YR1326 7 channel remote
11101101 - www.machinon.com
