Re: buienradar lua script
Posted: Thursday 23 August 2018 10:53
nice
Join 16,000+ members discussing home automation with Domoticz. Get help with Zigbee, ZWave, MQTT, scripting, and 150+ integrations
https://forum.domoticz.com/
-- BuienRadar Module
-- curl in os required!!
-- create dummy text device from dummy hardware 'Buien Radar'
-- create dummy rain sensor from dummy hardware 'BuienRadarMeter'
-- create dummy switch from dummy hardware for triggering screens etc based on rain
-- add as time based lua script
-- set your longitude & latitude below!
-- 2017-12-27 working version
-- 2017-12-28 trying to get the rain device working .. missing documentation ..
-- 2017-12-30 isolated the bug, i was overwriting the updatedevice .. should be ok now
-- 2018-03-28 updated buienradar url
-- 2018-04-02 added follow redirect for curl & fixed typo as tipped by gizmocuz
local myBuienRadarDevice='Buien Radar'
local myBuienRadarMeter='BuienRadarMeter'
local myBuienRadarFlg='flgBuienRadar'
-- longitude latitude
local lat='51.59'
local lon='4.77'
time = os.date("*t")
if time.min % 5 == 0 then
print('BuienRadar module')
function os.capture(cmd, rep) -- execute command to get site
-- rep is nr of repeats if result is empty
r = rep or 1
local s = ""
while ( s == "" and r > 0) do
r = r-1
local f = assert(io.popen(cmd, 'r'))
s = assert(f:read('*a'))
f:close()
if ( rep - r > 1 ) then
print("os.capture needed more than 1 call: " .. rep-r)
return s
-- get data from buienradar
local command = "curl --max-time 5 -L -s 'http://gpsgadget.buienradar.nl/data/raintext?lat=" .. lat .. "&lon=" .. lon .. "'"
-- print("command: " .. command)
local tmp = os.capture(command, 3)
-- print('buienRadar data:\n' .. tmp)
if ( tmp == "" ) then
print("buienRadar: Empty result from curl command")
-- analyse data
-- to mm/h 10^((waarde-109)/32)
function tomm(r)
return 10^((r-109)/32)
-- to string formatted
function tos(r, c)
c = c or 1
return string.format("%." .. c .. "f", r)
local c=0
local rainNow=0
local rainNowAvg = 0
local rainSoon = 0
local rainTime = ""
local rainMax = 0
for k,v in tmp:gmatch('(.-)|(.-)\r?\n') do
-- k is rain value, v is time
kn = tonumber(k)
if c<=1 then
if rainNow < kn then
rainNow = kn
if kn > 0 then
rainNowAvg = rainNowAvg + tomm(kn)/2
if c<=3 and rainSoon < kn then
rainSoon = kn
if rainTime == "" and kn > 0 then
rainTime = v
if kn > rainMax then
rainMax = kn
c = c+1
-- if c = 0 no data found!
if ( c == 0 ) then
print("buienRadar: Unparsable result from curl command")
if rainNow>0 then
tmp = "now; " .. tos(tomm(rainNow)) .. "mm/h"
if rainMax > rainNow then
tmp = tmp .. " upto " .. tos(tomm(rainMax)) .. "mm/h"
elseif rainSoon>0 then
tmp = "soon in 15mins; " .. tos(tomm(rainSoon)) .. "mm/h"
if rainMax > rainSoon then
elseif rainTime ~= "" then
tmp = "expected @ " .. rainTime .. "; upto " .. tos(tomm(rainMax)) .. "mm/h"
else tmp = "No rain"
-- calculate totalrainfall using rainNowAvg as average of 2 next reports
-- print("buienRadarMeterOld: " .. otherdevices_svalues[myBuienRadarMeter])
local rainTot = tonumber(otherdevices_svalues[myBuienRadarMeter]:match("[^;]+;([^;]+)")) + rainNowAvg/12 -- /12 to acount for 5min measurements ?? ..
-- print("buienRadarDebug: rainNow=" .. tos(tomm(rainNow)) .. " rainNowAvg=" .. tos(rainNowAvg) .. " rainSoon=" ..
-- tos(tomm(rainSoon)) .. " rainTot=" .. tos(rainTot,2) .. " rainTime=" .. rainTime .. " rainMax=" .. tos(tomm(rainMax)))
local cmd = otherdevices_idx[myBuienRadarMeter] .. "|0|" .. tos(tomm(rainNow)*100,0) .. ";" .. tos(rainTot,2)
-- print("buienRadar: " .. cmd)
table.insert(commandArray, { ['UpdateDevice'] = cmd } ) -- table.insert needed to avoid overwriting with next updatedevice
-- write to text device
if otherdevices[myBuienRadarDevice] ~= tmp then
table.insert(commandArray, { ['UpdateDevice'] = otherdevices_idx[myBuienRadarDevice] .. '|0|' .. tmp })
-- trigger based when rainNow or rainSoon
if ( rainNow>0 or rainSoon>0 ) then
if otherdevices[myBuienRadarFlg] == "Off" then
commandArray[myBuienRadarFlg] = "On"
elseif otherdevices[myBuienRadarFlg] == "On" then
commandArray[myBuienRadarFlg] = "Off"
end -- unparsable
end -- empty result
hello i'm having the same error (attempt to perform arithmetic on a nil value)
Interesting, could you tell me how to set that up?jvdz wrote:I am running a buienradar LUA script as well, but am not running it with the Domoticz event systems as these type of script have to go to the internet to grab the information, so will slow down the single threaded process. So I am running it with crontab and use the JSON/API interface to update the Domoticz devices to avoid these issues and potential slowness of the event system.
Jos
Sure: this is the script I run via crontab and the info is in it. Let me know when you have questions.
--- Get rain info from buienradar for the next xx minutes
--- This is the crontab entry I have which creates the log file in /var/tmp. remember to have this cleaned regularly which I do daily.
--- Crontab task: */5 * * * * sudo lua /home/pi/domoticz/scripts/buienradar_rainprediction.lua >> /var/tmp/BRP.log
-- Start config ---------------------------------------------------------
lat='52.??'
lon='4.??'
-- use information for the next xx minutes to calculate the percentage for prediction
minutesinfuture=15
-- Domoticz server url
domoticzurl="http://192.168.xx.xx:8080"
-- IDX dummy rain device
DEVIDX=111
-- IDX dummy General Percentage device
PDEVIDX=222
debug=true
-- can be anywhere writeable
tempfilename = '/var/tmp/rain.tmp'
-- END config ---------------------------------------------------------
url='http://gadgets.buienradar.nl/data/raintext?lat='..lat..'&lon='..lon
if debug then print(url) end
read = os.execute('curl -Lo '..tempfilename..' "'..url..'"')
file = io.open(tempfilename, "r")
totalrain=0
rainlines=0
-- now analyse the received lines, format is like 000|15:30 per line.
while true do
line = file:read("*line")
if not line then break end
linetime=string.sub(tostring(line), 5, 9)
-- Linetime2 holds the full date calculated from the time on a line
linetime2 = os.time{year=os.date('%Y'), month=os.date('%m'), day=os.date('%d'), hour=string.sub(linetime,1,2), min=string.sub(linetime,4,5), sec=os.date('%S')}
difference = os.difftime (linetime2,os.time())
-- When a line entry has a time in the future AND is in the given range, then totalize the rainfall
if ((difference >= 20) and (difference<=minutesinfuture*60)) then
rain=tonumber(string.sub(tostring(line), 0, 3))
totalrain = totalrain+rain
rainlines=rainlines+1
if debug then print('Rain in timerange: '..rain .. ' Total rain now: '..totalrain .. ' difference:' .. difference .. ' Line:' ..line ) end
file:close()
-- Returned value is average rain fall for next time
-- 0 is no rain, 255 is very heavy rain
-- When needed, mm/h is calculated by 10^((value -109)/32) (example: 77 = 0.1 mm/hour)
if rainlines == 0 then
averagerain=0
averagerain=math.ceil(totalrain/rainlines)
function round(num, idp)
return tonumber(string.format("%." .. (idp or 0) .. "f", num))
-- Calculate the mm/h
calcmmh = round(10^((averagerain -109)/32),2)
if debug then print(os.date() .. " averagerain:" .. averagerain .. " calcmmh:" .. calcmmh) end
-- Update Domotics Device
url=domoticzurl..'/json.htm?type=command¶m=udevice&idx=' .. DEVIDX .. '&nvalue=0&svalue=' .. calcmmh .. ';' .. calcmmh
read = os.execute('curl -s "'..url..'"')
if debug then print(read) end
-- Update percentage regenkans Domotics Device
result = round(averagerain*0.392156862745098,2)
url=domoticzurl..'/json.htm?type=command¶m=udevice&idx=' .. PDEVIDX .. '&nvalue=0&svalue=' .. result
if debug then print('==> Rain chance: '..result .. '%') end
if debug then print('------------------------------------------------------------------------------------------------------------------------------------------') end
You created 2 rain devices but you need 1 rain device and 1 percentage device:goblin wrote: Monday 15 July 2019 23:09 any idea to solve this.
i have two dummies (copied from devices)
6 regen_percentage 14056 1 regen percentage Rain TFA 0, 0
3 regen_buienalarm 14053 1 regen_buienalarm Rain TFA 0;0
000|14:30
000|14:35
000|14:40
000|14:45
113|14:50
131|14:55
132|15:00
132|15:05
133|15:10
134|15:15
135|15:20
131|15:25
092|15:30
092|15:35
000|15:40
077|15:45
092|15:50
092|15:55
099|16:00
077|16:05
000|16:10
000|16:15
000|16:20
000|16:25
