buienradar lua script
JuanUil
Domoticz version: 4.11083
Re: buienradar lua script
Post by JuanUil »
nice :D :D
Driesser
Post by Driesser »
Hmm,
It rained a couple of time last weekend (also shown on the "BuienRadarMeter") but thes witch didn't flipped.
I added an the following switch, but it doesn't do anything.
My Lua Script is as follow
-- BuienRadar Module
-- curl in os required!!
-- create dummy text device from dummy hardware 'Buien Radar'
-- create dummy rain sensor from dummy hardware 'BuienRadarMeter'
-- create dummy switch from dummy hardware for triggering screens etc based on rain
-- add as time based lua script
-- set your longitude & latitude below!
-- 2017-12-27 working version
-- 2017-12-28 trying to get the rain device working .. missing documentation ..
-- 2017-12-30 isolated the bug, i was overwriting the updatedevice .. should be ok now
-- 2018-03-28 updated buienradar url
-- 2018-04-02 added follow redirect for curl & fixed typo as tipped by gizmocuz
local myBuienRadarDevice='Buien Radar'
local myBuienRadarMeter='BuienRadarMeter'
local myBuienRadarFlg='flgBuienRadar'
-- longitude latitude
local lat='51.59'
local lon='4.77'
time = os.date("*t")
if time.min % 5 == 0 then
    print('BuienRadar module')
    function os.capture(cmd, rep)   -- execute command to get site
        -- rep is nr of repeats if result is empty
        r = rep or 1
        local s = ""
        while ( s == "" and r > 0) do
            r = r-1
            local f = assert(io.popen(cmd, 'r'))
            s = assert(f:read('*a'))
            f:close()
        if ( rep - r > 1 ) then
            print("os.capture needed more than 1 call: " .. rep-r)
      return s
    --  get data from buienradar
    local command = "curl --max-time 5 -L -s 'http://gpsgadget.buienradar.nl/data/raintext?lat=" .. lat .. "&lon=" .. lon .. "'"
    -- print("command: " .. command)
    local tmp = os.capture(command, 3)
    -- print('buienRadar data:\n' .. tmp)
    if ( tmp == "" ) then
        print("buienRadar: Empty result from curl command")
        -- analyse data
        -- to mm/h 10^((waarde-109)/32)
        function tomm(r)
            return 10^((r-109)/32)
        -- to string formatted
        function tos(r, c)
            c = c or 1
            return string.format("%." .. c .. "f", r)
        local c=0
        local rainNow=0
        local rainNowAvg = 0
        local rainSoon = 0
        local rainTime = ""
        local rainMax = 0
        for k,v in tmp:gmatch('(.-)|(.-)\r?\n') do
            -- k is rain value, v is time
            kn = tonumber(k)
            if c<=1 then
                if rainNow < kn then
                    rainNow = kn
                if kn > 0 then
                    rainNowAvg = rainNowAvg + tomm(kn)/2
            if c<=3 and rainSoon < kn then
                rainSoon = kn
            if rainTime == "" and kn > 0 then
                rainTime = v
            if kn > rainMax then
                rainMax = kn
            c = c+1
        -- if c = 0 no data found!
        if ( c == 0 ) then
            print("buienRadar: Unparsable result from curl command")
            if rainNow>0 then
                tmp = "now; " .. tos(tomm(rainNow)) .. "mm/h"
                if rainMax > rainNow then
                    tmp = tmp .. " upto " .. tos(tomm(rainMax)) .. "mm/h"
            elseif rainSoon>0 then
                tmp = "soon in 15mins; " .. tos(tomm(rainSoon)) .. "mm/h"
                if rainMax > rainSoon then
            elseif rainTime ~= "" then
                tmp = "expected @ " .. rainTime .. "; upto " .. tos(tomm(rainMax)) .. "mm/h"
            else tmp = "No rain"
            -- calculate totalrainfall using rainNowAvg as average of 2 next reports
            -- print("buienRadarMeterOld: " .. otherdevices_svalues[myBuienRadarMeter])
            local rainTot = tonumber(otherdevices_svalues[myBuienRadarMeter]:match("[^;]+;([^;]+)")) + rainNowAvg/12 -- /12 to acount for 5min measurements ?? ..
            -- print("buienRadarDebug: rainNow=" .. tos(tomm(rainNow)) .. " rainNowAvg=" .. tos(rainNowAvg) .. " rainSoon=" ..
            --      tos(tomm(rainSoon)) .. " rainTot=" .. tos(rainTot,2) .. " rainTime=" .. rainTime .. " rainMax=" .. tos(tomm(rainMax)))
            local cmd = otherdevices_idx[myBuienRadarMeter] .. "|0|" .. tos(tomm(rainNow)*100,0) .. ";" .. tos(rainTot,2)
            -- print("buienRadar: " .. cmd)
            table.insert(commandArray, { ['UpdateDevice'] = cmd } ) -- table.insert needed to avoid overwriting with next updatedevice
            -- write to text device
            if otherdevices[myBuienRadarDevice] ~= tmp then
                table.insert(commandArray, { ['UpdateDevice'] = otherdevices_idx[myBuienRadarDevice] .. '|0|' .. tmp })
                -- trigger based when rainNow or rainSoon
                if ( rainNow>0 or rainSoon>0 ) then
                    if otherdevices[myBuienRadarFlg] == "Off" then
                        commandArray[myBuienRadarFlg] = "On"
                elseif otherdevices[myBuienRadarFlg] == "On" then
                    commandArray[myBuienRadarFlg] = "Off"
        end -- unparsable
    end -- empty result
I thought the switch should be the same als rule 20.
Can you help me?
HansieNL
Post by HansieNL »
Is your switch a dummy switch as it is saying buienradar hardware and not dummy?
Edit: My mistake. I named my dummy hardware Dummy and create all dummies from there :oops:
Blah blah blah
sjocha
Post by sjocha »
HansieNL wrote: Thursday 05 April 2018 17:07 @nf999: Got it working :-)
hello i'm having the same error (attempt to perform arithmetic on a nil value)
could you share how you solved this problem ?
HansieNL
Post by HansieNL »
I got several times a day errors: Error: EventSystem: Warning!, lua script /home/pi/domoticz/scripts/lua/script_time_buienradar.lua has been running for more than 10 seconds. Is there something I can do to get rid of these errors?
Blah blah blah
jvdz
Domoticz version: 4.107
Post by jvdz »
I am running a buienradar LUA script as well, but am not running it with the Domoticz event systems as these type of script have to go to the internet to grab the information, so will slow down the single threaded process. So I am running it with crontab and use the JSON/API interface to update the Domoticz devices to avoid these issues and potential slowness of the event system. :)
Jos
dressie
Domoticz version: V2020.2
Post by dressie »
jvdz wrote:I am running a buienradar LUA script as well, but am not running it with the Domoticz event systems as these type of script have to go to the internet to grab the information, so will slow down the single threaded process. So I am running it with crontab and use the JSON/API interface to update the Domoticz devices to avoid these issues and potential slowness of the event system. :)
Jos
Interesting, could you tell me how to set that up?
Verstuurd vanaf mijn SM-G950F met Tapatalk
jvdz
Post by jvdz »
dressie wrote: Sunday 21 April 2019 9:06 Interesting, could you tell me how to set that up?
Sure: this is the script I run via crontab and the info is in it. Let me know when you have questions.
Just file in the information in the Config section. This script requires 2 devices: a Rain and a Percentage device.
Scriptfile: buienradar_rainprediction.lua
---  Get rain info from buienradar for the next xx minutes
---  This is the crontab entry I have which creates the log file in /var/tmp. remember to have this cleaned regularly which I do daily.
---           Crontab task:  */5 * * * * sudo lua /home/pi/domoticz/scripts/buienradar_rainprediction.lua >> /var/tmp/BRP.log
-- Start config ---------------------------------------------------------
lat='52.??'
lon='4.??'
-- use information for the next xx minutes to calculate the percentage for prediction
minutesinfuture=15
-- Domoticz server url
domoticzurl="http://192.168.xx.xx:8080"
-- IDX dummy rain device
DEVIDX=111
-- IDX dummy General Percentage device
PDEVIDX=222
debug=true
-- can be anywhere writeable
tempfilename = '/var/tmp/rain.tmp'
-- END config ---------------------------------------------------------
url='http://gadgets.buienradar.nl/data/raintext?lat='..lat..'&lon='..lon
if debug then print(url) end
read = os.execute('curl -Lo '..tempfilename..' "'..url..'"')
file = io.open(tempfilename, "r")
totalrain=0
rainlines=0
-- now analyse the received lines, format is like 000|15:30 per line.
while true do
	line = file:read("*line")
	if not line then break end
	linetime=string.sub(tostring(line), 5, 9)
	-- Linetime2 holds the full date calculated from the time on a line
	linetime2 = os.time{year=os.date('%Y'), month=os.date('%m'), day=os.date('%d'), hour=string.sub(linetime,1,2), min=string.sub(linetime,4,5), sec=os.date('%S')}
	difference = os.difftime (linetime2,os.time())
	-- When a line entry has a time in the future AND is in the given range, then totalize the rainfall
	if ((difference >= 20) and (difference<=minutesinfuture*60)) then
		rain=tonumber(string.sub(tostring(line), 0, 3))
		totalrain = totalrain+rain
		rainlines=rainlines+1
		if debug then print('Rain in timerange: '..rain .. '   Total rain now: '..totalrain .. '   difference:' .. difference .. '    Line:' ..line ) end
file:close()
-- Returned value is average rain fall for next time
-- 0 is no rain, 255 is very heavy rain
-- When needed, mm/h is calculated by 10^((value -109)/32) (example: 77 = 0.1 mm/hour)
if rainlines == 0 then
	averagerain=0
	averagerain=math.ceil(totalrain/rainlines)
function round(num, idp)
  return tonumber(string.format("%." .. (idp or 0) .. "f", num))
-- Calculate the mm/h
calcmmh = round(10^((averagerain -109)/32),2)
if debug then print(os.date() .. "  averagerain:" .. averagerain .. "  calcmmh:" .. calcmmh) end
-- Update Domotics Device
url=domoticzurl..'/json.htm?type=command&param=udevice&idx=' .. DEVIDX .. '&nvalue=0&svalue=' .. calcmmh .. ';' .. calcmmh
read = os.execute('curl -s "'..url..'"')
if debug then print(read) end
-- Update percentage regenkans Domotics Device
result = round(averagerain*0.392156862745098,2)
url=domoticzurl..'/json.htm?type=command&param=udevice&idx=' .. PDEVIDX .. '&nvalue=0&svalue=' .. result
if debug then print('==> Rain chance: '..result .. '%') end
if debug then print('------------------------------------------------------------------------------------------------------------------------------------------') end
Jos
goblin
Domoticz version: 2023.1
Post by goblin »
it is partly working.
i get an error in my log file "
2019-07-15 22:55:02.046 Status: Warning: Expecting svalue with at least 2 elements separated by semicolon, 1 elements received ("0"), notification not sent (Hardware: 8 - regen_percentage, ID: 82006, Unit: 1, Type: 55 - Rain, SubType: 3 - TFA)"
any idea to solve this.
i have two dummies (copied from devices)
6 regen_percentage 14056 1 regen percentage Rain TFA 0, 0
3 regen_buienalarm 14053 1 regen_buienalarm Rain TFA 0;0
the only thing i see is the difference at the end (data)
i have checked for typos but all is copy/paste from above.
thanks
Joep123
Post by Joep123 »
goblin wrote: Monday 15 July 2019 23:09 any idea to solve this.
You created 2 rain devices but you need 1 rain device and 1 percentage device:
338 Dummy Hardware 00082338 1 regen_percentage General Percentage 0%
139 Dummy Hardware 140DB 1 regen_buienalarm Rain TFA 0;0
goblin
Post by goblin »
thanks, solved (i think)
now waiting for rain :D
dheuts
Post by dheuts »
Thanks a lot for the nice script!
I want to edit the script so it predicts if there will be rain in the next hours instead of minutes.
How to edit the script?
I changed the minutes to 600, to know if there will be rain in the next 10 hours....
But it's not working, the User Variable stays: "0".
Raspberry Pi 4 With Domoticz - RFXCom - Tuya Wifi LED lights - Chuango Alarm - Zwave+ - Zigbee2MQTT - Anna Thermostat - Broadlink IR, P1 - Eufy Robo Vacuum - Worx Robo Mower
jvdz
Post by jvdz »
When you open the downloaded file from buienradar you would see that the provided information is limited to something like this: (file date 14:25)
000|14:30
000|14:35
000|14:40
000|14:45
113|14:50
131|14:55
132|15:00
132|15:05
133|15:10
134|15:15
135|15:20
131|15:25
092|15:30
092|15:35
000|15:40
077|15:45
092|15:50
092|15:55
099|16:00
077|16:05
000|16:10
000|16:15
000|16:20
000|16:25
So that means you can only predict for the next 2 hours.
Jos
arnaudarduino
Post by arnaudarduino »
Hello Jos, and all other
The "Afvalkalender"i till working. Great Txs.
Now i like to put buienradar to Domoticz
I'v made two devices from the dummy does nothing switch 1 Rain ( TFA) sensor and 1 Percetage (General) sensor.
Uploaded the "buienradar_rainprediction.lua"script .(latest version with crontab)
But ,the box with percentage shows up (74)
the box with the ammount of rain is not showing up (75).
When i make another box (76) that one shows up too.
Last edited by arnaudarduino on Saturday 11 January 2020 16:24, edited 2 times in total.
jvdz
Post by jvdz »
I assume you use the last posted version which is ran by the crontab?
Have you tried running it from the commandline first , with debug=true, to see what it does?
Jos
arnaudarduino
When i run this from the command line:
~/domoticz/scripts/lua $ sudo lua buienradar_rainprediction.lua
http://gadgets.buienradar.nl/data/raint ... 2&lon=5.47
% Total % Received % Xferd Average Speed Time Time Time Current
Dload Upload Total Spent Left Speed
0 0 0 0 0 0 0 0 --:--:-- --:--:-- --:--:-- 0
100 264 100 264 0 0 2486 0 --:--:-- --:--:-- --:--:-- 2486
Rain in timerange: 0 Total rain now: 0 difference:60 Line:000|16:05
Rain in timerange: 0 Total rain now: 0 difference:360 Line:000|16:10
Rain in timerange: 0 Total rain now: 0 difference:660 Line:000|16:15
Sat Jan 11 16:04:21 2020 averagerain:0 calcmmh:0
http://192.168.2.18:8080/json.htm?type= ... svalue=0;0
"status" : "OK",
"title" : "Update Device"
0
http://192.168.2.18:8080/json.htm?type= ... 0&svalue=0
"status" : "OK",
0
==> Rain chance: 0%
Look there is no box idx 75
https://ibb.co/G33T3M5
Last edited by arnaudarduino on Saturday 11 January 2020 16:49, edited 4 times in total.
jvdz
Post by jvdz »
So that looks good i would say. The amount of rainfall builds up as it is expected, so makes sense it's zero at this moment. Just let it run and see what happens when rain is expected.
Jos
marktn
Post by marktn »
Nice script!
I have only a error, EventSystem: in buienradar: [string "-- BuienRadar Module..."]:121: attempt to perform arithmetic on a nil value
Any idea?
Domoticz latest stable, Intel NUC, Proxmox, Zigate, RFLink, Kaku switches, Ikea lights, Xiaomi sensors, Honeywell smoke detectors, Yeelight, Shelly, Slave Domoticz PI 3B+, Node-Red, Espeasy.
jvdz
Post by jvdz »
Same questions .... what happens when rain from the commandline with debug=true?
Jos
arnaudarduino
The box didn't show up ,because the MENU weather was off.
Now it works. Of course.
Txs
