dzVents 2.4.0 merged into Beta v3.8837+
EddyG
Re: dzVents 2.4.0 merged into Beta v3.8837+
Post by EddyG »
This is just the output of the Lux device:
   "ActTime" : 1516901014,
   "AstrTwilightEnd" : "19:11",
   "AstrTwilightStart" : "06:29",
   "CivTwilightEnd" : "17:50",
   "CivTwilightStart" : "07:50",
   "DayLength" : "08:45",
   "NautTwilightEnd" : "18:31",
   "NautTwilightStart" : "07:09",
   "ServerTime" : "2018-01-25 18:23:34",
   "SunAtSouth" : "12:05",
   "Sunrise" : "08:27",
   "Sunset" : "17:13",
   "result" : [
         "AddjMulti" : 1.0,
         "AddjMulti2" : 1.0,
         "AddjValue" : 0.0,
         "AddjValue2" : 0.0,
         "BatteryLevel" : 255,
         "CustomImage" : 0,
         "Data" : "1 Lux",
         "Description" : "",
         "Favorite" : 0,
         "HardwareID" : 24,
         "HardwareName" : "RaZberry",
         "HardwareTypeVal" : 21,
         "HaveTimeout" : false,
         "ID" : "0001003",
         "LastUpdate" : "2018-01-25 16:47:59",
         "Name" : "PIR Achterkamer Lux",
         "Notifications" : "false",
         "PlanID" : "0",
         "PlanIDs" : [ 0 ],
         "Protected" : false,
         "ShowNotifications" : true,
         "SignalLevel" : "-",
         "SubType" : "Lux",
         "Timers" : "false",
         "Type" : "Lux",
         "TypeImg" : "lux",
         "Unit" : 255,
         "Used" : 1,
         "XOffset" : "0",
         "YOffset" : "0",
         "idx" : "417"
   "status" : "OK",
   "title" : "Devices"
This part of the script:
        active = true,
--      active = false,
                devices = { 'PIR*' }
        execute = function(domoticz, detector)
print( '<b style="color:Red">>> ' .. detector.switchType )
                if detector.switchType == 'Motion Sensor' then
                        print('<b style="color:DarkOrange">>> ' .. detector.name  .. ' - ' .. detector.state )
dannybloe
Post by dannybloe »
So there aren’t any other devices whose name start with PIR? As you are using a wildcard.
EddyG
Post by EddyG »
I have 4 PIR* hardware devices, 3 from NeoCool and 1 from Fibaro.
Ofcourse each give several devices.
I use only the Motion, Temp and Lux devices.
Here is a Lux device that has a switchType "On/Off" and that's not normal.
I want to use the switchType to do different things when a device triggers.
Motion triggers more than Temp and Lux.
dannybloe
Post by dannybloe »
Can you start a new topic in bugs and describe your problem again with a full dump of domoticzData.lua (debug
Mode). We will continue there. This is off-topic for this thread.
elmortero
Domoticz version: 3.9639
Post by elmortero »
Hi dannybloe,
Is there any chance that checkFirst will be extended to Text sensors too?
That way you can avoid updating a text sensor with the same value over and over (unless the script checks that first of course)
Eoreh
Post by Eoreh »
Is future or bug ? In "Logs" we lost in dzVents "RED" color for "LOG_ERROR" ?
for eg line like this -> domoticz.log('TEST', domoticz.LOG_ERROR)
I think we need We need a larger selection of colors, no less
jake
Post by jake »
I just updated to Beta 3.8872 and came across some error
onkyomode.switchSelector(domoticz.data.KodiAudioMode).afterSec(onkyo_delay).silent().checkFirst()
gives the log error
dzVents: Error (2.4.1): /home/pi/domoticz/scripts/dzVents/scripts/kodi.lua:68: attempt to call field 'checkFirst' (a nil value)
I assume a switchselector has always a value, therefore not being able to be 'nil'.
Secondly, has the option for using the more standard LUA way: otherdevices_svalues been removed?
DHW_GasLua = otherdevices_svalues['DHW gas']
results in log error
dzVents: Error (2.4.1): /home/pi/domoticz/scripts/dzVents/scripts/GasMeterCheck.lua:23: attempt to index global 'otherdevices_svalues' (a nil value)
manutremo
Post by manutremo »
I just upgraded to 3.8841 and started to get this error in the log everytime a dzVents script tries to execute:
Error: EventSystem: in /usr/local/domoticz/var/dzVents/runtime/dzVents.lua: /usr/local/domoticz/var/dzVents/runtime/dzVents.lua:33: attempt to concatenate local 'triggerReason' (a nil value)
Not sure if it will be related but after activating dzVents debug, I'm getting:
dzVents: Debug: Dumping domoticz data to /usr/local/domoticz/var/scripts/dzVents//domoticzData.lua
dzVents: Debug: dzVents version: 2.3.0
Shouldn't I be seeing dzVents version 2.4.0 with this version of Domoticz?
dannybloe
Post by dannybloe »
You have a mixup of old and new. This is not a standard distribution that you have.
Eoreh
Post by Eoreh »
EddyG wrote: Thursday 25 January 2018 18:29
Thx for nice tip regarding the possibility of coloring in the log !
jake
Post by jake »
jake wrote:I just updated to Beta 3.8872 and came across some error
gives the log error
Besides the mentioned items here above, I came across 2 things while working on a script to influence the OTGW setpoint:
.updateSetPoint(xyz).checkFirst() is not accepted, like as with the switchSelector
while giving the .updateSetpoint() command, the log returns the following error:
2018-02-04 23:39:00.666 EventSystem: Script event triggered: /home/pi/domoticz/dzVents/runtime/dzVents.lua
2018-02-04 23:39:00.701 Error: Error opening url: http://127.0.0.1:8080/json.htm?type=command¶m=udevice&idx=87&nvalue=0&svalue=17.5
Of course, when I replace the '¶m' with '&param' in a browser window, the json call works as expected.
I tried fixing the dzVents device adapter.lua by replacing the ampersand '&' symbol by ' .. string.char(38) .. '
Unfortunately this is handled identical to the original string and gives the same error in the log file.
jake
Post by jake »
In this topic the suggestion is done to change the 'param=udevice' and 'type=command' around. I did this and now the log tells me
2018-02-05 23:13:00.553 Error: Error opening url: http://127.0.0.1:8080/json.htm?param=udevice&type=command&idx=87&nvalue=0&svalue=17.5
quite weird, since I can copy the exact http command (only changing the 127.0.0.1 to the internal IP-address of the RPI: 192.168.etc) in the browser window and have it running alright with an acknowledgement that it has run correctly.
So, I went back to the opentherm_gateway_device.lua and modified the lines
local url = domoticz.settings['Domoticz url'] ..
               '/json.htm?type=command&param=udevice&idx=' .. device.id .. '&nvalue=0&svalue=' .. setPoint
to
local url = 'http://192.168.myIP:8080' ..
               '/json.htm?param=udevice&type=command&idx=' .. device.id .. '&nvalue=0&svalue=' .. setPoint
and now it works out of the box.
So 2 changes:
- moving param and type around
- moving the local host IP address 127.0.0.1 (coming from domoticz settings) to the internal IP address that the RPI has on the network
Hi Danny,
while investigation the possibility to (re)set one of the zones of my evohome installation to auto, I noticed that dzVents did not recognize my Evohome via Web API device as evohome resulting in the message:
dzVents: Error (2.4.1): Method updateSetPoint is not available for device "Slaapkamer" (deviceType=Heating, deviceSubType=Zone). If you believe this is not correct, please report.
using the dump() method I notitced that my device was hardwareType 75 and device-adapters/evohome_device.lua checks on hardwareTypeValue == 39
at line 10:
local res = ( device.hardwareTypeValue == 39 ) and device.deviceSubType == 'Zone')
after changing line 10 to
local res = (( device.hardwareTypeValue == 39 or device.hardwareTypeValue == 75 ) and device.deviceSubType == 'Zone')
the line of code:
domoticz.devices('Slaapkamer').updateSetPoint(nil, Auto,nil )
now works as expected.
Question: should we use a separate device-adapter for this or is it ok to leave it like this ?
dannybloe
Post by dannybloe »
waaren wrote: Tuesday 06 February 2018 12:42 Hi Danny,
at line 10:
the line of code:
Ah, thanks for reporting. I have EvoHome as well but never got to actually using it like you do. I will add this to my todo and figure out if it should be a separate adapter.
dannybloe
Post by dannybloe »
jake wrote: Monday 29 January 2018 21:10 I just updated to Beta 3.8872 and came across some error
gives the log error
That's correct. A selector switch doesn't have a 'clean' state value to check internally (it's Set Level 20 or something like that). So I will have to extend the checkFirst() functionality to support this as well.
jake wrote: Monday 29 January 2018 21:10 Secondly, has the option for using the more standard LUA way: otherdevices_svalues been removed?
Yep, that's gone. There's absolutely no need to use those ancient tables anymore in dzVents. You can always use rawData which is exactly what you found in sValues earlier. But even then... rawData should not be necessary at all so if you miss specific device attributes let me know and we will adjust or create the proper device adapters to fix this.
dannybloe
Post by dannybloe »
jake wrote: Monday 05 February 2018 23:41 In this topic the suggestion is done to change the 'param=udevice' and 'type=command' around. I did this and now the log tells me
to
So 2 changes:
You have to allow 127.0.0.1 to access the API in the Domoticz settings (see getting started in the documentation). Then this should work.
jake
Post by jake »
dannybloe wrote:
jake wrote: Monday 05 February 2018 23:41 ...
So 2 changes:
Thanks, I had to go through the Wiki 3 times before I found the section about 127.0.0.1, but ... it did the trick. The solution wasn't that obvious, based on the error in the log. In order to help other users: is it possible to add this solution suggestion to the error when it occurs?
The change around of param and type is still necessary. Although I see the issue of malformed json commands in more topic on the forum (therefore not specifically dzVents?), this is still a problem to use this specific device adapter in dzVents. Will you permanently change the 2 parameters around? I guess that at an update of Domoticz my adapation is overwritten by the default file.
dannybloe
Post by dannybloe »
jake wrote: Friday 09 February 2018 8:28
So 2 changes:
This is very hard to do because this is beyond dzVents. The url is opened by Domoticz and the error occurs way after dzVents has finished so I cannot catch the error. Weird that you couldn't find it in the docs.. it's in the second chapter just after the introduction.
I'll look into it.
Charley
Domoticz version: V3.9030
Post by Charley »
I am trying to allow access to the API through 127.0.0.1 but I am not able to find the solution for Raspberry PI
Is there anyone who can help me out.
SweetPants
Post by SweetPants »
Charley wrote: Tuesday 06 March 2018 12:23 I am trying to allow access to the API through 127.0.0.1 but I am not able to find the solution for Raspberry PI
What do you mean with API? If it is JSON commands, allow access to 127.0.0.1 in setup->settings->Local Networks if you want to use it without authentication
